FRS
Family Radio Service
totally awesome sweet alabama liquid snake
- Do you need a license to use the 22 FRS channels? No, you do not need a license to use all 22 FRS frequencies. Transmitting more than 2 watts on the 462 MHz channels requires a GMRS license, however.
- Are the "color dot" frequencies license free or part of FRS? Yes and no. The old White Dot (462.575 MHz), Black Dot (462.625 MHz) and Orange Dot (462.675 MHz) are now part of the FRS and GMRS services. Use of those three frequencies is legal without a license for business purposes under the FRS rules.
- Are Baofeng radios illegal? or Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be just fine. Do not use the default out of the box channels unless the radio comes programmed with the FRS channels out of the box. Make sure to use narrow band mode on the MURS and FRS/GMRS frequencies. Certain radios are FCC type accepted for Part 95 use. Examples include the Baofeng Baofeng Tech BTECH MURS-V1 and GMRS-V1 radios currently available on the market.
- What are the FRS channels? I want to program them in my Baofeng, Hytera, Motorola, Kenwood, Icom, etc. See the section above listing the 22 FRS frequencies. Remember to use narrow deviation FM mode (on Baofeng radios this is the NARR/WIDE setting - do not use WIDE). Program in whichever CTCSS or DCS (PL or DPL) tone or codes you wish to use on whichever channels you wish to use.
14 channel radios operating under the previous rules remain legal and the prohibition against removable antennas remains in effect. All transmissions must be made in narrowband FM - NBFM or NFM - 11K2F3E, 11K0F3E, 9K20F3E, 8K50F3E, 8K00F3E, 6K00F3E and other narrowband (11 kHz or less bandwidth) FM emissions voice are often found. Data transmissions must be in FSK mode and follow the narrowband requirement. Note that GMRS users are not required to use narrowband FM and many continue to use regular "wide" FM - 20K0F3E emission or 16K0F3E emission. However, older-style "combination" FRS/GMRS handheld radios operate narrowband FM only on the 462 MHz and 467 MHz frequencies.
- Channel 1 - 462.5625 MHz
- Channel 2 - 462.5875 MHz
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
- Code 2 - 69.3 Hz PL
- Code 3 - 67.0 Hz PL
- CHANNEL 1 - 462.5625 MHz
- Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- CHANNEL 2 - 462.6125 MHz
- CHANNEL 3 - 462.6375 MHz
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
- Code B - 136.5 Hz PL
- Code C - 186.2 Hz PL
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
- CHANNEL 7 - 462.7125 MHz
- CHANNEL 10 - 467.6125 MHz
- CHANNEL 11 - 467.6375 MHz
- CHANNEL 12 - 467.6625 MHz
- CHANNEL 13 - 467.6875 MHz
- CHANNEL 14 - 467.7125 MHz
- CHANNEL 15 - 462.5500 MHz
- CHANNEL 16 - 462.5750 MHz
- CHANNEL 17 - 462.6000 MHz
- CHANNEL 19 - 462.6500 MHz
- CHANNEL 20 - 462.6750 MHz
- CHANNEL 21 - 462.7000 MHz
- CHANNEL 22 - 462.5625 MHz
- Code 01 - 754 DCS / 754 DPL
- Code 02 - 743 DCS / 743 DPL
- Code 03 - 734 DCS / 734 DPL
- Code 04 - 77.0 Hz PL
- Code 05 - 79.7 Hz PL
- Code 06 - 82.5 Hz PL
- Code 07 - 85.4 Hz PL
- Code 08 - 88.5 Hz PL
- Code 09 - 91.5 Hz PL
- Code 10 - 94.8 Hz PL
- Code 11 - 97.4 Hz PL
- Code 12 - 100.0 Hz PL
- Code 13 - 103.5 Hz PL
- Code 14 - 107.2 Hz PL
- Code 15 - 110.9 Hz PL
- Code 16 - 114.8 Hz PL
- Code 17 - 118.8 Hz PL
- Code 18 - 123.0 Hz PL
- Code 19 - 127.3 Hz PL
- Code 20 - 131.8 Hz PL
- Code 21 - 136.5 Hz PL
- Code 22 - 141.3 Hz PL
- Code 23 - 146.2 Hz PL
- Code 24 - 151.4 Hz PL
- Code 25 - 156.7 Hz PL
- Code 26 - 162.2 Hz PL
- Code 27 - 167.9 Hz PL
- Code 28 - 173.8 Hz PL
- Code 29 - 179.9 Hz PL
- Code 30 - 186.2 Hz PL
- Code 31 - 192.8 Hz PL
- Code 32 - 203.5 Hz PL
- Code 33 - 210.7 Hz PL
- Code 34 - 218.1 Hz PL
- Code 35 - 225.7 Hz PL
- Code 36 - 233.6 Hz PL
- Code 37 - 241.8 Hz PL
- Code 38 - 250.3 Hz PL
- Code 39 - 023 DCS
- Code 40 - 025 DCS
- Code 41 - 026 DCS
- Code 42 - 031 DCS
- Code 43 - 032 DCS
- Code 44 - 043 DCS
- Code 45 - 047 DCS
- Code 46 - 051 DCS
- Code 47 - 054 DCS
- Code 48 - 065 DCS
- Code 49 - 071 DCS
- Code 50 - 072 DCS
- Code 51 - 073 DCS
- Code 52 - 074 DCS
- Code 53 - 114 DCS
- Code 54 - 115 DCS
- Code 55 - 116 DCS
- Code 56 - 125 DCS
- Code 57 - 131 DCS
- Code 58 - 132 DCS
- Code 59 - 143 DCS
- Code 60 - 143 DCS
- Code 61 - 152 DCS
- Code 62 - 155 DCS
- Code 63 - 156 DCS
- Code 64 - 162 DCS
- Code 65 - 165 DCS
- Code 66 - 172 DCS
- Code 67 - 174 DCS
- Code 68 - 205 DCS
- Code 69 - 223 DCS
- Code 70 - 226 DCS
- Code 71 - 243 DCS
- Code 72 - 244 DCS
- Code 73 - 245 DCS
- Code 74 - 251 DCS
- Code 75 - 261 DCS
- Code 76 - 263 DCS
- Code 77 - 265 DCS
- Code 78 - 271 DCS
- Code 79 - 306 DCS
- Code 80 - 311 DCS
- Code 81 - 315 DCS
- Code 82 - 331 DCS
- Code 83 - 343 DCS
- Code 84 - 346 DCS
- Code 85 - 351 DCS
- Code 86 - 364 DCS
- Code 87 - 365 DCS
- Code 88 - 371 DCS
- Code 89 - 411 DCS
- Code 90 - 412 DCS
- Code 91 - 413 DCS
- Code 92 - 423 DCS
- Code 93 - 431 DCS
- Code 94 - 432 DCS
- Code 95 - 445 DCS
- Code 96 - 464 DCS
- Code 97 - 465 DCS
- Code 98 - 466 DCS
- Code 99 - 503 DCS
- 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS)
- 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS)
- 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS)
- 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business freq
- 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS)
- 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS)
-Future section, basically the opposite of the commonly used tones/codes list - intended as guidance for somebody programming radios for a work crew, special event, radio rental, custom programming Baofeng BF-888S, BF-88A, UV-5R, UV-82, BTECH GMRS-V1 or similar field-programmable radios. There will be another sister section for business radio frequencies in the future as well.
Here are a list of FRS frequencies - channels and code combinations that are not commonly used:
*Recommended Programming A1-C - CTCSS (PL), 16-channel radios: *Channels 9-16 are the same as channels 1-8
- CH01 - 467.6625 MHz - 156.7 Hz
- CH02 - 467.6375 MHz - 156.7 Hz
- CH05 - 462.6000 MHz - 156.7 Hz
- CH09 - 467.6625 MHz - 156.7 Hz
- CH10 - 467.6375 MHz - 156.7 Hz
- CH13 - 462.6000 MHz - 156.7 Hz
*Recommended Programming A2-C - CTCSS (PL), 16-channel radios:
- CH01 - MHz -
- CH02 - MHz -
- CH03 - MHz -
- CH04 - MHz -
- CH05 - MHz -
- CH06 - MHz -
- CH07 - MHz -
- CH08 - MHz -
- CH09 - MHz -
- CH10 - MHz -
- CH11 - MHz -
- CH12 - MHz -
- CH13 - MHz -
- CH14 - MHz -
- CH15 - MHz -
- CH16 - MHz -
*Recommended Programming A3-C - CTCSS (PL), 16-channel radios:
- CH01 - MHz -
- CH02 - MHz -
- CH03 - MHz -
- CH04 - MHz -
- CH05 - MHz -
- CH06 - MHz -
- CH07 - MHz -
- CH08 - MHz -
- CH09 - MHz -
- CH10 - MHz -
- CH11 - MHz -
- CH12 - MHz -
- CH13 - MHz -
- CH14 - MHz -
- CH15 - MHz -
- CH16 - MHz -
*Recommended Programming A4-C - CTCSS (PL), 16-channel radios:
- CH01 - MHz -
- CH02 - MHz -
- CH03 - MHz -
- CH04 - MHz -
- CH05 - MHz -
- CH06 - MHz -
- CH07 - MHz -
- CH08 - MHz -
- CH09 - MHz -
- CH10 - MHz -
- CH11 - MHz -
- CH12 - MHz -
- CH13 - MHz -
- CH14 - MHz -
- CH15 - MHz -
- CH16 - MHz -
- CH01 - MHz -
- CH02 - MHz -
- CH03 - MHz -
- CH04 - MHz -
- CH05 - MHz -
- CH06 - MHz -
- CH07 - MHz -
- CH08 - MHz -
- CH09 - MHz -
- CH10 - MHz -
- CH11 - MHz -
- CH12 - MHz -
- CH13 - MHz -
- CH14 - MHz -
- CH15 - MHz -
- CH16 - MHz -
*Recommended Programming A1-D - DCS (DPL), 16-channel radios:
- CH01 - 467.6625 MHz - DCS 371 371N
- CH02 - 467.6125 MHz - DCS 371 371N
- CH03 - 462.6625 MHz - DCS 251 251N
- CH04 - 462.6125 MHz - DCS 251 251N
- CH05 - 462.5750 MHz - DCS 251 251N
- CH06 - 462.5500 MHz - DCS 251 251N
- CH07 - 462.6000 MHz - DCS 251 251N
- CH08 - 462.6500 MHz - DCS 251 251N
- CH09 - 467.6625 MHz - DCS 371 371N
- CH10 - 467.6125 MHz - DCS 371 371N
- CH11 - 462.6625 MHz - DCS 251 251N
- CH12 - 462.6125 MHz - DCS 251 251N
- CH13 - 462.5750 MHz - DCS 251 251N
- CH14 - 462.5500 MHz - DCS 251 251N
- CH15 - 462.6000 MHz - DCS 251 251N
- CH16 - 462.6500 MHz - DCS 251 251N
- CH01 - 462.5500 MHz -
- CH02 - 462.6500 MHz -
- CH03 - 467.6875 MHz -
- CH04 - 462.7125 MHz -
- CH05 - 467.6625 MHz -
- CH06 - 462.6000 MHz -
- CH07 - 462.7000 MHz -
- CH08 - 467.6375 MHz -
- CH09 - 467.5875 MHz -
- CH10 - 462.6375 MHz -
- CH11 - 462.6125 MHz -
- CH12 - 462.5750 MHz -
- CH13 - 462.6750 MHz -
- CH15 - 467.5625 MHz -
- CH16 - 462.7250 MHz -
- CH01 - MHz -
- CH02 - MHz -
- CH03 - MHz -
- CH04 - MHz -
- CH05 - MHz -
- CH06 - MHz -
- CH07 - MHz -
- CH08 - MHz -
- CH09 - MHz -
- CH10 - MHz -
- CH11 - MHz -
- CH12 - MHz -
- CH13 - MHz -
- CH14 - MHz -
- CH15 - MHz -
- CH16 - MHz -
4 watt or 5 watt GMRS walkie talkies that were often sold as a more “professional” version of FRS. Up to 5 watt power on all 15 channels. GMRS license required. The proliferation of 15-channel GMRS walkie talkie radios and 22-channel FRS/GMRS dual-service or dual-use radios led the FCC to change the rules to add the 8 GMRS simplex channels to FRS (with a 2 watt power limit) and make FRS/GMRS combination radios or dual-use radios illegal. All FRS/GMRS combination radios with transmitter output power of 2 watts or less legally turned into 22 channel FRS radios the rule change.
- Channel 8 - 462.5500 MHz
- Channel 9 - 462.5750 MHz
- Channel 10 - 462.6000 MHz
- Channel 11 - 462.6250 MHz
- Channel 12 - 462.6500 MHz
- Channel 13 - 462.6750 MHz
- Channel 14 - 462.7000 MHz
- Channel 15 - 462.7250 MHz
- PMR446 and DPMR446 - Europe and numerous other countries, UHF analog and digital license free service, 446 MHz
