The 25 MHz, 27 MHz and 29 MHz frequencies are shared with numerous other services worldwide, including the HF SSB marine mobile service. Removed 27.555 MHz, 27.615 MHz, 27.635 MHz, 27.655 MHz, 27.765 MHz and 27.86 MHz from list..there are no active, canceled or expired licenses for any of those frequencies.
| 25.160 MHz | |
| 25.200 MHz | |
| 25.240 MHz | |
| 25.280 MHz | |
| 25.320 MHz | |
| 27.430 MHz | |
| 27.450 MHz | |
| 27.470 MHz | |
| 29.710 MHz | |
| 29.730 MHz | |
| 29.750 MHz | |
| 29.770 MHz | |
| 29.790 MHz | |
| 30.580 MHz | |
| 30.600 MHz | |
| 30.620 MHz | |
| 30.640 MHz | |
| 30.680 MHz | |
| 30.720 MHz | |
| 30.760 MHz | |
| 30.800 MHz | |
| 30.880 MHz | |
| 30.920 MHz | |
| 30.960 MHz | |
| 31.000 MHz | |
| 31.040 MHz | |
| 31.080 MHz | |
| 31.120 MHz | |
| 31.160 MHz | |
| 31.200 MHz | |
| 31.240 MHz | |
| 31.280 MHz | |
| 31.320 MHz | |
| 31.360 MHz | |
| 31.400 MHz | |
| 31.440 MHz | |
| 31.480 MHz | |
| 31.520 MHz | |
| 31.560 MHz | |
| 31.600 MHz | |
| 31.640 MHz | |
| 31.680 MHz | |
| 31.720 MHz | |
| 31.760 MHz | |
| 31.800 MHz | |
| 31.840 MHz | |
| 31.880 MHz | |
| 31.920 MHz | |
| 31.960 MHz | |
| 33.160 MHz | |
| 33.180 MHz | |
| 33.200 MHz | |
| 33.220 MHz | |
| 33.240 MHz | |
| 33.260 MHz | |
| 33.280 MHz | |
| 33.300 MHz | |
| 33.320 MHz | |
| 33.340 MHz | |
| 33.360 MHz | |
| 33.380 MHz | |
| 35.060 MHz | |
| 35.080 MHz | |
| 35.100 MHz | |
| 35.120 MHz | |
| 35.160 MHz | |
| 35.200 MHz | |
| 35.220 MHz | |
| 35.240 MHz | |
| 35.280 MHz | |
| 35.320 MHz | |
| 35.360 MHz | |
| 35.400 MHz | |
| 35.440 MHz | |
| 35.480 MHz | |
| 35.520 MHz | |
| 35.560 MHz | |
| 35.580 MHz | |
| 35.600 MHz | |
| 35.700 MHz | |
| 35.720 MHz | |
| 35.740 MHz | |
| 35.760 MHz | |
| 35.780 MHz | |
| 35.820 MHz | |
| 35.840 MHz | |
| 35.860 MHz | |
| 35.880 MHz | |
| 35.900 MHz | |
| 35.920 MHz | |
| 35.940 MHz | |
| 35.960 MHz | |
| 35.980 MHz | |
| 37.440 MHz | |
| 37.460 MHz | |
| 37.480 MHz | |
| 37.500 MHz | |
| 37.520 MHz | |
| 37.520 MHz | |
| 37.560 MHz | |
| 37.580 MHz | |
| 37.620 MHz | |
| 37.640 MHz | |
| 37.660 MHz | |
| 37.680 MHz | |
| 37.700 MHz | |
| 37.720 MHz | |
| 37.760 MHz | |
| 37.780 MHz | |
| 37.800 MHz | |
| 37.820 MHz | |
| 37.840 MHz | |
| 37.860 MHz | |
| 37.880 MHz | |
| 42.960 MHz | |
| 43.000 MHz | |
| 43.020 MHz | |
| 43.060 MHz | |
| 43.080 MHz | |
| 43.100 MHz | |
| 43.120 MHz | |
| 43.140 MHz | |
| 43.180 MHz | |
| 43.200 MHz | |
| 43.280 MHz | |
| 43.320 MHz | |
| 43.360 MHz | |
| 43.400 MHz | |
| 43.440 MHz | |
| 43.480 MHz | |
| 43.520 MHz | |
| 43.700 MHz | |
| 43.760 MHz | |
| 43.780 MHz | |
| 43.860 MHz | |
| 43.880 MHz | |
| 43.900 MHz | |
| 43.940 MHz | |
| 44.000 MHz | |
| 44.020 MHz | |
| 44.040 MHz | |
| 44.060 MHz | |
| 44.080 MHz | |
| 44.140 MHz | |
| 44.220 MHz | |
| 44.240 MHz | |
| 44.260 MHz | |
| 44.280 MHz | |
| 44.300 MHz | |
| 44.340 MHz | |
| 44.380 MHz | |
| 44.420 MHz | |
| 44.440 MHz | |
| 44.500 MHz | |
| 44.520 MHz | |
| 44.540 MHz | |
| 44.560 MHz | |
| 44.600 MHz | |
| 47.440 MHz | |
| 47.480 MHz | |
| 47.520 MHz | |
| 47.560 MHz | |
| 47.600 MHz | |
| 47.640 MHz | |
| 47.680 MHz | |
| 47.700 MHz | |
| 47.720 MHz | |
| 47.740 MHz | |
| 47.760 MHz | |
| 47.780 MHz | |
| 47.800 MHz | |
| 47.820 MHz | |
| 47.840 MHz | |
| 47.860 MHz | |
| 47.880 MHz | |
| 47.900 MHz | |
| 47.920 MHz | |
| 47.940 MHz | |
| 47.960 MHz | |
| 47.980 MHz | |
| 48.000 MHz | |
| 48.020 MHz | |
| 48.040 MHz | |
| 48.060 MHz | |
| 48.080 MHz | |
| 48.100 MHz | |
| 48.120 MHz | |
| 48.140 MHz | |
| 48.160 MHz | |
| 48.180 MHz | |
| 48.200 MHz | |
| 48.220 MHz | |
| 48.240 MHz | |
| 48.260 MHz | |
| 48.280 MHz | |
| 48.300 MHz | |
| 48.320 MHz | |
| 48.340 MHz | |
| 48.360 MHz | |
| 48.380 MHz | |
| 48.400 MHz | |
| 48.420 MHz | |
| 48.440 MHz | |
| 48.480 MHz | |
| 48.500 MHz | |
| 48.520 MHz | |
| 48.540 MHz | |
| 48.560 MHz | |
| 48.580 MHz | |
| 48.600 MHz | |
| 48.620 MHz | |
| 48.640 MHz | |
| 48.660 MHz | |
| 48.680 MHz | |
| 48.700 MHz | |
| 48.720 MHz | |
| 48.740 MHz | |
| 48.760 MHz | |
| 48.780 MHz | |
| 48.800 MHz | |
| 48.820 MHz | |
| 48.840 MHz | |
| 48.860 MHz | |
| 48.880 MHz | |
| 48.900 MHz | |
| 48.920 MHz | |
| 48.940 MHz | |
| 48.960 MHz | |
| 48.980 MHz | |
| 49.000 MHz | |
| 49.020 MHz | |
| 49.040 MHz | |
| 49.060 MHz | |
| 49.080 MHz | |
| 49.100 MHz | |
| 49.120 MHz | |
| 49.140 MHz | |
| 49.160 MHz | |
| 49.180 MHz | |
| 49.200 MHz | |
| 49.220 MHz | |
| 49.240 MHz | |
| 49.260 MHz | |
| 49.280 MHz | |
| 49.300 MHz | |
| 49.320 MHz | |
| 49.340 MHz | |
| 49.360 MHz | |
| 49.380 MHz | |
| 49.400 MHz | |
| 49.420 MHz | |
| 49.440 MHz | |
| 49.480 MHz | |
| 49.500 MHz | |
| 49.520 MHz | |
| 49.540 MHz | |
| 49.560 MHz | |
| 49.580 MHz |
Frequencies below 150 MHz may continue to use 20K0F3E or 16K0F3E "wideband" FM mode (also known as 25 kHz bandwidth or 20 kHz bandwidth).  In the land mobile / business radio industry the term is often “25 kHz channels” or “25 kHz bandwidth”.  VHF low band is not subject to the 2013 FCC narrowband mandate.  However, narrowband FM may be used on low band.  Some licenses will be authorized for 11K0F3E, 16K0F3E and 20K0F3E emissions.
| Frequency (MHz) |
| 72.020 MHz |
| 72.040 MHz |
| 72.060 MHz |
| 72.080 MHz |
| 72.100 MHz |
| 72.120 MHz |
| 72.140 MHz |
| 72.160 MHz |
| 72.180 MHz |
| 72.200 MHz |
| 72.220 MHz |
| 72.240 MHz |
| 72.260 MHz |
| 72.280 MHz |
| 72.300 MHz |
| 72.320 MHz |
| 72.340 MHz |
| 72.360 MHz |
| 72.380 MHz |
| 72.400 MHz |
| 150.8225 MHz | |
| 150.8375 MHz | |
| 152.4725 MHz | |
| 154.4825 MHz | |
| 154.490 MHz | |
| 154.4975 MHz | |
| 154.515 MHz | |
| 154.540 MHz | |
| 154.5475 MHz | |
| 157.7325 MHz | |
| 158.4525 MHz | |
| 158.460 MHz | |
| 173.2375 MHz | |
| 173.250 MHz | |
| 173.2625 MHz | |
| 173.275 MHz | |
| 173.2875 MHz | |
| 173.300 MHz | |
| 173.3125 MHz | |
| 173.325 MHz | |
| 173.3375 MHz | |
| 173.350 MHz | |
| 173.3625 MHz | |
| 173.390 MHz | |
UHF Band 406-413 MHz
Like the UHF-T (UHF-TV) band 470-512 MHz, the 421-430 MHz band was allocated to alleviate pressure in large metro areas where frequency congestion is a significant problem.  Detroit, Cleveland and Buffalo are located near large Canadian cities.  Frequency coordination with Canada is performed for license authorization in these areas.
- 451.18125 MHz
 - 451.1875 MHz
 - 451.19375 MHz
 - 451.28125 MHz
 - 451.2875 MHz
 - 451.29375 MHz
 - 451.30625 MHz
 - 451.3125 MHz
 - 451.31875 MHz
 - 451.35625 MHz
 - 451.3625 MHz
 - 451.36875 MHz
 - 451.38125 MHz
 - 451.3875 MHz
 - 451.39375 MHz
 - 451.40625 MHz
 - 451.41875 MHz
 - 451.45625 MHz
 - 451.4625 MHz
 - 451.46875 MHz
 - 451.48125 MHz
 - 451.4875 MHz
 - 451.49375 MHz
 - 451.50625 MHz
 - 451.5125 MHz
 - 451.51875 MHz
 - 451.55625 MHz
 - 451.5625 MHz
 - 451.56875 MHz
 - 451.58125 MHz
 - 451.5875 MHz
 - 451.59375 MHz
 - 451.60625 MHz
 - 451.6125 MHz
 - 451.61875 MHz
 - 451.65625 MHz
 - 451.6625 MHz
 - 451.66875 MHz
 - 451.68125 MHz
 - 451.6875 MHz
 - 451.69375 MHz
 - 451.70625 MHz
 - 451.7125 MHz
 - 451.71875 MHz
 - 451.73125 MHz
 - 451.7375 MHz
 - 451.74375 MHz
 - 451.75625 MHz
 - 451.7625 MHz
 - 451.76875 MHz
 - 452.03125 MHz
 - 452.0375 MHz
 - 452.04375 MHz
 - 452.05625 MHz
 - 452.0625 MHz
 - 452.06875 MHz
 - 452.08125 MHz
 - 452.0875 MHz
 - 452.09375 MHz
 - 452.10625 MHz
 - 452.1125 MHz
 - 452.11875 MHz
 - 452.13125 MHz
 - 452.1375 MHz
 - 452.14375 MHz
 - 452.15625 MHz
 - 452.1625 MHz
 - 452.16875 MHz
 - 452.18125 MHz
 - 452.1875 MHz
 - 452.19375 MHz
 - 452.28125 MHz
 - 452.2875 MHz
 - 452.29375 MHz
 - 452.48125 MHz
 - 452.4875 MHz
 - 452.49375 MHz
 - 452.53125 MHz
 - 452.5375 MHz
 - 452.54375 MHz
 - 452.63125 MHz
 - 452.6375 MHz
 - 452.64375 MHz
 - 452.65625 MHz
 - 452.6625 MHz
 - 452.66875 MHz
 - 452.68125 MHz
 - 452.6875 MHz
 - 452.69375 MHz
 - 452.70625 MHz
 - 452.7125 MHz
 - 452.71875 MHz
 - 452.78125 MHz
 - 452.7875 MHz
 - 452.79375 MHz
 - 452.80625 MHz
 - 452.8125 MHz
 - 452.81875 MHz
 - 452.83125 MHz
 - 452.8375 MHz
 - 452.84375 MHz
 - 452.88125 MHz
 - 452.8875 MHz
 - 452.89375 MHz
 - 452.98125 MHz
 - 452.9875 MHz
 - 452.99375 MHz
 - 456.18125 MHz
 - 456.1875 MHz
 - 456.19375 MHz
 - 456.28125 MHz
 - 456.2875 MHz
 - 456.29375 MHz
 - 456.30625 MHz
 - 456.3125 MHz
 - 456.31875 MHz
 - 456.35625 MHz
 - 456.3625 MHz
 - 456.36875 MHz
 - 456.38125 MHz
 - 456.3875 MHz
 - 456.39375 MHz
 - 456.40625 MHz
 - 456.41875 MHz
 - 456.45625 MHz
 - 456.4625 MHz
 - 456.46875 MHz
 - 456.48125 MHz
 - 456.4875 MHz
 - 456.49375 MHz
 - 456.50625 MHz
 - 456.5125 MHz
 - 456.51875 MHz
 - 456.55625 MHz
 - 456.5625 MHz
 - 456.56875 MHz
 - 456.58125 MHz
 - 456.5875 MHz
 - 456.59375 MHz
 - 456.60625 MHz
 - 456.6125 MHz
 - 456.61875 MHz
 - 456.65625 MHz
 - 456.6625 MHz
 - 456.66875 MHz
 - 456.68125 MHz
 - 456.6875 MHz
 - 456.69375 MHz
 - 456.70625 MHz
 - 456.7125 MHz
 - 456.71875 MHz
 - 456.73125 MHz
 - 456.7375 MHz
 - 456.74375 MHz
 - 456.75625 MHz
 - 456.7625 MHz
 - 456.76875 MHz
 - 457.03125 MHz
 - 457.0375 MHz
 - 457.04375 MHz
 - 457.05625 MHz
 - 457.0625 MHz
 - 457.06875 MHz
 - 457.08125 MHz
 - 457.0875 MHz
 - 457.09375 MHz
 - 457.10625 MHz
 - 457.1125 MHz
 - 457.11875 MHz
 - 457.13125 MHz
 - 457.1375 MHz
 - 457.14375 MHz
 - 457.15625 MHz
 - 457.1625 MHz
 - 457.16875 MHz
 - 457.18125 MHz
 - 457.1875 MHz
 - 457.19375 MHz
 - 457.28125 MHz
 - 457.2875 MHz
 - 457.29375 MHz
 - 457.48125 MHz
 - 457.4875 MHz
 - 457.49375 MHz
 - 457.63125 MHz
 - 457.6375 MHz
 - 457.64375 MHz
 - 457.65625 MHz
 - 457.6625 MHz
 - 457.66875 MHz
 - 457.68125 MHz
 - 457.6875 MHz
 - 457.69375 MHz
 - 457.70625 MHz
 - 457.7125 MHz
 - 457.71875 MHz
 - 457.78125 MHz
 - 457.7875 MHz
 - 457.79375 MHz
 - 457.80625 MHz
 - 457.8125 MHz
 - 457.81875 MHz
 - 457.83125 MHz
 - 457.8375 MHz
 - 457.84375 MHz
 - 457.88125 MHz
 - 457.8875 MHz
 - 457.89375 MHz
 - 457.98125 MHz
 - 457.9875 MHz
 - 457.99375 MHz
 - 462.18125 MHz
 - 462.1875 MHz
 - 462.19375 MHz
 - 462.45625 MHz
 - 462.4625 MHz
 - 462.46875 MHz
 - 462.48125 MHz
 - 462.4875 MHz
 - 462.49375 MHz
 - 462.50625 MHz
 - 462.5125 MHz
 - 462.51875 MHz
 - 467.18125 MHz
 - 467.1875 MHz
 - 467.19375 MHz
 - 467.45625 MHz
 - 467.4625 MHz
 - 467.46875 MHz
 - 467.48125 MHz
 - 467.4875 MHz
 - 467.49375 MHz
 - 467.50625 MHz
 - 467.5125 MHz
 - 467.51875 MHz
- 451.23125 MHz
 - 451.2375 MHz
 - 451.24375 MHz
 - 451.33125 MHz
 - 451.3375 MHz
 - 451.34375 MHz
 - 451.43125 MHz
 - 451.4375 MHz
 - 451.44375 MHz
 - 451.53125 MHz
 - 451.5375 MHz
 - 451.54375 MHz
 - 451.63125 MHz
 - 451.6375 MHz
 - 451.64375 MHz
 - 452.30625 MHz
 - 452.3125 MHz
 - 452.31875 MHz
 - 452.40625 MHz
 - 452.4125 MHz
 - 452.41875 MHz
 - 452.50625 MHz
 - 452.5125 MHz
 - 452.51875 MHz
 - 452.75625 MHz
 - 452.7625 MHz
 - 452.76875 MHz
 - 452.85625 MHz
 - 452.8625 MHz
 - 452.86875 MHz
 - 456.23125 MHz
 - 456.2375 MHz
 - 456.24375 MHz
 - 456.33125 MHz
 - 456.3375 MHz
 - 456.34375 MHz
 - 456.43125 MHz
 - 456.4375 MHz
 - 456.44375 MHz
 - 456.53125 MHz
 - 456.5375 MHz
 - 456.54375 MHz
 - 456.63125 MHz
 - 456.6375 MHz
 - 456.64375 MHz
 - 457.30625 MHz
 - 457.3125 MHz
 - 457.31875 MHz
 - 457.40625 MHz
 - 457.4125 MHz
 - 457.41875 MHz
 - 457.50625 MHz
 - 457.5125 MHz
 - 457.51875 MHz
 - 457.75625 MHz
 - 457.7625 MHz
 - 457.76875 MHz
 - 457.85625 MHz
 - 457.8625 MHz
 - 457.86875 MHz
- 462.20625 MHz
 - 462.2125 MHz
 - 462.21875 MHz
 - 462.23125 MHz
 - 462.2375 MHz
 - 462.24375 MHz
 - 462.25625 MHz
 - 462.2625 MHz
 - 462.26875 MHz
 - 462.28125 MHz
 - 462.2875 MHz
 - 462.29375 MHz
 - 462.30625 MHz
 - 462.3125 MHz
 - 462.31875 MHz
 - 462.33125 MHz
 - 462.3375 MHz
 - 462.34375 MHz
 - 462.35625 MHz
 - 462.3625 MHz
 - 462.36875 MHz
 - 462.38125 MHz
 - 462.3875 MHz
 - 462.39375 MHz
 - 462.40625 MHz
 - 462.4125 MHz
 - 462.41875 MHz
 - 462.43125 MHz
 - 462.4375 MHz
 - 462.44375 MHz
 - 467.20625 MHz
 - 467.2125 MHz
 - 467.21875 MHz
 - 467.23125 MHz
 - 467.2375 MHz
 - 467.24375 MHz
 - 467.25625 MHz
 - 467.2625 MHz
 - 467.26875 MHz
 - 467.28125 MHz
 - 467.2875 MHz
 - 467.29375 MHz
 - 467.30625 MHz
 - 467.3125 MHz
 - 467.31875 MHz
 - 467.33125 MHz
 - 467.3375 MHz
 - 467.34375 MHz
 - 467.35625 MHz
 - 467.3625 MHz
 - 467.36875 MHz
 - 467.38125 MHz
 - 467.3875 MHz
 - 467.39375 MHz
 - 467.40625 MHz
 - 467.4125 MHz
 - 467.41875 MHz
 - 467.43125 MHz
 - 467.4375 MHz
 - 467.44375 MHz
- 461.03125 MHz
 - 461.0375 MHz
 - 461.04375 MHz
 - 461.05625 MHz
 - 461.0625 MHz
 - 461.06875 MHz
 - 461.08125 MHz
 - 461.0875 MHz
 - 461.09375 MHz
 - 461.10625 MHz
 - 461.1125 MHz
 - 461.11875 MHz
 - 461.13125 MHz
 - 461.1375 MHz
 - 461.14375 MHz
 - 461.15625 MHz
 - 461.1625 MHz
 - 461.16875 MHz
 - 461.18125 MHz
 - 461.1875 MHz
 - 461.19375 MHz
 - 461.20625 MHz
 - 461.2125 MHz
 - 461.21875 MHz
 - 461.23125 MHz
 - 461.2375 MHz
 - 461.24375 MHz
 - 461.25625 MHz
 - 461.2625 MHz
 - 461.26875 MHz
 - 461.28125 MHz
 - 461.2875 MHz
 - 461.29375 MHz
 - 461.30625 MHz
 - 461.3125 MHz
 - 461.31875 MHz
 - 461.33125 MHz
 - 461.3375 MHz
 - 461.34375 MHz
 - 461.35625 MHz
 - 461.3625 MHz
 - 461.36875 MHz
 - 462.7625 MHz
 - 462.7875 MHz
 - 462.8125 MHz
 - 462.8375 MHz
 - 462.8625 MHz
 - 462.8875 MHz
 - 462.9125 MHz
 - 464.4875 MHz
 - 464.48125 MHz
 - 464.5125 MHz
 - 464.51875 MHz
 - 464.53125 MHz
 - 464.5375 MHz
 - 464.5625 MHz
 - 464.56875 MHz
 - 466.03125 MHz
 - 466.0375 MHz
 - 466.04375 MHz
 - 466.05625 MHz
 - 466.0625 MHz
 - 466.06875 MHz
 - 466.08125 MHz
 - 466.0875 MHz
 - 466.09375 MHz
 - 466.10625 MHz
 - 466.1125 MHz
 - 466.11875 MHz
 - 466.13125 MHz
 - 466.1375 MHz
 - 466.14375 MHz
 - 466.15625 MHz
 - 466.1625 MHz
 - 466.16875 MHz
 - 466.18125 MHz
 - 466.1875 MHz
 - 466.19375 MHz
 - 466.20625 MHz
 - 466.2125 MHz
 - 466.21875 MHz
 - 466.23125 MHz
 - 466.2375 MHz
 - 466.24375 MHz
 - 466.25625 MHz
 - 466.2625 MHz
 - 466.26875 MHz
 - 466.28125 MHz
 - 466.2875 MHz
 - 466.29375 MHz
 - 466.30625 MHz
 - 466.3125 MHz
 - 466.31875 MHz
 - 466.33125 MHz
 - 466.3375 MHz
 - 466.34375 MHz
 - 466.35625 MHz
 - 466.3625 MHz
 - 466.36875 MHz
 - 467.8625 MHz
 - 467.8875 MHz
 - 467.9125 MHz
 - 469.4875 MHz
 - 469.48125 MHz
 - 469.5125 MHz
 - 469.51875 MHz
 - 469.53125 MHz
 - 469.5375 MHz
 - 469.5625 MHz
 - 469.56875 MHz
- 460.90625 MHz
 - 460.9125 MHz
 - 460.91875 MHz
 - 460.93125 MHz
 - 460.9375 MHz
 - 460.94375 MHz
 - 460.95625 MHz
 - 460.9625 MHz
 - 460.96875 MHz
 - 460.98125 MHz
 - 460.9875 MHz
 - 460.99375 MHz
 - 461.00625 MHz
 - 461.0125 MHz
 - 461.01875 MHz
 - 465.90625 MHz
 - 465.9125 MHz
 - 465.91875 MHz
 - 465.93125 MHz
 - 465.9375 MHz
 - 465.94375 MHz
 - 465.95625 MHz
 - 465.9625 MHz
 - 465.96875 MHz
 - 465.98125 MHz
 - 465.9875 MHz
 - 465.99375 MHz
 - 466.00625 MHz
 - 466.0125 MHz
 - 466.01875 MHz
 - one set of 68 channel pairs
 - 160 available channel pairs
 - 22 available channel pairs
Can businesses use FRS radios?  Yes they can under Part 95 of the FCC rules. Only the 5 MURS frequencies and the 22 FRS frequencies may be used without a license, however.
Often heard at construction sites, special events, shopping malls, stores, gas stations, etc.  There is also movement in the hunting community away from CB/11 meter and VHF marine towards licensed Part 90 land mobile/business radio systems.
- Itinerant
 - 151.5125 MHz - Itinerant
 - 158.4000 MHz - Itinerant
 - 158.4075 MHz - Itinerant
 - 27.5100 MHz - Low Power
 - 27.5300 MHz - Low Power
 - 33.4000 MHz - Low Power
 - 35.0200 MHz - Low Power
 - 42.9800 MHz - Low Power
 - 151.6550 MHz
 - 151.6850 MHz
 - 151.7150 MHz
 - 151.7450 MHz
 - 151.7750 MHz
 - 151.8050 MHz
 - 151.8350 MHz
 - 151.8650 MHz
 - 151.8950 MHz
 - 151.9250 MHz
 - 151.9550 MHz - Purple Dot
 - 152.8850 MHz
 - 152.9000 MHz
 - 152.9150 MHz
 - 152.9450 MHz
 - 153.0050 MHz
 - 154.4900 MHz
 - 154.5150 MHz
 - 154.5400 MHz
 - 154.5475 MHz
 - 450.0000 MHz - Unlicensed use, 88.5 Hz PL reported
 - 450.2250 MHz - Unlicensed use
 - 451.1875 MHz
 - 451.2375 MHz
 - 451.2875 MHz
 - 451.3125 MHz
 - 451.3375 MHz
 - 451.3625 MHz
 - 451.3875 MHz
 - 451.4375 MHz
 - 451.4625 MHz
 - 451.4875 MHz
 - 451.5125 MHz
 - 451.5375 MHz
 - 451.5625 MHz
 - 451.5875 MHz
 - 451.6125 MHz
 - 451.6375 MHz
 - 451.6625 MHz
 - 451.6875 MHz
 - 451.7125 MHz
 - 451.7375 MHz
 - 451.7625 MHz
 - 452.0375 MHz
 - 452.0625 MHz
 - 452.0875 MHz
 - 452.1125 MHz
 - 452.1375 MHz
 - 452.1625 MHz
 - 452.1875 MHz
 - 452.2875 MHz
 - 452.3125 MHz
 - 452.4125 MHz
 - 452.4875 MHz
 - 452.5125 MHz
 - 452.5375 MHz
 - 452.6375 MHz
 - 452.6625 MHz
 - 452.6875 MHz
 - 452.7125 MHz
 - 452.7625 MHz
 - 452.7875 MHz
 - 452.8125 MHz
 - 452.8375 MHz
 - 452.8625 MHz
 - 452.8875 MHz
 - 452.9875 MHz
 - 456.1875 MHz
 - 456.2375 MHz
 - 456.2875 MHz
 - 456.3125 MHz
 - 456.3375 MHz
 - 456.3625 MHz
 - 456.3875 MHz
 - 456.4375 MHz
 - 456.4625 MHz
 - 456.4875 MHz
 - 456.5125 MHz
 - 456.5375 MHz
 - 456.5625 MHz
 - 456.5875 MHz
 - 456.6125 MHz
 - 456.6375 MHz
 - 456.6625 MHz
 - 456.6875 MHz
 - 456.7125 MHz
 - 456.7375 MHz
 - 456.7625 MHz
 - 457.0375 MHz
 - 457.0625 MHz
 - 457.0875 MHz
 - 457.1125 MHz
 - 457.1375 MHz
 - 457.1625 MHz
 - 457.1875 MHz
 - 457.2875 MHz
 - 457.3125 MHz
 - 457.4125 MHz
 - 457.4875 MHz
 - 457.5125 MHz
 - 457.6375 MHz
 - 457.6625 MHz
 - 457.7125 MHz
 - 457.7375 MHz
 - 457.7625 MHz
 - 457.7875 MHz
 - 457.8125 MHz
 - 457.8375 MHz
 - 457.8625 MHz
 - 457.8875 MHz
 - 457.9875 MHz
 - 461.0375 MHz
 - 461.0625 MHz
 - 461.0875 MHz
 - 461.1125 MHz
 - 461.1375 MHz
 - 461.1625 MHz
 - 461.1875 MHz
 - 461.2125 MHz
 - 461.2375 MHz
 - 461.2625 MHz
 - 461.2875 MHz
 - 461.3125 MHz
 - 461.3375 MHz
 - 461.3625 MHz
 - 462.1875 MHz
 - 462.4625 MHz
 - 462.4875 MHz
 - 462.5125 MHz
 - 466.0375 MHz
 - 466.0625 MHz
 - 466.0875 MHz
 - 466.1125 MHz
 - 466.1375 MHz
 - 466.1625 MHz
 - 466.1875 MHz
 - 466.2125 MHz
 - 466.2375 MHz
 - 466.2625 MHz
 - 466.2875 MHz
 - 466.3125 MHz
 - 466.3375 MHz
 - 466.3625 MHz
 - 467.1875 MHz
 - 467.4625 MHz
 - 467.4875 MHz
 - 467.5125 MHz
 - 467.7875 MHz - 2 watts
 - 467.8375 MHz - 2 watts
 - 467.8875 MHz - 2 watts
 - 467.9125 MHz - 2 watts
 - 468.2125 MHz
 - 468.2625 MHz
 - 468.3125 MHz
 - 468.3375 MHz
 - 468.3625 MHz
 - 468.4125 MHz
 - 468.4625 MHz
 - 468.5125 MHz
 - 468.5625 MHz
 - 468.5875 MHz
 - 468.6125 MHz
 - 468.6375 MHz
 - 468.6625 MHz
Do I need a license to transmit on 151.625 MHz? Yes, you do.  You need a license to use all the business band frequencies, including 151.625 MHz, 151.505 MHz, 158.400 MHz, 151.955 MHz, 151.700 MHz, 151.760 MHz, 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.875 MHz, 467.900 MHz, etc.  Only the 22 FRS frequencies, the 5 MURS frequencies and the 40 CB channels do not require a license.  Getting a business license for the Itinerant channels is extremely easy.
- 464.5500 MHz
 - 464.5000 MHz
 - 467.9250 MHz
 - 467.9000 MHz
 - 467.8750 MHz
 - 467.8500 MHz
 - 469.5500 MHz
 - 469.5000 MHz
 - 461.0375 MHz
 - 461.1125 MHz
 - 461.1375 MHz
 - 461.2375 MHz
 - 467.8125 MHz
 - 467.7625 MHz
 - 451.8000 MHz
 - 456.8000 MHz
 - 451.8125 MHz
 - 456.8125 MHz
- 151.6250 MHz
 - 154.5700 MHz
 - 154.6000 MHz
 - 151.9550 MHz
 - 151.5125 MHz
 - 151.5050 MHz
 - 151.7000 MHz
 - 151.7600 MHz
 - 151.8200 MHz
 - 151.9400 MHz
 - 151.8800 MHz
 - 151.9250 MHz
 - 151.8050 MHz
 - 158.4000 MHz
 - 158.4075 MHz
 - 151.6550 MHz
 - 151.8650 MHz
 - 152.9000 MHz
Motorola refers to CTCSS and DCS as "codes", Kenwood and other companies refer to CTCSS as QT (Quiet Tone) and DCS as DQT (Digital Quiet Tone).  The terms "PL" and "DPL" are still heavily used in the two-way radio community to refer to CTCSS and DCS, respectively.  Baofeng radios refer to CTCSS as CTCS and DCS as DCS.  Transmit CTCSS is T-CTCS and receive CTCSS is R-CTCS.  Radio programming software will refer to tone encode (transmit) and decode (receive).  An example of this is the Retevis series of radios - QT or DQT Enc is CTCSS or DCS encode (transmit) and QT or DQT Dec CTCSS or DCS decode (receive).
Higher-end VHF and UHF handheld radios are simply sold by the band they operate on, and the end user (or vendor) programs the radio accordingly.  This is changing by the early 2020s and the flooding of the market with inexpensive Chinese radios that often come with factory default frequencies out of the box.  Some of these radios have received FCC approval for Part 95 (FRS, GMRS or MURS) usage, while others have Part 90 land mobile authorization (with the programming software of course).    See also:  commonly used, popular and out of the box factory default FRS and GMRS frequencies channels codes tones.
 - Frequency 151.655 MHz
 - Frequency 151.685 MHz
 - Frequency 151.715 MHz
 - Frequency 151.775 MHz
 - Frequency 151.835 MHz
 - Frequency 151.895 MHz
 - Frequency 151.925 MHz
 - Frequency 154.490 MHz
 - Frequency 154.515 MHz
 - Frequency 154.540 MHz
 - Frequency 158.400 MHz
- Frequency - 462.5750 MHz - FRS Channel 16 (FRS simplex, GMRS simplex)
 - Frequency - 462.6250 MHz - FRS Channel 18 (FRS simplex, GMRS simplex)
 - Frequency - 462.6750 MHz - FRS Channel 20 (FRS simplex, GMRS simplex)
 - Frequency - 464.3250 MHz
 - Frequency - 464.8250 MHz
 - Frequency - 469.2625 MHz
 - Frequency - 469.5000 MHz
 - Frequency - 469.5500 MHz
Motorola Spirit-M VHF radio
Motorola Spirit-M UHF radio
Frequencies
Motorola Sport UHF GMRS radio
Lowband 1 - Low 1
Lowband 2 - Low 2
VHF High Band - VHF
700 MHz Band - 700
800 MHz Band - 800
 - Channel 6- 462.6875 MHz 071 DCS Code DCS 11
KidDesigns Walkie Talkies
 - Power Output: 0.133mW
 - Emission: 11K0F3E
 - FCC ID IAJ-210
 - Power Output: 7mW
 - Emission: 11K0F3E
 - FCC ID IAJ-212C7A
 - Power Output: 3.2mW
 - Emission: 11K0F3E
 - FCC ID IAJ-212C7B
 - Power Output: 4.2mW
 - Emission: 4K26F3E
 - FCC ID IAJ-216
These radios operate on FRS channel 1, 2, 3, 4, 5, 6 and 7.  Power output 59.7mW, 59.98mW, 70.795mW and 72.277mW
Radioditty GA-2S
 - Channel 8 - 462.5500 MHz
 - Channel 10 - 462.6000 MHz
 - Channel 11 - 462.6250 MHz
 - Channel 12 - 462.6500 MHz
 - Channel 13 - 462.6750 MHz
 - Channel 14 - 462.7000 MHz
 - Channel 15 - 462.7250 MHz
TYT TC-568  - Quanzhou TYT Electronics Co. Ltd. FRS TC-568 UHF Analog FRS Portable Transceiver
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
 - Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
Retevis RT1-VHF RT1 RT-1
Retevis RT-24 FRS 16 channel
US license free 462 MHz FRS GMRS specification version.  Like the other Retevis 16 channel UHF radios, it includes the 462.6250 127.3 Hz, 462.7250 136.5 Hz BF-888S default frequencies as well as Retevis-specific frequency/tone combinations - namely 462.5625 with 67.0 Hz, 462.5875 with 118.8 Hz, 462.6125 with 127.3 Hz, 462.6375 with 131.8 Hz, 462.6625 with 136.5 Hz, 462.6875 with 141.3 Hz, 462.7125 with 146.2 Hz, 462.550 with 123.0 Hz and so on.
Retevis RT-27V MURS VHF
RETEVIS RT27V RT47V RB27V RB47  US license free 151.82-151.94/154.57-154.6 MHz MURS specification version.
Like Kenwood, CTCSS is referred to as QT and DCS is referred to as DQT.  Dec is decode (receive) and Enc is encode (transmit).
US license free UHF FRS GMRS specification version.  Note that this radio includes the Retevis standardized CTCSS tones for FRS channels 1-7 (67.0 Hz, 118.8 Hz, 127.3 Hz, 131.8 Hz, 136.5 Hz, 141.3 Hz, 146.2 Hz as well as channel 15 (123.0 Hz), 18 (127.3 Hz) and 22 (136.5 Hz).  The channel 18 and channel 22 tones match with the Baofeng BF-888S default CTCSS tones for those respective frequencies as well.
Retevis RT-47V MURS VHF
US license free 151.82-151.94/154.57-154.6 MHz MURS specification version.   New Retevis MURS RB38V with 5 MURS channels and 10 NOAA weather channels (receive only).   RT27V  RT47V RB38V
- Channel 1 - 400.1250 MHz
 - Channel 2 - 410.1250 MHz
 - Channel 3 - 420.1250 MHz
 - Channel 4 - 430.1250 MHz
 - Channel 5 - 440.1250 MHz
 - Channel 6 - 450.1250 MHz
 - Channel 7 - 460.1250 MHz
 - Channel 8 - 470.1250 MHz
 - Channel 9 - 480.1250 MHz
 - Channel 10 - 490.1250 MHz
 - Channel 11 - 500.1250 MHz
 - Channel 12 - 510.1250 MHz
 - Channel 13 - 519.9750 MHz
 - Channel 14 - 136.1250 MHz
 - Channel 15 - 145.1250 MHz
 - Channel 16 - 155.1250 MHz
 - Channel 17 - 165.1250 MHz
 - Channel 18 - 173.9750 MHz
- Freq 1 - 464.5000 MHz
 - Freq 2 - 464.5500 MHz
 - Freq 3 - 467.7625 MHz
 - Freq 4 - 467.8125 MHz
 - Freq 5 - 467.8500 MHz
 - Freq 6 - 467.8750 MHz
 - Freq 7 - 467.9000 MHz
 - Freq 8 - 467.9250 MHz
 - Freq 9 - 461.0375 MHz
 - Freq 10 - 461.0625 MHz
 - Freq 11 - 461.0875 MHz
 - Freq 12 - 461.1125 MHz
 - Freq 13 - 461.1375 MHz
 - Freq 14 - 461.1625 MHz
 - Freq 15 - 461.1875 MHz
 - Freq 16 - 461.2125 MHz
 - Freq 17 - 461.2375 MHz
 - Freq 18 - 461.2625 MHz
 - Freq 19 - 461.2875 MHz
 - Freq 20 - 461.3125 MHz
 - Freq 21 - 461.3375 MHz
 - Freq 22 - 461.3625 MHz
 - Freq 23 - 462.7625 MHz
 - Freq 24 - 462.7875 MHz
 - Freq 25 - 462.8125 MHz
 - Freq 26 - 462.8375 MHz
 - Freq 27 - 462.8625 MHz
 - Freq 28 - 462.8875 MHz
 - Freq 29 - 462.9125 MHz
 - Freq 30 - 464.4875 MHz
 - Freq 31 - 464.5125 MHz
 - Freq 32 - 464.5375 MHz
 - Freq 33 - 464.5625 MHz
 - Freq 34 - 466.0375 MHz
 - Freq 35 - 466.0625 MHz
 - Freq 36 - 466.0875 MHz
 - Freq 37 - 466.1125 MHz
 - Freq 38 - 466.1375 MHz
 - Freq 39 - 466.1625 MHz
 - Freq 40 - 466.1875 MHz
 - Freq 41 - 466.2125 MHz
 - Freq 42 - 466.2375 MHz
 - Freq 43 - 466.2625 MHz
 - Freq 44 - 466.2875 MHz
 - Freq 45 - 466.3125 MHz
 - Freq 46 - 466.3375 MHz
 - Freq 47 - 466.3625 MHz
 - Freq 48 - 467.7875 MHz
 - Freq 49 - 467.8375 MHz
 - Freq 50 - 467.8625 MHz
 - Freq 51 - 467.8875 MHz
 - Freq 52 - 467.9125 MHz
 - Freq 53 - 469.4875 MHz
 - Freq 54 - 469.5125 MHz
 - Freq 55 - 469.5375 MHz
 - Freq 56 - 469.5625 MHz
 - Freq 9 - 462.5750 MHz
 - Freq 10 - 462.6250 MHz
 - Freq 11 - 462.6750 MHz
 - Freq 12 - 464.3250 MHz
 - Freq 13 - 464.8250 MHz
 - Freq 14 - 469.2625 MHz
 - Freq 15 - 469.5000 MHz
 - Freq 16 - 469.5500 MHz
 - Freq 17 - 462.7625 MHz
 - Freq 18 - 462.7875 MHz
 - Freq 19 - 462.8125 MHz
 - Freq 20 - 462.8375 MHz
 - Freq 21 - 462.8625 MHz
 - Freq 22 - 462.8875 MHz
 - Freq 23 - 462.9125 MHz
 - Freq 23 - 461.0375 MHz
 - Freq 25 - 461.0625 MHz
 - Freq 26 - 461.0875 MHz
 - Freq 27 - 461.1125 MHz
 - Freq 28 - 461.1375 MHz
 - Freq 29 - 461.1625 MHz
 - Freq 30 - 461.1875 MHz
 - Freq 31 - 461.2125 MHz
 - Freq 32 - 461.2375 MHz
 - Freq 33 - 461.2625 MHz
 - Freq 34 - 461.2875 MHz
 - Freq 35 - 461.3125 MHz
 - Freq 36 - 461.3375 MHz
 - Freq 37 - 461.3625 MHz
 - Freq 38 - 467.7875 MHz
 - Freq 39 - 467.8375 MHz
 - Freq 40 - 467.8625 MHz
 - Freq 41 - 467.8875 MHz
 - Freq 42 - 467.9125 MHz
 - Freq 43 - 464.4875 MHz
 - Freq 44 - 464.5125 MHz
 - Freq 45 - 464.5375 MHz
 - Freq 46 - 464.5625 MHz
 - Freq 47 - 466.0375 MHz
 - Freq 48 - 466.0625 MHz
 - Freq 49 - 466.0875 MHz
 - Freq 50 - 466.1125 MHz
 - Freq 51 - 466.1375 MHz
 - Freq 52 - 466.1625 MHz
 - Freq 53 - 466.1875 MHz
 - Freq 54 - 466.2125 MHz
 - Freq 55 - 466.2375 MHz
 - Freq 56 - 466.2625 MHz
- Freq 1 - 151.6250 MHz
 - Freq 2 - 151.9550 MHz
 - Freq 3 - 154.5700 MHz
 - Freq 4 - 154.6000 MHz
 - Freq 5 - 151.7000 MHz
 - Freq 6 - 151.7600 MHz
 - Freq 7 - 151.8200 MHz
 - Freq 8 - 151.8800 MHz
 - Freq 9 - 151.9400 MHz
 - Freq 10 - 151.5125 MHz
 - Freq 11 - 151.6550 MHz
 - Freq 12 - 151.6850 MHz
 - Freq 13 - 151.7150 MHz
 - Freq 14 - 151.7450 MHz
 - Freq 15 - 151.7750 MHz
 - Freq 16 - 151.8650 MHz
 - Freq 17 - 151.8950 MHz
 - Freq 18 - 151.9250 MHz
 - Freq 20 - 154.4900 MHz
 - Freq 21 - 154.5150 MHz
 - Freq 22 - 154.5275 MHz
 - Freq 23 - 154.5400 MHz
 - Freq 24 - 154.6000 MHz
 - Freq 26 - 158.4000 MHz
 - Freq 27 - 158.4075 MHz
 - Freq 57 - 462.1875 MHz
 - Freq 58 - 462.4625 MHz
 - Freq 59 - 462.4875 MHz
 - Freq 60 - 462.5125 MHz
 - Freq 61 - 467.1875 MHz
 - Freq 62 - 467.4625 MHz
 - Freq 63 - 467.4875 MHz
 - Freq 64 - 467.5125 MHz
 - Freq 65 - 451.1875 MHz
 - Freq 66 - 451.2375 MHz
 - Freq 67 - 451.2875 MHz
 - Freq 68 - 451.3375 MHz
 - Freq 69 - 451.4375 MHz
 - Freq 70 - 451.5375 MHz
 - Freq 71 - 451.6375 MHz
 - Freq 72 - 452.3125 MHz
 - Freq 73 - 452.5375 MHz
 - Freq 74 - 452.4125 MHz
 - Freq 75 - 452.5125 MHz
 - Freq 76 - 452.7625 MHz
 - Freq 77 - 452.8625 MHz
 - Freq 78 - 456.1875 MHz
 - Freq 79 - 456.2375 MHz
 - Freq 80 - 456.2875 MHz
 - Freq 81 - 468.2125 MHz
 - Freq 82 - 468.2625 MHz
 - Freq 83 - 468.3125 MHz
 - Freq 84 - 468.3625 MHz
 - Freq 85 - 468.4125 MHz
 - Freq 86 - 468.4625 MHz
 - Freq 87 - 468.5125 MHz
 - Freq 88 - 468.5625 MHz
 - Freq 89 - 468.6125 MHz
 - Freq 90 - 468.6625 MHz
 - Freq 81 - 456.3375 MHz
 - Freq 82 - 456.4375 MHz
 - Freq 83 - 456.5375 MHz
 - Freq 84 - 456.6375 MHz
 - Freq 85 - 457.3125 MHz
 - Freq 86 - 457.4125 MHz
 - Freq 87 - 457.5125 MHz
 - Freq 88 - 457.7625 MHz
 - Freq 89 - 457.8625 MHz
 - Freq 3 - 152.8850 MHz
 - Freq 4 - 152.9150 MHz
 - Freq 7 - 152.9450 MHz
 - Freq 8 - 151.8350 MHz
 - Freq 9 - 151.8050 MHz
 - Freq 24 - 153.0050 MHz
- Freq 0 - OFF (BLANK)
 - Code 1 - 67.0 Hz PL - XZ
 - Code 2 - 71.9 Hz PL - XA
 - Code 3 - 74.4 Hz PL - WA
 - Code 4 - 77.0 Hz PL - XB
 - Code 5 - 79.7 Hz PL - WB
 - Code 6 - 82.5 Hz PL - YZ
 - Code 7 - 85.4 Hz PL - YA
 - Code 8 - 88.5 Hz PL - YB
 - Code 9 - 91.5 Hz PL - ZZ
 - Code 10 - 94.8 Hz PL - ZA
 - Code 11 - 97.4 Hz PL - ZB
 - Code 12 - 100.0 Hz PL - 1Z
 - Code 13 - 103.5 Hz PL - 1A
 - Code 14 - 107.2 Hz PL - 1B
 - Code 15 - 110.9 Hz PL - 2Z
 - Code 16 - 114.8 Hz PL - 2A
 - Code 17 - 118.8 Hz PL - 2B
 - Code 18 - 123.0 Hz PL - 3Z
 - Code 19 - 127.3 Hz PL - 3A
 - Code 20 - 131.8 Hz PL - 3B
 - Code 21 - 136.5 Hz PL - 4Z
 - Code 22 - 141.3 Hz PL - 4A
 - Code 23 - 146.2 Hz PL - 4B
 - Code 24 - 151.4 Hz PL - 5Z
 - Code 25 - 156.7 Hz PL - 5A
 - Code 26 - 162.2 Hz PL - 5B
 - Code 27 - 167.9 Hz PL - 6Z
 - Code 28 - 173.8 Hz PL - 6A
 - Code 29 - 179.9 Hz PL - 6B
 - Code 30 - 186.2 Hz PL - 7Z
 - Code 31 - 192.8 Hz PL - 7A
 - Code 32 - 203.5 Hz PL - M1
 - Code 33 - 210.7 Hz PL - M2
 - Code 34 - 218.1 Hz PL - M3
 - Code 35 - 225.7 Hz PL - M4
 - Code 36 - 233.6 Hz PL - M5
 - Code 37 - 241.8 Hz PL - M6
 - Code 38 - 250.3 Hz PL - M7
 - Code 39 - 023 DPL D023N
 - Code 40 - 025 DPL D025N
 - Code 41 - 026 DPL D026N
 - Code 42 - 031 DPL D031N
 - Code 43 - 032 DPL D032N
 - Code 44 - 043 DPL D043N
 - Code 45 - 047 DPL D047N
 - Code 46 - 051 DPL D051N
 - Code 47 - 054 DPL D054N
 - Code 48 - 065 DPL D065N
 - Code 49 - 071 DPL D071N
 - Code 50 - 072 DPL D072N
 - Code 51 - 073 DPL D073N
 - Code 52 - 074 DPL D074N
 - Code 53 - 114 DPL D114N
 - Code 54 - 115 DPL D115N
 - Code 55 - 116 DPL D116N
 - Code 56 - 125 DPL D125N
 - Code 57 - 131 DPL D131N
 - Code 58 - 132 DPL D132N
 - Code 59 - 134 DPL D134N
 - Code 60 - 143 DPL D143N
 - Code 61 - 152 DPL D152N
 - Code 62 - 155 DPL D155N
 - Code 63 - 156 DPL D156N
 - Code 64 - 162 DPL D162N
 - Code 65 - 165 DPL D165N
 - Code 66 - 172 DPL D172N
 - Code 67 - 174 DPL D174N
 - Code 68 - 205 DPL D205N
 - Code 69 - 223 DPL D223N
 - Code 70 - 226 DPL D226N
 - Code 71 - 243 DPL D243N
 - Code 72 - 244 DPL D244N
 - Code 73 - 245 DPL D245N
 - Code 74 - 251 DPL D251N
 - Code 75 - 261 DPL D261N
 - Code 76 - 263 DPL D263N
 - Code 77 - 265 DPL D265N
 - Code 78 - 271 DPL D271N
 - Code 79 - 306 DPL D306N
 - Code 80 - 311 DPL D311N
 - Code 81 - 315 DPL D315N
 - Code 82 - 331 DPL D331N
 - Code 83 - 343 DPL D343N
 - Code 84 - 346 DPL D346N
 - Code 85 - 351 DPL D351N
 - Code 86 - 364 DPL D364N
 - Code 87 - 365 DPL D365N
 - Code 88 - 371 DPL D371N
 - Code 89 - 411 DPL D411N
 - Code 90 - 412 DPL D412N
 - Code 91 - 413 DPL D413N
 - Code 92 - 423 DPL D423N
 - Code 93 - 431 DPL D431N
 - Code 94 - 432 DPL D432N
 - Code 95 - 445 DPL D445N
 - Code 96 - 464 DPL D464N
 - Code 97 - 465 DPL D465N
 - Code 98 - 466 DPL D466N
 - Code 99 - 503 DPL D503N
 - Code 100 - 506 DPL D506N
 - Code 101 - 516 DPL D516N
 - Code 102 - 532 DPL D532N
 - Code 103 - 546 DPL D546N
 - Code 104 - 565 DPL D565N
 - Code 105 - 606 DPL D606N
 - Code 106 - 612 DPL D612N
 - Code 107 - 624 DPL D624N
 - Code 108 - 627 DPL D627N
 - Code 109 - 631 DPL D631N
 - Code 110 - 632 DPL D632N
 - Code 111 - 654 DPL D654N
 - Code 112 - 662 DPL D662N
 - Code 113 - 664 DPL D664N
 - Code 114 - 703 DPL D703N
 - Code 115 - 712 DPL D712N
 - Code 116 - 723 DPL D723N
 - Code 117 - 731 DPL D731N
 - Code 118 - 732 DPL D732N
 - Code 119 - 734 DPL D734N
 - Code 120 - 743 DPL D743N
 - Code 121 - 754 DPL D754N
 - Code 122 - 69.3 Hz PL
 - Code 123 - 645 DPL D645N
- DCS Code 1 - 023 DPL
 - DCS Code 2 - 025 DPL
 - DCS Code 3 - 026 DPL
 - DCS Code 4 - 031 DPL
 - DCS Code 5 - 032 DPL
 - DCS Code 6 - 043 DPL
 - DCS Code 7 - 047 DPL
 - DCS Code 8 - 051 DPL
 - DCS Code 9 - 054 DPL
 - DCS Code 10 - 065 DPL
 - DCS Code 11 - 071 DPL
 - DCS Code 12 - 072 DPL
 - DCS Code 13 - 073 DPL
 - DCS Code 14 - 074 DPL
 - DCS Code 15 - 114 DPL
 - DCS Code 16 - 115 DPL
 - DCS Code 17 - 116 DPL
 - DCS Code 18 - 125 DPL
 - DCS Code 19 - 131 DPL
 - DCS Code 20 - 132 DPL
 - DCS Code 21 - 134 DPL
 - DCS Code 22 - 143 DPL
 - DCS Code 23 - 152 DPL
 - DCS Code 24 - 155 DPL
 - DCS Code 25 - 156 DPL
 - DCS Code 26 - 162 DPL
 - DCS Code 27 - 165 DPL
 - DCS Code 28 - 172 DPL
 - DCS Code 29 - 174 DPL
 - DCS Code 30 - 205 DPL
 - DCS Code 31 - 223 DPL
 - DCS Code 32 - 226 DPL
 - DCS Code 33 - 243 DPL
 - DCS Code 34 - 244 DPL
 - DCS Code 35 - 245 DPL
 - DCS Code 36 - 251 DPL
 - DCS Code 37 - 261 DPL
 - DCS Code 38 - 263 DPL
 - DCS Code 39 - 265 DPL
 - DCS Code 40 - 271 DPL
 - DCS Code 41 - 306 DPL
 - DCS Code 42 - 311 DPL
 - DCS Code 43 - 315 DPL
 - DCS Code 44 - 331 DPL
 - DCS Code 45 - 343 DPL
 - DCS Code 46 - 346 DPL
 - DCS Code 47 - 351 DPL
 - DCS Code 48 - 364 DPL
 - DCS Code 49 - 365 DPL
 - DCS Code 50 - 371 DPL
 - DCS Code 51 - 411 DPL
 - DCS Code 52 - 412 DPL
 - DCS Code 53 - 413 DPL
 - DCS Code 54 - 423 DPL
 - DCS Code 55 - 431 DPL
 - DCS Code 56 - 432 DPL
 - DCS Code 57 - 445 DPL
 - DCS Code 58 - 464 DPL
 - DCS Code 59 - 465 DPL
 - DCS Code 60 - 466 DPL
 - DCS Code 61 - 503 DPL
 - DCS Code 62 - 506 DPL
 - DCS Code 63 - 516 DPL
 - DCS Code 64 - 532 DPL
 - DCS Code 65 - 546 DPL
 - DCS Code 66 - 565 DPL
 - DCS Code 67 - 606 DPL
 - DCS Code 68 - 612 DPL
 - DCS Code 69 - 624 DPL
 - DCS Code 70 - 627 DPL
 - DCS Code 71 - 631 DPL
 - DCS Code 72 - 632 DPL
 - DCS Code 73 - 654 DPL
 - DCS Code 74 - 662 DPL
 - DCS Code 75 - 664 DPL
 - DCS Code 76 - 703 DPL
 - DCS Code 77 - 712 DPL
 - DCS Code 78 - 723 DPL
 - DCS Code 79 - 731 DPL
 - DCS Code 80 - 732 DPL
 - DCS Code 81 - 734 DPL
 - DCS Code 82 - 743 DPL
 - DCS Code 83 - 754 DPL
 - DCS Code 84 - 036 DPL
 - DCS Code 85 - 053 DPL
 - DCS Code 86 - 122 DPL
 - DCS Code 87 - 145 DPL
 - DCS Code 88 - 212 DPL
 - DCS Code 89 - 225 DPL
 - DCS Code 90 - 246 DPL
 - DCS Code 91 - 252 DPL
 - DCS Code 92 - 255 DPL
 - DCS Code 93 - 266 DPL
 - DCS Code 94 - 274 DPL
 - DCS Code 95 - 325 DPL
 - DCS Code 96 - 332 DPL
 - DCS Code 97 - 356 DPL
 - DCS Code 98 - 446 DPL
 - DCS Code 99 - 452 DPL
 - DCS Code 100 - 454 DPL
 - DCS Code 101 - 455 DPL
 - DCS Code 102 - 462 DPL
 - DCS Code 103 - 523 DPL
 - DCS Code 104 - 526 DPL
- CTCSS Code 1 - 67.0 Hz
 - CTCSS Code 2 - 69.3 Hz
 - CTCSS Code 3 - 71.9 Hz
 - CTCSS Code 4 - 74.4 Hz
 - CTCSS Code 5 - 77.0 Hz
 - CTCSS Code 6 - 79.7 Hz
 - CTCSS Code 7 - 82.5 Hz
 - CTCSS Code 8 - 85.4 Hz
 - CTCSS Code 9 - 88.5 Hz
 - CTCSS Code 10 - 91.5 Hz
 - CTCSS Code 11 - 94.8 Hz
 - CTCSS Code 12 - 97.4 Hz
 - CTCSS Code 13 - 100.0 Hz
 - CTCSS Code 14 - 103.5 Hz
 - CTCSS Code 15 - 107.2 Hz
 - CTCSS Code 16 - 110.9 Hz
 - CTCSS Code 17 - 114.8 Hz
 - CTCSS Code 18 - 118.8 Hz
 - CTCSS Code 19 - 123.0 Hz
 - CTCSS Code 20 - 127.3 Hz
 - CTCSS Code 21 - 131.8 Hz
 - CTCSS Code 22 - 136.5 Hz
 - CTCSS Code 23 - 141.3 Hz
 - CTCSS Code 24 - 146.2 Hz
 - CTCSS Code 25 - 151.4 Hz
 - CTCSS Code 26 - 156.7 Hz
 - CTCSS Code 27 - 159.8 Hz
 - CTCSS Code 28 - 162.2 Hz
 - CTCSS Code 29 - 165.5 Hz
 - CTCSS Code 30 - 167.9 Hz
 - CTCSS Code 31 - 171.3 Hz
 - CTCSS Code 32 - 173.8 Hz
 - CTCSS Code 33 - 177.3 Hz
 - CTCSS Code 34 - 179.9 Hz
 - CTCSS Code 35 - 183.5 Hz
 - CTCSS Code 36 - 186.2 Hz
 - CTCSS Code 37 - 189.9 Hz
 - CTCSS Code 38 - 192.8 Hz
 - CTCSS Code 39 - 196.6 Hz
 - CTCSS Code 40 - 199.5 Hz
 - CTCSS Code 41 - 203.5 Hz
 - CTCSS Code 42 - 206.5 Hz
 - CTCSS Code 43 - 210.7 Hz
 - CTCSS Code 44 - 218.1 Hz
 - CTCSS Code 45 - 225.7 Hz
 - CTCSS Code 46 - 229.1 Hz
 - CTCSS Code 47 - 233.6 Hz
 - CTCSS Code 48 - 241.8 Hz
 - CTCSS Code 49 - 250.3 Hz
 - CTCSS Code 50 - 254.1 Hz
- CTCSS (T-CTCS and R-CTCS)
- OFF
 - 67.0HZ
 - 69.3HZ
 - 71.9HZ
 - 74.4HZ
 - 77.0HZ
 - 79.7HZ
 - 82.5HZ
 - 85.4HZ
 - 88.5HZ
 - 91.5HZ
 - 94.8HZ
 - 97.4HZ
 - 100.0HZ
 - 103.5HZ
 - 107.2HZ
 - 110.9HZ
 - 114.8HZ
 - 118.8HZ
 - 123.0HZ
 - 127.3HZ
 - 131.8HZ
 - 136.5HZ
 - 141.3HZ
 - 146.2HZ
 - 151.4HZ
 - 156.7HZ
 - 159.8HZ
 - 162.2HZ
 - 165.5HZ
 - 167.9HZ
 - 171.3HZ
 - 173.8HZ
 - 177.3HZ
 - 179.9HZ
 - 183.5HZ
 - 186.2HZ
 - 189.9HZ
 - 192.8HZ
 - 196.6HZ
 - 199.5HZ
 - 203.5HZ
 - 206.5HZ
 - 210.7HZ
 - 218.1HZ
 - 225.7HZ
 - 229.1HZ
 - 233.6HZ
 - 241.8HZ
 - 250.3HZ
 - 254.1HZ
- DCS (T-DCS and R-DCS)
- OFF
 - D023N
 - D025N
 - D026N
 - D031N
 - D032N
 - D036N
 - D043N
 - D047N
 - D051N
 - D053N
 - D054N
 - D065N
 - D071N
 - D072N
 - D073N
 - D074N
 - D114N
 - D115N
 - D116N
 - D122N
 - D125N
 - D131N
 - D132N
 - D134N
 - D143N
 - D145N
 - D152N
 - D155N
 - D156N
 - D162N
 - D165N
 - D172N
 - D174N
 - D205N
 - D212N
 - D223N
 - D225N
 - D226N
 - D243N
 - D244N
 - D245N
 - D246N
 - D251N
 - D252N
 - D255N
 - D261N
 - D263N
 - D265N
 - D266N
 - D271N
 - D274N
 - D306N
 - D311N
 - D315N
 - D325N
 - D331N
 - D332N
 - D343N
 - D346N
 - D351N
 - D356N
 - D364N
 - D365N
 - D371N
 - D411N
 - D412N
 - D413N
 - D423N
 - D431N
 - D432N
 - D445N
 - D446N
 - D452N
 - D454N
 - D455N
 - D462N
 - D464N
 - D465N
 - D466N
 - D503N
 - D506N
 - D516N
 - D523N
 - D526N
 - D532N
 - D546N
 - D564N
 - D606N
 - D612N
 - D624N
 - D627N
 - D631N
 - D632N
 - D645N
 - D654N
 - D662N
 - D664N
 - D703N
 - D712N
 - D723N
 - D731N
 - D732N
 - D734N
 - D743N
 - D754N
*Ace Hardware
- 464.5000 MHz - 67.0 Hz PL
 - 464.5500 MHz - 67.0 Hz PL
 - 467.9000 MHz - 85.4 Hz PL
*American Eagle
- 461.0625 MHz - 67.0 Hz PL
 - 461.3625 MHz - 67.0 Hz PL
 - 466.3375 MHz - 67.0 Hz PL
 - 467.7625 MHz - 67.0 Hz PL
 - 467.8500 MHz - 67.0 Hz PL
 - 467.8750 MHz - 67.0 Hz PL
 - 469.5625 MHz - 67.0 Hz PL
*Anthropologie
- 467.8750 MHz 192.8 Hz PL
*Apple
The Apple Store
- 461.1875 MHz - 67.0 Hz PL
 - 461.1875 MHz - 85.4 Hz PL
 - 462.8625 MHz - 167.9 Hz PL
 - 467.8500 MHz - 79.7 Hz PL
 - 467.8750 MHz - 85.4 Hz PL
 - 467.9000 MHz - 203.5 Hz PL
 - 467.9250 MHz - 156.7 Hz PL
*Ashley Home Store
- 462.8125 MHz 67.0 Hz PL
 - 462.8625 MHz 67.0 Hz PL
*Bass Pro
- 451.5875 MHz 073 DPL
 - 464.5000 MHz 466 DPL
 - 468.9375 MHz 703 DPL
 - 469.6000 MHz 606 DPL
 - 469.8875 MHz 703 DPL
- 461.0375 MHz 445 DPL
 - 467.7625 MHz 743 DPL
 - 467.9000 MHz 743 DPL
*BJ's Wholesale Club
- 469.4875 MHz - 413 DPL
*Buffalo Wild Wings
*CarMax
- 462.5750 MHz - 026 DPL
 - 462.6250 MHz - 127.3 Hz PL
 - 462.6250 MHz - 026 DPL
 - 462.6750 MHz - 071 DPL
 - 462.6750 MHz - 606 DPL
 - 462.7250 MHz - 136.5 Hz PL
 - 462.7250 MHz - 026 DPL
 - 464.3250 MHz - 026 DPL
 - 464.8250 MHz - 026 DPL
 - 467.8500 MHz - 071 DPL
 - 467.8750 MHz - 026 DPL
 - 467.8750 MHz - 071 DPL
 - 467.9250 MHz - 071 DPL
*Chick-Fil-A
- 462.5500 MHz - 127.3 Hz PL
 - 462.5625 MHz - 67.0 Hz PL
 - 462.5750 MHz - 654 DPL
 - 462.5875 MHz - 118.8 Hz PL
 - 462.5875 MHz - 026 DPL
 - 462.6000 MHz - 455 DPL
 - 462.6125 MHz - 127.3 Hz PL
 - 462.6375 MHz - 131.8 Hz PL
 - 462.6500 MHz - 351 DPL
 - 462.6625 MHz - 88.5 Hz PL
 - 462.6625 MHz - 136.5 Hz PL
 - 462.6875 MHz - 141.3 Hz PL
 - 462.7000 MHz - 192.8 Hz PL
 - 462.7000 MHz - 155 DPL
 - 462.7125 MHz - 146.2 Hz PL
 - 462.7250 MHz - 252 DPL
 - 462.7250 MHz - 462 DPL
 - 467.5625 MHz - 243 DPL
 - 467.5875 MHz - 032 DPL
 - 467.6125 MHz - 047 DPL
 - 467.6375 MHz - 051 DPL
 - 467.6625 MHz - 053 DPL
 - 467.6875 MHz - 065 DPL
 - 467.7125 MHz - 116 DPL
*Costco
Some Costco locations are using FRS radios in place of or in addition to the frequencies listed below.  Confirmed FRS channels and tones codes include:
- 462.5500 MHz - 123.0 Hz PL
 - 462.6000 MHz - 241.8 Hz PL
 - 462.7250 MHz - 250.3 Hz PL
Costco stores are (allegedly) in the process of upgrading from the VHF to UHF, especially when interference from other stores using the popular VHF frequencies (including 154.570 MHz and 154.600 MHz) is an issue.  However, Costco retains extensive VHF systems and numerous licenses with dozens of VHF frequencies authorized in hundreds of locations.
- VHF:
- 151.6550 MHz
 - 151.6850 MHz
 - 151.7150 MHz
 - 151.7450 MHz
 - 151.7750 MHz
 - 151.8650 MHz
 - 151.8950 MHz
 - 151.9250 MHz
 - 151.9550 MHz
 - 151.9850 MHz
 - 152.8850 MHz
 - 152.9150 MHz
 - 153.0050 MHz
 - 154.4900 MHz
 - 154.5150 MHz
 - 154.5400 MHz
- 468.2125 MHz
 - 468.2625 MHz
 - 468.3125 MHz
 - 468.3625 MHz
 - 468.4125 MHz
 - 468.4625 MHz
 - 468.5125 MHz
 - 468.5625 MHz
 - 468.6125 MHz
 - 468.6625 MHz
- 451.4125 MHz
 - 451.5125 MHz
 - 451.5375 MHz
 - 451.5875 MHz
 - 451.6375 MHz
 - 451.6625 MHz
 - 451.6875 MHz
 - 452.7625 MHz
 - 456.4125 MHz
 - 456.5125 MHz
 - 456.6125 MHz
 - 456.6875 MHz
 - 457.7625 MHz
 - 467.7625 MHz
 - 467.8125 MHz
 - 467.8500 MHz
 - 467.8750 MHz
 - 467.9000 MHz
 - 467.9250 MHz
- 467.8500 MHz Channel 1
 - 467.8750 MHz Channel 2
 - 467.9000 MHz Channel 3
 - 467.9250 MHz Channel 4
- 468.6625 MHz - 127.3 Hz PL
- 467.8500 MHz
 - 467.8750 MHz
 - 467.9000 MHz
 - 467.9250 MHz
*DSW
- 450.0000 MHz - 88.5 Hz PL
 - 456.8250 MHz - 127.3 Hz PL
 - 457.5750 MHz - 107.2 Hz PL
 - 461.0375 MHz - 023 DPL
 - 461.1125 MHz - 025 DPL
 - 462.4250 MHz - 103.5 Hz PL
 - 462.5250 MHz - 114.8 Hz PL
 - 464.5000 MHz - 023 DPL
 - 466.0875 MHz - 464 DPL
 - 467.8375 MHz - 88.5 Hz PL
 - 467.9000 MHz - 145 DPL
 - 469.5000 MHz - 023 DPL
- 467.7625 MHz - 205 DPL
 - 467.8125 MHz - 205 DPL
 - 467.8500 MHz - 205 DPL
 - 467.9250 MHz - 205 DPL
*H & M
- 466.2875 MHz - 155 DPL
 - 467.1375 MHz - 155 DPL
 - 468.8375 MHz - 155 DPL
 - 469.0000 MHz - 103.5 Hz PL
 - 469.7625 MHz - 155 DPL
 - 467.7625 MHz - 107.2 Hz PL
 - 467.8125 MHz - 346 DPL
 - 467.8500 MHz - 343 DPL
 - 467.8500 MHz - 631 DPL
 - 467.8750 MHz - 343 DPL
 - 467.8750 MHz - 411 DPL
 - 467.9000 MHz - 343 DPL
 - 467.9000 MHz - 346 DPL
 - 467.9250 MHz - 67.0 Hz PL
 - 467.9250 MHz - 343 DPL
*Hard Rock Cafe
- 462.8875 MHz - 205 DPL
 - 467.8375 MHz - 205 DPL
- 467.8500 MHz 146.2 Hz PL
- 464.5000 MHz 186.2 Hz PL
 - 464.5500 MHz 186.2 Hz PL
 - 469.2625 MHz 186.2 Hz PL
 - 469.5000 MHz 186.2 Hz PL
 - 469.5500 MHz 186.2 Hz PL
 - 467.8750 MHz - 100.0 Hz PL
 - 467.9000 MHz - 100.0 Hz PL
 - 467.9250 MHz - 100.0 Hz PL
*Loft
- 466.0375 MHz - 94.8 Hz PL
 - 467.9000 MHz - 265 DPL
- 151.6250 MHz - 110.9 Hz PL
 - 151.8200 MHz - 110.9 Hz PL
 - 151.8800 MHz - 110.9 Hz PL
 - 151.9400 MHz - 110.9 Hz PL
 - 151.9550 MHz - 110.9 Hz PL
 - 154.4900 MHz - 110.9 Hz PL
 - 154.5700 MHz - 110.9 Hz PL
 - 154.6000 MHz - 110.9 Hz PL
- 461.0375 MHz
 - 461.1125 MHz
 - 461.2125 MHz
 - 462.7625 MHz
 - 462.8125 MHz
 - 464.5375 MHz
 - 464.5625 MHz
 - 466.0375 MHz
 - 466.1125 MHz
 - 466.1375 MHz
 - 469.4875 MHz
 - 469.5375 MHz
*Northern Tool + Equipment
- 462.5500 MHz 71.9 Hz
 - 462.6000 MHz 241.8 Hz
 - 462.6500 MHz 218.1 Hz
 - 462.7000 MHz 118.8 Hz
 - 462.7000 MHz 192.8 Hz
- 467.9000 MHz - 131 DPL
- 464.5000 MHz - 162.2 Hz PL
 - 464.5500 MHz - 162.2 Hz PL
*Pottery Barn
- 151.625 MHz - 97.4 Hz PL
 - 151.700 MHz - 71.9 Hz PL
 - 151.700 MHz - 79.7 Hz PL
*Regal Cinemas
- 464.3250 MHz - 100.0 Hz PL
 - 464.8250 MHz - 100.0 Hz PL
 - 464.8750 MHz - 100.0 Hz PL
*Sears
- 461.1625 MHz - 413 DPL
 - 464.5250 MHz - 131.8 Hz PL
 - 464.5500 MHz - 118.8 Hz PL
 - 468.4875 MHz - 103.5 Hz PL
- 464.5500 MHz - 413 DPL
- 467.9000 MHz - 225.7 Hz PL
 - 467.9250 MHz - 225.7 Hz PL
- 151.6250 MHz 179.9 Hz PL
 - 151.9550 MHz 179.9 Hz PL
 - 151.9250 MHz 506 DPL
 - 151.8950 MHz 506 DPL
*Texas Roadhouse
- 467.9250 MHz 67.0 Hz PL
*Victoria’s Secret
- 467.8500 MHz - 743 DPL
 - 467.9000 MHz - 743 DPL
 - 467.9250 MHz - 743 DPL
 - 469.4875 MHz - 743 DPL
 - 469.5375 MHz - 743 DPL
- 151.5050 MHz
 - 151.6250 MHz
 - 151.7000 MHz
 - 151.8200 MHz
 - 151.9250 MHz
 - 154.5700 MHz
 - 154.6000 MHz
 - 158.4000 MHz
 - 451.8000 MHz
 - 451.8125 MHz
 - 456.8125 MHz
- 154.5700 MHz - Primary
 - 154.6000 MHz - Primary
 - 151.8200 MHz
 - 151.8800 MHz
 - 151.9400 MHz
 - 151.6250 MHz
 - 151.7600 MHz
 - 151.7750 MHz
 - 151.8200 MHz
 - 151.8350 MHz
 - 151.8650 MHz
 - 151.9550 MHz
- 461.0375 MHz 172 DPL
 - 461.0875 MHz 223 DPL
 - 461.1125 MHz 172 DPL
 - 461.1875 MHz 172 DPL
 - 461.3625 MHz 172 DPL
 - 464.5000 MHz 172 DPL
 - 464.5500 MHz 172 DPL
 - 464.5500 MHz 223 DPL
 - 469.5000 MHz 172 DPL
*Whole Foods
- 464.5500 MHz 466 DPL
 - 467.8500 MHz 67.0 Hz PL
 - 467.9000 MHz 67.0 Hz PL
