Amateur radio
- Not to be confused with 27 MHz CB radio, often referred to by ham operators as 11 meters.
- Not to be confused with other land mobile, both HF maritime mobile and VHF marine band radio, aircraft band and numerous other types of radio services, license free, unlicensed and simple license requirement personal radio services / walkie-talkie radio services such as FRS, MURS, GMRS, PMR446, various SRD services (LPD433, SRD860 and others), RC model control, R/C, datalinks, control links for drones so-called ISM and Part 15 systems Wi-Fi in the VHF/UHF and higher frequency bands, and so on.
Amateur Radio Bands MF/HF
Note that parts of many popular MF and HF amateur radio bands are shared with other services, including the maritime mobile service, the fixed service, fixed/mobile services, broadcasting, land mobile services and other non-amateur radio services and users. 80m / 75 meters, 40 meters and the 28MHz band / 10 meters appear to be the worst impacted worldwide. In many areas, the 28 MHz band is unusable when the band is open due to QRM from CB radio type signals.
- 50-54 MHz - 6 meter band (50-51 MHz or 50-52 MHz in some countries) - see also: 50 MHz / 53 MHz RC channels
US band plan. ITU Region 2.
- 146.415 MHz
- 146.430 MHz
- 146.445 MHz
- 146.460 MHz
- 146.475 MHz
- 146.490 MHz
- 146.505 MHz
- 146.520 MHz - Calling frequency
- 146.535 MHz
- 146.550 MHz
- 146.565 MHz
- 146.580 MHz
- 146.595 MHz
- 147.405 MHz
- 147.420 MHz
- 147.435 MHz
- 147.450 MHz
- 147.465 MHz
- 147.480 MHz
- 147.495 MHz
- 147.510 MHz
- 147.525 MHz
- 147.540 MHz
- 147.555 MHz
- 147.570 MHz
- 147.585 MHz
*1.25m band - 220 band or 222MHz Band
- 223.400 MHz
- 223.420 MHz
- 223.440 MHz
- 223.460 MHz
- 223.480 MHz
- 223.500 MHz - Calling frequency
- 223.520 MHz
- 223.540 MHz
- 223.560 MHz
- 223.580 MHz
- 223.600 MHz
- 223.620 MHz
*70cm band
- 445.9125 MHz
- 445.9250 MHz
- 445.9375 MHz
- 445.9500 MHz
- 445.9625 MHz
- 445.9750 MHz
- 445.9875 MHz
- 446.0000 MHz - Calling frequency
- 446.0125 MHz
- 446.0250 MHz
- 446.0375 MHz
- 446.0500 MHz
- 446.0625 MHz
- 446.0750 MHz
- 446.0875 MHz
- 446.1000 MHz
- 446.1125 MHz
- 446.1250 MHz
- 446.1375 MHz
- 446.1500 MHz
- 446.1625 MHz
- 446.1750 MHz
- 446.5000 MHz
- 446.5125 MHz
- 446.5375 MHz
- 446.5625 MHz
- 446.5875 MHz
- 446.6125 MHz
- 446.6375 MHz
- 446.6625 MHz
- 446.6875 MHz
- 446.7125 MHz
- 446.7375 MHz
- 446.7625 MHz
- 446.7875 MHz
- 440.9125 MHz
- 440.9250 MHz
- 440.9375 MHz
- 440.9500 MHz
- 440.9625 MHz
- 440.9750 MHz
- 440.9875 MHz
- 441.0000 MHz
- 441.0125 MHz
- 441.0250 MHz
- 441.0375 MHz
- 441.0500 MHz
- 441.0625 MHz
- 441.0750 MHz
- 441.0875 MHz
- 441.1000 MHz
- 441.1125 MHz
- 441.1250 MHz
- 441.1375 MHz
- 441.1500 MHz
- 441.1625 MHz
- 441.1750 MHz
- 441.5000 MHz
- 441.5125 MHz
- 441.5375 MHz
- 441.5625 MHz
- 441.5875 MHz
- 441.6125 MHz
- 441.6375 MHz
- 441.6625 MHz
- 441.6875 MHz
- 441.7125 MHz
- 441.7375 MHz
- 441.7625 MHz
- 441.7875 MHz
*33cm band - 900MHz band
See notes above regarding the numerous other licensed and unlicensed users of the 902-928 MHz band.
- 902.500 MHz
- 906.500 MHz
- 927.500 MHz
- 927.750 MHz
