Revision as of 11:55, 29 September 2021 by R4002 (Talk | contribs)
AM and SSB Modulation in the Americas, Australia, Asia, FM allowed in Europe and elsewhere. Most communications heard on CB radio are in AM mode. Yes, truckers (and lots of other people) still use CB radio in 2021. These are the de facto standard CB channel frequencies. Depending on where you're located they're the American CB radio channels, 27 MHz CB channels, the mid band channels, the CEPT channels or the European/EU channels.
As of mid-2021, the US FCC is considering allowing FM on the 40 CB channels, with 2 kHz deviation limits to match the current 10 kHz channel spacing.
CB Channel Frequency Remarks
Channel 2 26.975 MHz
Channel 5 27.015 MHz
Channel 7 27.035 MHz
Channel 12 27.105 MHz
Channel 15 27.135 MHz
Channel 18 27.175 MHz
Channel 22 27.225 MHz
Channel 27 27.275 MHz
Channel 29 27.295 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
FM (Frequency Modulation)
Channel 1 27.60125 MHz
Channel 2 27.61125 MHz
Channel 3 27.62125 MHz
Channel 4 27.63125 MHz
Channel 5 27.64125 MHz
Channel 6 27.65125 MHz
Channel 7 27.66125 MHz
Channel 8 27.67125 MHz
Channel 9 27.68125 MHz
Channel 10 27.69125 MHz
Channel 11 27.70125 MHz
Channel 12 27.71125 MHz
Channel 13 27.72125 MHz
Channel 14 27.73125 MHz
Channel 15 27.74125 MHz
Channel 16 27.75125 MHz
Channel 17 27.76125 MHz
Channel 18 27.77125 MHz
Channel 19 27.78125 MHz
Channel 20 27.79125 MHz
Channel 21 27.80125 MHz
Channel 22 27.81125 MHz
Channel 23 27.82125 MHz
Channel 24 27.83125 MHz
Channel 25 27.84125 MHz
Channel 26 27.85125 MHz
Channel 27 27.86125 MHz
Channel 28 27.87125 MHz
Channel 29 27.88125 MHz
Channel 30 27.89125 MHz
Channel 31 27.90125 MHz
Channel 32 27.91125 MHz
Channel 33 27.92125 MHz
Channel 34 27.93125 MHz
Channel 35 27.94125 MHz
Channel 36 27.95125 MHz
Channel 37 27.96125 MHz
Channel 38 27.97125 MHz
Channel 39 27.98125 MHz
Channel 40 27.99125 MHz
Channel 41 26.565 MHz
Channel 42 26.575 MHz
Channel 43 26.585 MHz
Channel 44 26.595 MHz
Channel 45 26.605 MHz
Channel 46 26.615 MHz
Channel 47 26.625 MHz
Channel 48 26.635 MHz
Channel 49 26.645 MHz
Channel 50 26.655 MHz
Channel 51 26.665 MHz
Channel 52 26.675 MHz
Channel 53 26.685 MHz
Channel 54 26.695 MHz
Channel 55 26.705 MHz
Channel 56 26.715 MHz
Channel 57 26.725 MHz
Channel 58 26.735 MHz
Channel 59 26.745 MHz
Channel 60 26.755 MHz
Channel 61 26.765 MHz
Channel 62 26.775 MHz
Channel 63 26.785 MHz
Channel 64 26.795 MHz
Channel 65 26.805 MHz
Channel 66 26.815 MHz
Channel 67 26.825 MHz
Channel 68 26.835 MHz
Channel 69 26.845 MHz
Channel 70 26.855 MHz
Channel 71 26.865 MHz
Channel 72 26.875 MHz
Channel 73 26.885 MHz
Channel 74 26.895 MHz
Channel 75 26.905 MHz
Channel 76 26.915 MHz
Channel 77 26.925 MHz
Channel 78 26.935 MHz
Channel 79 26.945 MHz
Channel 80 26.955 MHz
26 MHz AM Public Channels:
Channel 1 26.330 MHz
Channel 2 26.340 MHz
Channel 3 26.350 MHz
Channel 4 26.370 MHz
Channel 5 26.380 MHz
Channel 6 26.390 MHz
Channel 7 26.400 MHz
Channel 8 26.420 MHz
Channel 9 26.430 MHz
Channel 10 26.440 MHz
Channel 11 26.450 MHz
Channel 12 26.470 MHz
Channel 13 26.480 MHz
Channel 14 26.490 MHz
Channel 15 26.500 MHz
Channel 16 26.520 MHz
Channel 17 26.530 MHz
Channel 18 26.540 MHz
Channel 19 26.550 MHz
Channel 20 26.570 MHz
Channel 21 26.580 MHz
Channel 22 26.590 MHz
Channel 23 26.620 MHz
Channel 24 26.600 MHz
Channel 25 26.610 MHz
Channel 26 26.630 MHz
Channel 27 26.640 MHz
Channel 28 26.650 MHz
Channel 29 26.660 MHz
Channel 30 26.670 MHz
Channel 31 26.680 MHz
Channel 32 26.690 MHz
Channel 33 26.700 MHz
Channel 34 26.710 MHz
Channel 35 26.720 MHz
Channel 36 26.730 MHz
Channel 37 26.740 MHz
Channel 38 26.750 MHz
Channel 39 26.760 MHz
Channel 40 26.770 MHz
Channel 1 26.960 MHz
Channel 2 26.970 MHz
Channel 3 26.980 MHz
Channel 4 27.000 MHz
Channel 5 27.010 MHz
Channel 6 27.020 MHz
Channel 7 27.030 MHz
Channel 8 27.050 MHz
Channel 9 27.060 MHz
Channel 10 27.070 MHz
Channel 11 27.080 MHz
Channel 12 27.100 MHz
Channel 13 27.110 MHz
Channel 14 27.120 MHz
Channel 15 27.130 MHz
Channel 16 27.150 MHz
Channel 17 27.160 MHz
Channel 18 27.170 MHz
Channel 19 27.180 MHz
Channel 20 27.200 MHz
Channel 21 27.210 MHz
Channel 22 27.220 MHz
Channel 23 27.250 MHz
Channel 24 27.230 MHz
Channel 25 27.240 MHz
Channel 26 27.260 MHz
Channel 27 27.270 MHz
Channel 28 27.280 MHz
Channel 29 27.290 MHz
Channel 30 27.300 MHz
Channel 31 27.310 MHz
Channel 32 27.320 MHz
Channel 33 27.330 MHz
Channel 34 27.340 MHz
Channel 36 27.360 MHz
Channel 37 27.370 MHz
Channel 38 27.380 MHz
Channel 39 27.390 MHz
Channel 40 27.400 MHz
For example,
Calling frequencies include 26.985 MHz AM (CB Channel 3 AM), 27.375 MHz USB (CB Channel 37 USB), 27.425 MHz USB (Channel 42, Channel "E2", Channel E02, "425")
  • 26.962 MHz LSB - Drop Gap 1
  • 26.965 MHz AM - Normal CB 1
  • 26.968 MHz USB - High Gap 1
  • 26.972 MHz LSB - Drop Gap 2
  • 26.975 MHz AM - Normal CB 2
FREEBAND | HIGH GAP ==2 | 26.978 USB FREEBAND | GAP =====2/3 | 26.980 LSB/USB FREEBAND | DROP GAP ==3 | 26.982 LSB NORMAL CB| CHANNEL ===3 | 26.985 AM *CB PREPPER CH 3 AM* FREEBAND | HIGH GAP ==3 | 26.988 USB FREEBAND | GAP ====3/3A | 26.990 LSB/USB FREEBAND | DROP GAP =3A | 26.992 LSB CONTROL= | CHANNEL ==3A | 26.995 REMOTE CONTROL TOYS/ALARMS FREEBAND | HIGH GAP =3A | 26.998 USB FREEBAND | GAP ====3A/4 | 27.000 LSB/USB FREEBAND | DROP GAP ==4 | 27.002 LSB NORMAL CB| CHANNEL ===4 | 27.005 AM CB 4X4 4WD JEEP CLUBS FREEBAND | HIGH GAP ==4 | 27.008 USB FREEBAND | GAP =====4/5 | 27.010 LSB/USB FREEBAND | DROP GAP ==5 | 27.012 LSB NORMAL CB| CHANNEL ===5 | 27.015 AM FREEBAND | HIGH GAP ==5 | 27.018 USB FREEBAND | GAP =====5/6 | 27.020 LSB/USB FREEBAND | DROP GAP ==6 | 27.022 LSB NORMAL CB| CHANNEL ===6 | 27.025 AM SKIP TALKER HIGH POWER CB FREEBAND | HIGH GAP ==6 | 27.028 USB FREEBAND | GAP =====6/7 | 27.030 LSB/USB FREEBAND | DROP GAP ==7 | 27.032 LSB NORMAL CB| CHANNEL ===7 | 27.035 AM FREEBAND | HIGH GAP ==7 | 27.038 USB FREEBAND | GAP ====7/7A | 27.040 LSB/USB FREEBAND | DROP GAP =7A | 27.042 LSB CONTROL= | CHANNEL ==7A | 27.045 REMOTE CONTROL TOYS/ALARMS FREEBAND | HIGH GAP =7A | 27.048 USB FREEBAND | GAP ====7A/8 | 27.050 LSB/USB FREEBAND | DROP GAP ==8 | 27.052 LSB NORMAL CB| CHANNEL ===8 | 27.055 AM FREEBAND | HIGH GAP ==8 | 27.058 USB FREEBAND | GAP =====8/9 | 27.060 LSB/USB FREEBAND | DROP GAP ==9 | 27.062 LSB NORMAL CB| CHANNEL ===9 | 27.065 AM EMERGENCY CB AM FREEBAND | HIGH GAP ==9 | 27.068 USB FREEBAND | GAP ====9/10 | 27.070 LSB/USB
CHAN TYPE| CHANNEL NAME | FREQ. | MODE | COMMON CHANNEL USAGE
FREEBAND | DROP GAP =10 | 27.072 LSB NORMAL CB| CHANNEL ==10 | 27.075 AM FREEBAND | HIGH GAP =10 | 27.078 USB FREEBAND | GAP ===10/11 | 27.080 LSB/USB FREEBAND | DROP GAP =11 | 27.082 LSB NORMAL CB| CHANNEL ==11 | 27.085 AM LOCAL CB CALLING FREEBAND | HIGH GAP =11 | 27.088 USB FREEBAND | GAP ==11/11A | 27.090 LSB/USB FREEBAND | DROP GAP 11A | 27.092 LSB CONTROL= | CHANNEL =11A | 27.095 REMOTE CONTROL TOYS/ALARMS FREEBAND | HIGH GAP 11A | 27.098 USB FREEBAND | GAP ==11A/12 | 27.100 LSB/USB FREEBAND | DROP GAP 12A | 27.102 LSB NORMAL CB| CHANNEL ==12 | 27.105 AM FREEBAND | HIGH GAP =12 | 27.108 USB FREEBAND | GAP ===12/13 | 27.110 LSB/USB FREEBAND | DROP GAP =13 | 27.112 LSB NORMAL CB| CHANNEL ==13 | 27.115 AM RV OR CAMPERS CB FREEBAND | HIGH GAP =13 | 27.118 USB FREEBAND | GAP ===13/14 | 27.120 LSB/USB FREEBAND | DROP GAP =14 | 27.122 LSB NORMAL CB| CHANNEL ==14 | 27.125 AM CB WALKIE=TALKIES FREEBAND | HIGH GAP =14 | 27.128 USB FREEBAND | GAP ===14/15 | 27.130 LSB/USB FREEBAND | DROP GAP =15 | 27.132 LSB NORMAL CB| CHANNEL ==15 | 27.135 AM FREEBAND | HIGH GAP =15 | 27.138 USB FREEBAND | GAP ==15/15A | 27.140 LSB/USB FREEBAND | DROP GAP 15A | 27.142 LSB CONTROL= | CHANNEL =15A | 27.155 REMOTE CONTROL TOYS/ALARMS FREEBAND | HIGH GAP 15A | 27.148 USB FREEBAND | GAP ==15A/16 | 27.150 LSB/USB FREEBAND | DROP GAP =16 | 27.152 LSB NORMAL CB| CHANNEL ==16 | 27.155 AM CB 4X4 4WD JEEP CLUBS FREEBAND | HIGH GAP =16 | 27.158 USB FREEBAND | GAP ===16/17 | 27.160 LSB/USB FREEBAND | DROP GAP =17 | 27.162 LSB NORMAL CB| CHANNEL ==17 | 27.165 AM CB HIGHWAY TRUCKERS FREEBAND | HIGH GAP =17 | 27.168 USB FREEBAND | GAP ===17/18 | 27.170 LSB/USB FREEBAND | DROP GAP =18 | 27.172 LSB NORMAL CB| CHANNEL ==18 | 27.175 AM FREEBAND | HIGH GAP =18 | 27.178 USB FREEBAND | GAP ===18/19 | 27.180 LSB/USB FREEBAND | DROP GAP =19 | 27.182 LSB NORMAL CB| CHANNEL ==19 | 27.185 AM CB HIGHWAY TRUCKER PRIMARY FREEBAND | HIGH GAP =19 | 27.188 USB FREEBAND | GAP ==19/19A | 27.190 LSB/USB FREEBAND | DROP GAP 19A | 27.192 LSB CONTROL= | CHANNEL =19A | 27.195 REMOTE CONTROL TOYS/ALARMS FREEBAND | HIGH GAP 19A | 27.198 USB FREEBAND | GAP ==19A/20 | 27.200 LSB/USB
FREEBAND | DROP GAP =20 | 27.202 LSB NORMAL CB| CHANNEL ==20 | 27.205 AM FREEBAND | HIGH GAP =20 | 27.208 USB FREEBAND | GAP ===20/21 | 27.210 LSB/USB FREEBAND | DROP GAP =21 | 27.212 LSB NORMAL CB| CHANNEL ==21 | 27.215 AM CB HIGHWAY TRUCKERS FREEBAND | HIGH GAP =21 | 27.218 USB FREEBAND | GAP ===21/22 | 27.220 LSB/USB FREEBAND | DROP GAP =22 | 27.222 LSB NORMAL CB| CHANNEL ==22 | 27.225 AM FREEBAND | HIGH GAP =22 | 27.228 USB FREEBAND | GAP ===22/24 | 27.230 LSB/USB FREEBAND | DROP GAP =24 | 27.232 LSB NORMAL CB| CHANNEL ==24 | 27.235 AM FREEBAND | HIGH GAP =24 | 27.238 USB FREEBAND | GAP ===24/25 | 27.240 LSB/USB FREEBAND | DROP GAP =25 | 27.242 LSB NORMAL CB| CHANNEL ==25 | 27.245 AM FREEBAND | HIGH GAP =25 | 27.248 USB FREEBAND | GAP ===25/23 | 27.250 LSB/USB FREEBAND | DROP GAP =23 | 27.252 LSB NORMAL CB| CHANNEL ==23 | 27.255 AM FREEBAND | HIGH GAP =23 | 27.258 USB FREEBAND | GAP ===23/26 | 27.260 LSB/USB FREEBAND | DROP GAP =26 | 27.262 LSB NORMAL CB| CHANNEL ==26 | 27.265 AM FREEBAND | HIGH GAP =26 | 27.268 USB FREEBAND | GAP ===26/27 | 27.270 LSB/USB FREEBAND | DROP GAP =27 | 27.272 LSB NORMAL CB| CHANNEL ==27 | 27.275 AM FREEBAND | HIGH GAP =27 | 27.278 USB FREEBAND | GAP ===27/28 | 27.280 LSB/USB FREEBAND | DROP GAP =28 | 27.282 LSB NORMAL CB| CHANNEL ==28 | 27.285 AM FREEBAND | HIGH GAP =28 | 27.288 USB FREEBAND | GAP ===28/29 | 27.290 LSB/USB FREEBAND | DROP GAP =29 | 27.292 LSB NORMAL CB| CHANNEL ==29 | 27.295 AM FREEBAND | HIGH GAP =29 | 27.298 USB FREEBAND | GAP ===29/30 | 27.300 LSB/USB
FREEBAND | DROP GAP =30 | 27.302 LSB NORMAL CB| CHANNEL ==30 | 27.305 AM/LSB/USB FREEBAND | HIGH GAP =30 | 27.308 USB FREEBAND | GAP ===30/31 | 27.310 LSB/USB FREEBAND | DROP GAP =31 | 27.312 LSB NORMAL CB| CHANNEL ==31 | 27.315 AM/LSB/USB FREEBAND | HIGH GAP =31 | 27.318 USB FREEBAND | GAP ===31/32 | 27.310 LSB/USB FREEBAND | DROP GAP =32 | 27.322 LSB NORMAL CB| CHANNEL ==32 | 27.325 AM/LSB/USB FREEBAND | HIGH GAP =32 | 27.328 USB FREEBAND | GAP ===32/33 | 27.330 LSB/USB FREEBAND | DROP GAP =33 | 27.332 LSB NORMAL CB| CHANNEL ==33 | 27.335 AM/LSB/USB FREEBAND | HIGH GAP =33 | 27.338 USB FREEBAND | GAP ===33/34 | 27.340 LSB/USB FREEBAND | DROP GAP =34 | 27.342 LSB NORMAL CB| CHANNEL ==34 | 27.345 AM/LSB/USB FREEBAND | HIGH GAP =34 | 27.348 USB FREEBAND | GAP ===34/35 | 27.350 LSB/USB FREEBAND | DROP GAP =35 | 27.352 LSB NORMAL CB| CHANNEL ==35 | 27.355 LSB/USB FREEBAND | HIGH GAP =35 | 27.358 USB FREEBAND | GAP ===35/36 | 27.360 LSB/USB FREEBAND | DROP GAP =36 | 27.362 LSB NORMAL CB| CHANNEL ==36 | 27.365 USB FREEBAND | HIGH GAP =36 | 27.368 USB [OBSOLETE SURVIVALIST] FREEBAND | GAP ===36/37 | 27.370 LSB/USB [SOME PREPPERS] FREEBAND | DROP GAP =37 | 27.372 LSB NORMAL CB| CHANNEL ==37 | 27.375 USB PREPPER SURVIVALIST SSB* FREEBAND | HIGH GAP =37 | 27.378 USB [OBSOLETE PREPPER] FREEBAND | GAP ===37/38 | 27.380 LSB/USB FREEBAND | DROP GAP =38 | 27.382 LSB NORMAL CB| CHANNEL ==38 | 27.385 LSB/USB MAIN CB LSB CALLING FREEBAND | HIGH GAP =38 | 27.388 USB FREEBAND | GAP ===38/39 | 27.390 USB [SOME PREPPERS] FREEBAND | DROP GAP =39 | 27.392 LSB NORMAL CB| CHANNEL ==39 | 27.395 LSB/USB FREEBAND | HIGH GAP =39 | 27.398 USB FREEBAND | GAP ===39/40 | 27.400 LSB/USB FREEBAND | DROP GAP =40 | 27.402 LSB NORMAL CB| CHANNEL ==40 | 27.405 AM/LSB/USB
=== THE UPPERS==== ======= ====== === HIGH BAND E
FREEBAND | ==== 41 ZERO | 27.410 LSB/USB FREEBAND | CHANNEL ==41 | 27.415 LSB/USB BAND=E CHAN 1 FREEBAND | ==== 42 ZERO | 27.420 LSB/USB FREEBAND | CHANNEL ==42 | 27.425 USB SURVIVALIST PREPPER “E2” FREEBAND | ==== 43 ZERO | 27.430 LSB/USB FREEBAND | CHANNEL ==43 | 27.435 LSB/USB BAND=E CHAN=3 FREEBAND | ==== 44 ZERO | 27.440 LSB/USB FREEBAND | CHANNEL ==44 | 27.445 LSB/USB BAND=E CHAN=3A FREEBAND | ==== 45 ZERO | 27.450 LSB/USB FREEBAND | CHANNEL ==45 | 27.455 LSB/USB BAND=E CHAN=4 FREEBAND | ==== 46 ZERO | 27.460 LSB/USB FREEBAND | CHANNEL ==46 | 27.465 LSB/USB BAND=E CHAN=5 FREEBAND | ==== 47 ZERO | 27.470 LSB/USB FREEBAND | CHANNEL ==47 | 27.475 LSB/USB BAND=E CHAN=6 FREEBAND | ==== 48 ZERO | 27.480 LSB/USB FREEBAND | CHANNEL ==48 | 27.485 LSB/USB BAND=E CHAN=7 FREEBAND | ==== 49 ZERO | 27.490 LSB/USB FREEBAND | CHANNEL ==49 | 27.495 LSB/USB BAND=E CHAN=7A FREEBAND | ==== 50 ZERO | 27.500 LSB/USB FREEBAND | CHANNEL ==50 | 27.505 LSB/USB BAND=E CHAN=8
=== THE UPPERS==== ======= ====== ================
FREEBAND | ==== 51 ZERO | 27.510 LSB/USB FREEBAND | CHANNEL ==51 | 27.515 LSB/USB BAND=E CHAN=9 FREEBAND | ==== 52 ZERO | 27.520 LSB/USB FREEBAND | CHANNEL ==51 | 27.515 LSB/USB BAND=E CHAN=10 FREEBAND | ==== 53 ZERO | 27.530 LSB/USB FREEBAND | CHANNEL ==53 | 27.535 LSB/USB BAND=E CHAN=11 FREEBAND | ==== 54 ZERO | 27.540 LSB/USB FREEBAND | CHANNEL ==54 | 27.545 LSB/USB BAND=E CHAN=11A FREEBAND | ==== 55 ZERO | 27.550 LSB/USB FREEBAND | CHANNEL ==55 | 27.555 LSB/USB E12 FREEBAND CALLING FREEBAND | ==== 56 ZERO | 27.560 LSB/USB FREEBAND | CHANNEL ==56 | 27.565 LSB/USB BAND=E CHAN=13 FREEBAND | ==== 57 ZERO | 27.570 LSB/USB FREEBAND | CHANNEL ==57 | 27.575 LSB/USB E14 =NOT RECOMMENDED FREEBAND | ==== 58 ZERO | 27.580 LSB/USB =====NOT RECOMMENDED! FREEBAND | CHANNEL ==58 | 27.585 LSB/USB E15 =NOT RECOMMENDED! FREEBAND | ==== 59 ZERO | 27.590 LSB/USB =====NOT RECOMMENDED! FREEBAND | CHANNEL ==59 | 27.595 LSB/USB E15A NOT RECOMMENDED FREEBAND | ==== 60 ZERO | 27.600 LSB/USB FREEBAND | CHANNEL ==60 | 27.605 AM/LSB/USB BAND=E CHAN=16 FREEBAND | ABOVE CH==61 | 27.610 TO 27.999 E17 NOT RECOMMENDED
Channel 1 26.968 MHz
Channel 2 26.976 MHz
Channel 3 27.040 MHz
Channel 4 27.080 MHz
Channel 5 27.088 MHz
Channel 6 27.112 MHz
Channel 7 27.120 MHz
Channel 8 27.144 MHz
Channel 26760 26.760 MHz
Channel 26768 26.768 MHz
Channel 26776 26.776 MHz
Channel 26824 26.824 MHz
Channel 26840 26.840 MHz
Channel 26848 26.848 MHz
Channel 26856 26.856 MHz
Channel 26864 26.864 MHz
Channel 26872 26.872 MHz
Channel 26880 26.880 MHz
Channel 26888 26.888 MHz
Channel 26896 26.896 MHz
Channel 26912 26.912 MHz
Channel 26920 26.920 MHz
Channel 26928 26.928 MHz
Channel 26936 26.936 MHz
Channel 26944 26.944 MHz
Channel 27016 27.016 MHz
Channel 27524 27.524 MHz
Channel 27532 27.532 MHz
Channel 27540 27.540 MHz
Channel 27548 27.548 MHz
Channel 27556 27.556 MHz
Channel 27572 27.572 MHz
Channel 27580 27.580 MHz
Channel 27628 27.628 MHz
Channel 27636 27.636 MHz
Channel 27644 27.644 MHz
Channel 27652 27.652 MHz
Channel 27660 27.660 MHz
Channel 27668 27.668 MHz
Channel 27676 27.676 MHz
Channel 27724 27.724 MHz
Channel 27732 27.732 MHz
Channel 27740 27.740 MHz
Channel 27748 27.748 MHz
Channel 27756 27.756 MHz
Channel 27764 27.764 MHz
Channel 27772 27.772 MHz
Channel 27780 27.780 MHz
Channel 27828 27.828 MHz
Channel 27836 27.836 MHz
Channel 27852 27.852 MHz
Channel 27860 27.860 MHz
Channel 27884 27.884 MHz
Channel 27892 27.892 MHz
Channel 27908 27.908 MHz
Channel 27916 27.916 MHz
Channel 27932 27.932 MHz
Channel 27940 27.940 MHz
Channel 27956 27.956 MHz
Channel 27964 27.964 MHz
Channel 27980 27.980 MHz
Channel 27988 27.988 MHz
27310.5 kHz 27.3105 MHz
27334.5 kHz 27.3345 MHz
27338.5 kHz 27.3385 MHz
27342.5 kHz 27.3425 MHz
27346.5 kHz 27.3465 MHz
27350.5 kHz 27.3505 MHz
27354.5 kHz 27.3545 MHz
27358.5 kHz 27.3585 MHz
27362.5 kHz 27.3625 MHz
27366.5 kHz 27.3665 MHz
27370.5 kHz 27.3705 MHz
27378.5 kHz 27.3785 MHz
27382.5 kHz 27.3825 MHz
27386.5 kHz 27.3865 MHz
27388.5 kHz 27.3885 MHz
27398.5 kHz 27.3985 MHz
27404.5 kHz 27.4045 MHz
27418.5 kHz 27.4185 MHz
27426.5 kHz 27.4265 MHz
27434.5 kHz 27.4345 MHz
27442.5 kHz 27.4425 MHz
27452.5 kHz 27.4525 MHz
27458.5 kHz 27.4585 MHz
27466.5 kHz 27.4665 MHz
27470.5 kHz 27.4705 MHz
  • SPECIFICATIONS
  • 25 kHz channel spacing
  • 480 channels
  • FEATURES
  • SPECIFICATIONS
  • 20 channels
  • AM modulation
  • FEATURES
CB Channel Frequency
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
Channel 1 26.965 MHz
Channel 2 26.975 MHz
Channel 3 26.985 MHz
Channel 4 27.005 MHz
Channel 5 27.015 MHz
Channel 6 27.025 MHz
Channel 7 27.035 MHz
Channel 8 27.055 MHz
Channel 9 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.175 MHz
Channel 41 27.415 MHz
Channel 42 27.425 MHz
Channel 43 27.435 MHz
Channel 44 27.455 MHz
Channel 45 27.465 MHz
Channel 46 27.475 MHz
Channel 47 27.485 MHz
Channel 48 27.505 MHz
Channel 49 27.515 MHz
Channel 50 27.525 MHz
Channel 51 27.535 MHz
Channel 52 27.555 MHz
Channel 53 27.565 MHz
Channel 54 27.575 MHz
Channel 55 27.585 MHz
Channel 56 27.605 MHz
Channel 57 27.615 MHz
Channel 58 27.625 MHz
Channel 59 27.635 MHz
Channel 60 27.655 MHz
Channel 61 27.665 MHz
Channel 62 27.675 MHz
Channel 63 27.685 MHz
Channel 64 27.695 MHz
Channel 65 27.705 MHz
Channel 66 27.715 MHz
Channel 67 27.725 MHz
Channel 68 27.735 MHz
Channel 69 27.745 MHz
Channel 70 27.755 MHz
Channel 71 27.765 MHz
Channel 72 27.775 MHz
Channel 73 27.785 MHz
Channel 74 27.795 MHz
Channel 75 27.805 MHz
Channel 76 27.815 MHz
Channel 77 27.825 MHz
Channel 78 27.835 MHz
Channel 79 27.845 MHz
Channel 80 27.855 MHz
Channel Frequency
26.515 MHz FM Russia
26.575 MHz FM Poland
26.685 MHz FM Western Russia
26.955 MHz FM Russia
26.970 MHz FM Lithuania
27.030 MHz FM Minsk, Belarus
27.040 MHz FM Minsk, Belarus
27.060 MHz FM Kiev, Ukraine
27.110 MHz FM Poland
27.110 MHz FM Russia
27.150 MHz FM Poland
27.170 MHz FM Poland
27.190 MHz FM
27.200 MHz FM Zaykova, Russia
27.220 MHz FM
27.250 MHz FM Belarus
27.250 MHz FM Russia
27.270 MHz FM Saratov, Russia
27.270 MHz FM Kiev, Ukraine
27.290 MHz FM Minsk, Belarus
27.295 MHz FM Moscow, Russia
27.370 MHz FM Western Russia
27.430 MHz FM
27.450 MHz FM
27.470 MHz FM
27.505 MHz FM Moscow, Russia
27.580 MHz FM Moscow, Russia
27.605 MHz FM Moscow, Russia
27.630 MHz FM Moscow, Russia
27.635 MHz FM Moscow, Russia
27.650 MHz FM Western Europe
27.675 MHz FM Russia
27.765 MHz FM Germany
27.840 MHz FM Poland
27.875 MHz FM Rostov, Russia
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band 27.9 MHz 27.900 MHz 20-27.9 MHz 27-38.9 MHz 20-28 mc megacycle 27.8 MHz, 27.4 MHz, 27.41 MHz what are the freeband CB frequencies survivalist CB frequencies emergency frequencies near me emergency channels near me UHF emergency frequency VHF emergency frequency 4125 kHz 4417 kHz 6215 kHz 6200 kHz 6212 kHz 6516 kHz 8255 kHz 8779 kHz 12290 kHz 12359 kHz 11175 kHz 13200 kHz 13137 kHz 16420 kHz 16537 kHz 17302 kHz 18795 kHz 19770 kHz 22060 kHz 22756 kHz 25097 kHz 26.097 MHz R4002 26172 kHz 26.172 MHz 2045 kHz 2638 kHz 2003 kHz 6765 kHz 6770 kHz 2048 kHz 2635 kHz ship-to-shore international frequencies radiotelephone emergency calling frequencies GMDSS DSC 2182 kHz 2187.5 kHz 4207.5 kHz 6312 kHz 8414.4 kHz 12577 kHz 16804.5 kHz 156.525 MHz 156.3 MHz 156.8 MHz 156.800 MHz telegraphy distress safety narrow band direct printing 2174.5 kHz 4177.5 kHz 6268 kHz 8376.5 kHz 12520 kHz 16695 kHz 8291 kHz 16420 kHz 4125kHz 3023 kHz 5680 kHz 8364 kHz 10003 kHz 14993 kHz 19993 kHz 19.993 MHz 10.003 MHz 14.993 MHz 123.025 MHz 123.1 MHz 122.9 MHz 455.5 kHz 458.5 kHz 16805.5 kHz 16805 kHz 25208 kHz 25.208 MHz 26121 kHz 26122 kHz 26.840 MHz
