FRS
Family Radio Service
- FRS Channel 12 -
- FRS Channel 13 -
- FRS Channel 14 -
- FRS Channel 15 -
- FRS Channel 16 -
- FRS Channel 17 -
- FRS Channel 18 -
- FRS Channel 19 -
- FRS Channel 20 -
- FRS Channel 21 -
- FRS Channel 22 -
- Channel 1 - 462.5625 MHz
- Channel 2 - 462.5875 MHz
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
- Code 2 - 69.3 Hz PL
- Code 3 - 67.0 Hz PL
- CHANNEL 1 - 462.5625 MHz
- Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- CHANNEL 2 - 462.6125 MHz
- CHANNEL 3 - 462.6375 MHz
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
- Code B - 136.5 Hz PL
- Code C - 186.2 Hz PL
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
- CHANNEL 7 - 462.7125 MHz
- CHANNEL 10 - 467.6125 MHz
- CHANNEL 11 - 467.6375 MHz
- CHANNEL 12 - 467.6625 MHz
- CHANNEL 13 - 467.6875 MHz
- CHANNEL 14 - 467.7125 MHz
- CHANNEL 15 - 462.5500 MHz
- CHANNEL 16 - 462.5750 MHz
- CHANNEL 17 - 462.6000 MHz
- CHANNEL 19 - 462.6500 MHz
- CHANNEL 20 - 462.6750 MHz
- CHANNEL 21 - 462.7000 MHz
- CHANNEL 22 - 462.5625 MHz
- Code 01 - 754 DCS / 754 DPL
- Code 02 - 743 DCS / 743 DPL
- Code 03 - 734 DCS / 734 DPL
- Code 04 - 77.0 Hz PL
- Code 05 - 79.7 Hz PL
- Code 06 - 82.5 Hz PL
- Code 07 - 85.4 Hz PL
- Code 08 - 88.5 Hz PL
- Code 09 - 91.5 Hz PL
- Code 10 - 94.8 Hz PL
- Code 11 - 97.4 Hz PL
- Code 12 - 100.0 Hz PL
- Code 13 - 103.5 Hz PL
- Code 14 - 107.2 Hz PL
- Code 15 - 110.9 Hz PL
- Code 16 - 114.8 Hz PL
- Code 17 - 118.8 Hz PL
- Code 18 - 123.0 Hz PL
- Code 19 - 127.3 Hz PL
- Code 20 - 131.8 Hz PL
- Code 21 - 136.5 Hz PL
- Code 22 - 141.3 Hz PL
- Code 23 - 146.2 Hz PL
- Code 24 - 151.4 Hz PL
- Code 25 - 156.7 Hz PL
- Code 26 - 162.2 Hz PL
- Code 27 - 167.9 Hz PL
- Code 28 - 173.8 Hz PL
- Code 29 - 179.9 Hz PL
- Code 30 - 186.2 Hz PL
- Code 31 - 192.8 Hz PL
- Code 32 - 203.5 Hz PL
- Code 33 - 210.7 Hz PL
- Code 34 - 218.1 Hz PL
- Code 35 - 225.7 Hz PL
- Code 36 - 233.6 Hz PL
- Code 37 - 241.8 Hz PL
- Code 38 - 250.3 Hz PL
- Code 39 - 023 DCS / 023 DPL
- Code 40 - 025 DCS / 025 DPL
- Code 41 - 026
- Code 42 - 031
- Code 43 - 032
- Code 44 - 043
- Code 45 - 047
- Code 46 - 051
- 054
- 065
- 071
- 072
- 073
- 074
- 114
- 115
- 116
- 125
- 131
- 132
- 143
- Code 60 - 143 DCS / 143 DPL
- 152
- 155
- 156
- 162
- 165
- 172
- 174
- 205
- 223
- Code 70 - 226 DCS / 226 DPL
- 243
- 244
- 245
- 251
- 261
- 263
- 265
- 271
- 306
- Code 80 - 311 DCS / 311 DPL
- 315
- 331
- 343
- 346
- 351
- 364
- 365
- 371
- 411
- Code 90 - 412 DCS / 412 DPL
- 413
- 423
- 431
- 432
- 445
- 464
- 465
- 466
- Code 99 - 503 DCS / 503 DPL
- 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS)
- 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS)
- 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS)
- 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS)
- 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS)
- PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
