FRS
Family Radio Service
Ch | Freq MHz | - Notes - |
1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
20 | 462.6750 | Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power |
21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
- Channel 1 - 462.5625 MHz
- Channel 2 - 462.5875 MHz
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
- Code 2 - 69.3 Hz PL
- Code 3 - 67.0 Hz PL
- CHANNEL 1 - 462.5625 MHz
- Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- CHANNEL 2 - 462.6125 MHz
- CHANNEL 3 - 462.6375 MHz
- Group CTCSS Code A - 67.0 Hz
- Group CTCSS Code B - 69.3 Hz
- Group CTCSS Code C - 165.5 Hz
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
- Code B - 136.5 Hz PL
- Code C - 186.2 Hz PL
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same code.
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
- Wuloo 22 channel 100 code Wuloo WL888 888 TD-888 wireless intercom
- GROUP CALL - 467.7125 MHz 743 DCS / 743 DPL
- CHANNEL 2 - 21 are regular FRS channels 2-21
- CHANNEL 22 - 462.5625 MHz
- Code 01 - 754 DCS / 754 DPL
- Code 02 - 743 DCS / 743 DPL
- Code 03 - 734 DCS / 734 DPL
- Code 04 - 77.0 Hz PL
- Code 05 - 79.7 Hz PL
- Code 06 - Code 38 - 82.5 Hz PL to 250.3 Hz PL (standard 38 CTCSS codes 4-38)
- Code 39 - 023 DCS / 023 DPL
- Code 40 - 025 DCS / 025 DPL
- Code 41 - Code 99 - 032 DCS to 503 DCS (straight sequence through standard DCS/DPL codes)
- 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS)
- 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS)
- 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS)
- 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS)
- 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS)
- PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
