| CB Channel | Frequency | Old Designated Use (Mostly Defunct) |
| Channel 1 | 26.965 MHz | Stations operating under the same license - “intrastation” |
| Channel 2 | 26.975 MHz | Stations operating under the same license - “intrastation” |
| Channel 3 | 26.985 MHz | Stations operating under the same license - “intrastation” |
| Channel 4 | 27.005 MHz | Stations operating under the same license - “intrastation” |
| Channel 5 | 27.015 MHz | Stations operating under the same license - “intrastation” |
| Channel 6 | 27.025 MHz | Stations operating under the same license - “intrastation” |
| Channel 7 | 27.035 MHz | Stations operating under the same license - “intrastation” |
| Channel 8 | 27.055 MHz | Stations operating under the same license - “intrastation” |
| Channel 9 | 27.065 MHz | Emergency channel |
| Channel 11 | 27.085 MHz | Calling channel |
| Channel 12 | 27.105 MHz | |
| Channel 13 | 27.115 MHz | |
| Channel 14 | 27.125 MHz | |
| Channel 15 | 27.135 MHz | Stations operating under the same license - “intrastation” |
| Channel 16 | 27.155 MHz | Stations operating under the same license - “intrastation” |
| Channel 17 | 27.165 MHz | Stations operating under the same license - “intrastation” |
| Channel 18 | 27.175 MHz | Stations operating under the same license - “intrastation” |
| Channel 19 | 27.185 MHz | Trucker channel or road channel |
| Channel 20 | 27.205 MHz | Stations operating under the same license - “intrastation” |
| Channel 21 | 27.215 MHz | Stations operating under the same license - “intrastation” |
| Channel 22 | 27.225 MHz | Stations operating under the same license - “intrastation” |
| Channel 23 | 27.255 MHz | Stations operating under different licenses - “interstation” - shared with pagers/high power data |
- 26.755 MHz AM - Often active in southern USA + every 10 kHz to 26.955 MHz|
- 26.805 MHz FM - 26 MHz FM calling frequency - 11 meter freeband FM calling channel 26.805 FM
| Channel 2 | 26.975 MHz | |
| Channel 5 | 27.015 MHz | |
| Channel 7 | 27.035 MHz | |
| Channel 15 | 27.135 MHz | |
| Channel 16 | 27.155 MHz | 4x4 and off-roader common channel (4x4 = 16), old SSB calling channel, still used for SSB in some areas |
| Channel 18 | 27.175 MHz | |
| Channel 22 | 27.225 MHz | |
| Channel 27 | 27.275 MHz | USA FM CB Calling Channel - USA FM CB Working Channel FM CB DX Channel |
| Channel 29 | 27.295 MHz | Trucker FM CB Channel in USA - the "Trucker's FM Channel" or Channel 29 FM 27.295 FM |
| Channel 30 | 27.305 MHz | |
| Channel 31 | 27.315 MHz | Calling channel (FM mode) in Europe, USA FM CB calling channel (see also: 27.275 MHz and 27.295 MHz / FM CB Channel 27 and 29) |
| Channel 32 | 27.325 MHz | |
| Channel 33 | 27.335 MHz | |
| Channel 34 | 27.345 MHz | |
| Channel 1 | 27.60125 MHz | |
| Channel 2 | 27.61125 MHz | |
| Channel 3 | 27.62125 MHz | |
| Channel 4 | 27.63125 MHz | |
| Channel 5 | 27.64125 MHz | |
| Channel 6 | 27.65125 MHz | |
| Channel 7 | 27.66125 MHz | |
| Channel 8 | 27.67125 MHz | |
| Channel 9 | 27.68125 MHz | |
| Channel 10 | 27.69125 MHz | |
| Channel 11 | 27.70125 MHz | |
| Channel 12 | 27.71125 MHz | |
| Channel 13 | 27.72125 MHz | |
| Channel 14 | 27.73125 MHz | Base station to base station channel "home base" channel |
| Channel 15 | 27.74125 MHz | |
| Channel 16 | 27.75125 MHz | |
| Channel 17 | 27.76125 MHz | |
| Channel 18 | 27.77125 MHz | |
| Channel 19 | 27.78125 MHz | Calling and Road Channel |
| Channel 20 | 27.79125 MHz | |
| Channel 21 | 27.80125 MHz | |
| Channel 22 | 27.81125 MHz | |
| Channel 23 | 27.82125 MHz | |
| Channel 24 | 27.83125 MHz | |
| Channel 25 | 27.84125 MHz | |
| Channel 26 | 27.85125 MHz | |
| Channel 27 | 27.86125 MHz | |
| Channel 28 | 27.87125 MHz | |
| Channel 29 | 27.88125 MHz | |
| Channel 30 | 27.89125 MHz | |
| Channel 31 | 27.90125 MHz | |
| Channel 32 | 27.91125 MHz | |
| Channel 33 | 27.92125 MHz | |
| Channel 34 | 27.93125 MHz | |
| Channel 35 | 27.94125 MHz | |
| Channel 36 | 27.95125 MHz | |
| Channel 37 | 27.96125 MHz | |
| Channel 38 | 27.97125 MHz | |
| Channel 39 | 27.98125 MHz | |
| Channel 40 | 27.99125 MHz |
80 Channel CB radio. DE mode on multi-norm CB radios.
FM modulation only in Germany, Czech Republic and Hungary on channels 41-80. AM, FM and SSB are allowed channels 1-40, while radios are supposed to switch to FM mode only (4 watt power limit) for the 26.565-26.955 MHz portion.
Digital modes allowed on specified channels (26.675 MHz, 26.685 MHz, 26.915 MHz and 26.925 MHz) in Germany - channels 52, 53, 76 and 77. Designated channels 41-80 (channels 1-40 are the US/CEPT standardized channels). Full 80 channel allocation 26.565 MHz to 27.405 MHz or 26.560 MHz to 27.410 MHz. Shared with paging services, fixed links, remote control (RC), on-campus voice and/or data pagers and the fixed service, especially in border areas.
Czech Republic regulations specify that data transmission between CB stations is permitted on channels 24, 25, 52, 53, 76 and 77. F1D, F2D, G1D, G2D, J1D, J2D, A1D and A2D emissions (modes) are permitted. Remote control transmitters are allowed on channels 18 and 23. Czech regulations also specify channel 1 and channel 80 as calling channels using selective calling systems, including tone-based such as DTMF as well as CTCSS and DCS (PL and DPL) with users switching to another channel as soon as possible.
| Channel 1 | 26.965 MHz | Calling channel - FM mode |
| Channel 3 | 26.985 MHz | |
| Channel 4 | 27.005 MHz | Recommended AM calling channel - AM mode |
| Channel 6 | 27.025 MHz | Digital modes permitted - data channel |
| Channel 7 | 27.035 MHz | Digital modes permitted - data channel |
| Channel 8 | 27.055 MHz | |
| Channel 9 | 27.065 MHz | |
| Channel 10 | 27.075 MHz | |
| Channel 11 | 27.085 MHz | Internet gateways |
| Channel 15 | 27.135 MHz | SSB calling channel - USB mode |
| Channel 16 | 27.155 MHz | SSB activity - LSB and USB |
| Channel 17 | 27.165 MHz | |
| Channel 19 | 27.185 MHz | Trucker channel / road channel - FM mode |
| Channel 20 | 27.205 MHz | Simplex repeaters - FM mode |
| Channel 21 | 27.215 MHz | |
| Channel 23 | 27.255 MHz | Digital modes permitted - data channel |
| Channel 24 | 27.235 MHz | Digital modes permitted - data channel |
| Channel 25 | 27.245 MHz | Digital modes permitted - data channel |
| Channel 26 | 27.265 MHz | |
| Channel 27 | 27.275 MHz | |
| Channel 28 | 27.285 MHz | |
| Channel 29 | 27.295 MHz | Internet gateways |
| Channel 30 | 27.305 MHz | Recommended FM calling/DX channel - FM mode |
| Channel 31 | 27.315 MHz | FM DX calling (see also: 27.305 MHz) |
| Channel 35 | 27.355 MHz | |
| Channel 36 | 27.365 MHz | |
| Channel 37 | 27.375 MHz | |
| Channel 39 | 27.395 MHz | Internet gateways |
| Channel 40 | 27.405 MHz | Digital modes permitted - data channel |
| Channel 41 | 26.565 MHz | DX calling channel - FM mode |
| Channel 42 | 26.575 MHz | DX calling channel - FM mode |
| Channel 43 | 26.585 MHz | |
| Channel 44 | 26.595 MHz | |
| Channel 45 | 26.605 MHz | |
| Channel 46 | 26.615 MHz | |
| Channel 47 | 26.625 MHz | |
| Channel 48 | 26.635 MHz | |
| Channel 49 | 26.645 MHz | |
| Channel 50 | 26.655 MHz | |
| Channel 51 | 26.665 MHz | |
| Channel 52 | 26.675 MHz | Digital modes permitted - data channel |
| Channel 53 | 26.685 MHz | Digital modes permitted - data channel |
| Channel 54 | 26.695 MHz | |
| Channel 55 | 26.705 MHz | |
| Channel 56 | 26.715 MHz | |
| Channel 57 | 26.725 MHz | |
| Channel 58 | 26.735 MHz | |
| Channel 59 | 26.745 MHz | |
| Channel 60 | 26.755 MHz | |
| Channel 61 | 26.765 MHz | Internet gateways |
| Channel 62 | 26.775 MHz | |
| Channel 63 | 26.785 MHz | |
| Channel 64 | 26.795 MHz | |
| Channel 65 | 26.805 MHz | |
| Channel 66 | 26.815 MHz | |
| Channel 67 | 26.825 MHz | |
| Channel 68 | 26.835 MHz | |
| Channel 69 | 26.845 MHz | |
| Channel 70 | 26.855 MHz | |
| Channel 71 | 26.865 MHz | Internet gateways |
| Channel 72 | 26.875 MHz | |
| Channel 73 | 26.885 MHz | |
| Channel 74 | 26.895 MHz | |
| Channel 75 | 26.905 MHz | |
| Channel 76 | 26.915 MHz | Digital modes permitted - data channel |
| Channel 77 | 26.925 MHz | Digital modes permitted - data channel |
| Channel 78 | 26.935 MHz | |
| Channel 79 | 26.945 MHz | |
| Channel 80 | 26.955 MHz | Internet gateways |
Italian I2 Band Italy CB I2 34 Channel CB 26.875 MHz - 27.265 MHz
Not to be confused with the Italian 43 MHz VHF low band "VHF CB" band.
Italy permits use of the standard European harmonized CEPT band "mid band FM" as well as the same band plan - identical to the American CB radio allocation - with AM, FM and SSB allowed on the regular 40 channels.
Note that channels 1-23 match the standard CB band plan. Channel 24 (27.245 MHz) is channel 25 on the standard band and channel 25 (27.265 MHz) is channel 26 on the standard band. Channels 26 to 34 are the out of band frequencies, 26.875 MHz to 26.955 MHz. While AM and FM modes are permitted on these frequencies, SSB use is also reported and quite common. Channels 26-34 overlap with German 80 Channel CB channels 72 to 80 and the "low channels".
| Channel 24 | 27.245 MHz |
| Channel 25 | 27.265 MHz |
| Channel 26 | 26.875 MHz |
| Channel 27 | 26.885 MHz |
| Channel 28 | 26.895 MHz |
| Channel 29 | 26.905 MHz |
| Channel 30 | 26.915 MHz |
| Channel 31 | 26.925 MHz |
| Channel 32 | 26.935 MHz |
| Channel 33 | 26.945 MHz |
| Channel 34 | 26.955 MHz |
| 27 MHz Marine Channel | Frequency |
26 MHz AM Public Channels:
| Channel 1 | 26.330 MHz | AM and SSB |
| Channel 2 | 26.340 MHz | AM and SSB |
| Channel 3 | 26.350 MHz | AM and SSB |
| Channel 4 | 26.370 MHz | AM and SSB |
| Channel 5 | 26.380 MHz | AM and SSB |
| Channel 6 | 26.390 MHz | AM and SSB |
| Channel 7 | 26.400 MHz | AM and SSB |
| Channel 8 | 26.420 MHz | AM and SSB |
| Channel 9 | 26.430 MHz | AM and SSB |
| Channel 10 | 26.440 MHz | AM and SSB |
| Channel 11 | 26.450 MHz | Trucker channel/road channel (AM mode) |
| Channel 12 | 26.470 MHz | AM and SSB |
| Channel 13 | 26.480 MHz | AM and SSB |
| Channel 14 | 26.490 MHz | AM and SSB |
| Channel 15 | 26.500 MHz | AM calling channel |
| Channel 16 | 26.520 MHz | AM and SSB |
| Channel 17 | 26.530 MHz | AM and SSB |
| Channel 18 | 26.540 MHz | AM mode only |
| Channel 19 | 26.550 MHz | AM mode only |
| Channel 20 | 26.570 MHz | AM mode only |
| Channel 21 | 26.580 MHz | AM mode only |
| Channel 22 | 26.590 MHz | AM mode only |
| Channel 23 | 26.620 MHz | AM mode only |
| Channel 24 | 26.600 MHz | AM mode only |
| Channel 25 | 26.610 MHz | AM and SSB |
| Channel 26 | 26.630 MHz | AM and SSB |
| Channel 27 | 26.640 MHz | AM and SSB |
| Channel 28 | 26.650 MHz | AM and SSB |
| Channel 29 | 26.660 MHz | AM and SSB |
| Channel 30 | 26.670 MHz | AM and SSB |
| Channel 31 | 26.680 MHz | AM and SSB |
| Channel 32 | 26.690 MHz | AM and SSB |
| Channel 33 | 26.700 MHz | AM and SSB |
| Channel 34 | 26.710 MHz | AM and SSB |
| Channel 35 | 26.720 MHz | SSB calling channel - LSB mode |
| Channel 36 | 26.730 MHz | AM and SSB |
| Channel 37 | 26.740 MHz | AM and SSB |
| Channel 38 | 26.750 MHz | AM and SSB |
| Channel 39 | 26.760 MHz | AM and SSB |
| Channel 40 | 26.770 MHz | AM and SSB |
| Channel 1 | 26.960 MHz |
| Channel 2 | 26.970 MHz |
| Channel 3 | 26.980 MHz |
| Channel 4 | 27.000 MHz |
| Channel 5 | 27.010 MHz |
| Channel 6 | 27.020 MHz |
| Channel 7 | 27.030 MHz |
| Channel 8 | 27.050 MHz |
| Channel 9 | 27.060 MHz |
| Channel 10 | 27.070 MHz |
| Channel 11 | 27.080 MHz |
| Channel 12 | 27.100 MHz |
| Channel 13 | 27.110 MHz |
| Channel 14 | 27.120 MHz |
| Channel 15 | 27.130 MHz |
| Channel 16 | 27.150 MHz |
| Channel 17 | 27.160 MHz |
| Channel 18 | 27.170 MHz |
| Channel 19 | 27.180 MHz |
| Channel 20 | 27.200 MHz |
| Channel 21 | 27.210 MHz |
| Channel 22 | 27.220 MHz |
| Channel 23 | 27.250 MHz |
| Channel 24 | 27.230 MHz |
| Channel 25 | 27.240 MHz |
| Channel 26 | 27.260 MHz |
| Channel 27 | 27.270 MHz |
| Channel 28 | 27.280 MHz |
| Channel 29 | 27.290 MHz |
| Channel 30 | 27.300 MHz |
| Channel 31 | 27.310 MHz |
| Channel 32 | 27.320 MHz |
| Channel 33 | 27.330 MHz |
| Channel 34 | 27.340 MHz |
| Channel 36 | 27.360 MHz |
| Channel 37 | 27.370 MHz |
| Channel 38 | 27.380 MHz |
| Channel 39 | 27.390 MHz |
| Channel 40 | 27.400 MHz |
For example,
- 27.060 MHz FM - Secondary rescue / emergency channel (unrestricted use) 27.060 FM - C9RF (D9RF)
- 27.065 MHz FM - Official rescue service calling channel 27.065 FM - C9EF (D9EF)
- 27.135 MHz AM - Road channel / car calling channel (slowly being replaced by 27.135 MHz FM) - C15EA (D15EA)
- 27.135 MHz FM - Road channel and trucker channel - C15EF (D15EF)
- 27.185 MHz AM - Information channel and trucker road channel AM mode C19EA (D19EA)
- 27.185 MHz FM - Information channel and trucker road channel FM mode C19EF (D19EF)
- 27.190 MHz FM - Long range calling DX channel (also used in SSB mode)
- 27.200 MHz FM - Long range calling DX channel - C20RF (D20RF)
- 27.270 MHz AM - Radio hobbyist channel AM mode - C27RA (D27RA)
- 27.315 MHz FM - FM calling channel European grid - C31EF (D31EF)
- 27.635 MHz FM - Information and traffic channel (some areas only) D19EF (E19EF) - previously used for traffic information broadcasts in St. Petersburg only (service discontinued in 2014)
| Channel D40 +10 kHz | 27.860 MHz | 27.865 MHz |
- CE - Europe Harmonized FM - 26.965 MHz - 27.405 MHz - 40 channels - FM - 4W - European standard band, CE or "CEPT"
- EU - Europe Harmonized AM/FM or AM/FM/SSB - 26.965 MHz - 27.405 MHz - 40 channels - AM/FM/SSB 4W AM carrier + 4W FM + -12W SSB PEP European standard AM/FM/SSB band
- F - France - 26.965 MHz - 27.405 MHz - 40 channels - AM/FM - 1W AM carrier + 4W FM
- UK - UK "27/81" CB Band - 27.60125 MHz - 27.99125 MHz - 40 channels - FM - 4W - UK FM CB 27/81 allocation - UK has 80 available channels - UK + EU
- UE - UK Full 80 Channels - EU 40 channels + UK FM 40 channels (80 channels), some radios require the user to switch between the two bands
- dE - Germany - 26.565 MHz - 27.405 MHz - 80 channels, channels 1-40 are AM/FM 4W/4W, same as CE band, channels 41-80 are FM only (4W) 26.565-26.955
- I - Italy - 26.965 MHz - 27.405 MHz - 40 channels - AM/FM - 4W AM carrier + 4W FM - same European standard AM/FM band
- I2 - Italy 2 - 26.875 MHz - 27.405 MHz - 34 channels - AM/FM 4W/4W or 40 regular EU channels
- PL - Poland - 26.960 MHz - 27.400 MHz - 40 channels - AM/FM 4W/4W (regular 40 channels -5 kHz)
- IN - India - 26.965 MHz - 27.275 MHz - 27 channels - AM/FM 4W/4W
Calling frequencies include:
- 26.985 MHz AM (CB Channel 3 AM)
- 27.368 MHz USB Old Prepper Survivalist frequency, 27.375 USB or 27.425 USB recommended
- 27.375 MHz USB (CB Channel 37 USB)
- 27.378 MHz USB Old Prepper Survivalist frequency, 27.375 USB or 27.425 USB recommended
- 27.390 MHz LSB - Alternate Prepper/Survivalist Frequency
- 27.390 MHz USB - Alternate Prepper/Survivalist Frequency
- 27.425 MHz USB (Channel 42, Channel "E2", Channel E02, "425")
- 26.962 MHz LSB - Drop Gap 1
- 26.965 MHz AM - Normal CB 1
- 26.968 MHz USB - High Gap 1
- 26.970 MHz USB/LSB - High Gap 1/2
- 26.972 MHz LSB - Drop Gap 2
- 26.975 MHz AM - Normal CB 2
| Channel 1 | 26.968 MHz |
| Channel 2 | 26.976 MHz |
| Channel 3 | 27.040 MHz |
| Channel 4 | 27.080 MHz |
| Channel 5 | 27.088 MHz |
| Channel 6 | 27.112 MHz |
| Channel 7 | 27.120 MHz |
| Channel 8 | 27.144 MHz |
| 27310.5 kHz | 27.3105 MHz |
| 27334.5 kHz | 27.3345 MHz |
| 27338.5 kHz | 27.3385 MHz |
| 27342.5 kHz | 27.3425 MHz |
| 27346.5 kHz | 27.3465 MHz |
| 27350.5 kHz | 27.3505 MHz |
| 27354.5 kHz | 27.3545 MHz |
| 27358.5 kHz | 27.3585 MHz |
| 27362.5 kHz | 27.3625 MHz |
| 27366.5 kHz | 27.3665 MHz |
| 27370.5 kHz | 27.3705 MHz |
| 27378.5 kHz | 27.3785 MHz |
| 27382.5 kHz | 27.3825 MHz |
| 27386.5 kHz | 27.3865 MHz |
| 27388.5 kHz | 27.3885 MHz |
| 27398.5 kHz | 27.3985 MHz |
| 27404.5 kHz | 27.4045 MHz |
| 27418.5 kHz | 27.4185 MHz |
| 27426.5 kHz | 27.4265 MHz |
| 27434.5 kHz | 27.4345 MHz |
| 27442.5 kHz | 27.4425 MHz |
| 27452.5 kHz | 27.4525 MHz |
| 27458.5 kHz | 27.4585 MHz |
| 27466.5 kHz | 27.4665 MHz |
| 27470.5 kHz | 27.4705 MHz |
- SPECIFICATIONS
- 25 kHz channel spacing
- 480 channels
- FEATURES
| Channel | Frequency (MHz) | Designated Use China Fishery Radio Network 27.5-39.475 MHz FM |
| 1 | 27.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 2 | 27.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 3 | 27.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 4 | 27.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 5 | 27.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 6 | 27.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 7 | 27.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 8 | 27.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 9 | 27.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 10 | 27.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 11 | 27.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 12 | 27.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 13 | 27.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 14 | 27.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 15 | 27.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 16 | 27.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 17 | 27.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 18 | 27.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 19 | 27.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 20 | 27.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 21 | 28.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 22 | 28.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 23 | 28.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 24 | 28.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 25 | 28.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 26 | 28.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 27 | 28.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 28 | 28.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 29 | 28.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 30 | 28.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 31 | 28.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 32 | 28.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 33 | 28.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 34 | 28.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 35 | 28.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 36 | 28.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 37 | 28.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 38 | 28.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 39 | 28.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 40 | 28.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 41 | 28.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 42 | 28.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 43 | 28.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 44 | 28.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 45 | 28.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 46 | 28.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 47 | 28.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 48 | 28.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 49 | 28.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 50 | 28.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 51 | 28.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 52 | 28.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 53 | 28.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 54 | 28.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 55 | 28.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 56 | 28.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 57 | 28.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 58 | 28.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 59 | 28.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 60 | 28.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 61 | 28.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 62 | 28.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 63 | 28.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 64 | 28.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 65 | 29.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 66 | 29.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 67 | 29.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 68 | 29.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 69 | 29.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 70 | 29.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 71 | 29.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 72 | 29.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 73 | 29.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 74 | 29.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 75 | 29.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 76 | 29.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 77 | 29.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 78 | 29.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 79 | 29.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 80 | 29.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 81 | 29.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 82 | 29.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 83 | 29.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 84 | 29.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 85 | 29.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 86 | 29.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 87 | 29.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 88 | 29.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 89 | 29.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 90 | 29.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 91 | 29.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 92 | 29.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 93 | 29.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 94 | 29.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 95 | 29.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 96 | 29.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 97 | 29.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 98 | 29.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 99 | 29.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 100 | 29.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 101 | 29.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 102 | 29.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 103 | 29.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 104 | 29.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 105 | 30.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 106 | 30.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 107 | 30.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 108 | 30.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 109 | 30.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 110 | 30.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 111 | 30.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 112 | 30.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 113 | 30.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 114 | 30.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 115 | 30.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 116 | 30.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 117 | 30.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 118 | 30.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 119 | 30.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 120 | 30.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 121 | 30.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 122 | 30.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 123 | 30.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 124 | 30.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 125 | 30.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 126 | 30.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 127 | 30.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 128 | 30.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 129 | 30.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 130 | 30.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 131 | 30.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 132 | 30.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 133 | 30.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 134 | 30.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 135 | 30.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 136 | 30.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 137 | 30.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 138 | 30.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 139 | 30.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 140 | 30.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 141 | 30.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 142 | 30.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 143 | 30.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 144 | 30.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 145 | 31.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 146 | 31.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 147 | 31.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 148 | 31.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 149 | 31.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 150 | 31.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 151 | 31.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 152 | 31.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 153 | 31.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 154 | 31.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 155 | 31.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 156 | 31.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 158 | 31.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 159 | 31.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 160 | 31.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 161 | 31.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 162 | 31.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 163 | 31.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 164 | 31.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 165 | 31.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 166 | 31.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 167 | 31.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 168 | 31.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 169 | 31.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 170 | 31.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 171 | 31.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 172 | 31.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 173 | 31.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 174 | 31.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 175 | 31.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 176 | 31.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 177 | 31.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 178 | 31.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 179 | 31.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 180 | 31.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 181 | 31.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 182 | 31.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 183 | 31.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 184 | 31.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 185 | 31.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 186 | 32.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 187 | 32.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 188 | 32.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 189 | 32.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 190 | 32.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 191 | 32.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 192 | 32.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 193 | 32.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 194 | 32.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 195 | 32.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 196 | 32.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 197 | 32.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 198 | 32.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 199 | 32.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 200 | 32.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 201 | 32.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 202 | 32.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 203 | 32.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 204 | 32.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 205 | 32.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 206 | 32.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 207 | 32.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 208 | 32.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 209 | 32.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 210 | 32.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 211 | 32.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 212 | 32.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 213 | 32.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 214 | 32.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 215 | 32.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 216 | 32.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 217 | 32.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 218 | 32.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 219 | 32.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 220 | 32.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 221 | 32.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 222 | 32.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 223 | 32.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 224 | 32.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 225 | 32.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 226 | 33.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 227 | 33.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 228 | 33.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 229 | 33.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 231 | 33.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 232 | 33.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 233 | 33.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 234 | 33.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 235 | 33.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 236 | 33.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 237 | 33.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 238 | 33.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 239 | 33.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 240 | 33.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 241 | 33.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 242 | 33.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 243 | 33.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 244 | 33.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 245 | 33.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 246 | 33.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 247 | 33.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 248 | 33.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 249 | 33.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 250 | 33.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 251 | 33.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 252 | 33.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 253 | 33.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 254 | 33.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 255 | 33.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 256 | 33.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 257 | 33.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 258 | 33.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 259 | 33.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 260 | 33.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 261 | 33.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 262 | 33.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 263 | 33.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 264 | 33.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 265 | 33.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 266 | 33.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 267 | 34.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 268 | 34.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 269 | 34.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 270 | 34.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 271 | 34.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 272 | 34.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 273 | 34.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 274 | 34.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 275 | 34.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 276 | 34.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 278 | 34.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 279 | 34.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 280 | 34.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 281 | 34.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 282 | 34.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 283 | 34.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 284 | 34.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 285 | 34.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 286 | 34.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 287 | 34.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 288 | 34.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 289 | 34.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 290 | 34.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 291 | 34.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 292 | 34.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 293 | 34.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 294 | 34.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 295 | 34.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 296 | 34.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 297 | 34.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 298 | 34.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 299 | 34.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 300 | 34.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 301 | 34.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 302 | 34.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 303 | 34.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 304 | 34.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 305 | 34.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 306 | 34.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 307 | 34.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 308 | 35.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 309 | 35.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 310 | 35.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 311 | 35.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 312 | 35.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 313 | 35.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 314 | 35.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 315 | 35.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 316 | 35.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 317 | 35.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 318 | 35.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 319 | 35.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 320 | 35.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 321 | 35.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 322 | 35.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 323 | 35.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 324 | 35.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 325 | 35.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 326 | 35.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 327 | 35.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 328 | 35.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 329 | 35.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 330 | 35.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 331 | 35.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 332 | 35.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 333 | 35.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 334 | 35.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 335 | 35.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 336 | 35.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 337 | 35.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 338 | 35.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 339 | 35.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 340 | 35.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 341 | 35.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 342 | 35.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 343 | 35.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 344 | 35.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 345 | 35.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 346 | 35.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 347 | 35.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 348 | 36.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 349 | 36.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 350 | 36.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 351 | 36.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 352 | 36.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 353 | 36.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 354 | 36.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 355 | 36.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 356 | 36.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 357 | 36.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 358 | 36.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 359 | 36.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 360 | 36.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 361 | 36.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 362 | 36.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 363 | 36.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 364 | 36.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 365 | 36.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 366 | 36.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 367 | 36.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 368 | 36.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 369 | 36.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 370 | 36.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 371 | 36.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 372 | 36.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 373 | 36.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 374 | 36.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 375 | 36.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 376 | 36.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 377 | 36.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 378 | 36.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 379 | 36.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 380 | 37.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 381 | 37.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 382 | 37.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 383 | 37.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 384 | 37.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 385 | 37.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 386 | 37.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 387 | 37.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 388 | 37.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 389 | 37.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 390 | 37.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 391 | 37.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 392 | 37.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 393 | 37.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 394 | 37.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 395 | 37.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 396 | 37.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 398 | 37.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 399 | 37.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 400 | 37.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 401 | 37.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 402 | 37.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 403 | 37.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 404 | 37.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 405 | 37.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 406 | 37.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 407 | 37.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 408 | 37.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 409 | 37.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 410 | 37.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 411 | 37.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 412 | 37.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 413 | 37.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 414 | 37.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 415 | 37.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 416 | 37.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 417 | 37.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 418 | 37.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 419 | 37.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 420 | 37.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 421 | 38.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 422 | 38.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 423 | 38.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 424 | 38.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 425 | 38.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 426 | 38.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 427 | 38.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 428 | 38.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 429 | 38.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 430 | 38.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 431 | 38.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 432 | 38.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 433 | 38.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 434 | 38.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 435 | 38.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 436 | 38.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 437 | 38.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 438 | 38.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 439 | 38.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 440 | 38.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 441 | 38.500 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 442 | 38.525 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 443 | 38.550 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 444 | 38.575 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 445 | 38.600 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 446 | 38.625 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 447 | 38.650 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 448 | 38.675 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 449 | 38.700 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 450 | 38.725 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 451 | 38.750 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 452 | 38.775 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 453 | 38.800 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 454 | 38.825 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 455 | 38.850 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 456 | 38.875 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 457 | 38.900 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 458 | 38.925 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 459 | 38.950 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 460 | 38.975 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 461 | 39.000 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 462 | 39.025 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 463 | 39.050 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 464 | 39.075 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 465 | 39.100 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 466 | 39.125 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 467 | 39.150 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 468 | 39.175 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 469 | 39.200 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 470 | 39.225 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 471 | 39.250 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 472 | 39.275 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 473 | 39.300 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 474 | 39.325 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 475 | 39.350 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 476 | 39.375 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 477 | 39.400 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 478 | 39.425 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 479 | 39.450 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 480 | 39.475 MHz FM | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
- SPECIFICATIONS
- 20 channels
- AM modulation
- FEATURES
| CB Channel | Frequency |
| Channel 19 | 27.185 MHz |
| Channel 20 | 27.205 MHz |
| Channel 21 | 27.215 MHz |
| Channel 22 | 27.225 MHz |
| Channel 23 | 27.255 MHz |
| Channel 24 | 27.235 MHz |
| Channel 25 | 27.245 MHz |
| Channel 26 | 27.265 MHz |
| Channel 27 | 27.275 MHz |
AM and FM modes allowed. Shared with the fixed service. 5 watt power limit (expressed as ERP) Unclear if SSB is permitted. Full allocation band 26.957-27.283 MHz.
Channel frequencies 26.965 MHz - 27.275 MHz. Several VHF and UHF services are allowed in India for two-way radio, making 26 MHz/27 MHz CB radio a bit of a niche, with most two way walkie talkies in India such as the 350 MHz band SRR Short Range Radio. However, so-called multi-norm AM/FM CB radios are beginning to be shipped with the Indian band programmed in as one of the country modes the user may select.
IND08 - Use of wireless equipments intended to be used while in motion or during halts, in the frequency band 26.957 MHz - 27.283 MHz (same as the 27 MHz ISM band), with a maximum Effective Radiated Power (ERP) of 5 Watts has been exempted from licensing requirements.
| Channel 1 | 26.965 MHz |
| Channel 2 | 26.975 MHz |
| Channel 3 | 26.985 MHz |
| Channel 4 | 27.005 MHz |
| Channel 5 | 27.015 MHz |
| Channel 6 | 27.025 MHz |
| Channel 7 | 27.035 MHz |
| Channel 8 | 27.055 MHz |
| Channel 9 | 27.065 MHz |
| Channel 10 | 27.075 MHz |
| Channel 11 | 27.085 MHz |
| Channel 12 | 27.105 MHz |
| Channel 13 | 27.115 MHz |
| Channel 14 | 27.125 MHz |
| Channel 15 | 27.135 MHz |
| Channel 16 | 27.155 MHz |
| Channel 17 | 27.165 MHz |
| Channel 18 | 27.175 MHz |
| Channel 41 | 27.415 MHz |
| Channel 42 | 27.425 MHz |
| Channel 43 | 27.435 MHz |
| Channel 44 | 27.455 MHz |
| Channel 45 | 27.465 MHz |
| Channel 46 | 27.475 MHz |
| Channel 47 | 27.485 MHz |
| Channel 48 | 27.505 MHz |
| Channel 49 | 27.515 MHz |
| Channel 50 | 27.525 MHz |
| Channel 51 | 27.535 MHz |
| Channel 52 | 27.555 MHz |
| Channel 53 | 27.565 MHz |
| Channel 54 | 27.575 MHz |
| Channel 55 | 27.585 MHz |
| Channel 56 | 27.605 MHz |
| Channel 57 | 27.615 MHz |
| Channel 58 | 27.625 MHz |
| Channel 59 | 27.635 MHz |
| Channel 60 | 27.655 MHz |
| Channel 61 | 27.665 MHz |
| Channel 62 | 27.675 MHz |
| Channel 63 | 27.685 MHz |
| Channel 64 | 27.695 MHz |
| Channel 65 | 27.705 MHz |
| Channel 66 | 27.715 MHz |
| Channel 67 | 27.725 MHz |
| Channel 68 | 27.735 MHz |
| Channel 69 | 27.745 MHz |
| Channel 70 | 27.755 MHz |
| Channel 71 | 27.765 MHz |
| Channel 72 | 27.775 MHz |
| Channel 73 | 27.785 MHz |
| Channel 74 | 27.795 MHz |
| Channel 75 | 27.805 MHz |
| Channel 76 | 27.815 MHz |
| Channel 77 | 27.825 MHz |
| Channel 78 | 27.835 MHz |
| Channel 79 | 27.845 MHz |
| Channel 80 | 27.855 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 1 | 26.330 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 2 | 26.340 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 3 | 26.350 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 4 | 26.370 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 5 | 26.380 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 6 | 26.390 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 7 | 26.400 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 8 | 26.420 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 9 | 26.430 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 10 | 26.440 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 11 | 26.450 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 12 | 26.470 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 13 | 26.480 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 14 | 26.490 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 15 | 26.500 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 16 | 26.520 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 17 | 26.530 MHz |
| New Zealand 26 MHz CB AM Channel 18 | 26.540 MHz |
| New Zealand 26 MHz CB AM Channel 19 | 26.550 MHz |
| German Auxiliary CB Channel 41 | 26.565 MHz |
| New Zealand 26 MHz CB AM Channel 20 | 26.570 MHz |
| German Auxiliary CB Channel 42 | 26.575 MHz |
| New Zealand 26 MHz CB AM Channel 21 | 26.580 MHz |
| German Auxiliary CB Channel 43 | 26.585 MHz |
| New Zealand 26 MHz CB AM Channel 22 | 26.590 MHz |
| German Auxiliary CB Channel 44 | 26.595 MHz |
| New Zealand 26 MHz CB AM Channel 24 | 26.600 MHz |
| German Auxiliary CB Channel 45 | 26.605 MHz |
| New Zealand 26 MHz CB AM Channel 25 | 26.610 MHz |
| German Auxiliary CB Channel 46 | 26.615 MHz |
| New Zealand 26 MHz CB AM Channel 23 | 26.620 MHz |
| German Auxiliary CB Channel 47 | 26.625 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 26 | 26.630 MHz |
| German Auxiliary CB Channel 48 | 26.635 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 27 | 26.640 MHz |
| German Auxiliary CB Channel 49 | 26.645 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 28 | 26.650 MHz |
| German Auxiliary CB Channel 50 | 26.655 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 29 | 26.660 MHz |
| German Auxiliary CB Channel 51 | 26.665 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 30 | 26.670 MHz |
| German Auxiliary CB Channel 52 | 26.675 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 31 | 26.680 MHz |
| German Auxiliary CB Channel 53 | 26.685 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 32 | 26.690 MHz |
| German Auxiliary CB Channel 54 | 26.695 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 33 | 26.700 MHz |
| German Auxiliary CB Channel 55 | 26.705 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 34 | 26.710 MHz |
| German Auxiliary CB Channel 56 | 26.715 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 35 | 26.720 MHz |
| German Auxiliary CB Channel 57 | 26.725 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 36 | 26.730 MHz |
| German Auxiliary CB Channel 58 | 26.735 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 37 | 26.740 MHz |
| German Auxiliary CB Channel 59 | 26.745 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 38 | 26.750 MHz |
| German Auxiliary CB Channel 60 | 26.755 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.760 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 39 | 26.760 MHz |
| German Auxiliary CB Channel 61 | 26.765 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.768 MHz |
| New Zealand 26 MHz CB AM/SSB Channel 40 | 26.770 MHz |
| German Auxiliary CB Channel 62 | 26.775 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.776 MHz |
| German Auxiliary CB Channel 63 | 26.785 MHz |
| German Auxiliary CB Channel 64 | 26.795 MHz |
| German Auxiliary CB Channel 65 | 26.805 MHz |
| German Auxiliary CB Channel 66 | 26.815 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.824 MHz |
| German Auxiliary CB Channel 67 | 26.825 MHz |
| German Auxiliary CB Channel 68 | 26.835 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.840 MHz |
| German Auxiliary CB Channel 69 | 26.845 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.848 MHz |
| German Auxiliary CB Channel 70 | 26.855 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.856 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.864 MHz |
| German Auxiliary CB Channel 71 | 26.865 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.872 MHz |
| German Auxiliary CB Channel 72 | 26.875 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.880 MHz |
| German Auxiliary CB Channel 73 | 26.885 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.888 MHz |
| German Auxiliary CB Channel 74 | 26.895 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.896 MHz |
| German Auxiliary CB Channel 75 | 26.905 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.912 MHz |
| German Auxiliary CB Channel 76 | 26.915 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.920 MHz |
| German Auxiliary CB Channel 77 | 26.925 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.928 MHz |
| German Auxiliary CB Channel 78 | 26.935 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.938 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 26.944 MHz |
| German Auxiliary CB Channel 79 | 26.945 MHz |
| German Auxiliary CB Channel 80 | 26.955 MHz |
| Polish (PL) "Zeros" CB Band Channel 1 | 26.960 MHz |
| USA FCC/CEPT Standard CB Band Channel 1 | 26.965 MHz |
| Japan CB Radio Japanese CB Channel 1 | 26.968 MHz |
| Polish (PL) "Zeros" CB Band Channel 2 | 26.970 MHz |
| USA FCC/CEPT Standard CB Band Channel 2 | 26.975 MHz |
| Japan CB Radio Japanese CB Channel 2 | 26.976 MHz |
| Polish (PL) "Zeros" CB Band Channel 3 | 26.980 MHz |
| USA FCC/CEPT Standard CB Band Channel 3 | 26.985 MHz |
| Polish (PL) "Zeros" CB Band Channel 4 | 27.000 MHz |
| USA FCC/CEPT Standard CB Band Channel 4 | 27.005 MHz |
| Polish (PL) "Zeros" CB Band Channel 5 | 27.010 MHz |
| USA FCC/CEPT Standard CB Band Channel 5 | 27.015 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.016 MHz |
| Polish (PL) "Zeros" CB Band Channel 6 | 27.020 MHz |
| USA FCC/CEPT Standard CB Band Channel 6 | 27.025 MHz |
| Polish (PL) "Zeros" CB Band Channel 7 | 27.030 MHz |
| USA FCC/CEPT Standard CB Band Channel 7 | 27.035 MHz |
| Japan CB Radio Japanese CB Channel 3 | 27.040 MHz |
| Polish (PL) "Zeros" CB Band Channel 8 | 27.050 MHz |
| USA FCC/CEPT Standard CB Band Channel 8 | 27.055 MHz |
| Polish (PL) "Zeros" CB Band Channel 9 | 27.060 MHz |
| USA FCC/CEPT Standard CB Band Channel 9 | 27.065 MHz |
| Polish (PL) "Zeros" CB Band Channel 10 | 27.070 MHz |
| USA FCC/CEPT Standard CB Band Channel 10 | 27.075 MHz |
| Japan CB Radio Japanese CB Channel 4 | 27.080 MHz |
| Polish (PL) "Zeros" CB Band Channel 11 | 27.080 MHz |
| USA FCC/CEPT Standard CB Band Channel 11 | 27.085 MHz |
| Japan CB Radio Japanese CB Channel 5 | 27.088 MHz |
| Finland and Nordic Countries Channel 11A | 27.095 MHz |
| Polish (PL) "Zeros" CB Band Channel 12 | 27.100 MHz |
| USA FCC/CEPT Standard CB Band Channel 12 | 27.105 MHz |
| Polish (PL) "Zeros" CB Band Channel 13 | 27.110 MHz |
| Japan CB Radio Japanese CB Channel 6 | 27.112 MHz |
| USA FCC/CEPT Standard CB Band Channel 13 | 27.115 MHz |
| Japan CB Radio Japanese CB Channel 7 | 27.120 MHz |
| Polish (PL) "Zeros" CB Band Channel 14 | 27.120 MHz |
| USA FCC/CEPT Standard CB Band Channel 14 | 27.125 MHz |
| Polish (PL) "Zeros" CB Band Channel 15 | 27.130 MHz |
| USA FCC/CEPT Standard CB Band Channel 15 | 27.135 MHz |
| Japan CB Radio Japanese CB Channel 8 | 27.144 MHz |
| Polish (PL) "Zeros" CB Band Channel 16 | 27.150 MHz |
| USA FCC/CEPT Standard CB Band Channel 16 | 27.155 MHz |
| Polish (PL) "Zeros" CB Band Channel 17 | 27.160 MHz |
| USA FCC/CEPT Standard CB Band Channel 17 | 27.165 MHz |
| Polish (PL) "Zeros" CB Band Channel 18 | 27.170 MHz |
| USA FCC/CEPT Standard CB Band Channel 18 | 27.175 MHz |
| Polish (PL) "Zeros" CB Band Channel 19 | 27.180 MHz |
| USA FCC/CEPT Standard CB Band Channel 19 | 27.185 MHz |
| Polish (PL) "Zeros" CB Band Channel 20 | 27.200 MHz |
| USA FCC/CEPT Standard CB Band Channel 20 | 27.205 MHz |
| Polish (PL) "Zeros" CB Band Channel 21 | 27.210 MHz |
| USA FCC/CEPT Standard CB Band Channel 21 | 27.215 MHz |
| Polish (PL) "Zeros" CB Band Channel 22 | 27.220 MHz |
| USA FCC/CEPT Standard CB Band Channel 22 | 27.225 MHz |
| Polish (PL) "Zeros" CB Band Channel 24 | 27.230 MHz |
| USA FCC/CEPT Standard CB Band Channel 24 | 27.235 MHz |
| Polish (PL) "Zeros" CB Band Channel 25 | 27.240 MHz |
| USA FCC/CEPT Standard CB Band Channel 25 | 27.245 MHz |
| Polish (PL) "Zeros" CB Band Channel 23 | 27.250 MHz |
| USA FCC/CEPT Standard CB Band Channel 23 | 27.255 MHz |
| Polish (PL) "Zeros" CB Band Channel 26 | 27.260 MHz |
| USA FCC/CEPT Standard CB Band Channel 26 | 27.265 MHz |
| Polish (PL) "Zeros" CB Band Channel 27 | 27.270 MHz |
| USA FCC/CEPT Standard CB Band Channel 27 | 27.275 MHz |
| Polish (PL) "Zeros" CB Band Channel 28 | 27.280 MHz |
| USA FCC/CEPT Standard CB Band Channel 28 | 27.285 MHz |
| Polish (PL) "Zeros" CB Band Channel 29 | 27.290 MHz |
| USA FCC/CEPT Standard CB Band Channel 29 | 27.295 MHz |
| Polish (PL) "Zeros" CB Band Channel 30 | 27.300 MHz |
| USA FCC/CEPT Standard CB Band Channel 30 | 27.305 MHz |
| Polish (PL) "Zeros" CB Band Channel 31 | 27.310 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3105 MHz |
| USA FCC/CEPT Standard CB Band Channel 31 | 27.315 MHz |
| Polish (PL) "Zeros" CB Band Channel 32 | 27.320 MHz |
| USA FCC/CEPT Standard CB Band Channel 32 | 27.325 MHz |
| Polish (PL) "Zeros" CB Band Channel 33 | 27.330 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3345 MHz |
| USA FCC/CEPT Standard CB Band Channel 33 | 27.335 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3385 MHz |
| Polish (PL) "Zeros" CB Band Channel 34 | 27.340 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3425 MHz |
| USA FCC/CEPT Standard CB Band Channel 34 | 27.345 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3465 MHz |
| Polish (PL) "Zeros" CB Band Channel 35 | 27.350 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3505 MHz |
| USA FCC/CEPT Standard CB Band Channel 35 | 27.355 MHz |
| Polish (PL) "Zeros" CB Band Channel 36 | 27.360 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3625 MHz |
| USA FCC/CEPT Standard CB Band Channel 36 | 27.365 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3665 MHz |
| Polish (PL) "Zeros" CB Band Channel 37 | 27.370 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3705 MHz |
| USA FCC/CEPT Standard CB Band Channel 37 | 27.375 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3785 MHz |
| Polish (PL) "Zeros" CB Band Channel 38 | 27.380 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3825 MHz |
| USA FCC/CEPT Standard CB Band Channel 38 | 27.385 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3865 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3885 MHz |
| Polish (PL) "Zeros" CB Band Channel 39 | 27.390 MHz |
| USA FCC/CEPT Standard CB Band Channel 39 | 27.395 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.3985 MHz |
| Polish (PL) "Zeros" CB Band Channel 40 | 27.400 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4045 MHz |
| USA FCC/CEPT Standard CB Band Channel 40 | 27.405 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4185 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4265 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4425 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4525 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4585 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4665 MHz |
| 25w SSB Fishery Radio Japan Japanese Fishery Radio | 27.4705 MHz |
| Chinese Fishery Radio Channel 1 | 27.500 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.508 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.516 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.524 MHz |
| Chinese Fishery Radio Channel 2 | 27.525 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.532 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.540 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.544 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.548 MHz |
| Chinese Fishery Radio Channel 3 | 27.550 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.552 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.556 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.572 MHz |
| Chinese Fishery Radio Channel 4 | 27.575 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.580 MHz |
| Chinese Fishery Radio Channel 5 | 27.600 MHz |
| UK FM 27/81 and CADS/WPAS Channel 1 | 27.60125 MHz |
| CADS/WPAS Channel UW01 | 27.605 MHz |
| UK FM 27/81 and CADS/WPAS Channel 2 | 27.61125 MHz |
| CADS/WPAS Channel UW02 | 27.615 MHz |
| UK FM 27/81 and CADS/WPAS Channel 3 | 27.62125 MHz |
| Chinese Fishery Radio Channel 6 | 27.625 MHz |
| CADS/WPAS Channel UW03 | 27.625 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.628 MHz |
| UK FM 27/81 and CADS/WPAS Channel 4 | 27.63125 MHz |
| CADS/WPAS Channel UW04 | 27.635 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.636 MHz |
| UK FM 27/81 and CADS/WPAS Channel 5 | 27.64125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.644 MHz |
| CADS/WPAS Channel UW05 | 27.645 MHz |
| Chinese Fishery Radio Channel 7 | 27.650 MHz |
| UK FM 27/81 and CADS/WPAS Channel 6 | 27.65125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.652 MHz |
| CADS/WPAS Channel UW06 | 27.655 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.660 MHz |
| UK FM 27/81 and CADS/WPAS Channel 7 | 27.66125 MHz |
| CADS/WPAS Channel UW07 | 27.665 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.668 MHz |
| UK FM 27/81 and CADS/WPAS Channel 8 | 27.67125 MHz |
| Chinese Fishery Radio Channel 8 | 27.675 MHz |
| CADS/WPAS Channel UW08 | 27.675 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.676 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 68 | 27.680 MHz |
| UK FM 27/81 and CADS/WPAS Channel 9 | 27.68125 MHz |
| CADS/WPAS Channel UW09 | 27.685 MHz |
| UK FM 27/81 and CADS/WPAS Channel 10 | 27.69125 MHz |
| CADS/WPAS Channel UW10 | 27.695 MHz |
| Chinese Fishery Radio Channel 9 | 27.700 MHz |
| UK FM 27/81 and CADS/WPAS Channel 11 | 27.70125 MHz |
| CADS/WPAS Channel UW11 | 27.705 MHz |
| UK FM 27/81 and CADS/WPAS Channel 12 | 27.71125 MHz |
| CADS/WPAS Channel UW12 | 27.715 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 72 | 27.720 MHz |
| UK FM 27/81 and CADS/WPAS Channel 13 | 27.72125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.724 MHz |
| Chinese Fishery Radio Channel 10 | 27.725 MHz |
| CADS/WPAS Channel UW13 | 27.725 MHz |
| UK FM 27/81 and CADS/WPAS Channel 14 | 27.73125 MHz |
| CADS/WPAS Channel UW14 | 27.735 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.732 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.740 MHz |
| UK FM 27/81 and CADS/WPAS Channel 15 | 27.74125 MHz |
| CADS/WPAS Channel UW15 | 27.745 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.748 MHz |
| Chinese Fishery Radio Channel 11 | 27.750 MHz |
| UK FM 27/81 and CADS/WPAS Channel 16 | 27.75125 MHz |
| CADS/WPAS Channel UW16 | 27.755 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.756 MHz |
| UK FM 27/81 and CADS/WPAS Channel 17 | 27.76125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.764 MHz |
| CADS/WPAS Channel UW17 | 27.765 MHz |
| UK FM 27/81 and CADS/WPAS Channel 18 | 27.77125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.772 MHz |
| Chinese Fishery Radio Channel 12 | 27.775 MHz |
| CADS/WPAS Channel UW18 | 27.775 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.776 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.780 MHz |
| UK FM 27/81 and CADS/WPAS Channel 19 | 27.78125 MHz |
| CADS/WPAS Channel UW19 | 27.785 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.789 MHz |
| UK FM 27/81 and CADS/WPAS Channel 20 | 27.79125 MHz |
| CADS/WPAS Channel UW20 | 27.795 MHz |
| Chinese Fishery Radio Channel 13 | 27.800 MHz |
| UK FM 27/81 and CADS/WPAS Channel 21 | 27.80125 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.805 MHz |
| CADS/WPAS Channel UW21 | 27.805 MHz |
| UK FM 27/81 and CADS/WPAS Channel 22 | 27.81125 MHz |
| CADS/WPAS Channel UW22 | 27.815 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 82 | 27.820 MHz |
| Republic of Korea Fishery Radio - Ship to Ship/Ship to Shore | 27.821 MHz |
| UK FM 27/81 and CADS/WPAS Channel 23 | 27.82125 MHz |
| Chinese Fishery Radio Channel 14 | 27.825 MHz |
| CADS/WPAS Channel UW23 | 27.825 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.828 MHz |
| UK FM 27/81 and CADS/WPAS Channel 24 | 27.83125 MHz |
| CADS/WPAS Channel UW24 | 27.835 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.836 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.837 MHz |
| UK FM 27/81 and CADS/WPAS Channel 25 | 27.84125 MHz |
| CADS/WPAS Channel UW25 | 27.845 MHz |
| Chinese Fishery Radio Channel 15 | 27.850 MHz |
| UK FM 27/81 and CADS/WPAS Channel 26 | 27.85125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.852 MHz |
| CADS/WPAS Channel UW26 | 27.855 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.856 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 86 | 27.860 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.860 MHz |
| UK FM 27/81 and CADS/WPAS Channel 27 | 27.86125 MHz |
| CADS/WPAS Channel UW27 | 27.865 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.869 MHz |
| UK FM 27/81 and CADS/WPAS Channel 28 | 27.87125 MHz |
| Chinese Fishery Radio Channel 16 | 27.875 MHz |
| CADS/WPAS Channel UW28 | 27.875 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 88 | 27.880 MHz |
| UK FM 27/81 and CADS/WPAS Channel 29 | 27.88125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.884 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.885 MHz |
| CADS/WPAS Channel UW29 | 27.885 MHz |
| UK FM 27/81 and CADS/WPAS Channel 30 | 27.89125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.892 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.895 MHz |
| CADS/WPAS Channel UW30 | 27.895 MHz |
| Chinese Fishery Radio Channel 17 | 27.900 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 90 | 27.900 MHz |
| Republic of Korea Fishery Radio - Ship to Shore | 27.901 MHz |
| UK FM 27/81 and CADS/WPAS Channel 31 | 27.90125 MHz |
| CADS/WPAS Channel UW31 | 27.905 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.908 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 91 | 27.910 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.911 MHz |
| UK FM 27/81 and CADS/WPAS Channel 32 | 27.91125 MHz |
| CADS/WPAS Channel UW32 | 27.915 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.916 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.919 MHz |
| UK FM 27/81 and CADS/WPAS Channel 33 | 27.92125 MHz |
| Chinese Fishery Radio Channel 18 | 27.925 MHz |
| CADS/WPAS Channel UW33 | 27.925 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.927 MHz |
| UK FM 27/81 and CADS/WPAS Channel 34 | 27.93125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.932 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.935 MHz |
| CADS/WPAS Channel UW34 | 27.935 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 94 | 27.940 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.940 MHz |
| UK FM 27/81 and CADS/WPAS Channel 35 | 27.94125 MHz |
| Republic of Korea Fishery Radio - Ship to Ship | 27.943 MHz |
| CADS/WPAS Channel UW35 | 27.945 MHz |
| Chinese Fishery Radio Channel 19 | 27.950 MHz |
| UK FM 27/81 and CADS/WPAS Channel 36 | 27.95125 MHz |
| CADS/WPAS Channel UW36 | 27.955 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.956 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 96 | 27.960 MHz |
| UK FM 27/81 and CADS/WPAS Channel 37 | 27.96125 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.964 MHz |
| CADS/WPAS Channel UW37 | 27.965 MHz |
| UK FM 27/81 and CADS/WPAS Channel 38 | 27.97125 MHz |
| Chinese Fishery Radio Channel 20 | 27.975 MHz |
| CADS/WPAS Channel UW38 | 27.975 MHz |
| Australian Marine 27MHz 27 Meg Australia Channel 98 | 27.980 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.980 MHz |
| UK FM 27/81 and CADS/WPAS Channel 39 | 27.98125 MHz |
| CADS/WPAS Channel UW39 | 27.985 MHz |
| 1w DSB Fishery Radio Japan Japanese Fishery Radio | 27.988 MHz |
| UK FM 27/81 and CADS/WPAS Channel 40 | 27.99125 MHz |
| CADS/WPAS Channel UW40 | 27.995 MHz |
| Chinese Fishery Radio Channel 21 | 28.000 MHz |
| 27.405 MHz | 26.565 MHz | Germany Oschenwang Germany Southern Germany | CH40 output/CH41 input (German 80-channel CB) 840 kHz offset |
| 27.085 MHz | 27.175 MHz | Netherlands FM mode channel 11 and channel 18 | Multiple TX/RX sites, each site assigned a CW ID transmitted at the end of transmission |
| 27.400 MHz | 26.960 MHz | Poland FM mode, 26.960 FM input, 27.400 FM output | 6 second time out timer |
| 26.515 MHz FM | Russia | Channel B01 E or C01E FM - CB Repeater 26515 kHz | |
| 26.575 MHz FM | Germany | German 80 channel CB channel 42 - 26.575 FM repeater | |
| 26.575 MHz FM | Poland | ||
| 26.625 MHz FM | Czech Republic | ||
| 26.635 MHz FM | Central Europe | Multiple repeaters and Internet links 88.5 Hz CTCSS | |
| 26.675 MHz FM | Unknown location 11m repeater | 26 MHz repeater 26.675 FM | |
| 26.685 MHz FM | Western Russia | ||
| 26.685 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.695 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.715 MHz FM | Chelyabinsk, Russia | ||
| 26.735 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.745 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.755 MHz FM | Central Europe - multiple repeaters | 88.5 Hz tone, 94.8 Hz tone and 100.0 Hz CTCSS | |
| 26.765 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.775 MHz FM | Central Europe | Simplex repeater - Germany or Czech Republic | |
| 26.785 MHz FM | Central Europe | ||
| 26.795 MHz FM | Czech Republic | ||
| 26.805 MHz FM | Europe | 26.805 MHz FM Simplex Repeater | |
| 26.815 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.825 MHz FM | Central Europe | CB Simplex Repeater 26.825 FM | |
| 26.855 MHz FM | Central Europe | CB Simplex Repeater 26.855 FM | |
| 26.865 MHz FM | Central Europe | CB Simplex Repeater 26.865 FM | |
| 26.875 MHz FM | Central Europe | CSQ (no tone) multiple repeaters on frequency | |
| 26.875 MHz FM | Central Europe | 88.5 Hz tone | |
| 26.875 MHz FM | Central Europe | 100.0 Hz tone | |
| 26.885 MHz FM | Germany | CB Channel 73 Simplex Repeater 26.885MHz FM | |
| 26.895 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.915 MHz FM | Unknown location 11m repeater | 26 MHz repeater 26.915 FM | |
| 26.925 MHz FM | Unknown location 11m repeater | 26 MHz repeater 26.925 FM | |
| 26.935 MHz FM | Unknown location, Eastern Europe/Russia | ||
| 26.935 MHz AM | Somewhere in the USA | Cross band repeater linked to FRS channel 3 - 462.6125 MHz FM | |
| 26.945 MHz FM | Central Europe | Multiple repeaters and Internet links | |
| 26.955 MHz FM | Germany | German 80 channel CB channel 80 - 26.955 FM repeater | |
| 26.955 MHz FM | Russia | ||
| 26.960 MHz FM | Poland | Polish CB Radio Channel 1 FM Repeater | |
| 26.965 MHz FM | Europe | CB Repeater Channel 1 FM | |
| 26.970 MHz FM | Poland (multiple sites) | ||
| 26.970 MHz FM | Russia (multiple sites) | ||
| 26.970 MHz FM | Lithuania | ||
| 26.975 MHz FM | Samara, Russia | CB Repeater Channel 2 FM - 10 watt transmitter 26.975 FM repeater | |
| 26.985 MHz FM | Samara, Russia | CB Repeater Channel 3 FM - 10 watt transmitter 26.985 FM repeater | |
| 26.985 MHz FM | Tver, Russia | CB Repeater Channel 3 FM | |
| 26.985 MHz FM | Sweden - multiple sites 26.985 FM repeater | CB Repeater Channel 3 FM | |
| 27.000 MHz FM | Kiev, Ukraine | 27MHz repeater 11m repeater | |
| 27.000 MHz FM | Possibly multiple locations in Russia and/or Eastern Europe | 27 MHz Repeater | |
| 27.005 MHz FM | Yekaterinburg (Ekaterinburg), Russia | CB Repeater Channel 4 FM | |
| 27.005 MHz FM | Multiple simplex repeaters - Europe / Russia | CB Repeater Channel 4 FM | |
| 27.015 MHz FM | Moscow, Russia (multiple sites) | CB Repeater Channel 5 FM | |
| 27.015 MHz FM | Samara, Russia | 10 watt TX power | |
| 27.015 MHz FM | Naro-Fominsk, Russia | CB Repeater Channel 5 FM | |
| 27.025 MHz FM | Russia | CB Repeater Channel 6 FM | |
| 27.030 MHz FM | Minsk, Belarus | CB Repeater Channel 7R | |
| 27.030 MHz FM | Shymkent, Kazakhstan | CB Repeater Parrot Channel 7R FM | |
| 27.035 MHz FM | Kiev, Ukraine | CB Repeater Channel 7 FM 4 watt TX power | |
| 27.035 MHz FM | Multiple simplex repeaters - Europe / Russia | CB Repeater Channel 7 FM | |
| 27.035 MHz FM | Sweden | Swedish CB Repeater Channel 7 FM | |
| 27.040 MHz FM | Minsk, Belarus | ||
| 27.050 MHz FM | Russia | CB Channel 8R FM 27.050MHz FM | |
| 27.055 MHz FM | Multiple simplex repeaters on 27.055 MHz | Europe CB Channel 8 FM | |
| 27.055 MHz FM | Germany | CB Channel 8 FM Repeater | |
| 27.060 MHz FM | Kiev, Ukraine | Possibly off the air? | |
| 27.060 MHz FM | Eastern Europe or Russia | Multiple locations | |
| 27.065 MHz FM | Eastern Europe or Russia | CB Repeater Channel 9 FM | |
| 27.070 MHz FM | Unknown location, Russia or Eastern Europe | Channel 10R C10R FM 27070 FM repeater | |
| 27.075 MHz FM | Anapa, Russia | CB Repeater Channel 10 FM | |
| 27.075 MHz FM | Moscow, Russia | CB Repeater Channel 10 FM Channel C10E FM D10E FM | |
| 27.085 MHz FM | Altai Region, South-Central Russia | CB Repeater Channel 11 FM | |
| 27.085 MHz FM | Barnaul - Altai Krai Siberia | CB Repeater APK Barnaul ARK Barnaul 11FM | |
| 27.085 MHz FM | Netherlands (several locations) | Simplex, each location ends transmission with single letter CW ID | |
| 27.085 MHz FM | Netherlands (several locations) | Output (input 27.175 MHz), each location has unique end of transmission CW ID | |
| 27.090 MHz FM | Russia | 27 MHz Simplex Repeater | |
| 27.100 MHz FM | Gomel, Belarus | 100 watt TX power | |
| 27.100 MHz FM | Krasnodar, Russia | CB Repeater Channel 12R C12R FM | |
| 27.105 MHz FM | Ulyanovsk, Russia | 4 watt TX power CB Repeater Channel 12 FM | |
| 27.105 MHz FM | Astana, Kazakhstan | CB Repeater Channel 12 FM | |
| 27.105 MHz FM | Germany | CB Repeater Channel 12 FM | |
| 27.110 MHz FM | Poland | CB Repeater Channel 13R FM Channel 13P | |
| 27.110 MHz FM | Russia | ||
| 27.115 MHz FM | Russia | CB Repeater Channel 13 FM | |
| 27.125 MHz FM | Finland | CB Repeater Channel 14 FM | |
| 27.130 MHz FM | Russia | CB Repeater Channel 15R FM | |
| 27.135 MHz FM | Moscow, Russia | CB Repeater Channel 15 FM | |
| 27.140 MHz FM | Eastern Europe | ||
| 27.150 MHz FM | Poland | ||
| 27.155 MHz FM | Central Europe | CB Repeater Channel 16 FM | |
| 27.165 MHz FM | Issyk, Kazakhstan | CB Repeater Channel 17 FM | |
| 27.165 MHz FM | Moscow Russia | CB Repeater Channel 17 FM | |
| 27.170 MHz FM | Poland | ||
| 27.170 MHz FM | Russia (multiple sites) | ||
| 27.175 MHz FM | Taraz, Kazakhstan | CB Repeater Channel 18 FM | |
| 27.175 MHz FM | Russia | CB Repeater 123.0 Hz CTCSS | |
| 27.175 MHz FM | Astrakhan Russia Astrakhan Oblast 18FM | Crossband link to LPD Channel 61 434.575 MHz | |
| 27.175 MHz FM | Netherlands (several locations) | Input (Output 27.085 MHz), each location has unique end of transmission CW ID | |
| 27.180 MHz FM | Multiple sites Eastern Europe/Russia | CB Repeater Channel 19R | |
| 27.185 MHz FM | Multiple sites Eastern Europe/Russia | CB Repeater Channel 19 FM | |
| 27.185 MHz AM | Colorado, USA - possibly Arizona? | Remote location, either patched to 462.550 MHz or 462.5625 MHz (cross-band repeat) | |
| 27.190 MHz FM | Russia | Russian simplex repeater 27.190MHz FM | |
| 27.195 MHz FM | Unknown location Eastern Europe or Russia | Data, paging and RCRS frequency | |
| 27.200 MHz FM | Zaykova, Russia | ||
| 27.200 MHz FM | Russia | Multiple simplex repeaters CB Channel 20 R | |
| 27.205 MHz FM | Sweden CB channel 20 FM repeater | DTMF-activated playback, possibly multiple repeaters on this frequency | |
| 27.205 MHz FM | Russia (multiple sites) | CB Repeater Channel 20 FM | |
| 27.205 MHz AM | New Zealand | CB Repeater AM mode Channel 20 AM repeater 27205 AM | |
| 27.210 MHz FM | Zhukovsky (Moscow Oblast), Russia | ||
| 27.215 MHz FM | Almaty, Kazakhstan | CB Repeater Channel 21 FM | |
| 27.215 MHz FM | Russia (multiple sites) | CB Repeater Channel 21 FM | |
| 27.220 MHz FM | Russia | CB Repeater Channel 22 R 27220kHz FM | |
| 27.225 MHz AM | Southern USA | CB Repeater Channel 22 AM | |
| 27.225 MHz FM | Altai Region, South-Central Russia | CB Repeater Channel 22 FM | |
| 27.235 MHz FM | Eastern Europe | CB Repeater Channel 24 FM | |
| 27.240 MHz FM | Moscow, Russia | 10 watt TX power, 5/8 wave vertical antenna | |
| 27.245 MHz FM | Almaty, Kazakhstan | 12 watt TX power, 1/2 wave vertical antenna | |
| 27.245 MHz FM | Eastern Europe | CB Repeater Channel 25 FM | |
| 27.250 MHz FM | Belarus | CH 23R 23R FM 27250 kHz FM repeater | |
| 27.250 MHz FM | Russia | Repeater Channel 23R C23R FM | |
| 27.255 MHz FM | Kiev, Ukraine | CB Repeater Channel 23 FM 4 watts TX power 27.255 MHz repeater | |
| 27.255 MHz FM | Sochi, Russia | CB Repeater Channel 23 FM | |
| 27.260 MHz FM | Krivoi Rog (Kryvyi Rih), Ukraine | CB Repeater Ukraine Channel 26R | |
| 27.260 MHz FM | Moscow, Russia | 10 watt TX power, 5/8 wave vertical antenna | |
| 27.265 MHz FM | Russia - possibly multiple locations | CB Repeater Channel 26 FM | |
| 27.265 MHz FM | Nordic countries - Northern Europe | CB Repeater Channel 26 FM | |
| 27.270 MHz FM | Saratov, Russia | ||
| 27.270 MHz FM | Kiev, Ukraine | 27mhz repeater Ukraine - OFF THE AIR? | |
| 27.275 MHz FM | Kemerovo, Russia | CB Repeater Channel 27 FM cross-band link to 434.500 MHz | |
| 27.275 MHz FM | Anzhero-Sudzhensk Russia Kemerovo Oblast, Russia | CB Repeater Channel 27 FM | |
| 27.275 MHz FM | Europe | Central Europe - Multiple repeaters on 27.275 FM | |
| 27.275 MHz FM | Sweden | Swedish CB Repeater Channel 27 FM | |
| 27.275 MHz FM | Central or Western Europe | CB Repeater Channel 27 FM | |
| 27.285 MHz FM | Central Europe | CB Repeater Channel 28 FM | |
| 27.290 MHz FM | Minsk, Belarus | ||
| 27.290 MHz FM | Moscow, Russia - Northern Moscow | ||
| 27.295 MHz FM | Tyumen, Russia | CB Repeater Channel 29 FM | |
| 27.295 MHz FM | Moscow, Russia | ||
| 27.295 MHz FM | Eastern or Central Europe | German language traffic heard 27.295 FM CB repeater | |
| 27.295 MHz FM | Omsk Russia | CB Parrot Repeater Omsk Russia 29E FM | |
| 27.295 MHz FM | Sweden | Swedish CB Repeater Channel 29 FM | |
| 27.300 MHz FM | Russia, unknown additional details | ||
| 27.305 MHz FM | Northern Europe | CB Repeater Channel 30 FM | |
| 27.305 MHz FM | Western Europe | CB Repeater Channel 30 FM | |
| 27.305 MHz FM | Italy | CB Repeater Channel 30 FM | |
| 27.315 MHz FM | Russia (multiple sites) | CB Repeater Channel 31 FM | |
| 27.325 MHz FM | Central Europe | CB Repeater Channel 32 FM | |
| 27.330 MHz FM | Saratov, Russia | Located on Sokolova Mountain (wide coverage area) | |
| 27.335 MHz FM | Almaty, Kazakhstan | CB Repeater Channel 33 FM | |
| 27.335 MHz FM | Unknown location (likely Russia) | CB Repeater Channel 33 FM | |
| 27.350 MHz FM | Bobrusk Belarus | CB Repeater Belarus 27.350 FM | |
| 27.355 MHz FM | St. Petersburg, Russia | CB Repeater Channel 35 FM | |
| 27.370 MHz FM | Western Russia | ||
| 27.375 MHz FM | Vladivostok, Russia | CB Repeater Channel 37 FM | |
| 27.390 MHz FM | Kaliningrad, Russia | 10 watt TX power, 5/8 wave vertical antenna | |
| 27.395 MHz FM | Netherlands | CB Repeater Channel 39 FM President Grant II RX/TX Radio | |
| 27.405 MHz FM | Russian simplex repeater | CB Repeater Channel 40 FM | |
| 27.415 MHz FM | Yekaterinburg (Ekaterinburg), Russia | ||
| 27.415 MHz FM | Russia or Eastern Europe | ||
| 27.420 MHz FM | Unknown location - Europe | ||
| 27.425 MHz FM | Rostov, Russia | CTCSS 88.5Hz Cross-band link to 434.575 MHz CTCSS 77.0Hz | |
| 27.430 MHz FM | Western Russia | ||
| 27.450 MHz FM | Eastern Europe | Data link and paging systems also active on this frequency | |
| 27.455 MHz FM | Yekaterinburg (Ekaterinburg), Russia | ||
| 27.470 MHz FM | Eastern Europe | ||
| 27.490 MHz FM | Moscow, Russia | Possible cross-band 11M 27MHz cross band to UHF 433MHz | |
| 27.505 MHz FM | Moscow, Russia | ||
| 27.515 MHz FM | Obninsk (Kaluga Oblast), Russia | ||
| 27.525 MHz FM | Pervouralsk Sverdlovsk Oblast Russia | ||
| 27.580 MHz FM | Moscow, Russia | ||
| 27.605 MHz FM | Kazan, Russia | CTCSS 88.5Hz, Alinco DR-03T 10 watt transmitter with UHF link | |
| 27.605 MHz FM | Moscow, Russia | ||
| 27.625 MHz FM | Russia (multiple locations) | ||
| 27.630 MHz FM | Moscow, Russia | ||
| 27.635 MHz FM | Moscow, Russia | ||
| 27.635 MHz FM | St. Petersburg, Russia | This is, or was, also used for traffic service radio in St. Petersburg, unknown if still on the air | |
| 27.635 MHz FM | Several locations | ||
| 27.650 MHz FM | Western Europe | ||
| 27.665 MHz FM | Moscow, Russia | 5/8 wave vertical antenna | |
| 27.675 MHz FM | Russia | ||
| 27.675 MHz FM | Russia | 88.5 Hz tone, likely multiple simplex repeaters on 27.675MHz FM | |
| 27.685 MHz FM | Severodvinsk Russia Arkhangelsk Oblast | ||
| 27.765 MHz FM | Germany | ||
| 27.775 MHz FM | Russia | 27.775MHz 11M LMR Repeater | |
| 27.840 MHz FM | Poland | 27.840MHz FM Repeater | |
| 27.855 MHz FM | Central or Eastern Europe | Simplex repeater parrot repeater 27MHz | |
| 27.875 MHz FM | Rostov, Russia Rostov On Don | 27.875MHz Channel E2 FM Parrot Repeater 27MHz |
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band 27.9 MHz 27.900 MHz 20-27.9 MHz 27-38.9 MHz 20-28 mc megacycle 27.8 MHz, 27.4 MHz, 27.41 MHz what are the freeband CB frequencies survivalist CB frequencies emergency frequencies near me emergency channels near me UHF emergency frequency VHF emergency frequency 4125 kHz 4417 kHz 6215 kHz 6200 kHz 6212 kHz 6516 kHz 8255 kHz 8779 kHz 12290 kHz 12359 kHz 11175 kHz 13200 kHz 13137 kHz 16420 kHz 16537 kHz 17302 kHz 18795 kHz 19770 kHz 22060 kHz 22756 kHz 25097 kHz 26.097 MHz R4002 26172 kHz 26.172 MHz 2045 kHz 2638 kHz 2003 kHz 6765 kHz 6770 kHz 2048 kHz 2635 kHz ship-to-shore international frequencies radiotelephone emergency calling frequencies GMDSS DSC 2182 kHz 2187.5 kHz 4207.5 kHz 6312 kHz 8414.4 kHz 12577 kHz 16804.5 kHz 156.525 MHz 156.3 MHz 156.8 MHz 156.800 MHz telegraphy distress safety narrow band direct printing 2174.5 kHz 4177.5 kHz 6268 kHz 8376.5 kHz 12520 kHz 16695 kHz 8291 kHz 16420 kHz 4125kHz 3023 kHz 5680 kHz 8364 kHz 10003 kHz 14993 kHz 19993 kHz 19.993 MHz 10.003 MHz 14.993 MHz 123.025 MHz 123.1 MHz 122.9 MHz 455.5 kHz 458.5 kHz 16805.5 kHz 16805 kHz 25208 kHz 25.208 MHz 26121 kHz 26122 kHz 26.840 MHz
