FRS
Family Radio Service
UHF 462 MHz/467 MHz replacement (or rather supplement) to the CB radio service. Short range walkie talkie radios, nearly endless uses. Popular with private individuals, businesses, families, security services, etc. The FRS channels are shared with the GMRS service. All users must share channels with each other.
Legal for use by individuals, families and businesses. All 22 channels are available for simplex without a license.
- Do you need a license to use the 22 FRS channels? No, you do not need a license to use all 22 FRS frequencies. Transmitting more than 2 watts on the 462 MHz channels requires a GMRS license, however.
- Are the "color dot" frequencies license free or part of FRS? Yes and no. The old White Dot (462.575 MHz), Black Dot (462.625 MHz) and Orange Dot (462.675 MHz) are now part of the FRS and GMRS services. Use of those three frequencies is legal without a license for business purposes under the FRS rules.
- Are Baofeng radios illegal? or Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be just fine. Do not use the default out of the box channels unless the radio comes programmed with the FRS channels out of the box. Make sure to use narrow band mode on the MURS and FRS/GMRS frequencies. Certain radios are FCC type accepted for Part 95 use. Examples include the Baofeng Baofeng Tech BTECH MURS-V1 and GMRS-V1 radios currently available on the market.
- What are the FRS channels? I want to program them in my Baofeng, Hytera, Motorola, Kenwood, Icom, etc. See the section above listing the 22 FRS frequencies. Remember to use narrow deviation FM mode (on Baofeng radios this is the NARR/WIDE setting - do not use WIDE). Program in whichever CTCSS or DCS (PL or DPL) tone or codes you wish to use on whichever channels you wish to use.
§ 95.587 FRS additional requirements. Each FRS transmitter type must be designed to meet the following additional requirements. (a) Transmit frequency capability. FRS transmitter types must not be capable of transmitting on any frequency or channel other than those listed in § 95.563. (b) Antenna. The antenna of each FRS transmitter type must meet the following requirements. (1) The antenna must be a non-removable integral part of the FRS transmitter type. (2) The gain of the antenna must not exceed that of a half-wave dipole antenna. (3) The antenna must be designed such that the electric field of the emitted waves is vertically polarized when the unit is operated in the normal orientation. (c) Digital data transmissions. FRS transmitter types having the capability to transmit digital data must be designed to meet the following requirements. (1) FRS units may transmit digital data containing location information, or requesting location information from one or more other FRS or GMRS units, or containing a brief text message to another specific FRS or GMRS unit or units. (2) Digital data transmissions must be initiated by a manual action or command of the operator, except that FRS units may be designed to automatically respond with location data upon receiving an interrogation request from another FRS unit or a GMRS unit. (3) Digital data transmissions must not exceed one second in duration. (4) Digital data transmissions must not be sent more frequently than one digital data transmission within a thirty-second period, except that an FRS unit may automatically respond to more than one interrogation request received within a thirty-second period. (d) Packet mode. FRS transmitter types must not be capable of transmitting data in the store-and-forward packet operation mode. (e) Effective September 30, 2019, no person shall manufacture or import hand-held portable radio equipment capable of operating under this subpart (FRS) and other licensed or licensed-by-rule services in this chapter (part 15 unlicensed equipment authorizations are permitted if consistent with part 15 rules).
 - FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) is the prepper/militia secondary channel (tactical)
 - FRS channel 8 - 467.5625 MHz subcode 8 (8-8) backup militia operations channel PL 88.5 Hz
 - FRS channel 16 - 462.5750 MHz Previously "White Dot" GMRS/Business Band shared itinerant channel
 - FRS channel 18 - 462.6250 MHz Previously "Black Dot" GMRS/Business Band shared itinerant channel
 - FRS channel 20 - 462.6750 MHz Previously "Orange Dot" GMRS/Business Band shared itinerant channel
- Channel 1 - 462.5625 MHz
 - Channel 2 - 462.5875 MHz
 - Channel 3 - 462.6125 MHz
 - Channel 4 - 462.6375 MHz
 - Channel 5 - 462.6625 MHz
 - Channel 6 - 462.6875 MHz
 - Channel 7 - 462.7125 MHz
 - Channel 8 - 467.5625 MHz
 - Channel 9 - 467.5875 MHz
 - Channel 10 - 467.6125 MHz
 - Channel 11 - 467.6375 MHz
 - Channel 12 - 467.6625 MHz
 - Channel 13 - 467.6875 MHz
 - Channel 14 - 467.7125 MHz
 - Channel 15 - 462.5500 MHz
 - Channel 16 - 462.5750 MHz
 - Channel 17 - 462.6000 MHz
 - Channel 18 - 462.6250 MHz
 - Channel 19 - 462.6500 MHz
 - Channel 20 - 462.6750 MHz
 - Channel 21 - 462.7000 MHz
 - Channel 22 - 462.7250 MHz
There is significant variation from manufacturer to manufacturer. Many use the 38 CTCSS tones + 83 DCS codes system (for a total of 121 available codes or subchannels per channel). Some use 39 CTCSS tones (add 69.3 Hz or 69.4 Hz as code # 2 or code # 39) or use 50 CTCSS tones + 83 DCS codes or some subset of these.
 - Code 1 - 67.0 Hz
 - Code 2 - 71.9 Hz
 - Code 3 - 74.4 Hz
 - Code 4 - 77.0 Hz
 - Code 5 - 79.7 Hz
 - Code 6 - 82.5 Hz
 - Code 7 - 85.4 Hz
 - Code 8 - 88.5 Hz
 - Code 9 - 91.5 Hz
 - Code 10 - 94.8 Hz
 - Code 11 - 97.4 Hz
 - Code 12 - 100.0 Hz
 - Code 13 - 103.5 Hz
 - Code 14 - 107.2 Hz
 - Code 15 - 110.9 Hz
 - Code 16 - 114.8 Hz
 - Code 17 - 118.8 Hz
 - Code 18 - 123.0 Hz
 - Code 19 - 127.3 Hz
 - Code 20 - 131.8 Hz
 - Code 21 - 136.5 Hz
 - Code 22 - 141.3 Hz
 - Code 23 - 146.2 Hz
 - Code 24 - 151.4 Hz
 - Code 25 - 156.7 Hz
 - Code 26 - 162.2 Hz
 - Code 27 - 167.9 Hz
 - Code 28 - 173.8 Hz
 - Code 29 - 179.9 Hz
 - Code 30 - 186.2 Hz
 - Code 31 - 192.8 Hz
 - Code 32 - 203.5 Hz
 - Code 33 - 210.7 Hz
 - Code 34 - 218.1 Hz
 - Code 35 - 225.7 Hz
 - Code 36 - 233.6 Hz
 - Code 37 - 241.8 Hz
 - Code 38 - 250.3 Hz
 - Code 39 - D023
 - Code 40 - D025
 - Code 41 - D026
 - Code 42 - D031
 - Code 43 - D032
 - Code 44 - D043
 - Code 45 - D047
 - Code 46 - D051
 - Code 47 - D054
 - Code 48 - D065
 - Code 49 - D071
 - Code 50 - D072
 - Code 51 - D073
 - Code 52 - D074
 - Code 53 - D114
 - Code 54 - D115
 - Code 55 - D116
 - Code 56 - D125
 - Code 57 - D131
 - Code 58 - D132
 - Code 59 - D134
 - Code 60 - D143
 - Code 61 - D152
 - Code 62 - D155
 - Code 63 - D156
 - Code 64 - D162
 - Code 65 - D165
 - Code 66 - D172
 - Code 67 - D174
 - Code 68 - D205
 - Code 69 - D223
 - Code 70 - D226
 - Code 71 - D243
 - Code 72 - D244
 - Code 73 - D245
 - Code 74 - D251
 - Code 75 - D261
 - Code 76 - D263
 - Code 77 - D265
 - Code 78 - D271
 - Code 79 - D306
 - Code 80 - D311
 - Code 81 - D315
 - Code 82 - D331
 - Code 83 - D343
 - Code 84 - D346
 - Code 85 - D351
 - Code 86 - D364
 - Code 87 - D365
 - Code 88 - D371
 - Code 89 - D411
 - Code 90 - D412
 - Code 91 - D413
 - Code 92 - D423
 - Code 93 - D431
 - Code 94 - D432
 - Code 95 - D445
 - Code 96 - D464
 - Code 97 - D465
 - Code 98 - D466
 - Code 99 - D503
 - Code 100 - D506
 - Code 101 - D516
 - Code 102 - D532
 - Code 103 - D546
 - Code 104 - D565
 - Code 105 - D606
 - Code 106 - D612
 - Code 107 - D624
 - Code 108 - D627
 - Code 109 - D631
 - Code 110 - D632
 - Code 111 - D654
 - Code 112 - D662
 - Code 113 - D664
 - Code 114 - D703
 - Code 115 - D712
 - Code 116 - D723
 - Code 117 - D731
 - Code 118 - D732
 - Code 119 - D734
 - Code 120 - D743
 - Code 121 - D754
 - CHANNEL 1 - 467.6375 MHz
 - CHANNEL 2 - 462.5875 MHz
 - CHANNEL 3 - 462.6125 MHz
 - CHANNEL 4 - 462.6375 MHz
 - CHANNEL 5 - 462.6625 MHz
 - CHANNEL 6 - 462.6875 MHz
 - CHANNEL 7 - 467.7125 MHz
 - CHANNEL 8 - 462.5500 MHz
 - CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
 - Code 2 - 69.3 Hz PL
 - Code 3 - 67.0 Hz PL
 - CHANNEL 1 - 462.5625 MHz
 - Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
 - Code 2 - 732 DCS / 732 DPL
 - Code 3 - 731 DCS / 731 DPL
 - CHANNEL 2 - 462.6125 MHz
 - CHANNEL 3 - 462.6375 MHz
- CHANNEL A - 462.5625 MHz
 - CHANNEL B - 462.5875 MHz
 - CHANNEL C - 462.6125 MHz
 - CHANNEL D - 462.6375 MHz
- CHANNEL 0 - 462.6625 MHz
 - CHANNEL 1 - 467.7125 MHz
 - CHANNEL 2 - 467.6875 MHz
 - CHANNEL 3 - 467.6625 MHz
 - CHANNEL 4 - 467.6375 MHz
 - CHANNEL 5 - 467.6125 MHz
 - CHANNEL 6 - 467.5875 MHz
 - CHANNEL 7 - 467.5625 MHz
 - CHANNEL 8 - 462.7125 MHz
 - CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
 - Code B - 136.5 Hz PL
 - Code C - 186.2 Hz PL
 - CHANNEL 10 - 462.6375 MHz
 - CHANNEL 11 - 462.6125 MHz
 - CHANNEL 12 - 462.5875 MHz
 - CHANNEL 13 - 462.5625 MHz
 - CHANNEL 14 - 462.7250 MHz
 - CHANNEL 15 - 462.7000 MHz
 - CHANNEL 16 - 462.6750 MHz
 - CHANNEL 17 - 462.6500 MHz
 - CHANNEL 18 - 462.6250 MHz
 - CHANNEL 19 - 462.6000 MHz
 - CHANNEL 0 - 467.6125 MHz
 - CHANNEL 1 - 462.7250 MHz
 - CHANNEL 8 - 467.5625 MHz
 - CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
 - Code B - 743 DCS / 743 DPL
 - Code C - 734 DCS / 734 DPL
 - CHANNEL 7 - 462.7125 MHz
 - CHANNEL 10 - 467.6125 MHz
 - CHANNEL 11 - 467.6375 MHz
 - CHANNEL 12 - 467.6625 MHz
 - CHANNEL 13 - 467.6875 MHz
 - CHANNEL 14 - 467.7125 MHz
 - CHANNEL 15 - 462.5500 MHz
 - CHANNEL 16 - 462.5750 MHz
 - CHANNEL 17 - 462.6000 MHz
 - CHANNEL 19 - 462.6500 MHz
 - CHANNEL 20 - 462.6750 MHz
 - CHANNEL 21 - 462.7000 MHz
 - CHANNEL 22 - 462.5625 MHz
 - Code 01 - 754 DCS / 754 DPL
 - Code 02 - 743 DCS / 743 DPL
 - Code 03 - 734 DCS / 734 DPL
 - Code 04 - 77.0 Hz PL
 - Code 05 - 79.7 Hz PL
 - Code 06 - 82.5 Hz PL
 - Code 07 - 85.4 Hz PL
 - Code 08 - 88.5 Hz PL
 - Code 09 - 91.5 Hz PL
 - Code 10 - 94.8 Hz PL
 - Code 11 - 97.4 Hz PL
 - Code 12 - 100.0 Hz PL
 - Code 13 - 103.5 Hz PL
 - Code 14 - 107.2 Hz PL
 - Code 15 - 110.9 Hz PL
 - Code 16 - 114.8 Hz PL
 - Code 17 - 118.8 Hz PL
 - Code 18 - 123.0 Hz PL
 - Code 19 - 127.3 Hz PL
 - Code 20 - 131.8 Hz PL
 - Code 21 - 136.5 Hz PL
 - Code 22 - 141.3 Hz PL
 - Code 23 - 146.2 Hz PL
 - Code 24 - 151.4 Hz PL
 - Code 25 - 156.7 Hz PL
 - Code 26 - 162.2 Hz PL
 - Code 27 - 167.9 Hz PL
 - Code 28 - 173.8 Hz PL
 - Code 29 - 179.9 Hz PL
 - Code 30 - 186.2 Hz PL
 - Code 31 - 192.8 Hz PL
 - Code 32 - 203.5 Hz PL
 - Code 33 - 210.7 Hz PL
 - Code 34 - 218.1 Hz PL
 - Code 35 - 225.7 Hz PL
 - Code 36 - 233.6 Hz PL
 - Code 37 - 241.8 Hz PL
 - Code 38 - 250.3 Hz PL
 - Code 39 - 023 DCS
 - Code 40 - 025 DCS
 - Code 41 - 026 DCS
 - Code 42 - 031 DCS
 - Code 43 - 032 DCS
 - Code 44 - 043 DCS
 - Code 45 - 047 DCS
 - Code 46 - 051 DCS
 - Code 47 - 054 DCS
 - Code 48 - 065 DCS
 - Code 49 - 071 DCS
 - Code 50 - 072 DCS
 - Code 51 - 073 DCS
 - Code 52 - 074 DCS
 - Code 53 - 114 DCS
 - Code 54 - 115 DCS
 - Code 55 - 116 DCS
 - Code 56 - 125 DCS
 - Code 57 - 131 DCS
 - Code 58 - 132 DCS
 - Code 59 - 143 DCS
 - Code 60 - 143 DCS
 - Code 61 - 152 DCS
 - Code 62 - 155 DCS
 - Code 63 - 156 DCS
 - Code 64 - 162 DCS
 - Code 65 - 165 DCS
 - Code 66 - 172 DCS
 - Code 67 - 174 DCS
 - Code 68 - 205 DCS
 - Code 69 - 223 DCS
 - Code 70 - 226 DCS
 - Code 71 - 243 DCS
 - Code 72 - 244 DCS
 - Code 73 - 245 DCS
 - Code 74 - 251 DCS
 - Code 75 - 261 DCS
 - Code 76 - 263 DCS
 - Code 77 - 265 DCS
 - Code 78 - 271 DCS
 - Code 79 - 306 DCS
 - Code 80 - 311 DCS
 - Code 81 - 315 DCS
 - Code 82 - 331 DCS
 - Code 83 - 343 DCS
 - Code 84 - 346 DCS
 - Code 85 - 351 DCS
 - Code 86 - 364 DCS
 - Code 87 - 365 DCS
 - Code 88 - 371 DCS
 - Code 89 - 411 DCS
 - Code 90 - 412 DCS
 - Code 91 - 413 DCS
 - Code 92 - 423 DCS
 - Code 93 - 431 DCS
 - Code 94 - 432 DCS
 - Code 95 - 445 DCS
 - Code 96 - 464 DCS
 - Code 97 - 465 DCS
 - Code 98 - 466 DCS
 - Code 99 - 503 DCS
*See also: default/factory radio settings for Business Radio and MURS.
 - 462.5625 MHz 67.0 Hz - Retevis FRS radios default channel 1
 - 462.5625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 1
 - 462.5625 MHz 026 DCS - Retevis RT-27 IC FRS radios default channel 15
 - 462.5750 MHz Various - White Dot Itinerant Business Band - old color dot star channel designation
 - 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
 - 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS, D743I)
 - 462.5875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 2
 - 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS, D332I)
 - 462.6125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 3
 - 462.6250 MHz Various - Black Dot Itinerant Business Band - old color dot star channel designation
 - 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
 - 462.6375 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 4
 - 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS, D243I)
 - 462.6625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 5
 - 462.6750 MHz Various - Orange Dot Itinerant Business Band - old color dot star channel designation
 - 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
 - 462.6875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 6
 - 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS, D731I)
 - 462.7125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 7
 - 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS, D462I)
 - 467.5625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 8
 - 467.5625 MHz 026 DCS - Retevis RT-27 IC FRS radios default channel 16
 - 467.5875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 9
 - 467.6125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 10
 - 467.6375 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 11
 - 467.6625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 12
 - 467.6875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 13
 - 467.7125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 14
The opposite of the commonly used tones/codes list - intended as guidance for somebody programming radios for a work crew, special event, radio rental, custom programming Baofeng BF-888S, BF-88A, UV-5R, UV-82, BTECH GMRS-V1 or similar field-programmable radios. There will be another sister section for business radio frequencies in the future as well.
Here are a list of FRS frequencies - channels and code combinations that are not commonly used:
*Recommended Programming A-22 - CTCSS (PL), 22-channel FRS radios: *22 FRS channels - recommended tone settings:
- CH01
 - CH02
 - CH03
 - CH04
 - CH05
 - CH06
 - CH07
 - CH08
 - CH09
 - CH10
 - CH11
 - CH12
 - CH13
 - CH14
 - CH15
 - CH16
 - CH17
 - CH18
 - CH19
 - CH20
 - CH21
 - CH22
*Recommended Programming B-22 - CTCSS (PL), 22-channel FRS radios:
- CH01
 - CH02
 - CH03
 - CH04
 - CH05
 - CH06
 - CH07
 - CH08
 - CH09
 - CH10
 - CH11
 - CH12
 - CH13
 - CH14
 - CH15
 - CH16
 - CH17
 - CH18
 - CH19
 - CH20
 - CH21
 - CH22
*Recommended Programming C-22 - CTCSS (PL), 22-channel FRS radios:
- CH01
 - CH02
 - CH03
 - CH04
 - CH05
 - CH06
 - CH07
 - CH08
 - CH09
 - CH10
 - CH11
 - CH12
 - CH13
 - CH14
 - CH15
 - CH16
 - CH17
 - CH18
 - CH19
 - CH20
 - CH21
 - CH22
*Recommended Programming A1-C - CTCSS (PL), 8 or 16-channel radios:
*Channels 9-16 are the same as channels 1-8
- CH01 - 467.6625 MHz - 156.7 Hz
 - CH02 - 467.6375 MHz - 156.7 Hz
 - CH05 - 462.6000 MHz - 156.7 Hz
 - CH09 - 467.6625 MHz - 156.7 Hz
 - CH10 - 467.6375 MHz - 156.7 Hz
 - CH13 - 462.6000 MHz - 156.7 Hz
 - Channel 8 - 462.5500 MHz
 - Channel 9 - 462.5750 MHz
 - Channel 10 - 462.6000 MHz
 - Channel 11 - 462.6250 MHz
 - Channel 12 - 462.6500 MHz
 - Channel 13 - 462.6750 MHz
 - Channel 14 - 462.7000 MHz
 - Channel 15 - 462.7250 MHz
