FRS
Family Radio Service
| Ch | Freq MHz | - Notes - |
| 1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
| 2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
| 3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
| 4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
| 5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
| 6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
| 7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
| 8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
| 9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
| 10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
| 11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
| 12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
| 13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
| 14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
| 15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
| 16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
| 17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
| 18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
| 19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
| 20 | 462.6750 | Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power |
| 21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
| 22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
- Channel 1 - 462.5625 MHz
- Channel 2 - 462.5875 MHz
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a "monitor" or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours).
These wireless intercom systems generally include a GROUP CALL or HOME channel feature, that switches all intercoms to a dedicated channel/code combination.
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
- Code 2 - 69.3 Hz PL
- Code 3 - 67.0 Hz PL
- CHANNEL 1 - 462.5625 MHz
- Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- Calford Technology Ltd. AF333 wireless intercom
234mw power output, 11K0F3E emission
- Calford Technology Ltd. AF411 wireless intercom
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- SAMCOM / SANCON FTAN10AA 10 channel wireless intercom
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
- Code B - 136.5 Hz PL
- Code C - 186.2 Hz PL
- SAMCOM / SANCON FTAN20AA 20 channel wireless intercom
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same code.
- Shenzhen Macros Industrial Co. Ltd. WL666 or LD666 wireless intercom
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
- 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS)
- 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS)
- 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS)
- 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS)
- 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS)
- PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
