FRS
Revision as of 18:43, 4 March 2022 by R4002 (Talk | contribs)
Family Radio Service
22-channel UHF short-distance two-way radio service walkie-talkie service operating in the 462/467 MHz bands - 462.5500 MHz to 462.7250 MHz and 467.5625 MHz to 467.7125 MHz bands, license free replacement (or rather supplement) to the CB radio service for personal, family, business or really any other use.
FM voice (narrow FM or NFM, see specifics below). 15 of the 22 FRS channels are shared with the GMRS service (GMRS requires a license, FRS does not). FRS is regulated as a license free ppersonal radio service and all users must share all channels with one another. FRS does allow some limited data transmissions (GPS location coordinates, for example) but digital voice modes are not permitted on FRS.
Short range walkie talkie radios.
  • Do you need a license to use the 22 FRS channels?
  • Are the "color dot" frequencies license free or part of FRS?
No.
The old White Dot (462.575 MHz, FRS channel 16), Black Dot (462.625 MHz, FRS channel 18) and Orange Dot (462.675 MHz, FRS channel 20) are now part of the FRS and GMRS services. Use of those three frequencies is legal without a license for business purposes under the FRS rules. Other color dot channels (151.625 MHz, 151.955 MHz, 464.550 MHz, 464.500 MHz, etc.) require FCC licensing. The 154.570 MHz (Blue Dot/MURS channel 4) and 154.600 MHz (Green Dot/MURS channel 5) MURS channels were previously color dot channels as well - and those are license free under the MURS service.
  • Are Baofeng radios illegal? or Are Baofeng radios legal?
  • My FRS radios claim 18 mile range or 22 mile range or 26 mile range 28 mile range or 32 mile range or 36 mile range or 40 mile range but mine only work within a 2-3 mile radius - how come my FRS walkie talkies aren't working at the advertised range? OR - What range can I expect with my FRS radios?
On top of tall peaks, very impressive range is possible with FRS handheld radios - as long as there aren't any obstructions between you and the person you're communicating with (this includes other mountain peaks). On the other hand, if you're down in a valley surrounded by mountains/hills, don't expect to be able to communicate with somebody on the other side of the mountain/hill. In urban areas, steel, concrete, brick, etc. block and absorb radio waves very well. Get up as high as possible (ideally above the obstructions) and move around. Often moving 5-10 feet in one direction or another can mean the difference between poor or no signal to a quality readable signal.
Most FRS radios have a high/low power setting - remember that channels 8 through 14 are low power only. Channels 1 through 7 and 15 through 22 may be used on high or low power. Check your transmit power setting. If you're using channel 8, 9, 10, 11, 12, 13 or 14, switch to one of the channels where high power is permitted (channels 1-7 and 15-22) and make sure all radios in your group are set to high power. However, if reliable communications are possible on the low power setting, use low power. Using low power mode unless you absolutely need to use high power will improve battery life significantly.
  • Are FRS channels part of the CB radio service?
  • Can I talk to CB radios with my FRS radio?
  • What are the FRS channels? I want to program them in my Baofeng, Hytera, Retevis, BTECH, TYT, QYT, Motorola, Kenwood, Icom, etc.
  • Should I program the FRS frequencies or channels FM deviation in wide or narrow mode?
  • I live in an urbanized area with lots of activity on the FRS channels, how do I avoid annoying interference from other groups on the same channel?
  • I'm programming a set of radios with the FRS frequencies - which CTCSS PL or DCS DPL DTCS tones or codes should I avoid?
  • CTCSS Tones To Avoid
  • FRS Channel 16 - 114.8 Hz
  • DCS Codes To Avoid
  • My FRS radio has something called privacy codes - what are these and how do they work?
  • My Midland FRS radio has more than 22 channels? How is this possible?
Up to date as of April 2021. FRS is licensed by rule (no individual license required) under Part 95 of the FCC rules 47 CFR 95 (Subpart B - Family Radio Service). It is considered a Personal Radio Service (PRS) under FCC regulations, just like the CB Radio Service (CB Radio or CBRS), Multi Use Radio Service (MURS), the General Mobile Radio Service, the Radio Control Radio Service (RCRS) and others.
§ 95.587 FRS additional requirements. Each FRS transmitter type must be designed to meet the following additional requirements. (a) Transmit frequency capability. FRS transmitter types must not be capable of transmitting on any frequency or channel other than those listed in § 95.563. (b) Antenna. The antenna of each FRS transmitter type must meet the following requirements. (1) The antenna must be a non-removable integral part of the FRS transmitter type. (2) The gain of the antenna must not exceed that of a half-wave dipole antenna. (3) The antenna must be designed such that the electric field of the emitted waves is vertically polarized when the unit is operated in the normal orientation. (c) Digital data transmissions. FRS transmitter types having the capability to transmit digital data must be designed to meet the following requirements. (1) FRS units may transmit digital data containing location information, or requesting location information from one or more other FRS or GMRS units, or containing a brief text message to another specific FRS or GMRS unit or units. (2) Digital data transmissions must be initiated by a manual action or command of the operator, except that FRS units may be designed to automatically respond with location data upon receiving an interrogation request from another FRS unit or a GMRS unit. (3) Digital data transmissions must not exceed one second in duration. (4) Digital data transmissions must not be sent more frequently than one digital data transmission within a thirty-second period, except that an FRS unit may automatically respond to more than one interrogation request received within a thirty-second period. (d) Packet mode. FRS transmitter types must not be capable of transmitting data in the store-and-forward packet operation mode. (e) Effective September 30, 2019, no person shall manufacture or import hand-held portable radio equipment capable of operating under this subpart (FRS) and other licensed or licensed-by-rule services in this chapter (part 15 unlicensed equipment authorizations are permitted if consistent with part 15 rules).
  • 462.6125 MHz - FRS 3 - UHF Primary/Calling FRS 3 - AmRRON - also MURS 3, CB 3
  • 462.6625 MHz - FRS 5
  • 462.6875 MHz - FRS 6
  • 462.7125 MHz - FRS 7
  • 462.5500 MHz - FRS 15
  • 462.6000 MHz - FRS 17
  • Channel 1 - 462.5625 MHz
  • Channel 2 - 462.5875 MHz
  • Channel 3 - 462.6125 MHz
  • Channel 4 - 462.6375 MHz
  • Channel 5 - 462.6625 MHz
  • Channel 6 - 462.6875 MHz
  • Channel 7 - 462.7125 MHz
  • Channel 8 - 467.5625 MHz
  • Channel 9 - 467.5875 MHz
  • Channel 10 - 467.6125 MHz
  • Channel 11 - 467.6375 MHz
  • Channel 12 - 467.6625 MHz
  • Channel 13 - 467.6875 MHz
  • Channel 14 - 467.7125 MHz
  • Channel 15 - 462.5500 MHz
  • Channel 16 - 462.5750 MHz
  • Channel 17 - 462.6000 MHz
  • Channel 18 - 462.6250 MHz
  • Channel 19 - 462.6500 MHz
  • Channel 20 - 462.6750 MHz
  • Channel 21 - 462.7000 MHz
  • Channel 22 - 462.7250 MHz
  • Code 1 - 67.0 Hz
  • Code 2 - 71.9 Hz
  • Code 3 - 74.4 Hz
  • Code 4 - 77.0 Hz
  • Code 5 - 79.7 Hz
  • Code 6 - 82.5 Hz
  • Code 7 - 85.4 Hz
  • Code 8 - 88.5 Hz
  • Code 9 - 91.5 Hz
  • Code 10 - 94.8 Hz
  • Code 11 - 97.4 Hz
  • Code 12 - 100.0 Hz
  • Code 13 - 103.5 Hz
  • Code 14 - 107.2 Hz
  • Code 15 - 110.9 Hz
  • Code 16 - 114.8 Hz
  • Code 17 - 118.8 Hz
  • Code 18 - 123.0 Hz
  • Code 19 - 127.3 Hz
  • Code 20 - 131.8 Hz
  • Code 21 - 136.5 Hz
  • Code 22 - 141.3 Hz
  • Code 23 - 146.2 Hz
  • Code 24 - 151.4 Hz
  • Code 25 - 156.7 Hz
  • Code 26 - 162.2 Hz
  • Code 27 - 167.9 Hz
  • Code 28 - 173.8 Hz
  • Code 29 - 179.9 Hz
  • Code 30 - 186.2 Hz
  • Code 31 - 192.8 Hz
  • Code 32 - 203.5 Hz
  • Code 33 - 210.7 Hz
  • Code 34 - 218.1 Hz
  • Code 35 - 225.7 Hz
  • Code 36 - 233.6 Hz
  • Code 37 - 241.8 Hz
  • Code 38 - 250.3 Hz
  • Code 39 - D023
  • Code 40 - D025
  • Code 41 - D026
  • Code 42 - D031
  • Code 43 - D032
  • Code 44 - D043
  • Code 45 - D047
  • Code 46 - D051
  • Code 47 - D054
  • Code 48 - D065
  • Code 49 - D071
  • Code 50 - D072
  • Code 51 - D073
  • Code 52 - D074
  • Code 53 - D114
  • Code 54 - D115
  • Code 55 - D116
  • Code 56 - D125
  • Code 57 - D131
  • Code 58 - D132
  • Code 59 - D134
  • Code 60 - D143
  • Code 61 - D152
  • Code 62 - D155
  • Code 63 - D156
  • Code 64 - D162
  • Code 65 - D165
  • Code 66 - D172
  • Code 67 - D174
  • Code 68 - D205
  • Code 69 - D223
  • Code 70 - D226
  • Code 71 - D243
  • Code 72 - D244
  • Code 73 - D245
  • Code 74 - D251
  • Code 75 - D261
  • Code 76 - D263
  • Code 77 - D265
  • Code 78 - D271
  • Code 79 - D306
  • Code 80 - D311
  • Code 81 - D315
  • Code 82 - D331
  • Code 83 - D343
  • Code 84 - D346
  • Code 85 - D351
  • Code 86 - D364
  • Code 87 - D365
  • Code 88 - D371
  • Code 89 - D411
  • Code 90 - D412
  • Code 91 - D413
  • Code 92 - D423
  • Code 93 - D431
  • Code 94 - D432
  • Code 95 - D445
  • Code 96 - D464
  • Code 97 - D465
  • Code 98 - D466
  • Code 99 - D503
  • Code 100 - D506
  • Code 101 - D516
  • Code 102 - D532
  • Code 103 - D546
  • Code 104 - D565
  • Code 105 - D606
  • Code 106 - D612
  • Code 107 - D624
  • Code 108 - D627
  • Code 109 - D631
  • Code 110 - D632
  • Code 111 - D654
  • Code 112 - D662
  • Code 113 - D664
  • Code 114 - D703
  • Code 115 - D712
  • Code 116 - D723
  • Code 117 - D731
  • Code 118 - D732
  • Code 119 - D734
  • Code 120 - D743
  • Code 121 - D754
  • Code 1 - 67.0 Hz
  • Code 2 - 69.3 Hz
  • Code 3 - 71.9 Hz
  • Code 4 - 74.4 Hz
  • Code 5 - 77.0 Hz
  • Code 6 - 79.7 Hz
  • Code 7 - 82.5 Hz
  • Code 8 - 85.4 Hz
  • Code 9 - 88.5 Hz
  • Code 10 - 91.5 Hz
  • Code 11 - 94.8 Hz
  • Code 12 - 97.4 Hz
  • Code 13 - 100.0 Hz
  • Code 14 - 103.5 Hz
  • Code 15 - 107.2 Hz
  • Code 16 - 110.9 Hz
  • Code 17 - 114.8 Hz
  • Code 18 - 118.8 Hz
  • Code 19 - 123.0 Hz
  • Code 20 - 127.3 Hz
  • Code 21 - 131.8 Hz
  • Code 22 - 136.5 Hz
  • Code 23 - 141.3 Hz
  • Code 24 - 146.2 Hz
  • Code 25 - 151.4 Hz
  • Code 26 - 156.7 Hz
  • Code 27 - 159.8 Hz
  • Code 28 - 162.2 Hz
  • Code 29 - 165.5 Hz
  • Code 30 - 167.9 Hz
  • Code 31 - 171.3 Hz
  • Code 32 - 173.8 Hz
  • Code 33 - 177.3 Hz
  • Code 34 - 179.9 Hz
  • Code 35 - 183.5 Hz
  • Code 36 - 186.2 Hz
  • Code 37 - 189.9 Hz
  • Code 38 - 192.8 Hz
  • Code 39 - 196.6 Hz
  • Code 40 - 199.5 Hz
  • Code 41 - 203.5 Hz
  • Code 42 - 206.5 Hz
  • Code 43 - 210.7 Hz
  • Code 44 - 218.1 Hz
  • Code 45 - 225.7 Hz
  • Code 46 - 229.1 Hz
  • Code 47 - 233.6 Hz
  • Code 48 - 241.8 Hz
  • Code 49 - 250.3 Hz
  • Code 50 - 254.1 Hz
  • FRS Channel 5 - 462.6625 MHz 225 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 0, group code A (new version)
  • FRS Channel 5 - 462.6625 MHz 332 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 0, group code B (new version)
  • FRS Channel 5 - 462.6625 MHz 464 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 0, group code C (new version)
  • FRS Channel 6 - 462.6875 MHz 261 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 9, group code A (new version)
  • FRS Channel 6 - 462.6875 MHz 412 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 9, group code B (new version)
  • FRS Channel 6 - 462.6875 MHz 546 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 9, group code C (new version)
  • FRS Channel 7 - 462.7125 MHz 255 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 8, group code A (new version)
  • FRS Channel 7 - 462.7125 MHz 411 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 8, group code B (new version)
  • FRS Channel 7 - 462.7125 MHz 532 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 8, group code C (new version)
  • FRS Channel 8 - 467.5625 MHz 252 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 7, group code A (new version)
  • FRS Channel 8 - 467.5625 MHz 371 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 7, group code B (new version)
  • FRS Channel 8 - 467.5625 MHz 526 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 7, group code C (new version)
  • FRS Channel 9 - 467.5875 MHz 251 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 6, group code A (new version)
  • FRS Channel 9 - 467.5875 MHz 365 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 6, group code B (new version)
  • FRS Channel 9 - 467.5875 MHz 523 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 6, group code C (new version)
  • FRS Channel 10 - 467.6125 MHz 246 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 5, group code A (new version)
  • FRS Channel 10 - 467.6125 MHz 364 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 5, group code B (new version)
  • FRS Channel 10 - 467.6125 MHz 516 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 5, group code C (new version)
  • FRS Channel 11 - 467.6375 MHz 245 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 4, group code A (new version)
  • FRS Channel 11 - 467.6375 MHz 356 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 4, group code B (new version)
  • FRS Channel 11 - 467.6375 MHz 506 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 4, group code C (new version)
  • FRS Channel 12 - 467.6625 MHz 244 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 3, group code A (new version)
  • FRS Channel 12 - 467.6625 MHz 351 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 3, group code B (new version)
  • FRS Channel 12 - 467.6625 MHz 503 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 3, group code C (new version)
  • FRS Channel 13 - 467.6875 MHz 243 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 2, group code A (new version)
  • FRS Channel 13 - 467.6875 MHz 346 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 2, group code B (new version)
  • FRS Channel 13 - 467.6875 MHz 466 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 2, group code C (new version)
  • FRS Channel 14 - 467.7125 MHz 250.3 Hz - Airshow and Milcom Hobbyist and Monitors Intercept Primary Channel
  • FRS Channel 14 - 467.7125 MHz 226 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 1, group code A (new version)
  • FRS Channel 14 - 467.7125 MHz 343 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 1, group code B (new version)
  • FRS Channel 14 - 467.7125 MHz 465 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 1, group code C (new version)
CTCSS (PL) and DCS (DPL) Tones and Codes To Avoid on FRS and GMRS Channels
Listing by channel. Note that many radios default to either carrier squelch (no tone) or "code 1", which is 67.0 Hz. Below are the most commonly found CTCSS and DCS tones and codes by channel.
CTCSS is also known as PL, QT or CTCS (as in T-CTCS and R-CTCS). DCS (as in T-DCS or R-DCS) is also known as DPL, DQT or DTCS. Use DCS may cause a some receivers set to 136.5 Hz or 131.8 Hz tone squelch to open due to DCS using a digital sub audible tone at 134 Hz. This is why a receiver set to CTCSS decode or PL decode may decode a transmission using DCS as using 136.5 Hz CTCSS.
Note that this listing includes regular DCS and inverted DCS. Due to issues with systems decoding inverted DCS incorrectly, I have included the "companion" regular DCS code with the inverted DCS, as many receivers will decode the "mirror image" DCS code when inverted DCS is used. For regular DCS, DxxxN is used, for inverted DCS, the code is shown as DxxxI. For example, 023 DCS would be indicated as D023N, whereas 464I DCS (inverted DCS code 464) would be shown as D464I.
  • FRS Channel 8 - 462.5625 MHz
  • FRS Channel 9 - 462.5875 MHz
  • FRS Channel 10 - 462.6125 MHz
  • FRS Channel 11 - 462.6375 MHz
  • FRS Channel 12 - 462.6625 MHz
  • FRS Channel 13 - 462.6875 MHz
  • FRS Channel 14 - 462.7125 MHz
  • FRS Channel 15 - 467.5625 MHz
  • FRS Channel 16
  • FRS Channel 17
  • FRS Channel 18
  • FRS Channel 19
Which CTCSS and DCS tones codes should I avoid using on the FRS Family Radio Service channels GMRS frequencies commonly used default factory frequencies most often heard most popular CTCSS tones most popular tones.
*Recommended Programming FRS-22-C - 22 channel FRS radios with 38 privacy codes - same code for blocks of channels *Recommended sub-channel or privacy code CTCSS settings for each channel, with radio display indicated
  • CH01 - Code # 05 [79.7 PL] - Display Channel 1-05 ----- 462.5625 MHz 79.7 Hz
  • CH02 - Code # 05 [79.7 PL] - Display Channel 2-05 ----- 462.5875 MHz 79.7 Hz
  • CH03 - Code # 05 [79.7 PL] - Display Channel 3-05 ----- 462.6125 MHz 79.7 Hz
  • CH04 - Code # 05 [79.7 PL] - Display Channel 4-05 ----- 462.6375 MHz 79.7 Hz
  • CH06 - Code # 05 [79.7 PL] - Display Channel 6-05 ----- 462.6875 MHz 79.7 Hz
  • CH07 - Code # 05 [79.7 PL] - Display Channel 7-05 ----- 462.7125 MHz 79.7 Hz
  • CH08 - Code # 02 [71.9 PL] - Display Channel 8-02 ----- 467.5625 MHz 71.9 Hz
  • CH09 - Code # 02 [71.9 PL] - Display Channel 9-02 ----- 467.5875 MHz 71.9 Hz
  • CH10 - Code # 02 [71.9 PL] - Display Channel 10-02 ----- 467.6125 MHz 71.9 Hz
  • CH11 - Code # 02 [71.9 PL] - Display Channel 11-02 ----- 467.6375 MHz 71.9 Hz
  • CH12 - Code # 02 [71.9 PL] - Display Channel 12-02 ----- 467.6625 MHz 71.9 Hz
  • CH13 - Code # 02 [71.9 PL] - Display Channel 13-02 ----- 467.6875 MHz 71.9 Hz
  • CH14 - Code # 02 [71.9 PL] - Display Channel 14-02 ----- 467.7125 MHz 71.9 Hz
  • CH15 - Code # 09 [91.5 PL] - Display Channel 15-09 ----- 462.5500 MHz 91.5 Hz
  • CH16 - Code # 09 [91.5 PL] - Display Channel 16-09 ----- 462.5750 MHz 91.5 Hz
  • CH17 - Code # 09 [91.5 PL] - Display Channel 17-09 ----- 462.6000 MHz 91.5 Hz
  • CH18 - Code # 09 [91.5 PL] - Display Channel 18-09 ----- 462.6250 MHz 91.5 Hz
  • CH19 - Code # 09 [91.5 PL] - Display Channel 19-09 ----- 462.6500 MHz 91.5 Hz
  • CH20 - Code # 09 [91.5 PL] - Display Channel 20-09 ----- 462.6750 MHz 91.5 Hz
  • CH21 - Code # 09 [91.5 PL] - Display Channel 21-09 ----- 462.7000 MHz 91.5 Hz
  • CH22 - Code # 09 [91.5 PL] - Display Channel 22-09 ----- 462.7250 MHz 91.5 Hz
*Recommended Programming FRS-22-D - 22 channel FRS radios with 38 privacy codes - same code for all 22 channels *Recommended sub-channel or privacy code CTCSS settings for each channel, with radio display indicated
  • CH01 - Code # 36 [233.6 PL] - Display Channel 1-36 ----- 462.5625 MHz 233.6 Hz
  • CH02 - Code # 36 [233.6 PL] - Display Channel 2-36 ----- 462.5875 MHz 233.6 Hz
  • CH03 - Code # 36 [233.6 PL] - Display Channel 3-36 ----- 462.6125 MHz 233.6 Hz
  • CH04 - Code # 36 [233.6 PL] - Display Channel 4-36 ----- 462.6375 MHz 233.6 Hz
  • CH05 - Code # 36 [233.6 PL] - Display Channel 5-36 ----- 462.6625 MHz 233.6 Hz
  • CH06 - Code # 36 [233.6 PL] - Display Channel 6-36 ----- 462.6875 MHz 233.6 Hz
  • CH07 - Code # 36 [233.6 PL] - Display Channel 7-36 ----- 462.7125 MHz 233.6 Hz
  • CH08 - Code # 36 [233.6 PL] - Display Channel 8-36 ----- 467.5625 MHz 233.6 Hz
  • CH09 - Code # 36 [233.6 PL] - Display Channel 9-36 ----- 467.5875 MHz 233.6 Hz
  • CH10 - Code # 36 [233.6 PL] - Display Channel 10-36 ----- 467.6125 MHz 233.6 Hz
  • CH11 - Code # 36 [233.6 PL] - Display Channel 11-36 ----- 467.6375 MHz 233.6 Hz
  • CH12 - Code # 36 [233.6 PL] - Display Channel 12-36 ----- 467.6625 MHz 233.6 Hz
  • CH13 - Code # 36 [233.6 PL] - Display Channel 13-36 ----- 467.6875 MHz 233.6 Hz
  • CH14 - Code # 36 [233.6 PL] - Display Channel 14-36 ----- 467.7125 MHz 233.6 Hz
  • CH15 - Code # 36 [233.6 PL] - Display Channel 15-36 ----- 462.5500 MHz 233.6 Hz
  • CH16 - Code # 36 [233.6 PL] - Display Channel 16-36 ----- 462.5750 MHz 233.6 Hz
  • CH17 - Code # 36 [233.6 PL] - Display Channel 17-36 ----- 462.6000 MHz 233.6 Hz
  • CH19 - Code # 36 [233.6 PL] - Display Channel 19-36 ----- 462.6500 MHz 233.6 Hz
  • CH20 - Code # 36 [233.6 PL] - Display Channel 20-36 ----- 462.6750 MHz 233.6 Hz
  • CH21 - Code # 36 [233.6 PL] - Display Channel 21-36 ----- 462.7000 MHz 233.6 Hz
  • CH22 - Code # 36 [233.6 PL] - Display Channel 22-36 ----- 462.7250 MHz 233.6 Hz
*Recommended Programming FRS-22-E - 22 channel FRS radios with 38 privacy codes - easy to remember add integer x to channel number - in this example, add 7 to channel number (so channel 1 + 7 = code 8, channel 1 + 7 = code 9, etc.) - this is easy to implement with any number as the X number - especially with radios that have 121 different codes to choose from - for example, add 50 to the channel number, add 70 to the channel number, subtract the channel number from 121, etc. *Recommended sub-channel or privacy code CTCSS settings for each channel, with radio display indicated
  • CH01 - Code # 08 [88.5 PL] - Display Channel 1-08 ----- 462.5625 MHz 88.5 Hz
  • CH02 - Code # 09 [91.5 PL] - Display Channel 2-09 ----- 462.5875 MHz 91.5 Hz
  • CH03 - Code # 10 [94.8 PL] - Display Channel 3-10 ----- 462.6125 MHz 94.8 Hz
  • CH05 - Code # 12 [100.0 PL] - Display Channel 5-12 ----- 462.6625 MHz 100.0 Hz
  • CH07 - Code # 14 [107.2 PL] - Display Channel 7-14 ----- 462.7125 MHz 107.2 Hz
  • CH08 - Code # 15 [110.9 PL] - Display Channel 8-15 ----- 467.5625 MHz 110.9 Hz
  • CH09 - Code # 16 [114.8 PL] - Display Channel 9-16 ----- 467.5875 MHz 114.8 Hz
  • CH10 - Code # 17 [118.8 PL] - Display Channel 10-17 ----- 467.6125 MHz 118.8 Hz
  • CH11 - Code # 18 [123.0 PL] - Display Channel 11-18 ----- 467.6375 MHz 123.0 Hz
  • CH12 - Code # 19 [127.3 PL] - Display Channel 12-19 ----- 467.6625 MHz 127.3 Hz
  • CH13 - Code # 20 [131.8 PL] - Display Channel 13-20 ----- 467.6875 MHz 131.8 Hz
  • CH14 - Code # 21 [136.5 PL] - Display Channel 14-21 ----- 467.7125 MHz 136.5 Hz
  • CH15 - Code # 22 [141.3 PL] - Display Channel 15-22 ----- 462.5500 MHz 141.3 Hz
  • CH16 - Code # 23 [146.2 PL] - Display Channel 16-23 ----- 462.5750 MHz 146.2 Hz
  • CH17 - Code # 24 [151.4 PL] - Display Channel 17-24 ----- 462.6000 MHz 151.4 Hz
  • CH18 - Code # 25 [156.7 PL] - Display Channel 18-25 ----- 462.6250 MHz 156.7 Hz
  • CH19 - Code # 26 [162.2 PL] - Display Channel 19-26 ----- 462.6500 MHz 162.2 Hz
  • CH20 - Code # 27 [167.9 PL] - Display Channel 20-27 ----- 462.6750 MHz 167.9 Hz
  • CH21 - Code # 28 [173.8 PL] - Display Channel 21-28 ----- 462.7000 MHz 173.8 Hz
  • CH22 - Code # 29 [179.9 PL] - Display Channel 22-29 ----- 462.7250 MHz 179.9 Hz
  • Channel 8 - 462.5500 MHz
  • Channel 9 - 462.5750 MHz
  • Channel 10 - 462.6000 MHz
  • Channel 11 - 462.6250 MHz
  • Channel 12 - 462.6500 MHz
  • Channel 13 - 462.6750 MHz
  • Channel 14 - 462.7000 MHz
  • Channel 15 - 462.7250 MHz
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a monitor, transmit lock, baby monitor or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours). While some intercoms only transmit in the 200mW to 300mW range, higher-end versions transmit close to 500mW with efficient antennas.
486.4mw (nominally <500mw) power output, 9K90F3E emission
  • CHANNEL 0 - 462.6125 MHz 118.8 Hz CTCSS
  • CHANNEL 1 - 467.6375 MHz
  • CHANNEL 2 - 462.5875 MHz
  • CHANNEL 3 - 462.6125 MHz
  • CHANNEL 4 - 462.6375 MHz
  • CHANNEL 5 - 462.6625 MHz
  • CHANNEL 6 - 462.6875 MHz
  • CHANNEL 7 - 467.7125 MHz
  • CHANNEL 8 - 462.5500 MHz
  • CHANNEL 9 - 462.5750 MHz
  • Code 1 - 162.2 Hz CTCSS
  • Code 2 - 69.3 Hz CTCSS
  • Code 3 - 67.0 Hz CTCSS
  • All intercoms in a given system must be set to the same code (3-position switch on the back of the unit).
484.2mw (nominally <500mw) power output, 9K80F3E emission, the HY787 wireless FM intercom uses the same channel and code plan
  • GROUP CALL - 462.6125 MHz 165.5 Hz CTCSS
  • CHANNEL 1 - 462.5625 MHz
  • CHANNEL 7 - 467.7125 MHz 118.8 Hz CTCSS
  • Code 1 - 743 DCS / 743 DPL
  • Code 2 - 732 DCS / 732 DPL
  • Code 3 - 731 DCS / 731 DPL
  • CHANNEL 2 - 462.6125 MHz
  • CHANNEL 3 - 462.6375 MHz
  • Code A - 67.0 Hz CTCSS
  • Code B - 69.3 Hz CTCSS
  • Code C - 165.5 Hz CTCSS
215mw power output, 11K0F3E emission. 3 different CTCSS code settings A, B and C. Tones are unconfirmed.
  • Calford Technology Ltd. AF388 9 channel FM wireless intercom
215mw power output, 11K0F3E emission. FCC ID: 2AAYF-AF388. 3 different CTCSS code settings A, B and C. Tones are unconfirmed.
  • CHANNEL 7 - 462.7125 MHz
  • CHANNEL 8 - 467.5625 MHz
  • CHANNEL 9 - 467.5875 MHz
234mw power output, 11K0F3E emission. 3 different CTCSS code settings A, B and C. Tones are unconfirmed.
  • CHANNEL A - 462.5625 MHz
  • CHANNEL B - 462.5875 MHz
  • CHANNEL C - 462.6125 MHz
  • CHANNEL D - 462.6375 MHz
  • SAMCOM FTAN10A 10 channel wireless intercom - older version
205mw - 213 mw power output, 11K0F3E emission SAMCOM intercoms are sold under numerous brand names including SANZUCO and several others. SANZUCO 10 channel wireless intercom. Various "updates" and "versions" exist, including some listed under the FTAN40A model number. FCC ID 2AS5R-FTAN40A 10-channel wireless intercom with 3 digital codes.
  • CHANNEL 0 - 462.6625 MHz
  • CHANNEL 1 - 467.7125 MHz
  • CHANNEL 2 - 467.6875 MHz
  • CHANNEL 3 - 467.6625 MHz
  • CHANNEL 4 - 467.6375 MHz
  • CHANNEL 5 - 467.6125 MHz
  • CHANNEL 6 - 467.5875 MHz
  • CHANNEL 7 - 467.5625 MHz
  • CHANNEL 8 - 462.7125 MHz
  • CHANNEL 9 - 462.6875 MHz
  • Code A - 110.9 Hz CTCSS
  • Code B - 136.5 Hz CTCSS
  • Code C - 186.2 Hz CTCSS
  • Channels 0-9 will use code A, code B or code C. All intercoms in a given system must be set to the same code. GROUP CALL channel is set to channel 0. However, end-user may assign any channel to as the GROUP channel (except for a channel already assigned to any unit in their network).
  • SAMCOM FTAN40A 10 channel wireless intercom - newer version
  • CHANNEL 0 - 462.6625 MHz - Code A: 225 DCS Code B: 332 DCS Code C: 464 DCS
  • CHANNEL 1 - 467.7125 MHz - Code A: 226 DCS Code B: 343 DCS Code C: 465 DCS
  • CHANNEL 2 - 467.6875 MHz - Code A: 243 DCS Code B: 346 DCS Code C: 466 DCS
  • CHANNEL 3 - 467.6625 MHz - Code A: 244 DCS Code B: 351 DCS Code C: 503 DCS
  • CHANNEL 4 - 467.6375 MHz - Code A: 245 DCS Code B: 356 DCS Code C: 506 DCS
  • CHANNEL 5 - 467.6125 MHz - Code A: 246 DCS Code B: 364 DCS Code C: 516 DCS
  • CHANNEL 6 - 467.5875 MHz - Code A: 251 DCS Code B: 365 DCS Code C: 523 DCS
  • CHANNEL 7 - 467.5625 MHz - Code A: 252 DCS Code B: 371 DCS Code C: 526 DCS
  • CHANNEL 8 - 462.7125 MHz - Code A: 255 DCS Code B: 411 DCS Code C: 532 DCS
  • CHANNEL 9 - 462.6875 MHz - Code A: 261 DCS Code B: 412 DCS Code C: 546 DCS
  • Channels 0-9 will use code A, code B or code C. Each intercom can only be set to one code at a time. All intercoms in a given system must be set to the same code. GROUP CALL channel is set to channel 0. However, end-user may assign any channel to as the GROUP channel (except for a channel already assigned to any unit in their network). All intercoms must be set to the same code A, B or C and must have the same channel 0-9 assigned as the GROUP or GROUP CALL channel set (if the user decides to switch from the default group channel setting).
As of 2021, the manufacturer or vendor is alternating so 2-packs and 4-packs of intercoms sold as ready-to-use systems may be set to Code A, Code B or Code C. Out of the box intercoms will be programmed on channel 1 or subnetwork 1 with channel 0 as the group channel. A user may assign as many intercoms to each channel as they wish, or may assign one intercom per channel (for one-to-one communication) and use the group call function to broadcast a message to all intercoms (one-to-many broadcasts).
The newer versions of these intercoms use different A/B/C DCS (DPL) codes for each channel (see above).
  • SAMCOM FTAN20A 10 channel wireless intercom
225mw - 235 mw power output, 11K0F3E emission SAMCOM intercoms are sold under numerous brand names including SANZUCO and several others. SANZUCO 20 channel wireless intercom.
  • CHANNEL 10 - 462.6375 MHz
  • CHANNEL 11 - 462.6125 MHz
  • CHANNEL 12 - 462.5875 MHz
  • CHANNEL 13 - 462.5625 MHz
  • CHANNEL 14 - 462.7250 MHz
  • CHANNEL 15 - 462.7000 MHz
  • CHANNEL 16 - 462.6750 MHz
  • CHANNEL 17 - 462.6500 MHz
  • CHANNEL 18 - 462.6250 MHz
  • CHANNEL 19 - 462.6000 MHz
  • Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same group code. As with the FTAN40A and FTAN10A...more recent versions may use different sets of CTCSS tones or DCS codes for anti-interference codes A, B and C. Newer versions also appear to alternate between anti-interference codes for each channel.
  • CHANNEL 0 - 467.6125 MHz
  • CHANNEL 1 - 462.7250 MHz
  • Code A - 754 DCS / 754 DPL
  • Code B - 743 DCS / 743 DPL
  • Code C - 734 DCS / 734 DPL
  • GROUP CALL - 467.7125 MHz 743 DCS / 743 DPL - systemwide calling frequency and code (FRS channel 14)
  • CHANNEL 10 - 467.6125 MHz
  • CHANNEL 11 - 467.6375 MHz
  • CHANNEL 12 - 467.6625 MHz
  • CHANNEL 13 - 467.6875 MHz
  • CHANNEL 14 - 467.7125 MHz
  • CHANNEL 15 - 462.5500 MHz
  • CHANNEL 16 - 462.5750 MHz
  • CHANNEL 17 - 462.6000 MHz
  • CHANNEL 19 - 462.6500 MHz
  • CHANNEL 20 - 462.6750 MHz
  • CHANNEL 21 - 462.7000 MHz
  • CHANNEL 22 - 462.5625 MHz
  • Code 01 - 754 DCS / 754 DPL
  • Code 02 - 743 DCS / 743 DPL
  • Code 03 - 734 DCS / 734 DPL
  • Code 04 - 77.0 Hz PL
  • Code 05 - 79.7 Hz PL
  • Code 06 - 82.5 Hz PL
  • Code 07 - 85.4 Hz PL
  • Code 08 - 88.5 Hz PL
  • Code 09 - 91.5 Hz PL
  • Code 10 - 94.8 Hz PL
  • Code 11 - 97.4 Hz PL
  • Code 12 - 100.0 Hz PL
  • Code 13 - 103.5 Hz PL
  • Code 14 - 107.2 Hz PL
  • Code 15 - 110.9 Hz PL
  • Code 16 - 114.8 Hz PL
  • Code 17 - 118.8 Hz PL
  • Code 18 - 123.0 Hz PL
  • Code 19 - 127.3 Hz PL
  • Code 20 - 131.8 Hz PL
  • Code 21 - 136.5 Hz PL
  • Code 22 - 141.3 Hz PL
  • Code 23 - 146.2 Hz PL
  • Code 24 - 151.4 Hz PL
  • Code 25 - 156.7 Hz PL
  • Code 26 - 162.2 Hz PL
  • Code 27 - 167.9 Hz PL
  • Code 28 - 173.8 Hz PL
  • Code 29 - 179.9 Hz PL
  • Code 30 - 186.2 Hz PL
  • Code 31 - 192.8 Hz PL
  • Code 32 - 203.5 Hz PL
  • Code 33 - 210.7 Hz PL
  • Code 34 - 218.1 Hz PL
  • Code 35 - 225.7 Hz PL
  • Code 36 - 233.6 Hz PL
  • Code 37 - 241.8 Hz PL
  • Code 38 - 250.3 Hz PL
  • Code 39 - 023 DCS
  • Code 40 - 025 DCS
  • Code 41 - 026 DCS
  • Code 42 - 031 DCS
  • Code 43 - 032 DCS
  • Code 44 - 043 DCS
  • Code 45 - 047 DCS
  • Code 46 - 051 DCS
  • Code 47 - 054 DCS
  • Code 48 - 065 DCS
  • Code 49 - 071 DCS
  • Code 50 - 072 DCS
  • Code 51 - 073 DCS
  • Code 52 - 074 DCS
  • Code 53 - 114 DCS
  • Code 54 - 115 DCS
  • Code 55 - 116 DCS
  • Code 56 - 125 DCS
  • Code 57 - 131 DCS
  • Code 58 - 132 DCS
  • Code 59 - 143 DCS
  • Code 60 - 143 DCS
  • Code 61 - 152 DCS
  • Code 62 - 155 DCS
  • Code 63 - 156 DCS
  • Code 64 - 162 DCS
  • Code 65 - 165 DCS
  • Code 66 - 172 DCS
  • Code 67 - 174 DCS
  • Code 68 - 205 DCS
  • Code 69 - 223 DCS
  • Code 70 - 226 DCS
  • Code 71 - 243 DCS
  • Code 72 - 244 DCS
  • Code 73 - 245 DCS
  • Code 74 - 251 DCS
  • Code 75 - 261 DCS
  • Code 76 - 263 DCS
  • Code 77 - 265 DCS
  • Code 78 - 271 DCS
  • Code 79 - 306 DCS
  • Code 80 - 311 DCS
  • Code 81 - 315 DCS
  • Code 82 - 331 DCS
  • Code 83 - 343 DCS
  • Code 84 - 346 DCS
  • Code 85 - 351 DCS
  • Code 86 - 364 DCS
  • Code 87 - 365 DCS
  • Code 88 - 371 DCS
  • Code 89 - 411 DCS
  • Code 90 - 412 DCS
  • Code 91 - 413 DCS
  • Code 92 - 423 DCS
  • Code 93 - 431 DCS
  • Code 94 - 432 DCS
  • Code 95 - 445 DCS
  • Code 96 - 464 DCS
  • Code 97 - 465 DCS
  • Code 98 - 466 DCS
  • Code 99 - 503 DCS
  • MaxTone 4 channel FM wireless intercom
FCC ID: 2AOXE-SK1204 - Heyuan SunKeungFung Technology LTD
340mw power output, 6K00F3E / 6K01F3E emission. User must set all intercoms to Group Code A, Group Code B or Group Code C
  • MaxTone 8 channel FM wireless intercom
FCC ID: 2AOXE-SK1208 - Heyuan SunKeungFung Technology LTD
  • MaxTone 6 channel FM wireless intercom
FCC ID: 2AOXE-SK12V6 - Heyuan SunKeungFung Technology LTD
365mw power output, 9K39F3E emission. User must set all intercoms to Group Code A, Group Code B or Group Code C
