| Frequency (MHz) | Remarks/Restrictions on usage | |
| 25.020 MHz | Petroleum companies | |
| 25.040 MHz | Primarily available for oil spill containment and cleanup, other uses secondary | |
| 25.060 MHz | Petroleum exploration | |
| 25.080 MHz | Primarily available for oil spill containment and cleanup, other uses secondary | |
| 25.100 MHz | Petroleum companies | |
| 25.120 MHz | Secondary to HF marine mobile | |
| 25.140 MHz | Petroleum companies | |
| 25.160 MHz | ||
| 25.180 MHz | Petroleum companies | |
| 25.200 MHz | ||
| 25.220 MHz | Petroleum companies | |
| 25.240 MHz | ||
| 25.260 MHz | Petroleum companies | |
| 25.280 MHz | ||
| 25.300 MHz | Petroleum companies | |
| 25.320 MHz | ||
| 27.430 MHz | ||
| 27.450 MHz | ||
| 27.470 MHz | ||
| 27.490 MHz | Itinerant use only | |
| 27.510 MHz | Mobile use only, 2 watts maximum power | |
| 27.530 MHz | Mobile use only, 2 watts maximum power | |
| 29.710 MHz | ||
| 29.730 MHz | ||
| 29.750 MHz | ||
| 29.770 MHz | ||
| 29.790 MHz | ||
| 30.580 MHz | ||
| 30.600 MHz | ||
| 30.620 MHz | ||
| 30.640 MHz | ||
| 30.660 MHz | ||
| 30.680 MHz | ||
| 30.700 MHz | ||
| 30.720 MHz | ||
| 30.740 MHz | ||
| 30.760 MHz | ||
| 30.780 MHz | ||
| 30.800 MHz | ||
| 30.820 MHz | ||
| 30.840 MHz | Mobile use only, 2 watts maximum power | |
| 30.860 MHz | Shared with Public Safety | |
| 30.880 MHz | ||
| 30.900 MHz | Shared with Public Safety | |
| 30.920 MHz | ||
| 30.940 MHz | Shared with Public Safety | |
| 30.960 MHz | ||
| 30.980 MHz | Shared with Public Safety | |
| 31.000 MHz | ||
| 31.020 MHz | Shared with Public Safety | |
| 31.040 MHz | ||
| 31.060 MHz | Shared with Public Safety | |
| 31.080 MHz | ||
| 31.100 MHz | Shared with Public Safety | |
| 31.120 MHz | ||
| 31.140 MHz | Shared with Public Safety | |
| 31.160 MHz | ||
| 31.200 MHz | ||
| 31.240 MHz | ||
| 31.280 MHz | ||
| 31.320 MHz | ||
| 31.360 MHz | ||
| 31.400 MHz | ||
| 31.440 MHz | ||
| 31.480 MHz | ||
| 31.520 MHz | ||
| 31.560 MHz | ||
| 31.600 MHz | ||
| 31.640 MHz | ||
| 31.680 MHz | ||
| 31.720 MHz | ||
| 31.760 MHz | ||
| 31.800 MHz | ||
| 31.840 MHz | ||
| 31.880 MHz | ||
| 31.920 MHz | ||
| 31.960 MHz | ||
| 33.120 MHz | Mobile use only, 2 watts maximum power | |
| 33.140 MHz | Mobile use only, 2 watts maximum power | |
| 33.160 MHz | ||
| 33.180 MHz | ||
| 33.200 MHz | ||
| 33.220 MHz | ||
| 33.240 MHz | ||
| 33.260 MHz | ||
| 33.280 MHz | ||
| 33.300 MHz | ||
| 33.320 MHz | ||
| 33.340 MHz | ||
| 33.360 MHz | ||
| 33.380 MHz | ||
| 33.400 MHz | Mobile use only, 1 watt maximum power | |
| 35.020 MHz | Mobile use only, 2 watts maximum power, shared with Public Safety | |
| 35.040 MHz | Itinerant use only | |
| 35.060 MHz | ||
| 35.080 MHz | ||
| 35.100 MHz | ||
| 35.120 MHz | ||
| 35.160 MHz | ||
| 35.180 MHz | Shared with on-site paging | |
| 35.200 MHz | ||
| 35.220 MHz | ||
| 35.240 MHz | ||
| 35.260 MHz | Old IMTS Base Channel ZO (paired with 43.26 MHz) | |
| 35.280 MHz | ||
| 35.300 MHz | Old IMTS Base Channel ZF (paired with 43.30 MHz) | |
| 35.320 MHz | ||
| 35.340 MHz | Old IMTS Base Channel ZH (paired with 43.34 MHz) | |
| 35.360 MHz | ||
| 35.380 MHz | Old IMTS Base Channel ZM (paired with 43.38 MHz) | |
| 35.400 MHz | ||
| 35.420 MHz | Old IMTS Base Channel ZA (paired with 43.42 MHz) | |
| 35.440 MHz | ||
| 35.460 MHz | Old IMTS Base Channel ZY (paired with 43.46 MHz) | |
| 35.480 MHz | ||
| 35.500 MHz | Old IMTS Base Channel ZR (paired with 43.50 MHz) | |
| 35.520 MHz | ||
| 35.540 MHz | Old IMTS Base Channel ZB (paired with 43.54 MHz) | |
| 35.560 MHz | ||
| 35.580 MHz | ||
| 35.600 MHz | ||
| 35.620 MHz | Old IMTS Base Channel ZW (paired with 43.62 MHz) | |
| 35.640 MHz | Paging only - may be used for on-site hospital paging | |
| 35.660 MHz | Old IMTS Base Channel ZL (paired with 43.66 MHz) | |
| 35.680 MHz | Paging only - may be used for on-site hospital paging | |
| 35.700 MHz | ||
| 35.720 MHz | ||
| 35.740 MHz | ||
| 35.760 MHz | ||
| 35.780 MHz | ||
| 35.820 MHz | ||
| 35.840 MHz | ||
| 35.860 MHz | ||
| 35.880 MHz | ||
| 35.900 MHz | ||
| 35.920 MHz | ||
| 35.940 MHz | ||
| 35.960 MHz | ||
| 35.980 MHz | ||
| 36.250 MHz | Oil companies, oil spill cleanup operations, shared with federal/military users, may be used as repeater input/output if paired with 41.71 MHz | |
| 37.440 MHz | ||
| 37.460 MHz | ||
| 37.480 MHz | ||
| 37.500 MHz | ||
| 37.520 MHz | ||
| 37.520 MHz | ||
| 37.560 MHz | ||
| 37.580 MHz | ||
| 37.600 MHz | Designated for interconnection of public utility systems | |
| 37.620 MHz | ||
| 37.640 MHz | ||
| 37.660 MHz | ||
| 37.680 MHz | ||
| 37.700 MHz | ||
| 37.720 MHz | ||
| 37.760 MHz | ||
| 37.780 MHz | ||
| 37.800 MHz | ||
| 37.820 MHz | ||
| 37.840 MHz | ||
| 37.860 MHz | ||
| 37.880 MHz | ||
| 40.670 MHz | SNOTEL Weather Telemetry system (Nationwide, data bursts often heard during VHF low band openings) | |
| 41.710 MHz | Oil companies, oil spill cleanup operations, shared with federal/military users, may be used as repeater input/output if paired with 36.25 MHz | |
| 42.960 MHz | ||
| 42.980 MHz | Mobile use only, 2 watts maximum power | |
| 43.000 MHz | ||
| 43.020 MHz | ||
| 43.040 MHz | Itinerant use only | |
| 43.060 MHz | ||
| 43.080 MHz | ||
| 43.100 MHz | ||
| 43.120 MHz | ||
| 43.140 MHz | ||
| 43.160 MHz | Mobile use only | |
| 43.180 MHz | ||
| 43.200 MHz | ||
| 43.260 MHz | Old IMTS Mobile Channel ZO (paired with 35.26 MHz) | |
| 43.280 MHz | ||
| 43.300 MHz | Old IMTS Mobile Channel ZF (paired with 35.30 MHz) | |
| 43.320 MHz | ||
| 43.340 MHz | Old IMTS Mobile Channel ZH (paired with 35.34 MHz) | |
| 43.360 MHz | ||
| 43.380 MHz | Old IMTS Mobile Channel ZM (paired with 35.38 MHz) | |
| 43.400 MHz | ||
| 43.420 MHz | Old IMTS Mobile Channel ZA (paired with 35.42 MHz) | |
| 43.440 MHz | ||
| 43.460 MHz | Old IMTS Base Channel ZY (paired with 35.46 MHz) | |
| 43.480 MHz | ||
| 43.500 MHz | Old IMTS Mobile Channel ZY (paired with 35.50 MHz) | |
| 43.520 MHz | ||
| 43.540 MHz | Old IMTS Mobile Channel ZR (paired with 35.54 MHz) | |
| 43.560 MHz | Also used for paging - including on site paging | |
| 43.580 MHz | ||
| 43.600 MHz | ||
| 43.620 MHz | Old IMTS Mobile Channel ZW (paired with 35.62 MHz) | |
| 43.640 MHz | ||
| 43.660 MHz | Old IMTS Mobile Channel ZL (paired with 35.66 MHz) | |
| 43.680 MHz | ||
| 43.700 MHz | ||
| 43.720 MHz | shared with low power cordless phones (base - paired with 48.76 MHz) | |
| 43.740 MHz | shared with low power cordless phones (base - paired with 48.84 MHz) | |
| 43.760 MHz | ||
| 43.780 MHz | ||
| 43.800 MHz | ||
| 43.820 MHz | shared with low power cordless phones (base - paired with 48.86 MHz) | |
| 43.840 MHz | shared with low power cordless phones (base - paired with 48.92 MHz) | |
| 43.860 MHz | ||
| 43.880 MHz | ||
| 43.900 MHz | ||
| 43.920 MHz | shared with low power cordless phones (base - paired with 49.00 MHz) | |
| 43.940 MHz | ||
| 43.960 MHz | shared with low power cordless phones (base - paired with 49.08 MHz) | |
| 43.980 MHz | ||
| 44.000 MHz | ||
| 44.020 MHz | ||
| 44.040 MHz | ||
| 44.060 MHz | ||
| 44.080 MHz | ||
| 44.100 MHz | also used for meteor burst communications (Alaska only) | |
| 44.120 MHz | shared with low power cordless phones (base - paired with 49.10 MHz) | |
| 44.140 MHz | ||
| 44.160 MHz | shared with low power cordless phones (base - paired with 49.16 MHz) | |
| 44.180 MHz | shared with low power cordless phones (base - paired with 49.20 MHz) | |
| 44.200 MHz | shared with low power cordless phones (base - paired with 49.24 MHz) | |
| 44.220 MHz | ||
| 44.240 MHz | ||
| 44.260 MHz | ||
| 44.280 MHz | ||
| 44.300 MHz | ||
| 44.320 MHz | shared with low power cordless phones (base - paired with 49.28 MHz) | |
| 44.340 MHz | ||
| 44.360 MHz | shared with low power cordless phones (base - paired with 49.36 MHz) | |
| 44.380 MHz | ||
| 44.400 MHz | shared with low power cordless phones (base - paired with 49.40 MHz) | |
| 44.420 MHz | ||
| 44.440 MHz | ||
| 44.460 MHz | shared with low power cordless phones (base - paired with 49.48 MHz) | |
| 44.480 MHz | shared with low power cordless phones (base - paired with 49.50 MHz) | |
| 44.500 MHz | ||
| 44.520 MHz | ||
| 44.540 MHz | ||
| 44.560 MHz | ||
| 44.580 MHz | BNSF Railroad telemetry datalink system (good band opening indicator) | |
| 44.600 MHz | ||
| 47.440 MHz | ||
| 47.480 MHz | ||
| 47.520 MHz | ||
| 47.560 MHz | ||
| 47.600 MHz | ||
| 47.640 MHz | ||
| 47.680 MHz | ||
| 47.700 MHz | ||
| 47.720 MHz | ||
| 47.740 MHz | ||
| 47.760 MHz | ||
| 47.780 MHz | ||
| 47.800 MHz | ||
| 47.820 MHz | ||
| 47.840 MHz | ||
| 47.860 MHz | ||
| 47.880 MHz | ||
| 47.900 MHz | ||
| 47.920 MHz | ||
| 47.940 MHz | ||
| 47.960 MHz | ||
| 47.980 MHz | ||
| 48.000 MHz | ||
| 48.020 MHz | ||
| 48.040 MHz | ||
| 48.060 MHz | ||
| 48.080 MHz | ||
| 48.100 MHz | ||
| 48.120 MHz | ||
| 48.140 MHz | ||
| 48.160 MHz | ||
| 48.180 MHz | ||
| 48.200 MHz | ||
| 48.220 MHz | ||
| 48.240 MHz | ||
| 48.260 MHz | ||
| 48.280 MHz | ||
| 48.300 MHz | ||
| 48.320 MHz | ||
| 48.340 MHz | ||
| 48.360 MHz | ||
| 48.380 MHz | ||
| 48.400 MHz | ||
| 48.420 MHz | ||
| 48.440 MHz | ||
| 48.480 MHz | ||
| 48.500 MHz | ||
| 48.520 MHz | ||
| 48.540 MHz | ||
| 48.560 MHz | ||
| 48.580 MHz | ||
| 48.600 MHz | ||
| 48.620 MHz | ||
| 48.640 MHz | ||
| 48.660 MHz | ||
| 48.680 MHz | ||
| 48.700 MHz | ||
| 48.720 MHz | ||
| 48.740 MHz | ||
| 48.760 MHz | ||
| 48.780 MHz | ||
| 48.800 MHz | ||
| 48.820 MHz | ||
| 48.840 MHz | ||
| 48.860 MHz | ||
| 48.880 MHz | ||
| 48.900 MHz | ||
| 48.920 MHz | ||
| 48.940 MHz | ||
| 48.960 MHz | ||
| 48.980 MHz | ||
| 49.000 MHz | ||
| 49.020 MHz | ||
| 49.040 MHz | ||
| 49.060 MHz | ||
| 49.080 MHz | ||
| 49.100 MHz | ||
| 49.120 MHz | ||
| 49.140 MHz | ||
| 49.160 MHz | ||
| 49.180 MHz | ||
| 49.200 MHz | ||
| 49.220 MHz | ||
| 49.240 MHz | ||
| 49.260 MHz | ||
| 49.280 MHz | ||
| 49.300 MHz | ||
| 49.320 MHz | ||
| 49.340 MHz | ||
| 49.360 MHz | ||
| 49.380 MHz | ||
| 49.400 MHz | ||
| 49.420 MHz | ||
| 49.440 MHz | ||
| 49.460 MHz | ||
| 49.480 MHz | ||
| 49.500 MHz | ||
| 49.520 MHz | ||
| 49.540 MHz | ||
| 49.560 MHz | ||
| 49.580 MHz |
| Frequency (MHz) |
| 72.020 MHz |
| 72.040 MHz |
| 72.060 MHz |
| 72.080 MHz |
| 72.100 MHz |
| 72.120 MHz |
| 72.140 MHz |
| 72.160 MHz |
| 72.180 MHz |
| 72.200 MHz |
| 72.220 MHz |
| 72.240 MHz |
| 72.260 MHz |
| 72.280 MHz |
| 72.300 MHz |
| 72.320 MHz |
| 72.340 MHz |
| 72.360 MHz |
| 72.380 MHz |
| 72.400 MHz |
| 72.420 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.460 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.500 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.540 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.580 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.620 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.640 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.660 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.680 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.700 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.720 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.740 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.760 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.780 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.800 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.820 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.840 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.860 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.880 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.900 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.920 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.940 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.960 MHz - operational fixed service, also assigned to maritime fixed service |
| 72.980 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.420 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.460 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.500 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.540 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.580 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.620 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.640 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.660 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.680 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.700 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.720 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.740 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.760 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.780 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.800 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.820 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.840 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.860 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.880 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.900 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.920 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.940 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.960 MHz - operational fixed service, also assigned to maritime fixed service |
| 75.980 MHz - operational fixed service, also assigned to maritime fixed service |
| 150.8225 MHz | |
| 150.8375 MHz | |
| 152.4725 MHz | |
| 154.4825 MHz | |
| 154.490 MHz | |
| 154.4975 MHz | |
| 154.515 MHz | |
| 154.540 MHz | |
| 154.5475 MHz | |
| 157.7325 MHz | |
| 158.4525 MHz | |
| 158.460 MHz | |
| 173.2375 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.250 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.2625 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.275 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.2875 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.300 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.3125 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.325 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.3375 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.350 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.3625 MHz | Shared with public safety fixed point to point systems (operational fixed, FX, FXO and FX2 station classes) |
| 173.390 MHz | |
UHF Band 406-413 MHz
- Group A1 - Simplex operations or paired operations. If the system uses a pair (5 MHz offset), the fixed station or base station operates on the low side (451 MHz, 452 MHz, 462 MHz) and the mobile / portable stations operate on the high side (456 MHz, 457 MHz, 467 MHz) as per UHF band plan. 20 watt ERP power limit for fixed stations / base stations. 6 watt ERP power limit for portable or mobile stations. Fixed station antennas may be up to 75 feet above the ground. Voice users are primary users, non-voice users are secondary. Single-frequency simplex systems are very common and may be found on the low or high side frequencies. Group A1 frequencies are only available for assignment within an 80 km radius (50 mile radius) of metropolitan areas.
- Group A2 - Simplex operations or paired operations. If the system uses a pair (5 MHz offset), the fixed station or base station operates on the low side (451 MHz, 452 MHz, 462 MHz) and the mobile / portable stations operate on the high side (456 MHz, 457 MHz, 467 MHz) as per UHF band plan. 20 watt ERP power limit for fixed stations / base stations. 6 watt ERP power limit for portable or mobile stations. Fixed station antennas may be up to 75 feet above the ground. Voice users are primary users, non-voice users are secondary. Single-frequency simplex systems are very common and may be found on the low or high side frequencies.
- Group B - Data and telemetry (including telecommand - remote control) are the primary users of these frequencies. Voice is permitted, but only on a secondary basis to non-voice uses. 6 watt ERP power limit for fixed stations, 2 watt ERP power limit for mobile and portable stations. Base stations (fixed stations) may be licensed as mobile stations. Fixed station antennas may be up to 20 feet above ground.
- Group C - Telemetry / data (non-voice) and voice systems, shared. 6 watt ERP power limit for fixed stations, 2 watt ERP power limit for mobile and portable stations. Fixed station antennas may be up to 20 feet above ground.
- Group D - Alarm system telemetry, wireless links back to central office control station. 2 watt power limit, antenna at the central alarm control station may be up to 20 feet above ground.
- 451.18125 MHz
- 451.1875 MHz
- 451.19375 MHz
- 451.28125 MHz
- 451.2875 MHz
- 451.29375 MHz
- 451.30625 MHz
- 451.3125 MHz
- 451.31875 MHz
- 451.35625 MHz
- 451.3625 MHz
- 451.36875 MHz
- 451.38125 MHz
- 451.3875 MHz
- 451.39375 MHz
- 451.40625 MHz
- 451.41875 MHz
- 451.45625 MHz
- 451.4625 MHz
- 451.46875 MHz
- 451.48125 MHz
- 451.4875 MHz
- 451.49375 MHz
- 451.50625 MHz
- 451.5125 MHz
- 451.51875 MHz
- 451.55625 MHz
- 451.5625 MHz
- 451.56875 MHz
- 451.58125 MHz
- 451.5875 MHz
- 451.59375 MHz
- 451.60625 MHz
- 451.6125 MHz
- 451.61875 MHz
- 451.65625 MHz
- 451.6625 MHz
- 451.66875 MHz
- 451.68125 MHz
- 451.6875 MHz
- 451.69375 MHz
- 451.70625 MHz
- 451.7125 MHz
- 451.71875 MHz
- 451.73125 MHz
- 451.7375 MHz
- 451.74375 MHz
- 451.75625 MHz
- 451.7625 MHz
- 451.76875 MHz
- 452.03125 MHz
- 452.0375 MHz
- 452.04375 MHz
- 452.05625 MHz
- 452.0625 MHz
- 452.06875 MHz
- 452.08125 MHz
- 452.0875 MHz
- 452.09375 MHz
- 452.10625 MHz
- 452.1125 MHz
- 452.11875 MHz
- 452.13125 MHz
- 452.1375 MHz
- 452.14375 MHz
- 452.15625 MHz
- 452.1625 MHz
- 452.16875 MHz
- 452.18125 MHz
- 452.1875 MHz
- 452.19375 MHz
- 452.28125 MHz
- 452.2875 MHz
- 452.29375 MHz
- 452.48125 MHz
- 452.4875 MHz
- 452.49375 MHz
- 452.53125 MHz
- 452.5375 MHz
- 452.54375 MHz
- 452.63125 MHz
- 452.6375 MHz
- 452.64375 MHz
- 452.65625 MHz
- 452.6625 MHz
- 452.66875 MHz
- 452.68125 MHz
- 452.6875 MHz
- 452.69375 MHz
- 452.70625 MHz
- 452.7125 MHz
- 452.71875 MHz
- 452.78125 MHz
- 452.7875 MHz
- 452.79375 MHz
- 452.80625 MHz
- 452.8125 MHz
- 452.81875 MHz
- 452.83125 MHz
- 452.8375 MHz
- 452.84375 MHz
- 452.88125 MHz
- 452.8875 MHz
- 452.89375 MHz
- 452.98125 MHz
- 452.9875 MHz
- 452.99375 MHz
- 456.18125 MHz
- 456.1875 MHz
- 456.19375 MHz
- 456.28125 MHz
- 456.2875 MHz
- 456.29375 MHz
- 456.30625 MHz
- 456.3125 MHz
- 456.31875 MHz
- 456.35625 MHz
- 456.3625 MHz
- 456.36875 MHz
- 456.38125 MHz
- 456.3875 MHz
- 456.39375 MHz
- 456.40625 MHz
- 456.41875 MHz
- 456.45625 MHz
- 456.4625 MHz
- 456.46875 MHz
- 456.48125 MHz
- 456.4875 MHz
- 456.49375 MHz
- 456.50625 MHz
- 456.5125 MHz
- 456.51875 MHz
- 456.55625 MHz
- 456.5625 MHz
- 456.56875 MHz
- 456.58125 MHz
- 456.5875 MHz
- 456.59375 MHz
- 456.60625 MHz
- 456.6125 MHz
- 456.61875 MHz
- 456.65625 MHz
- 456.6625 MHz
- 456.66875 MHz
- 456.68125 MHz
- 456.6875 MHz
- 456.69375 MHz
- 456.70625 MHz
- 456.7125 MHz
- 456.71875 MHz
- 456.73125 MHz
- 456.7375 MHz
- 456.74375 MHz
- 456.75625 MHz
- 456.7625 MHz
- 456.76875 MHz
- 457.03125 MHz
- 457.0375 MHz
- 457.04375 MHz
- 457.05625 MHz
- 457.0625 MHz
- 457.06875 MHz
- 457.08125 MHz
- 457.0875 MHz
- 457.09375 MHz
- 457.10625 MHz
- 457.1125 MHz
- 457.11875 MHz
- 457.13125 MHz
- 457.1375 MHz
- 457.14375 MHz
- 457.15625 MHz
- 457.1625 MHz
- 457.16875 MHz
- 457.18125 MHz
- 457.1875 MHz
- 457.19375 MHz
- 457.28125 MHz
- 457.2875 MHz
- 457.29375 MHz
- 457.48125 MHz
- 457.4875 MHz
- 457.49375 MHz
- 457.63125 MHz
- 457.6375 MHz
- 457.64375 MHz
- 457.65625 MHz
- 457.6625 MHz
- 457.66875 MHz
- 457.68125 MHz
- 457.6875 MHz
- 457.69375 MHz
- 457.70625 MHz
- 457.7125 MHz
- 457.71875 MHz
- 457.78125 MHz
- 457.7875 MHz
- 457.79375 MHz
- 457.80625 MHz
- 457.8125 MHz
- 457.81875 MHz
- 457.83125 MHz
- 457.8375 MHz
- 457.84375 MHz
- 457.88125 MHz
- 457.8875 MHz
- 457.89375 MHz
- 457.98125 MHz
- 457.9875 MHz
- 457.99375 MHz
- 462.18125 MHz
- 462.1875 MHz
- 462.19375 MHz
- 462.45625 MHz
- 462.4625 MHz
- 462.46875 MHz
- 462.48125 MHz
- 462.4875 MHz
- 462.49375 MHz
- 462.50625 MHz
- 462.5125 MHz
- 462.51875 MHz
- 467.18125 MHz
- 467.1875 MHz
- 467.19375 MHz
- 467.45625 MHz
- 467.4625 MHz
- 467.46875 MHz
- 467.48125 MHz
- 467.4875 MHz
- 467.49375 MHz
- 467.50625 MHz
- 467.5125 MHz
- 467.51875 MHz
- 451.23125 MHz
- 451.2375 MHz
- 451.24375 MHz
- 451.33125 MHz
- 451.3375 MHz
- 451.34375 MHz
- 451.43125 MHz
- 451.4375 MHz
- 451.44375 MHz
- 451.53125 MHz
- 451.5375 MHz
- 451.54375 MHz
- 451.63125 MHz
- 451.6375 MHz
- 451.64375 MHz
- 452.30625 MHz
- 452.3125 MHz
- 452.31875 MHz
- 452.40625 MHz
- 452.4125 MHz
- 452.41875 MHz
- 452.50625 MHz
- 452.5125 MHz
- 452.51875 MHz
- 452.75625 MHz
- 452.7625 MHz
- 452.76875 MHz
- 452.85625 MHz
- 452.8625 MHz
- 452.86875 MHz
- 456.23125 MHz
- 456.2375 MHz
- 456.24375 MHz
- 456.33125 MHz
- 456.3375 MHz
- 456.34375 MHz
- 456.43125 MHz
- 456.4375 MHz
- 456.44375 MHz
- 456.53125 MHz
- 456.5375 MHz
- 456.54375 MHz
- 456.63125 MHz
- 456.6375 MHz
- 456.64375 MHz
- 457.30625 MHz
- 457.3125 MHz
- 457.31875 MHz
- 457.40625 MHz
- 457.4125 MHz
- 457.41875 MHz
- 457.50625 MHz
- 457.5125 MHz
- 457.51875 MHz
- 457.75625 MHz
- 457.7625 MHz
- 457.76875 MHz
- 457.85625 MHz
- 457.8625 MHz
- 457.86875 MHz
- 462.20625 MHz
- 462.2125 MHz
- 462.21875 MHz
- 462.23125 MHz
- 462.2375 MHz
- 462.24375 MHz
- 462.25625 MHz
- 462.2625 MHz
- 462.26875 MHz
- 462.28125 MHz
- 462.2875 MHz
- 462.29375 MHz
- 462.30625 MHz
- 462.3125 MHz
- 462.31875 MHz
- 462.33125 MHz
- 462.3375 MHz
- 462.34375 MHz
- 462.35625 MHz
- 462.3625 MHz
- 462.36875 MHz
- 462.38125 MHz
- 462.3875 MHz
- 462.39375 MHz
- 462.40625 MHz
- 462.4125 MHz
- 462.41875 MHz
- 462.43125 MHz
- 462.4375 MHz
- 462.44375 MHz
- 467.20625 MHz
- 467.2125 MHz
- 467.21875 MHz
- 467.23125 MHz
- 467.2375 MHz
- 467.24375 MHz
- 467.25625 MHz
- 467.2625 MHz
- 467.26875 MHz
- 467.28125 MHz
- 467.2875 MHz
- 467.29375 MHz
- 467.30625 MHz
- 467.3125 MHz
- 467.31875 MHz
- 467.33125 MHz
- 467.3375 MHz
- 467.34375 MHz
- 467.35625 MHz
- 467.3625 MHz
- 467.36875 MHz
- 467.38125 MHz
- 467.3875 MHz
- 467.39375 MHz
- 467.40625 MHz
- 467.4125 MHz
- 467.41875 MHz
- 467.43125 MHz
- 467.4375 MHz
- 467.44375 MHz
- 461.03125 MHz
- 461.0375 MHz
- 461.04375 MHz
- 461.05625 MHz
- 461.0625 MHz
- 461.06875 MHz
- 461.08125 MHz
- 461.0875 MHz
- 461.09375 MHz
- 461.10625 MHz
- 461.1125 MHz
- 461.11875 MHz
- 461.13125 MHz
- 461.1375 MHz
- 461.14375 MHz
- 461.15625 MHz
- 461.1625 MHz
- 461.16875 MHz
- 461.18125 MHz
- 461.1875 MHz
- 461.19375 MHz
- 461.20625 MHz
- 461.2125 MHz
- 461.21875 MHz
- 461.23125 MHz
- 461.2375 MHz
- 461.24375 MHz
- 461.25625 MHz
- 461.2625 MHz
- 461.26875 MHz
- 461.28125 MHz
- 461.2875 MHz
- 461.29375 MHz
- 461.30625 MHz
- 461.3125 MHz
- 461.31875 MHz
- 461.33125 MHz
- 461.3375 MHz
- 461.34375 MHz
- 461.35625 MHz
- 461.3625 MHz
- 461.36875 MHz
- 462.7625 MHz
- 462.7875 MHz
- 462.8125 MHz
- 462.8375 MHz
- 462.8625 MHz
- 462.8875 MHz
- 462.9125 MHz
- 464.4875 MHz
- 464.48125 MHz
- 464.5125 MHz
- 464.51875 MHz
- 464.53125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 464.56875 MHz
- 466.03125 MHz
- 466.0375 MHz
- 466.04375 MHz
- 466.05625 MHz
- 466.0625 MHz
- 466.06875 MHz
- 466.08125 MHz
- 466.0875 MHz
- 466.09375 MHz
- 466.10625 MHz
- 466.1125 MHz
- 466.11875 MHz
- 466.13125 MHz
- 466.1375 MHz
- 466.14375 MHz
- 466.15625 MHz
- 466.1625 MHz
- 466.16875 MHz
- 466.18125 MHz
- 466.1875 MHz
- 466.19375 MHz
- 466.20625 MHz
- 466.2125 MHz
- 466.21875 MHz
- 466.23125 MHz
- 466.2375 MHz
- 466.24375 MHz
- 466.25625 MHz
- 466.2625 MHz
- 466.26875 MHz
- 466.28125 MHz
- 466.2875 MHz
- 466.29375 MHz
- 466.30625 MHz
- 466.3125 MHz
- 466.31875 MHz
- 466.33125 MHz
- 466.3375 MHz
- 466.34375 MHz
- 466.35625 MHz
- 466.3625 MHz
- 466.36875 MHz
- 467.8625 MHz
- 467.8875 MHz
- 467.9125 MHz
- 469.4875 MHz
- 469.48125 MHz
- 469.5125 MHz
- 469.51875 MHz
- 469.53125 MHz
- 469.5375 MHz
- 469.5625 MHz
- 469.56875 MHz
- 460.90625 MHz
- 460.9125 MHz
- 460.91875 MHz
- 460.93125 MHz
- 460.9375 MHz
- 460.94375 MHz
- 460.95625 MHz
- 460.9625 MHz
- 460.96875 MHz
- 460.98125 MHz
- 460.9875 MHz
- 460.99375 MHz
- 461.00625 MHz
- 461.0125 MHz
- 461.01875 MHz
- 465.90625 MHz
- 465.9125 MHz
- 465.91875 MHz
- 465.93125 MHz
- 465.9375 MHz
- 465.94375 MHz
- 465.95625 MHz
- 465.9625 MHz
- 465.96875 MHz
- 465.98125 MHz
- 465.9875 MHz
- 465.99375 MHz
- 466.00625 MHz
- 466.0125 MHz
- 466.01875 MHz
- one set of 68 channel pairs
- 160 available channel pairs
- 22 available channel pairs
| 902-928 MHz | 900 MHz ISM, Part 15 and ham radio band, subject to restrictions of this band, on-site 900 MHz ISM FHSS radios 1 watt power output |
- Itinerant
- 151.5125 MHz - Itinerant
- 158.4000 MHz - Itinerant
- 158.4075 MHz - Itinerant
- 27.5100 MHz - Low Power
- 27.5300 MHz - Low Power
- 33.4000 MHz - Low Power
- 35.0200 MHz - Low Power
- 42.9800 MHz - Low Power
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8050 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz - Purple Dot
- 152.8850 MHz
- 152.9000 MHz
- 152.9150 MHz
- 152.9450 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- 154.5475 MHz
- 450.0000 MHz - Unlicensed use, CSQ, 67.0 Hz, 69.3 Hz, 82.5 Hz and 88.5 Hz PL reported
- 450.0750 MHz - Unlicensed use, CSQ logged
- 450.2250 MHz - Unlicensed use, 023 DPL D023N logged (likely BF-888S Baofeng type handhelds)
- 450.4500 MHz - Unlicensed use
- 451.1875 MHz
- 451.2375 MHz
- 451.2875 MHz
- 451.3125 MHz
- 451.3375 MHz
- 451.3625 MHz
- 451.3875 MHz
- 451.4375 MHz
- 451.4625 MHz
- 451.4875 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5625 MHz
- 451.5875 MHz
- 451.6125 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 451.7125 MHz
- 451.7375 MHz
- 451.7625 MHz
- 452.0375 MHz
- 452.0625 MHz
- 452.0875 MHz
- 452.1125 MHz
- 452.1375 MHz
- 452.1625 MHz
- 452.1875 MHz
- 452.2875 MHz
- 452.3125 MHz
- 452.4125 MHz
- 452.4875 MHz
- 452.5125 MHz
- 452.5375 MHz
- 452.6375 MHz
- 452.6625 MHz
- 452.6875 MHz
- 452.7125 MHz
- 452.7625 MHz
- 452.7875 MHz
- 452.8125 MHz
- 452.8375 MHz
- 452.8625 MHz
- 452.8875 MHz
- 452.9875 MHz
- 456.1875 MHz
- 456.2375 MHz
- 456.2875 MHz
- 456.3125 MHz
- 456.3375 MHz
- 456.3625 MHz
- 456.3875 MHz
- 456.4375 MHz
- 456.4625 MHz
- 456.4875 MHz
- 456.5125 MHz
- 456.5375 MHz
- 456.5625 MHz
- 456.5875 MHz
- 456.6125 MHz
- 456.6375 MHz
- 456.6625 MHz
- 456.6875 MHz
- 456.7125 MHz
- 456.7375 MHz
- 456.7625 MHz
- 457.0375 MHz
- 457.0625 MHz
- 457.0875 MHz
- 457.1125 MHz
- 457.1375 MHz
- 457.1625 MHz
- 457.1875 MHz
- 457.2875 MHz
- 457.3125 MHz
- 457.4125 MHz
- 457.4875 MHz
- 457.5125 MHz
- 457.6375 MHz
- 457.6625 MHz
- 457.7125 MHz
- 457.7375 MHz
- 457.7625 MHz
- 457.7875 MHz
- 457.8125 MHz
- 457.8375 MHz
- 457.8625 MHz
- 457.8875 MHz
- 457.9875 MHz
- 461.0375 MHz
- 461.0625 MHz
- 461.0875 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.1625 MHz
- 461.1875 MHz
- 461.2125 MHz
- 461.2375 MHz
- 461.2625 MHz
- 461.2875 MHz
- 461.3125 MHz
- 461.3375 MHz
- 461.3625 MHz
- 462.1875 MHz
- 462.4625 MHz
- 462.4875 MHz
- 462.5125 MHz
- 466.0375 MHz
- 466.0625 MHz
- 466.0875 MHz
- 466.1125 MHz
- 466.1375 MHz
- 466.1625 MHz
- 466.1875 MHz
- 466.2125 MHz
- 466.2375 MHz
- 466.2625 MHz
- 466.2875 MHz
- 466.3125 MHz
- 466.3375 MHz
- 466.3625 MHz
- 467.1875 MHz
- 467.4625 MHz
- 467.4875 MHz
- 467.5125 MHz
- 467.7875 MHz - 2 watts
- 467.8375 MHz - 2 watts
- 467.8875 MHz - 2 watts
- 467.9125 MHz - 2 watts
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3375 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.5875 MHz
- 468.6125 MHz
- 468.6375 MHz
- 468.6625 MHz
- 464.5500 MHz
- 464.5000 MHz
- 467.9250 MHz
- 467.9000 MHz
- 467.8750 MHz
- 467.8500 MHz
- 469.5500 MHz
- 469.5000 MHz
- 461.0375 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.2375 MHz
- 467.8125 MHz
- 467.7625 MHz
- 451.8000 MHz
- 456.8000 MHz
- 451.8125 MHz
- 456.8125 MHz
- 151.6250 MHz
- 154.5700 MHz
- 154.6000 MHz
- 151.9550 MHz
- 151.5125 MHz
- 151.5050 MHz
- 151.7000 MHz
- 151.7600 MHz
- 151.8200 MHz
- 151.9400 MHz
- 151.8800 MHz
- 151.9250 MHz
- 151.8050 MHz
- 158.4000 MHz
- 158.4075 MHz
- 151.6550 MHz
- 151.8650 MHz
- 152.9000 MHz
- Frequency 151.655 MHz
- Frequency 151.685 MHz
- Frequency 151.715 MHz
- Frequency 151.775 MHz
- Frequency 151.835 MHz
- Frequency 151.895 MHz
- Frequency 151.925 MHz
- Frequency 154.490 MHz
- Frequency 154.515 MHz
- Frequency 154.540 MHz
- Frequency 158.400 MHz
Frequencies and CTCSS (PL) programmed via 4 on/off DIP switches. Note that 464.325 MHz, 464.825 MHz and 469.2625 MHz are not itinerant frequencies and high power business radio systems may be using these frequencies. 469.2625 MHz is technically for itinerant use in Canada.
462.575 MHz, 462.625 MHz and 462.675 MHz are now part of the FRS and GMRS services.
Unlicensed FRS simplex use and/or licensed GMRS simplex and/or licensed GMRS repeater output use of these frequencies is common and legal. It is legal to use 462.575MHz, 462.625MHz and 462.675MHz for business purposes under the FRS regulations. No license is required for simplex operation on the 22 FRS frequencies.
- Frequency - 462.5750 MHz - FRS Channel 16
- Frequency - 462.6250 MHz - FRS Channel 18
- Frequency - 462.6750 MHz - FRS Channel 20
- Frequency - 464.3250 MHz
- Frequency - 464.8250 MHz
- Frequency - 469.2625 MHz
- Frequency - 469.5000 MHz
- Frequency - 469.5500 MHz
Motorola Spirit-M VHF radio
Motorola Spirit-M UHF radio
Frequencies
Motorola Sport UHF GMRS radio
Lowband 1 - Low 1
Lowband 2 - Low 2
VHF High Band - VHF
700 MHz Band - 700
800 MHz Band - 800
- Channel 16 - 467.8750 MHz CSQ - No Tone
- Channel 1 - 446.00625 MHz NFM 97.4 Hz PL
- Channel 2 - 446.01875 MHz NFM 100.0 Hz PL
- Channel 3 - 446.03125 MHz NFM 103.5 Hz PL
- Channel 4 - 446.04375 MHz NFM 107.2 Hz PL
- Channel 5 - 446.05625 MHz NFM 110.9 Hz PL
- Channel 6 - 446.06875 MHz NFM 114.8 Hz PL
- Channel 7 - 446.08125 MHz NFM 118.8 Hz PL
- Channel 8 - 446.09375 MHz NFM 123.0 Hz PL
- Channel 9 - 446.00625 MHz NFM 127.3 Hz PL
- Channel 10 - 446.01875 MHz NFM 131.8 Hz PL
- Channel 11 - 446.03125 MHz NFM 136.5 Hz PL
- Channel 12 - 446.04375 MHz NFM 141.3 Hz PL
- Channel 13 - 446.05625 MHz NFM 146.2 Hz PL
- Channel 14 - 446.06875 MHz NFM 141.3 Hz PL
- Channel 15 - 446.08125 MHz NFM 156.7 Hz PL
- Channel 16 - 446.09375 MHz NFM 159.8 Hz PL
- Channel 1 - 446.10625 MHz NFM 97.4 Hz PL
- Channel 2 - 446.11875 MHz NFM 100.0 Hz PL
- Channel 3 - 446.13125 MHz NFM 103.5 Hz PL
- Channel 4 - 446.14375 MHz NFM 107.2 Hz PL
- Channel 5 - 446.15625 MHz NFM 110.9 Hz PL
- Channel 6 - 446.16875 MHz NFM 114.8 Hz PL
- Channel 7 - 446.18125 MHz NFM 118.8 Hz PL
- Channel 8 - 446.19375 MHz NFM 123.0 Hz PL
- Channel 9 - 446.10625 MHz NFM 127.3 Hz PL
- Channel 10 - 446.11875 MHz NFM 131.8 Hz PL
- Channel 11 - 446.13125 MHz NFM 136.5 Hz PL
- Channel 12 - 446.14375 MHz NFM 141.3 Hz PL
- Channel 13 - 446.15625 MHz NFM 146.2 Hz PL
- Channel 14 - 446.16875 MHz NFM 141.3 Hz PL
- Channel 15 - 446.18125 MHz NFM 156.7 Hz PL
- Channel 16 - 446.19375 MHz NFM 159.8 Hz PL
- Channel 1 - 446.003125 MHz Digital - Common ID 85
- Channel 2 - 446.009375 MHz Digital - Common ID 87
- Channel 3 - 446.015625 MHz Digital - Common ID 93
- Channel 4 - 446.021875 MHz Digital - Common ID 95
- Channel 5 - 446.028125 MHz Digital - Common ID 117
- Channel 6 - 446.034375 MHz Digital - Common ID 119
- Channel 7 - 446.040625 MHz Digital - Common ID 125
- Channel 8 - 446.046875 MHz Digital - Common ID 129
- Channel 9 - 446.053125 MHz Digital - Common ID 213
- Channel 10 - 446.059375 MHz Digital - Common ID 215
- Channel 11 - 446.065625 MHz Digital - Common ID 221
- Channel 12 - 446.071875 MHz Digital - Common ID 223
- Channel 13 - 446.078125 MHz Digital - Common ID 245
- Channel 14 - 446.084375 MHz Digital - Common ID 247
- Channel 15 - 446.090625 MHz Digital - Common ID 253
- Channel 16 - 446.096875 MHz Digital - Common ID 254
- Channel 1 - 446.103125 MHz Digital - Common ID 85
- Channel 2 - 446.109375 MHz Digital - Common ID 87
- Channel 3 - 446.115625 MHz Digital - Common ID 93
- Channel 4 - 446.121875 MHz Digital - Common ID 95
- Channel 5 - 446.128125 MHz Digital - Common ID 117
- Channel 6 - 446.134375 MHz Digital - Common ID 119
- Channel 7 - 446.140625 MHz Digital - Common ID 125
- Channel 8 - 446.146875 MHz Digital - Common ID 129
- Channel 9 - 446.153125 MHz Digital - Common ID 213
- Channel 10 - 446.159375 MHz Digital - Common ID 215
- Channel 11 - 446.165625 MHz Digital - Common ID 221
- Channel 12 - 446.171875 MHz Digital - Common ID 223
- Channel 13 - 446.178125 MHz Digital - Common ID 245
- Channel 14 - 446.184375 MHz Digital - Common ID 247
- Channel 15 - 446.190625 MHz Digital - Common ID 253
- Channel 16 - 446.196875 MHz Digital - Common ID 254
Wouxun KG-S86B Business Radio
CONNECOM GD100 and GD900
CONNECOM GD800
Default channel programming
- Channel 1 - 464.5500 MHz - DMR digital mode
- Channel 2 - 464.5000 MHz - DMR digital mode
- Channel 3 - 467.7625 MHz - DMR digital mode
- Channel 4 - 467.8125 MHz - DMR digital mode
- Channel 5 - 467.8500 MHz - DMR digital mode
- Channel 6 - 467.8750 MHz - DMR digital mode
- Channel 7 - 467.9000 MHz - DMR digital mode
- Channel 8 - 467.9250 MHz - DMR digital mode
- Channel 9 - 464.5500 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 10 - 464.5000 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 11 - 467.7625 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 12 - 467.8125 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 13 - 467.8500 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 14 - 467.8750 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 15 - 467.9000 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
- Channel 16 - 467.9250 MHz NFM - Analog mode - 67.0 Hz CTCSS TX/RX
KidDesigns Walkie Talkies
- Power Output: 0.133mW
- Emission: 11K0F3E
- FCC ID IAJ-210
- Power Output: 7mW
- Emission: 11K0F3E
- FCC ID IAJ-212C7A
- Power Output: 3.2mW
- Emission: 11K0F3E
- FCC ID IAJ-212C7B
- Power Output: 4.2mW
- Emission: 4K26F3E
- FCC ID IAJ-216
- Channel 51 - 462.6375 MHz 032 DCS
- Channel 52 - 462.6875 MHz 051 DCS
- Channel 53 - 467.5625 MHz 071 DCS
- Channel 54 - 467.6125 MHz 074 DCS
- Channel 55 - 467.6625 MHz 116 DCS
- Channel 56 - 467.7125 MHz 132 DCS
- Channel 57 - 462.5750 MHz 152 DCS
- Channel 58 - 462.6250 MHz 162 DCS
- Channel 59 - 462.6750 MHz 174 DCS
- Channel 60 - 462.7250 MHz 226 DCS
- Channel 61 - User configurable (user selects from channel 1-22 and then either selects no squelch, CTCSS code 1-38 or DCS code 1-83).
Cobra RX380 Series FRS Radios
Cobra RX380
SAMCOM 20 Channel UHF Radios
FCC ID 2AIOQ-FPCN30AA
- CH01 - 462.5500 MHz D226 [FRS Channel 15 - D226N | 226 DCS]
- CH02 - 462.5750 MHz D243 [FRS Channel 16 - D243N | 243 DCS]
- CH03 - 462.6000 MHz D244 [FRS Channel 17 - D244N | 244 DCS]
- CH04 - 462.6250 MHz D245 [FRS Channel 18 - D245N | 245 DCS]
- CH05 - 462.6500 MHz D246 [FRS Channel 19 - D246N | 246 DCS]
- CH06 - 462.6750 MHz D251 [FRS Channel 20 - D251N | 251 DCS]
- CH07 - 462.7000 MHz D252 [FRS Channel 21 - D252N | 252 DCS]
- CH08 - 462.7250 MHz D255 [FRS Channel 22 - D255N | 255 DCS]
- CH09 - 462.5625 MHz D261 [FRS Channel 1 - D261N | 261 DCS]
- CH10 - 462.5875 MHz D332 [FRS Channel 2 - D332N | 332 DCS]
- CH11 - 462.6125 MHz D265 [FRS Channel 3 - D265N | 265 DCS]
- CH12 - 462.6375 MHz D266 [FRS Channel 4 - D266N | 266 DCS]
- CH13 - 462.6625 MHz D271 [FRS Channel 5 - D271N | 271 DCS]
- CH14 - 462.6875 MHz D274 [FRS Channel 6 - D274N | 274 DCS]
- CH15 - 462.6500 MHz D306 [FRS Channel 19 - D306N | 306 DCS]
- CH16 - 462.5500 MHz D311 [FRS Channel 15 - D311N | 311 DCS]
- CH17 - 462.7000 MHz D315 [FRS Channel 21 - D315N | 315 DCS]
- CH18 - 462.6625 MHz D325 [FRS Channel 5 - D325N | 325 DCS]
- CH19 - 462.5625 MHz D331 [FRS Channel 1 - D331N | 331 DCS]
- CH0 - 462.7125 MHz D225 [FRS Channel 7 - D225N | 225 DCS]
Radioditty GA-2S
- Channel 8 - 462.5500 MHz
- Channel 10 - 462.6000 MHz
- Channel 11 - 462.6250 MHz
- Channel 12 - 462.6500 MHz
- Channel 13 - 462.6750 MHz
- Channel 14 - 462.7000 MHz
- Channel 15 - 462.7250 MHz
- VFO F1 - 400.5250 MHz FM [CSQ]
- VFO F2 - 226.0000 MHz FM [CSQ]
- VFO F3 - 469.5250 MHz FM [CSQ]
- Channel 1 - 136.4250 MHz FM CSQ
- Channel 2 - 150.4250 MHz FM 159.8 Hz PL
- Channel 3 - 173.9450 MHz FM CSQ
- Channel 4 - 220.4250 MHz FM CSQ
- Channel 5 - 240.4250 MHz FM D023N 023 DPL
- Channel 6 - 259.9450 MHz FM CSQ
- Channel 7 - 400.4250 MHz FM CSQ
- Channel 8 - 435.4250 MHz FM CSQ
- Channel 9 - 469.4250 MHz FM CSQ
- Channel 10 - 136.4250 MHz NFM 67.0 Hz PL
- Channel 11 - 150.4250 MHz NFM 254.1 Hz PL
- Channel 12 - 173.9450 MHz NFM D023N 023 DPL
- Channel 13 - 220.4250 MHz NFM 67.0 Hz
- Channel 14 - 240.4250 MHz NFM 254.1 Hz PL
- Channel 15 - 259.9450 MHz NFM D023N 023 DPL
- Channel 16 - 400.4250 MHz NFM 67.0 Hz PL
- Channel 17 - 435.4250 MHz NFM 254.1 Hz PL
- Channel 18 - 469.4250 MHz NFM D023N 023 DPL
TXPro TX-680AV VHF
VHF version 136-174 MHz
FCC ID: 2AS4FEPCOTX680AV
Retevis RT10
Zone 1
Zone 2
Zone 3
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
- Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
Retevis RT1-VHF RT1 RT-1
Retevis RT-24 FRS 16 channel
Retevis RT-27V MURS VHF
- Channel 15 - 462.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 1
- Channel 16 - 467.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 8
Retevis RT-47V MURS VHF
- Channel 1 - 462.5625 MHz 043 DPL D043N - FRS Channel 1
- Channel 2 - 462.5875 MHz 065 DPL D065N - FRS Channel 2
- Channel 3 - 462.6125 MHz 116 DPL D116N - FRS Channel 3
- Channel 4 - 462.6375 MHz 205 DPL D205N - FRS Channel 4
- Channel 5 - 462.6625 MHz 261 DPL D261N - FRS Channel 5
- Channel 6 - 462.6875 MHz 265 DPL D265N - FRS Channel 6
- Channel 7 - 462.7125 MHz 271 DPL D271N - FRS Channel 7
- Channel 8 - 467.5625 MHz 306 DPL D306N - FRS Channel 8
- Channel 9 - 467.5875 MHz 311 DPL D311N - FRS Channel 9
- Channel 10 - 467.6125 MHz 331 DPL D331N - FRS Channel 10
- Channel 11 - 467.6375 MHz 365 DPL D365N - FRS Channel 11
- Channel 12 - 467.6625 MHz 431 DPL D431N - FRS Channel 12
- Channel 13 - 467.6875 MHz 466 DPL D466N - FRS Channel 13
- Channel 14 - 467.7125 MHz 503 DPL D503N - FRS Channel 14
- Channel 1 - 446.00625 MHz 114 DPL D114N - PMR446 Channel 1
- Channel 2 - 446.01875 MHz 131 DPL D131N - PMR446 Channel 2
- Channel 3 - 446.03125 MHz 132 DPL D132N - PMR446 Channel 3
- Channel 4 - 446.04375 MHz 165 DPL D165N - PMR446 Channel 4
- Channel 5 - 446.05625 MHz 226 DPL D226N - PMR446 Channel 5
- Channel 6 - 446.06875 MHz 306 DPL D306N - PMR446 Channel 6
- Channel 7 - 446.08125 MHz 371 DPL D371N - PMR446 Channel 7
- Channel 8 - 446.09375 MHz 503 DPL D503N - PMR446 Channel 8
HN5RV01 firmware version
Baofeng UV-5R8W
- Channel 1 - 140.125 MHz CSQ High Power Wide
- Channel 2 - 145.225 MHz CSQ High Power Wide
- Channel 3 - 150.325 MHz CSQ High Power Wide
- Channel 4 - 440.125 MHz CSQ High Power Wide
- Channel 5 - 445.225 MHz CSQ High Power Wide
- Channel 6 - 450.325 MHz CSQ High Power Wide
- Channel 1 - 400.1250 MHz
- Channel 2 - 410.1250 MHz
- Channel 3 - 420.1250 MHz
- Channel 4 - 430.1250 MHz
- Channel 5 - 440.1250 MHz
- Channel 6 - 450.1250 MHz
- Channel 7 - 460.1250 MHz
- Channel 8 - 470.1250 MHz
- Channel 9 - 480.1250 MHz
- Channel 10 - 490.1250 MHz
- Channel 11 - 500.1250 MHz
- Channel 12 - 510.1250 MHz
- Channel 13 - 519.9750 MHz
- Channel 14 - 136.1250 MHz
- Channel 15 - 145.1250 MHz
- Channel 16 - 155.1250 MHz
- Channel 17 - 165.1250 MHz
- Channel 18 - 173.9750 MHz
Baofeng UV-98 UV98Pro
- Freq 1 - 464.5000 MHz
- Freq 2 - 464.5500 MHz
- Freq 3 - 467.7625 MHz
- Freq 4 - 467.8125 MHz
- Freq 5 - 467.8500 MHz
- Freq 6 - 467.8750 MHz
- Freq 7 - 467.9000 MHz
- Freq 8 - 467.9250 MHz
- Freq 9 - 461.0375 MHz
- Freq 10 - 461.0625 MHz
- Freq 11 - 461.0875 MHz
- Freq 12 - 461.1125 MHz
- Freq 13 - 461.1375 MHz
- Freq 14 - 461.1625 MHz
- Freq 15 - 461.1875 MHz
- Freq 16 - 461.2125 MHz
- Freq 17 - 461.2375 MHz
- Freq 18 - 461.2625 MHz
- Freq 19 - 461.2875 MHz
- Freq 20 - 461.3125 MHz
- Freq 21 - 461.3375 MHz
- Freq 22 - 461.3625 MHz
- Freq 23 - 462.7625 MHz
- Freq 24 - 462.7875 MHz
- Freq 25 - 462.8125 MHz
- Freq 26 - 462.8375 MHz
- Freq 27 - 462.8625 MHz
- Freq 28 - 462.8875 MHz
- Freq 29 - 462.9125 MHz
- Freq 30 - 464.4875 MHz
- Freq 31 - 464.5125 MHz
- Freq 32 - 464.5375 MHz
- Freq 33 - 464.5625 MHz
- Freq 34 - 466.0375 MHz
- Freq 35 - 466.0625 MHz
- Freq 36 - 466.0875 MHz
- Freq 37 - 466.1125 MHz
- Freq 38 - 466.1375 MHz
- Freq 39 - 466.1625 MHz
- Freq 40 - 466.1875 MHz
- Freq 41 - 466.2125 MHz
- Freq 42 - 466.2375 MHz
- Freq 43 - 466.2625 MHz
- Freq 44 - 466.2875 MHz
- Freq 45 - 466.3125 MHz
- Freq 46 - 466.3375 MHz
- Freq 47 - 466.3625 MHz
- Freq 48 - 467.7875 MHz
- Freq 49 - 467.8375 MHz
- Freq 50 - 467.8625 MHz
- Freq 51 - 467.8875 MHz
- Freq 52 - 467.9125 MHz
- Freq 53 - 469.4875 MHz
- Freq 54 - 469.5125 MHz
- Freq 55 - 469.5375 MHz
- Freq 56 - 469.5625 MHz
- Freq 9 - 462.5750 MHz
- Freq 10 - 462.6250 MHz
- Freq 11 - 462.6750 MHz
- Freq 12 - 464.3250 MHz
- Freq 13 - 464.8250 MHz
- Freq 14 - 469.2625 MHz
- Freq 15 - 469.5000 MHz
- Freq 16 - 469.5500 MHz
- Freq 17 - 462.7625 MHz
- Freq 18 - 462.7875 MHz
- Freq 19 - 462.8125 MHz
- Freq 20 - 462.8375 MHz
- Freq 21 - 462.8625 MHz
- Freq 22 - 462.8875 MHz
- Freq 23 - 462.9125 MHz
- Freq 23 - 461.0375 MHz
- Freq 25 - 461.0625 MHz
- Freq 26 - 461.0875 MHz
- Freq 27 - 461.1125 MHz
- Freq 28 - 461.1375 MHz
- Freq 29 - 461.1625 MHz
- Freq 30 - 461.1875 MHz
- Freq 31 - 461.2125 MHz
- Freq 32 - 461.2375 MHz
- Freq 33 - 461.2625 MHz
- Freq 34 - 461.2875 MHz
- Freq 35 - 461.3125 MHz
- Freq 36 - 461.3375 MHz
- Freq 37 - 461.3625 MHz
- Freq 38 - 467.7875 MHz
- Freq 39 - 467.8375 MHz
- Freq 40 - 467.8625 MHz
- Freq 41 - 467.8875 MHz
- Freq 42 - 467.9125 MHz
- Freq 43 - 464.4875 MHz
- Freq 44 - 464.5125 MHz
- Freq 45 - 464.5375 MHz
- Freq 46 - 464.5625 MHz
- Freq 47 - 466.0375 MHz
- Freq 48 - 466.0625 MHz
- Freq 49 - 466.0875 MHz
- Freq 50 - 466.1125 MHz
- Freq 51 - 466.1375 MHz
- Freq 52 - 466.1625 MHz
- Freq 53 - 466.1875 MHz
- Freq 54 - 466.2125 MHz
- Freq 55 - 466.2375 MHz
- Freq 56 - 466.2625 MHz
- Freq 1 - 151.6250 MHz
- Freq 2 - 151.9550 MHz
- Freq 3 - 154.5700 MHz
- Freq 4 - 154.6000 MHz
- Freq 5 - 151.7000 MHz
- Freq 6 - 151.7600 MHz
- Freq 7 - 151.8200 MHz
- Freq 8 - 151.8800 MHz
- Freq 9 - 151.9400 MHz
- Freq 10 - 151.5125 MHz
- Freq 11 - 151.6550 MHz
- Freq 12 - 151.6850 MHz
- Freq 13 - 151.7150 MHz
- Freq 14 - 151.7450 MHz
- Freq 15 - 151.7750 MHz
- Freq 16 - 151.8650 MHz
- Freq 17 - 151.8950 MHz
- Freq 18 - 151.9250 MHz
- Freq 20 - 154.4900 MHz
- Freq 21 - 154.5150 MHz
- Freq 22 - 154.5275 MHz
- Freq 23 - 154.5400 MHz
- Freq 24 - 154.6000 MHz
- Freq 26 - 158.4000 MHz
- Freq 27 - 158.4075 MHz
- Freq 57 - 462.1875 MHz
- Freq 58 - 462.4625 MHz
- Freq 59 - 462.4875 MHz
- Freq 60 - 462.5125 MHz
- Freq 61 - 467.1875 MHz
- Freq 62 - 467.4625 MHz
- Freq 63 - 467.4875 MHz
- Freq 64 - 467.5125 MHz
- Freq 65 - 451.1875 MHz
- Freq 66 - 451.2375 MHz
- Freq 67 - 451.2875 MHz
- Freq 68 - 451.3375 MHz
- Freq 69 - 451.4375 MHz
- Freq 70 - 451.5375 MHz
- Freq 71 - 451.6375 MHz
- Freq 72 - 452.3125 MHz
- Freq 73 - 452.5375 MHz
- Freq 74 - 452.4125 MHz
- Freq 75 - 452.5125 MHz
- Freq 76 - 452.7625 MHz
- Freq 77 - 452.8625 MHz
- Freq 78 - 456.1875 MHz
- Freq 79 - 456.2375 MHz
- Freq 80 - 456.2875 MHz
- Freq 81 - 468.2125 MHz
- Freq 82 - 468.2625 MHz
- Freq 83 - 468.3125 MHz
- Freq 84 - 468.3625 MHz
- Freq 85 - 468.4125 MHz
- Freq 86 - 468.4625 MHz
- Freq 87 - 468.5125 MHz
- Freq 88 - 468.5625 MHz
- Freq 89 - 468.6125 MHz
- Freq 90 - 468.6625 MHz
- Freq 81 - 456.3375 MHz
- Freq 82 - 456.4375 MHz
- Freq 83 - 456.5375 MHz
- Freq 84 - 456.6375 MHz
- Freq 85 - 457.3125 MHz
- Freq 86 - 457.4125 MHz
- Freq 87 - 457.5125 MHz
- Freq 88 - 457.7625 MHz
- Freq 89 - 457.8625 MHz
- Freq 3 - 152.8850 MHz
- Freq 4 - 152.9150 MHz
- Freq 7 - 152.9450 MHz
- Freq 8 - 151.8350 MHz
- Freq 9 - 151.8050 MHz
- Freq 24 - 153.0050 MHz
- Freq 0 - OFF (BLANK)
- Code 1 - 67.0 Hz PL - XZ
- Code 2 - 71.9 Hz PL - XA
- Code 3 - 74.4 Hz PL - WA
- Code 4 - 77.0 Hz PL - XB
- Code 5 - 79.7 Hz PL - WB
- Code 6 - 82.5 Hz PL - YZ
- Code 7 - 85.4 Hz PL - YA
- Code 8 - 88.5 Hz PL - YB
- Code 9 - 91.5 Hz PL - ZZ
- Code 10 - 94.8 Hz PL - ZA
- Code 11 - 97.4 Hz PL - ZB
- Code 12 - 100.0 Hz PL - 1Z
- Code 13 - 103.5 Hz PL - 1A
- Code 14 - 107.2 Hz PL - 1B
- Code 15 - 110.9 Hz PL - 2Z
- Code 16 - 114.8 Hz PL - 2A
- Code 17 - 118.8 Hz PL - 2B
- Code 18 - 123.0 Hz PL - 3Z
- Code 19 - 127.3 Hz PL - 3A
- Code 20 - 131.8 Hz PL - 3B
- Code 21 - 136.5 Hz PL - 4Z
- Code 22 - 141.3 Hz PL - 4A
- Code 23 - 146.2 Hz PL - 4B
- Code 24 - 151.4 Hz PL - 5Z
- Code 25 - 156.7 Hz PL - 5A
- Code 26 - 162.2 Hz PL - 5B
- Code 27 - 167.9 Hz PL - 6Z
- Code 28 - 173.8 Hz PL - 6A
- Code 29 - 179.9 Hz PL - 6B
- Code 30 - 186.2 Hz PL - 7Z
- Code 31 - 192.8 Hz PL - 7A
- Code 32 - 203.5 Hz PL - M1
- Code 33 - 210.7 Hz PL - M2
- Code 34 - 218.1 Hz PL - M3
- Code 35 - 225.7 Hz PL - M4
- Code 36 - 233.6 Hz PL - M5
- Code 37 - 241.8 Hz PL - M6
- Code 38 - 250.3 Hz PL - M7
- Code 39 - 023 DPL D023N
- Code 40 - 025 DPL D025N
- Code 41 - 026 DPL D026N
- Code 42 - 031 DPL D031N
- Code 43 - 032 DPL D032N
- Code 44 - 043 DPL D043N
- Code 45 - 047 DPL D047N
- Code 46 - 051 DPL D051N
- Code 47 - 054 DPL D054N
- Code 48 - 065 DPL D065N
- Code 49 - 071 DPL D071N
- Code 50 - 072 DPL D072N
- Code 51 - 073 DPL D073N
- Code 52 - 074 DPL D074N
- Code 53 - 114 DPL D114N
- Code 54 - 115 DPL D115N
- Code 55 - 116 DPL D116N
- Code 56 - 125 DPL D125N
- Code 57 - 131 DPL D131N
- Code 58 - 132 DPL D132N
- Code 59 - 134 DPL D134N
- Code 60 - 143 DPL D143N
- Code 61 - 152 DPL D152N
- Code 62 - 155 DPL D155N
- Code 63 - 156 DPL D156N
- Code 64 - 162 DPL D162N
- Code 65 - 165 DPL D165N
- Code 66 - 172 DPL D172N
- Code 67 - 174 DPL D174N
- Code 68 - 205 DPL D205N
- Code 69 - 223 DPL D223N
- Code 70 - 226 DPL D226N
- Code 71 - 243 DPL D243N
- Code 72 - 244 DPL D244N
- Code 73 - 245 DPL D245N
- Code 74 - 251 DPL D251N
- Code 75 - 261 DPL D261N
- Code 76 - 263 DPL D263N
- Code 77 - 265 DPL D265N
- Code 78 - 271 DPL D271N
- Code 79 - 306 DPL D306N
- Code 80 - 311 DPL D311N
- Code 81 - 315 DPL D315N
- Code 82 - 331 DPL D331N
- Code 83 - 343 DPL D343N
- Code 84 - 346 DPL D346N
- Code 85 - 351 DPL D351N
- Code 86 - 364 DPL D364N
- Code 87 - 365 DPL D365N
- Code 88 - 371 DPL D371N
- Code 89 - 411 DPL D411N
- Code 90 - 412 DPL D412N
- Code 91 - 413 DPL D413N
- Code 92 - 423 DPL D423N
- Code 93 - 431 DPL D431N
- Code 94 - 432 DPL D432N
- Code 95 - 445 DPL D445N
- Code 96 - 464 DPL D464N
- Code 97 - 465 DPL D465N
- Code 98 - 466 DPL D466N
- Code 99 - 503 DPL D503N
- Code 100 - 506 DPL D506N
- Code 101 - 516 DPL D516N
- Code 102 - 532 DPL D532N
- Code 103 - 546 DPL D546N
- Code 104 - 565 DPL D565N
- Code 105 - 606 DPL D606N
- Code 106 - 612 DPL D612N
- Code 107 - 624 DPL D624N
- Code 108 - 627 DPL D627N
- Code 109 - 631 DPL D631N
- Code 110 - 632 DPL D632N
- Code 111 - 654 DPL D654N
- Code 112 - 662 DPL D662N
- Code 113 - 664 DPL D664N
- Code 114 - 703 DPL D703N
- Code 115 - 712 DPL D712N
- Code 116 - 723 DPL D723N
- Code 117 - 731 DPL D731N
- Code 118 - 732 DPL D732N
- Code 119 - 734 DPL D734N
- Code 120 - 743 DPL D743N
- Code 121 - 754 DPL D754N
- Code 122 - 69.3 Hz PL
- Code 123 - 645 DPL D645N
- DCS Code 1 - 023 DPL
- DCS Code 2 - 025 DPL
- DCS Code 3 - 026 DPL
- DCS Code 4 - 031 DPL
- DCS Code 5 - 032 DPL
- DCS Code 6 - 043 DPL
- DCS Code 7 - 047 DPL
- DCS Code 8 - 051 DPL
- DCS Code 9 - 054 DPL
- DCS Code 10 - 065 DPL
- DCS Code 11 - 071 DPL
- DCS Code 12 - 072 DPL
- DCS Code 13 - 073 DPL
- DCS Code 14 - 074 DPL
- DCS Code 15 - 114 DPL
- DCS Code 16 - 115 DPL
- DCS Code 17 - 116 DPL
- DCS Code 18 - 125 DPL
- DCS Code 19 - 131 DPL
- DCS Code 20 - 132 DPL
- DCS Code 21 - 134 DPL
- DCS Code 22 - 143 DPL
- DCS Code 23 - 152 DPL
- DCS Code 24 - 155 DPL
- DCS Code 25 - 156 DPL
- DCS Code 26 - 162 DPL
- DCS Code 27 - 165 DPL
- DCS Code 28 - 172 DPL
- DCS Code 29 - 174 DPL
- DCS Code 30 - 205 DPL
- DCS Code 31 - 223 DPL
- DCS Code 32 - 226 DPL
- DCS Code 33 - 243 DPL
- DCS Code 34 - 244 DPL
- DCS Code 35 - 245 DPL
- DCS Code 36 - 251 DPL
- DCS Code 37 - 261 DPL
- DCS Code 38 - 263 DPL
- DCS Code 39 - 265 DPL
- DCS Code 40 - 271 DPL
- DCS Code 41 - 306 DPL
- DCS Code 42 - 311 DPL
- DCS Code 43 - 315 DPL
- DCS Code 44 - 331 DPL
- DCS Code 45 - 343 DPL
- DCS Code 46 - 346 DPL
- DCS Code 47 - 351 DPL
- DCS Code 48 - 364 DPL
- DCS Code 49 - 365 DPL
- DCS Code 50 - 371 DPL
- DCS Code 51 - 411 DPL
- DCS Code 52 - 412 DPL
- DCS Code 53 - 413 DPL
- DCS Code 54 - 423 DPL
- DCS Code 55 - 431 DPL
- DCS Code 56 - 432 DPL
- DCS Code 57 - 445 DPL
- DCS Code 58 - 464 DPL
- DCS Code 59 - 465 DPL
- DCS Code 60 - 466 DPL
- DCS Code 61 - 503 DPL
- DCS Code 62 - 506 DPL
- DCS Code 63 - 516 DPL
- DCS Code 64 - 532 DPL
- DCS Code 65 - 546 DPL
- DCS Code 66 - 565 DPL
- DCS Code 67 - 606 DPL
- DCS Code 68 - 612 DPL
- DCS Code 69 - 624 DPL
- DCS Code 70 - 627 DPL
- DCS Code 71 - 631 DPL
- DCS Code 72 - 632 DPL
- DCS Code 73 - 654 DPL
- DCS Code 74 - 662 DPL
- DCS Code 75 - 664 DPL
- DCS Code 76 - 703 DPL
- DCS Code 77 - 712 DPL
- DCS Code 78 - 723 DPL
- DCS Code 79 - 731 DPL
- DCS Code 80 - 732 DPL
- DCS Code 81 - 734 DPL
- DCS Code 82 - 743 DPL
- DCS Code 83 - 754 DPL
- DCS Code 84 - 036 DPL
- DCS Code 85 - 053 DPL
- DCS Code 86 - 122 DPL
- DCS Code 87 - 145 DPL
- DCS Code 88 - 212 DPL
- DCS Code 89 - 225 DPL
- DCS Code 90 - 246 DPL
- DCS Code 91 - 252 DPL
- DCS Code 92 - 255 DPL
- DCS Code 93 - 266 DPL
- DCS Code 94 - 274 DPL
- DCS Code 95 - 325 DPL
- DCS Code 96 - 332 DPL
- DCS Code 97 - 356 DPL
- DCS Code 98 - 446 DPL
- DCS Code 99 - 452 DPL
- DCS Code 100 - 454 DPL
- DCS Code 101 - 455 DPL
- DCS Code 102 - 462 DPL
- DCS Code 103 - 523 DPL
- DCS Code 104 - 526 DPL
42 Motorola Standard PL CTCSS / PL tone list privacy code list
- 67.0 - XZ
- 69.3 - WZ
- 71.9 - XA
- 74.4 - WX
- 77.0 - XB
- 79.7 - WB
- 82.5 - YZ
- 85.4 - YA
- 88.5 - YB
- 91.5 - ZZ
- 94.8 - ZA
- 97.4 - ZB
- 100.0 - 1Z
- 103.5 - 1A
- 107.2 - 1B
- 110.9 - 2Z
- 114.8 - 2A
- 118.8 - 2B
- 123.0 - 3Z
- 127.3 - 3A
- 131.8 - 3B
- 136.5 - 4Z
- 141.3 - 4A
- 146.2 - 4B
- 151.4 - 5Z
- 156.7 - 5A
- 162.2 - 5B
- 167.9 - 6Z
- 173.8 - 6A
- 179.9 - 6B
- 186.2 - 7Z
- 192.8 - 7A
- 203.5 - M1
- 206.5 - 8Z
- 210.7 - M2
- 218.1 - M3
- 225.7 - M4
- 229.1 - 9Z
- 233.6 - M5
- 241.8 - M6
- 250.3 - M7
- 254.1 - 0Z
- CTCSS Code 1 - 67.0 Hz
- CTCSS Code 2 - 69.3 Hz
- CTCSS Code 3 - 71.9 Hz
- CTCSS Code 4 - 74.4 Hz
- CTCSS Code 5 - 77.0 Hz
- CTCSS Code 6 - 79.7 Hz
- CTCSS Code 7 - 82.5 Hz
- CTCSS Code 8 - 85.4 Hz
- CTCSS Code 9 - 88.5 Hz
- CTCSS Code 10 - 91.5 Hz
- CTCSS Code 11 - 94.8 Hz
- CTCSS Code 12 - 97.4 Hz
- CTCSS Code 13 - 100.0 Hz
- CTCSS Code 14 - 103.5 Hz
- CTCSS Code 15 - 107.2 Hz
- CTCSS Code 16 - 110.9 Hz
- CTCSS Code 17 - 114.8 Hz
- CTCSS Code 18 - 118.8 Hz
- CTCSS Code 19 - 123.0 Hz
- CTCSS Code 20 - 127.3 Hz
- CTCSS Code 21 - 131.8 Hz
- CTCSS Code 22 - 136.5 Hz
- CTCSS Code 23 - 141.3 Hz
- CTCSS Code 24 - 146.2 Hz
- CTCSS Code 25 - 151.4 Hz
- CTCSS Code 26 - 156.7 Hz
- CTCSS Code 27 - 159.8 Hz
- CTCSS Code 28 - 162.2 Hz
- CTCSS Code 29 - 165.5 Hz
- CTCSS Code 30 - 167.9 Hz
- CTCSS Code 31 - 171.3 Hz
- CTCSS Code 32 - 173.8 Hz
- CTCSS Code 33 - 177.3 Hz
- CTCSS Code 34 - 179.9 Hz
- CTCSS Code 35 - 183.5 Hz
- CTCSS Code 36 - 186.2 Hz
- CTCSS Code 37 - 189.9 Hz
- CTCSS Code 38 - 192.8 Hz
- CTCSS Code 39 - 196.6 Hz
- CTCSS Code 40 - 199.5 Hz
- CTCSS Code 41 - 203.5 Hz
- CTCSS Code 42 - 206.5 Hz
- CTCSS Code 43 - 210.7 Hz
- CTCSS Code 44 - 218.1 Hz
- CTCSS Code 45 - 225.7 Hz
- CTCSS Code 46 - 229.1 Hz
- CTCSS Code 47 - 233.6 Hz
- CTCSS Code 48 - 241.8 Hz
- CTCSS Code 49 - 250.3 Hz
- CTCSS Code 50 - 254.1 Hz
Not be confused with DSC - Digital Selective Calling, a part of the worldwide MF/HF and VHF maritime (marine radio) GMDSS system. These are the 83 "standardized" codes, some radios may have additional codes. It should be noted that so-called inverted DCS codes are an illusion. Radios that claim to have 1024 different DCS codes actually have 512 codes (000 to 777 in octal notation) plus the -512 decimal codes (so called "negative" or "inverse" codes - -000 to -777 in octal notation). Because of the way DCS works - a 23 bit stream of bits to form a "word" (DCS code), depending on which bits the receiver receives first, a single DCS code could be interpreted as numerous different codes. The 83 standardized codes have been, well, standardized because they are the ones that avoid falsing (regardless of how the bitstream is received, the receiver will not accidentally "interpret" a different DCS code if one of the standard codes is used. This is why using so-called inverted DCS codes is stupid.
- DCS Code 1 - 023 DCS
- DCS Code 2 - 025 DCS
- DCS Code 3 - 026 DCS
- DCS Code 4 - 031 DCS
- DCS Code 5 - 032 DCS
- DCS Code 6 - 043 DCS
- DCS Code 7 - 047 DCS
- DCS Code 8 - 051 DCS
- DCS Code 9 - 054 DCS
- DCS Code 10 - 065 DCS
- DCS Code 11 - 071 DCS
- DCS Code 12 - 072 DCS
- DCS Code 13 - 073 DCS
- DCS Code 14 - 074 DCS
- DCS Code 15 - 114 DCS
- DCS Code 16 - 115 DCS
- DCS Code 17 - 116 DCS
- DCS Code 18 - 125 DCS
- DCS Code 19 - 131 DCS
- DCS Code 20 - 132 DCS
- DCS Code 21 - 134 DCS
- DCS Code 22 - 143 DCS
- DCS Code 23 - 152 DCS
- DCS Code 24 - 155 DCS
- DCS Code 25 - 156 DCS
- DCS Code 26 - 162 DCS
- DCS Code 27 - 165 DCS
- DCS Code 28 - 172 DCS
- DCS Code 29 - 174 DCS
- DCS Code 30 - 205 DCS
- DCS Code 31 - 223 DCS
- DCS Code 32 - 226 DCS
- DCS Code 33 - 243 DCS
- DCS Code 34 - 244 DCS
- DCS Code 35 - 245 DCS
- DCS Code 36 - 251 DCS
- DCS Code 37 - 261 DCS
- DCS Code 38 - 263 DCS
- DCS Code 39 - 265 DCS
- DCS Code 40 - 271 DCS
- DCS Code 41 - 306 DCS
- DCS Code 42 - 311 DCS
- DCS Code 43 - 315 DCS
- DCS Code 44 - 331 DCS
- DCS Code 45 - 343 DCS
- DCS Code 46 - 346 DCS
- DCS Code 47 - 351 DCS
- DCS Code 48 - 364 DCS
- DCS Code 49 - 365 DCS
- DCS Code 50 - 371 DCS
- DCS Code 51 - 411 DCS
- DCS Code 52 - 412 DCS
- DCS Code 53 - 413 DCS
- DCS Code 54 - 423 DCS
- DCS Code 55 - 431 DCS
- DCS Code 56 - 432 DCS
- DCS Code 57 - 445 DCS
- DCS Code 58 - 464 DCS
- DCS Code 59 - 465 DCS
- DCS Code 60 - 466 DCS
- DCS Code 61 - 503 DCS
- DCS Code 62 - 506 DCS
- DCS Code 63 - 516 DCS
- DCS Code 64 - 532 DCS
- DCS Code 65 - 546 DCS
- DCS Code 66 - 565 DCS
- DCS Code 67 - 606 DCS
- DCS Code 68 - 612 DCS
- DCS Code 69 - 624 DCS
- DCS Code 70 - 627 DCS
- DCS Code 71 - 631 DCS
- DCS Code 72 - 632 DCS
- DCS Code 73 - 654 DCS
- DCS Code 74 - 662 DCS
- DCS Code 75 - 664 DCS
- DCS Code 76 - 703 DCS
- DCS Code 77 - 712 DCS
- DCS Code 78 - 723 DCS
- DCS Code 79 - 731 DCS
- DCS Code 80 - 732 DCS
- DCS Code 81 - 734 DCS
- DCS Code 82 - 743 DCS
- DCS Code 83 - 754 DCS
- CTCSS (T-CTCS and R-CTCS)
- OFF
- 67.0HZ
- 69.3HZ
- 71.9HZ
- 74.4HZ
- 77.0HZ
- 79.7HZ
- 82.5HZ
- 85.4HZ
- 88.5HZ
- 91.5HZ
- 94.8HZ
- 97.4HZ
- 100.0HZ
- 103.5HZ
- 107.2HZ
- 110.9HZ
- 114.8HZ
- 118.8HZ
- 123.0HZ
- 127.3HZ
- 131.8HZ
- 136.5HZ
- 141.3HZ
- 146.2HZ
- 151.4HZ
- 156.7HZ
- 159.8HZ
- 162.2HZ
- 165.5HZ
- 167.9HZ
- 171.3HZ
- 173.8HZ
- 177.3HZ
- 179.9HZ
- 183.5HZ
- 186.2HZ
- 189.9HZ
- 192.8HZ
- 196.6HZ
- 199.5HZ
- 203.5HZ
- 206.5HZ
- 210.7HZ
- 218.1HZ
- 225.7HZ
- 229.1HZ
- 233.6HZ
- 241.8HZ
- 250.3HZ
- 254.1HZ
- DCS (T-DCS and R-DCS)
- OFF
- D023N
- D025N
- D026N
- D031N
- D032N
- D036N
- D043N
- D047N
- D051N
- D053N
- D054N
- D065N
- D071N
- D072N
- D073N
- D074N
- D114N
- D115N
- D116N
- D122N
- D125N
- D131N
- D132N
- D134N
- D143N
- D145N
- D152N
- D155N
- D156N
- D162N
- D165N
- D172N
- D174N
- D205N
- D212N
- D223N
- D225N
- D226N
- D243N
- D244N
- D245N
- D246N
- D251N
- D252N
- D255N
- D261N
- D263N
- D265N
- D266N
- D271N
- D274N
- D306N
- D311N
- D315N
- D325N
- D331N
- D332N
- D343N
- D346N
- D351N
- D356N
- D364N
- D365N
- D371N
- D411N
- D412N
- D413N
- D423N
- D431N
- D432N
- D445N
- D446N
- D452N
- D454N
- D455N
- D462N
- D464N
- D465N
- D466N
- D503N
- D506N
- D516N
- D523N
- D526N
- D532N
- D546N
- D564N
- D606N
- D612N
- D624N
- D627N
- D631N
- D632N
- D645N
- D654N
- D662N
- D664N
- D703N
- D712N
- D723N
- D731N
- D732N
- D734N
- D743N
- D754N
*Academy Sports and Outdoors
- 467.8750 MHz - 265 DPL
- 467.9000 MHz - 265 DPL
*Ace Hardware
- 464.5000 MHz - 67.0 Hz PL
- 464.5500 MHz - 67.0 Hz PL
- 467.9000 MHz - 85.4 Hz PL
*American Eagle
- 461.0625 MHz - 67.0 Hz PL
- 461.3625 MHz - 67.0 Hz PL
- 466.3375 MHz - 67.0 Hz PL
- 467.7625 MHz - 67.0 Hz PL
- 467.8500 MHz - 67.0 Hz PL
- 467.8750 MHz - 67.0 Hz PL
- 469.5625 MHz - 67.0 Hz PL
*Ann Taylor
Nationwide license WQKL423
- 464.5625 MHz - 94.8 Hz PL
- 466.0375 MHz - 94.8 Hz PL - Ann Taylor LOFT
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
*Anthropologie
- 467.8750 MHz 192.8 Hz PL
*Apple
The Apple Store
- 461.1875 MHz - 67.0 Hz PL
- 461.1875 MHz - 85.4 Hz PL
- 462.8625 MHz - 167.9 Hz PL
- 467.8500 MHz - 79.7 Hz PL
- 467.8750 MHz - 85.4 Hz PL
- 467.9000 MHz - 67.0 Hz PL
- 467.9000 MHz - 71.9 Hz PL
- 467.9000 MHz - 203.5 Hz PL
- 467.9250 MHz - 156.7 Hz PL
*Ashley Home Store
- 462.8125 MHz 67.0 Hz PL
- 462.8375 MHz 67.0 Hz PL
- 462.8625 MHz 67.0 Hz PL
- 462.8875 MHz 67.0 Hz PL
*Bath and Body Works
- 461.0625 MHz D632 632 DPL
- 461.1125 MHz 67.0 Hz PL
- 461.1625 MHz 67.0 Hz PL
- 467.9000 MHz D632 632 DPL
*Bass Pro
- 451.5875 MHz 073 DPL
- 464.5000 MHz 466 DPL
- 468.9375 MHz 703 DPL
- 469.6000 MHz 606 DPL
- 469.8875 MHz 703 DPL
- 461.0375 MHz 445 DPL
- 467.7625 MHz 743 DPL
- 467.9000 MHz 743 DPL
*BJ's Wholesale Club
- 469.4875 MHz - 413 DPL
*Buffalo Wild Wings
*CarMax
- 462.5750 MHz - 026 DPL
- 462.6250 MHz - 127.3 Hz PL
- 462.6250 MHz - 026 DPL
- 462.6750 MHz - 071 DPL
- 462.6750 MHz - 606 DPL
- 462.7250 MHz - 136.5 Hz PL
- 462.7250 MHz - 026 DPL
- 464.3250 MHz - 026 DPL
- 464.5000 MHz - 023 DPL
- 464.5000 MHz - 026 DPL
- 464.5500 MHz - 026 DPL
- 464.8250 MHz - 026 DPL
- 467.8500 MHz - 071 DPL
- 467.8750 MHz - 026 DPL
- 467.8750 MHz - 071 DPL
- 467.9250 MHz - 071 DPL
- 469.5625 MHz - 026 DPL
*Chick-Fil-A
- 462.5500 MHz - 127.3 Hz PL
- 462.5625 MHz - 67.0 Hz PL
- 462.5750 MHz - 654 DPL
- 462.5875 MHz - 118.8 Hz PL
- 462.5875 MHz - 026 DPL
- 462.6000 MHz - 455 DPL
- 462.6125 MHz - 127.3 Hz PL
- 462.6375 MHz - 131.8 Hz PL
- 462.6500 MHz - 351 DPL
- 462.6625 MHz - 88.5 Hz PL
- 462.6625 MHz - 136.5 Hz PL
- 462.6875 MHz - 141.3 Hz PL
- 462.7000 MHz - 192.8 Hz PL
- 462.7000 MHz - 155 DPL
- 462.7125 MHz - 146.2 Hz PL
- 462.7250 MHz - 252 DPL
- 462.7250 MHz - 462 DPL
- 467.5625 MHz - 243 DPL
- 467.5875 MHz - 032 DPL
- 467.6125 MHz - 047 DPL
- 467.6375 MHz - 051 DPL
- 467.6625 MHz - 053 DPL
- 467.6875 MHz - 065 DPL
- 467.7125 MHz - 116 DPL
*Costco
- 462.5500 MHz - 123.0 Hz PL
- 462.6000 MHz - 241.8 Hz PL
- 462.7250 MHz - 250.3 Hz PL
- VHF:
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz
- 151.9850 MHz
- 152.8850 MHz
- 152.9150 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- UHF - license WQLL302, 2w portables narrow FM voice 11K2F3E emission 67.0 Hz PL and 74.4 Hz PL noted in use on these frequencies. 67.0 Hz use confirmed on 468.2125 MHz, 468.3125 MHz.
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.6125 MHz
- 468.6625 MHz
- 451.4125 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5875 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 452.7625 MHz
- 456.4125 MHz
- 456.5125 MHz
- 456.6125 MHz
- 456.6875 MHz
- 457.7625 MHz
- 467.7625 MHz
- 467.8125 MHz
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
- 467.8500 MHz Channel 1
- 467.8750 MHz Channel 2
- 467.9000 MHz Channel 3
- 467.9250 MHz Channel 4
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.6125 MHz
- 468.6625 MHz - 127.3 Hz PL
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
*DSW
- 450.0000 MHz - 82.5 Hz PL
- 450.0000 MHz - 88.5 Hz PL
- 456.8250 MHz - 127.3 Hz PL
- 457.5750 MHz - 107.2 Hz PL
- 461.0375 MHz - 023 DPL
- 461.1125 MHz - 025 DPL
- 462.4250 MHz - 103.5 Hz PL
- 462.5250 MHz - 114.8 Hz PL
- 462.8250 MHz - 162.2 Hz PL
- 462.9250 MHz - 025 DPL
- 464.3250 MHz - 023 DPL
- 466.0875 MHz - 464 DPL
- 467.8375 MHz - 88.5 Hz PL
- 467.9000 MHz - 145 DPL
- 469.5000 MHz - 023 DPL
*Fresh Market
There appears to be significant variation in the frequencies and/or tones used, depending on local conditions, other nearby stores using the same frequency and/or PL/DPL tone/code.
- 464.5500 MHz - 77.0 Hz PL
- 467.8500 MHz - 88.5 Hz PL
- 467.9250 MHz - 100.0 Hz PL
- 467.7625 MHz - 205 DPL
- 467.8125 MHz - 205 DPL
- 467.8500 MHz - 205 DPL
- 467.9250 MHz - 205 DPL
*Giant Foods
- 467.8500 MHz - 412 DPL
- 467.9000 MHz - 412 DPL
*H & M
- 450.2250 MHz - 023 DPL
- 466.2875 MHz - 155 DPL
- 467.1375 MHz - 155 DPL
- 468.8375 MHz - 155 DPL
- 469.0000 MHz - 103.5 Hz PL
- 469.7625 MHz - 155 DPL
- 469.9500 MHz - 203.5 Hz PL
- 467.7625 MHz - 107.2 Hz PL
- 467.8125 MHz - 346 DPL
- 467.8500 MHz - 343 DPL
- 467.8500 MHz - 411 DPL
- 467.8500 MHz - 631 DPL
- 467.8750 MHz - 343 DPL
- 467.8750 MHz - 411 DPL
- 467.9000 MHz - 343 DPL
- 467.9000 MHz - 346 DPL
- 467.9250 MHz - 67.0 Hz PL
- 467.9250 MHz - 85.4 Hz PL
- 467.9250 MHz - 88.5 Hz PL
- 467.9250 MHz - 343 DPL
*Hard Rock Cafe
- 462.8875 MHz - 205 DPL
- 467.8375 MHz - 205 DPL
- 467.8500 MHz 146.2 Hz PL
- 458.6625 MHz 186.2 Hz PL
- 464.5000 MHz 186.2 Hz PL
- 464.5500 MHz 186.2 Hz PL
- 469.2625 MHz 186.2 Hz PL
- 469.5000 MHz 186.2 Hz PL
- 469.5500 MHz 186.2 Hz PL
- Nationwide UHF on-site channel plan below. FRS frequencies are in use at numerous stores. Some stores use different CTCSS (PL) tones and/or different DCS (DPL) codes.
*Home Goods
- 467.8750 MHz 100.0 Hz PL
- 469.4875 MHz 210.7 Hz PL
*JC Penny
- 467.2250 MHz 365 DPL - Nationwide Channel 1 (simplex)
- 461.1750 MHz
- 461.5875 MHz
- 461.7125 MHz
- 461.8375 MHz
- 461.9375 MHz 732 DPL / 732 DCS
- 463.6375 MHz 179.9 Hz PL
- 463.7250 MHz 85.4 Hz PL
- 464.7375 MHz 179.9 Hz PL
- 466.2625 MHz 85.4 Hz PL
- 466.9625 MHz 85.4 Hz PL
- 468.7250 MHz 85.4 Hz PL
- 467.8750 MHz - 100.0 Hz PL
- 467.9000 MHz - 100.0 Hz PL
*Loft
- 151.6250 MHz - 110.9 Hz PL
- 151.8200 MHz - 110.9 Hz PL
- 151.8800 MHz - 110.9 Hz PL
- 151.9400 MHz - 110.9 Hz PL
- 151.9550 MHz - 110.9 Hz PL
- 154.4900 MHz - 110.9 Hz PL
- 154.5700 MHz - 110.9 Hz PL
- 154.6000 MHz - 110.9 Hz PL
- 461.0375 MHz
- 461.1125 MHz
- 461.2125 MHz
- 462.7625 MHz
- 462.8125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 466.0375 MHz
- 466.1125 MHz
- 466.1375 MHz
- 469.4875 MHz
- 469.5375 MHz
*Marshall's
- 461.2375 MHz 100.0 Hz
*Northern Tool + Equipment
- 462.5500 MHz 71.9 Hz
- 462.5500 MHz 123.0 Hz
- 462.6000 MHz 241.8 Hz
- 462.6250 MHz 127.3 Hz
- 462.6500 MHz 218.1 Hz
- 462.7000 MHz 118.8 Hz
- 462.7000 MHz 192.8 Hz
- 467.8750 MHz - 131 DPL
- 467.9000 MHz - 131 DPL
*Party City
- 467.8125 MHz - 67.0 Hz PL
- 464.5000 MHz - 162.2 Hz PL
- 464.5500 MHz - 162.2 Hz PL
*PetCo
Nationwide license WQKY366
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
*Pottery Barn
- 467.8750 MHz - 165 DPL
- 151.625 MHz - 97.4 Hz PL
- 151.700 MHz - 71.9 Hz PL
- 151.700 MHz - 79.7 Hz PL
*Regal Cinemas
- 464.3250 MHz - 100.0 Hz PL
- 464.8250 MHz - 100.0 Hz PL
- 464.8750 MHz - 100.0 Hz PL
*Sears
- 461.1625 MHz - 413 DPL
- 464.5250 MHz - 131.8 Hz PL
- 464.5500 MHz - 118.8 Hz PL
- 468.4875 MHz - 103.5 Hz PL
*Sephora
- 461.1125 MHz - 412 DPL
- 461.2125 MHz - 412 DPL
- 461.3125 MHz - 412 DPL
- 464.5000 MHz - 413 DPL
- 464.5500 MHz - 413 DPL
- 467.8500 MHz - 225.7 Hz PL
- 467.8500 MHz - D047 047 DPL
- 467.8500 MHz - D306 306 DPL
- 467.8500 MHz - D331 331 DPL
- 467.9000 MHz - 225.7 Hz PL - Primary nationwide frequency and tone
- 467.9250 MHz - 225.7 Hz PL
- 467.7500 MHz D115 115 DPL - Channel 1
- 467.7750 MHz D072 072 DPL - Channel 2
- 467.9000 MHz D115 115 DPL - Channel 3
- 467.4875 MHz D072 072 DPL - Channel 4
- 467.5125 MHz D115 115 DPL - Channel 5
- 151.6250 MHz 179.9 Hz PL
- 151.9550 MHz 179.9 Hz PL
- 151.9250 MHz 506 DPL
- 151.8950 MHz 506 DPL
*Texas Roadhouse
- 464.5500 MHz 67.0 Hz PL
- 467.8500 MHz 67.0 Hz PL
- 467.8750 MHz 67.0 Hz PL
- 467.9250 MHz 67.0 Hz PL
- 467.7625 MHz 71.9 Hz PL
- 467.8500 MHz D047 047 DPL - Old Navy - Appears to be primary UHF
- 467.9250 MHz D311 311 DPL
*TJ Maxx
- 467.8500 MHz 100.0 Hz PL
- 469.4875 MHz 210.7 Hz PL - shared with Home Goods (same parent company - TJX Companies, see also: Marshall's)
*Tractor Supply
- 450.2250 MHz 023 DPL
*Urban Outfitters
- 467.9250 MHz 218.1 Hz PL
*Victoria’s Secret
- 467.7625 MHz - 743 DPL
- 467.8125 MHz - 743 DPL
- 467.8500 MHz - 743 DPL
- 467.9000 MHz - 743 DPL
- 467.9250 MHz - 743 DPL - Possible Primary
- 469.4875 MHz - 743 DPL
- 469.5375 MHz - 743 DPL - Possible Secondary / Alternate
- 151.5050 MHz
- 151.6250 MHz
- 151.7000 MHz
- 151.8200 MHz - 413 DPL
- 151.8800 MHz
- 151.9250 MHz
- 151.9400 MHz - 174 DPL
- 151.9550 MHz
- 154.5700 MHz - 413 DPL
- 154.6000 MHz - 074 DPL, 174 DPL, 413 DPL
- 158.4000 MHz - 174 DPL
- 451.8000 MHz
- 451.8125 MHz - 306 DPL, 506 DPL, 612 DPL, 654 DPL, 664 DPL
- 456.8125 MHz - 506 DPL, 662 DPL
- 074 DPL, 174 DPL, 306 DPL, 413 DPL, 423 DPL, 432 DPL, 445 DPL, 506 DPL, 612 DPL, 654 DPL, and 664 DPL reported, others likely in use. WAWA was licensed under callsign WQQU922 for:
- 154.5700 MHz - Primary
- 154.6000 MHz - Primary
- 151.8200 MHz
- 151.8800 MHz
- 151.9400 MHz
- 151.6250 MHz
- 151.7600 MHz
- 151.7750 MHz
- 151.8200 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.9550 MHz
- 461.0375 MHz 172 DPL
- 461.0875 MHz 223 DPL
- 461.1125 MHz 172 DPL
- 461.1875 MHz 172 DPL
- 461.3625 MHz 172 DPL
- 464.5000 MHz 172 DPL
- 464.5500 MHz 172 DPL
- 464.5500 MHz 223 DPL
- 469.5000 MHz 172 DPL
- 469.5500 MHz 172 DPL
- 469.5500 MHz 223 DPL
*Whole Foods
- 464.5000 MHz 67.0 Hz PL
- 464.5000 MHz 97.4 Hz PL
- 464.5500 MHz 466 DPL / 466 DCS
- 467.8500 MHz 351 DPL / 351 DCS
- 467.9000 MHz 67.0 Hz PL
- 467.9250 MHz 74.4 Hz PL
- 467.9250 MHz 351 DPL / 351 DCS
