| 25.160 MHz | |
| 25.200 MHz | |
| 25.240 MHz | |
| 25.280 MHz | |
| 25.320 MHz | |
| 27.430 MHz | |
| 27.450 MHz | |
| 27.470 MHz | |
| 29.710 MHz | |
| 29.730 MHz | |
| 29.750 MHz | |
| 29.770 MHz | |
| 29.790 MHz | |
| 30.580 MHz | |
| 30.600 MHz | |
| 30.620 MHz | |
| 30.680 MHz | |
| 30.720 MHz | |
| 30.760 MHz | |
| 30.800 MHz | |
| 30.880 MHz | |
| 30.920 MHz | |
| 30.960 MHz | |
| 31.000 MHz | |
| 31.040 MHz | |
| 31.080 MHz | |
| 31.120 MHz | |
| 31.160 MHz | |
| 31.200 MHz | |
| 31.240 MHz | |
| 31.280 MHz | |
| 31.320 MHz | |
| 31.360 MHz | |
| 31.400 MHz | |
| 31.440 MHz | |
| 31.480 MHz | |
| 31.520 MHz | |
| 31.560 MHz | |
| 31.600 MHz | |
| 31.640 MHz | |
| 31.680 MHz | |
| 31.720 MHz | |
| 31.760 MHz | |
| 31.800 MHz | |
| 31.840 MHz | |
| 31.880 MHz | |
| 31.920 MHz | |
| 31.960 MHz | |
| 33.160 MHz | |
| 33.180 MHz | |
| 33.200 MHz | |
| 33.220 MHz | |
| 33.240 MHz | |
| 33.260 MHz | |
| 33.280 MHz | |
| 33.300 MHz | |
| 33.320 MHz | |
| 33.340 MHz | |
| 33.360 MHz | |
| 33.380 MHz | |
| 35.060 MHz | |
| 35.080 MHz | |
| 35.100 MHz | |
| 35.120 MHz | |
| 35.160 MHz | |
| 35.280 MHz | |
| 35.320 MHz | |
| 35.360 MHz | |
| 35.400 MHz | |
| 35.440 MHz | |
| 35.480 MHz | |
| 35.520 MHz | |
| 35.700 MHz | |
| 35.720 MHz | |
| 35.740 MHz | |
| 35.760 MHz | |
| 35.780 MHz | |
| 35.820 MHz | |
| 35.840 MHz | |
| 35.860 MHz | |
| 35.880 MHz | |
| 35.900 MHz | |
| 35.920 MHz | |
| 35.940 MHz | |
| 35.960 MHz | |
| 35.980 MHz | |
| 37.440 MHz | |
| 37.460 MHz | |
| 37.480 MHz | |
| 37.500 MHz | |
| 37.520 MHz | |
| 37.520 MHz | |
| 37.560 MHz | |
| 37.580 MHz | |
| 37.620 MHz | |
| 37.640 MHz | |
| 37.660 MHz | |
| 37.680 MHz | |
| 37.700 MHz | |
| 37.720 MHz | |
| 37.760 MHz | |
| 37.780 MHz | |
| 37.800 MHz | |
| 37.820 MHz | |
| 37.840 MHz | |
| 37.860 MHz | |
| 37.880 MHz | |
| 42.960 MHz | |
| 43.000 MHz | |
| 43.020 MHz | |
| 43.060 MHz | |
| 43.080 MHz | |
| 43.100 MHz | |
| 43.120 MHz | |
| 43.140 MHz | |
| 43.180 MHz | |
| 43.280 MHz | |
| 43.320 MHz | |
| 43.360 MHz | |
| 43.400 MHz | |
| 43.440 MHz | |
| 43.480 MHz | |
| 43.520 MHz | |
| 43.700 MHz | |
| 43.760 MHz | |
| 43.780 MHz | |
| 43.860 MHz | |
| 43.880 MHz | |
| 43.900 MHz | |
| 43.940 MHz | |
| 44.000 MHz | |
| 44.020 MHz | |
| 44.040 MHz | |
| 44.060 MHz | |
| 44.080 MHz | |
| 44.140 MHz | |
| 44.220 MHz | |
| 44.240 MHz | |
| 44.260 MHz | |
| 44.280 MHz | |
| 44.300 MHz | |
| 44.340 MHz | |
| 44.380 MHz | |
| 44.420 MHz | |
| 44.440 MHz | |
| 44.500 MHz | |
| 44.520 MHz | |
| 44.540 MHz | |
| 44.560 MHz | |
| 44.600 MHz | |
| 47.440 MHz | |
| 47.480 MHz | |
| 47.520 MHz | |
| 47.560 MHz | |
| 47.600 MHz | |
| 47.640 MHz | |
| 47.680 MHz | |
| 47.700 MHz | |
| 47.720 MHz | |
| 47.740 MHz | |
| 47.760 MHz | |
| 47.780 MHz | |
| 47.800 MHz | |
| 47.820 MHz | |
| 47.840 MHz | |
| 47.860 MHz | |
| 47.880 MHz | |
| 47.900 MHz | |
| 47.920 MHz | |
| 47.940 MHz | |
| 47.960 MHz | |
| 47.980 MHz | |
| 48.000 MHz | |
| 48.020 MHz | |
| 48.040 MHz | |
| 48.060 MHz | |
| 48.080 MHz | |
| 48.100 MHz | |
| 48.120 MHz | |
| 48.140 MHz | |
| 48.160 MHz | |
| 48.180 MHz | |
| 48.200 MHz | |
| 48.220 MHz | |
| 48.240 MHz | |
| 48.260 MHz | |
| 48.280 MHz | |
| 48.300 MHz | |
| 48.320 MHz | |
| 48.340 MHz | |
| 48.360 MHz | |
| 48.380 MHz | |
| 48.400 MHz | |
| 48.420 MHz | |
| 48.440 MHz | |
| 48.480 MHz | |
| 48.500 MHz | |
| 48.520 MHz | |
| 48.540 MHz | |
| 48.560 MHz | |
| 48.580 MHz | |
| 48.600 MHz | |
| 48.620 MHz | |
| 48.640 MHz | |
| 48.660 MHz | |
| 48.680 MHz | |
| 48.700 MHz | |
| 48.720 MHz | |
| 48.740 MHz | |
| 48.760 MHz | |
| 48.780 MHz | |
| 48.800 MHz | |
| 48.820 MHz | |
| 48.840 MHz | |
| 48.860 MHz | |
| 48.880 MHz | |
| 48.900 MHz | |
| 48.920 MHz | |
| 48.940 MHz | |
| 48.960 MHz | |
| 48.980 MHz | |
| 49.000 MHz | |
| 49.020 MHz | |
| 49.040 MHz | |
| 49.060 MHz | |
| 49.080 MHz | |
| 49.100 MHz | |
| 49.120 MHz | |
| 49.140 MHz | |
| 49.160 MHz | |
| 49.180 MHz | |
| 49.200 MHz | |
| 49.220 MHz | |
| 49.240 MHz | |
| 49.260 MHz | |
| 49.280 MHz | |
| 49.300 MHz | |
| 49.320 MHz | |
| 49.340 MHz | |
| 49.360 MHz | |
| 49.380 MHz | |
| 49.400 MHz | |
| 49.420 MHz | |
| 49.440 MHz | |
| 49.480 MHz | |
| 49.500 MHz | |
| 49.520 MHz | |
| 49.540 MHz | |
| 49.560 MHz | |
| 49.580 MHz |
| Frequency (MHz) |
| 72.020 MHz |
| 72.040 MHz |
| 72.060 MHz |
| 72.100 MHz |
| 72.120 MHz |
| 72.140 MHz |
| 72.180 MHz |
| 72.200 MHz |
| 72.220 MHz |
| 72.260 MHz |
| 72.280 MHz |
| 72.300 MHz |
| 72.340 MHz |
| 72.360 MHz |
| 72.380 MHz |
| 152.4725 MHz | |
| 154.4825 MHz | |
| 154.490 MHz | |
| 154.4975 MHz | |
| 154.515 MHz | |
| 154.540 MHz | |
| 154.5475 MHz | |
| 154.555 MHz | |
| 157.7325 MHz | |
| 158.4525 MHz | |
| 158.460 MHz | |
| 173.2375 MHz | |
| 173.250 MHz | |
| 173.2625 MHz | |
| 173.275 MHz | |
| 173.2875 MHz | |
| 173.300 MHz | |
| 173.3125 MHz | |
| 173.325 MHz | |
| 173.3375 MHz | |
| 173.350 MHz | |
| 173.3625 MHz | |
| 173.390 MHz | |
UHF Band 406-413 MHz
| 409.675 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
| 409.725 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
| 412.625 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
Like the UHF-T (UHF-TV) band 470-512 MHz, the 421-430 MHz band was allocated to alleviate pressure in large metro areas where frequency congestion is a significant problem.  Detroit, Cleveland and Buffalo are located near large Canadian cities.  Frequency coordination with Canada is performed for license authorization in these areas.
- 451.18125 MHz
- 451.1875 MHz
- 451.19375 MHz
- 451.28125 MHz
- 451.2875 MHz
- 451.29375 MHz
- 451.30625 MHz
- 451.3125 MHz
- 451.31875 MHz
- 451.35625 MHz
- 451.3625 MHz
- 451.36875 MHz
- 451.38125 MHz
- 451.3875 MHz
- 451.39375 MHz
- 451.40625 MHz
- 451.41875 MHz
- 451.45625 MHz
- 451.4625 MHz
- 451.46875 MHz
- 451.48125 MHz
- 451.4875 MHz
- 451.49375 MHz
- 451.50625 MHz
- 451.5125 MHz
- 451.51875 MHz
- 451.55625 MHz
- 451.5625 MHz
- 451.56875 MHz
- 451.58125 MHz
- 451.5875 MHz
- 451.59375 MHz
- 451.60625 MHz
- 451.6125 MHz
- 451.61875 MHz
- 451.65625 MHz
- 451.6625 MHz
- 451.66875 MHz
- 451.68125 MHz
- 451.6875 MHz
- 451.69375 MHz
- 451.70625 MHz
- 451.7125 MHz
- 451.71875 MHz
- 451.73125 MHz
- 451.7375 MHz
- 451.74375 MHz
- 451.75625 MHz
- 451.7625 MHz
- 451.76875 MHz
- 452.03125 MHz
- 452.0375 MHz
- 452.04375 MHz
- 452.05625 MHz
- 452.0625 MHz
- 452.06875 MHz
- 452.08125 MHz
- 452.0875 MHz
- 452.09375 MHz
- 452.10625 MHz
- 452.1125 MHz
- 452.11875 MHz
- 452.13125 MHz
- 452.1375 MHz
- 452.14375 MHz
- 452.15625 MHz
- 452.1625 MHz
- 452.16875 MHz
- 452.18125 MHz
- 452.1875 MHz
- 452.19375 MHz
- 452.28125 MHz
- 452.2875 MHz
- 452.29375 MHz
- 452.48125 MHz
- 452.4875 MHz
- 452.49375 MHz
- 452.53125 MHz
- 452.5375 MHz
- 452.54375 MHz
- 452.63125 MHz
- 452.6375 MHz
- 452.64375 MHz
- 452.65625 MHz
- 452.6625 MHz
- 452.66875 MHz
- 452.68125 MHz
- 452.6875 MHz
- 452.69375 MHz
- 452.70625 MHz
- 452.7125 MHz
- 452.71875 MHz
- 452.78125 MHz
- 452.7875 MHz
- 452.79375 MHz
- 452.80625 MHz
- 452.8125 MHz
- 452.81875 MHz
- 452.83125 MHz
- 452.8375 MHz
- 452.84375 MHz
- 452.88125 MHz
- 452.8875 MHz
- 452.89375 MHz
- 452.98125 MHz
- 452.9875 MHz
- 452.99375 MHz
- 456.18125 MHz
- 456.1875 MHz
- 456.19375 MHz
- 456.28125 MHz
- 456.2875 MHz
- 456.29375 MHz
- 456.30625 MHz
- 456.3125 MHz
- 456.31875 MHz
- 456.35625 MHz
- 456.3625 MHz
- 456.36875 MHz
- 456.38125 MHz
- 456.3875 MHz
- 456.39375 MHz
- 456.40625 MHz
- 456.41875 MHz
- 456.45625 MHz
- 456.4625 MHz
- 456.46875 MHz
- 456.48125 MHz
- 456.4875 MHz
- 456.49375 MHz
- 456.50625 MHz
- 456.5125 MHz
- 456.51875 MHz
- 456.55625 MHz
- 456.5625 MHz
- 456.56875 MHz
- 456.58125 MHz
- 456.5875 MHz
- 456.59375 MHz
- 456.60625 MHz
- 456.6125 MHz
- 456.61875 MHz
- 456.65625 MHz
- 456.6625 MHz
- 456.66875 MHz
- 456.68125 MHz
- 456.6875 MHz
- 456.69375 MHz
- 456.70625 MHz
- 456.7125 MHz
- 456.71875 MHz
- 456.73125 MHz
- 456.7375 MHz
- 456.74375 MHz
- 456.75625 MHz
- 456.7625 MHz
- 456.76875 MHz
- 457.03125 MHz
- 457.0375 MHz
- 457.04375 MHz
- 457.05625 MHz
- 457.0625 MHz
- 457.06875 MHz
- 457.08125 MHz
- 457.0875 MHz
- 457.09375 MHz
- 457.10625 MHz
- 457.1125 MHz
- 457.11875 MHz
- 457.13125 MHz
- 457.1375 MHz
- 457.14375 MHz
- 457.15625 MHz
- 457.1625 MHz
- 457.16875 MHz
- 457.18125 MHz
- 457.1875 MHz
- 457.19375 MHz
- 457.28125 MHz
- 457.2875 MHz
- 457.29375 MHz
- 457.48125 MHz
- 457.4875 MHz
- 457.49375 MHz
- 457.63125 MHz
- 457.6375 MHz
- 457.64375 MHz
- 457.65625 MHz
- 457.6625 MHz
- 457.66875 MHz
- 457.68125 MHz
- 457.6875 MHz
- 457.69375 MHz
- 457.70625 MHz
- 457.7125 MHz
- 457.71875 MHz
- 457.78125 MHz
- 457.7875 MHz
- 457.79375 MHz
- 457.80625 MHz
- 457.8125 MHz
- 457.81875 MHz
- 457.83125 MHz
- 457.8375 MHz
- 457.84375 MHz
- 457.88125 MHz
- 457.8875 MHz
- 457.89375 MHz
- 457.98125 MHz
- 457.9875 MHz
- 457.99375 MHz
- 462.18125 MHz
- 462.1875 MHz
- 462.19375 MHz
- 462.45625 MHz
- 462.4625 MHz
- 462.46875 MHz
- 462.48125 MHz
- 462.4875 MHz
- 462.49375 MHz
- 462.50625 MHz
- 462.5125 MHz
- 462.51875 MHz
- 467.18125 MHz
- 467.1875 MHz
- 467.19375 MHz
- 467.45625 MHz
- 467.4625 MHz
- 467.46875 MHz
- 467.48125 MHz
- 467.4875 MHz
- 467.49375 MHz
- 467.50625 MHz
- 467.5125 MHz
- 467.51875 MHz
- 451.23125 MHz
- 451.2375 MHz
- 451.24375 MHz
- 451.33125 MHz
- 451.3375 MHz
- 451.34375 MHz
- 451.43125 MHz
- 451.4375 MHz
- 451.44375 MHz
- 451.53125 MHz
- 451.5375 MHz
- 451.54375 MHz
- 451.63125 MHz
- 451.6375 MHz
- 451.64375 MHz
- 452.30625 MHz
- 452.3125 MHz
- 452.31875 MHz
- 452.40625 MHz
- 452.4125 MHz
- 452.41875 MHz
- 452.50625 MHz
- 452.5125 MHz
- 452.51875 MHz
- 452.75625 MHz
- 452.7625 MHz
- 452.76875 MHz
- 452.85625 MHz
- 452.8625 MHz
- 452.86875 MHz
- 456.23125 MHz
- 456.2375 MHz
- 456.24375 MHz
- 456.33125 MHz
- 456.3375 MHz
- 456.34375 MHz
- 456.43125 MHz
- 456.4375 MHz
- 456.44375 MHz
- 456.53125 MHz
- 456.5375 MHz
- 456.54375 MHz
- 456.63125 MHz
- 456.6375 MHz
- 456.64375 MHz
- 457.30625 MHz
- 457.3125 MHz
- 457.31875 MHz
- 457.40625 MHz
- 457.4125 MHz
- 457.41875 MHz
- 457.50625 MHz
- 457.5125 MHz
- 457.51875 MHz
- 457.75625 MHz
- 457.7625 MHz
- 457.76875 MHz
- 457.85625 MHz
- 457.8625 MHz
- 457.86875 MHz
- 462.20625 MHz
- 462.2125 MHz
- 462.21875 MHz
- 462.23125 MHz
- 462.2375 MHz
- 462.24375 MHz
- 462.25625 MHz
- 462.2625 MHz
- 462.26875 MHz
- 462.28125 MHz
- 462.2875 MHz
- 462.29375 MHz
- 462.30625 MHz
- 462.3125 MHz
- 462.31875 MHz
- 462.33125 MHz
- 462.3375 MHz
- 462.34375 MHz
- 462.35625 MHz
- 462.3625 MHz
- 462.36875 MHz
- 462.38125 MHz
- 462.3875 MHz
- 462.39375 MHz
- 462.40625 MHz
- 462.4125 MHz
- 462.41875 MHz
- 462.43125 MHz
- 462.4375 MHz
- 462.44375 MHz
- 467.20625 MHz
- 467.2125 MHz
- 467.21875 MHz
- 467.23125 MHz
- 467.2375 MHz
- 467.24375 MHz
- 467.25625 MHz
- 467.2625 MHz
- 467.26875 MHz
- 467.28125 MHz
- 467.2875 MHz
- 467.29375 MHz
- 467.30625 MHz
- 467.3125 MHz
- 467.31875 MHz
- 467.33125 MHz
- 467.3375 MHz
- 467.34375 MHz
- 467.35625 MHz
- 467.3625 MHz
- 467.36875 MHz
- 467.38125 MHz
- 467.3875 MHz
- 467.39375 MHz
- 467.40625 MHz
- 467.4125 MHz
- 467.41875 MHz
- 467.43125 MHz
- 467.4375 MHz
- 467.44375 MHz
- 461.03125 MHz
- 461.0375 MHz
- 461.04375 MHz
- 461.05625 MHz
- 461.0625 MHz
- 461.06875 MHz
- 461.08125 MHz
- 461.0875 MHz
- 461.09375 MHz
- 461.10625 MHz
- 461.1125 MHz
- 461.11875 MHz
- 461.13125 MHz
- 461.1375 MHz
- 461.14375 MHz
- 461.15625 MHz
- 461.1625 MHz
- 461.16875 MHz
- 461.18125 MHz
- 461.1875 MHz
- 461.19375 MHz
- 461.20625 MHz
- 461.2125 MHz
- 461.21875 MHz
- 461.23125 MHz
- 461.2375 MHz
- 461.24375 MHz
- 461.25625 MHz
- 461.2625 MHz
- 461.26875 MHz
- 461.28125 MHz
- 461.2875 MHz
- 461.29375 MHz
- 461.30625 MHz
- 461.3125 MHz
- 461.31875 MHz
- 461.33125 MHz
- 461.3375 MHz
- 461.34375 MHz
- 461.35625 MHz
- 461.3625 MHz
- 461.36875 MHz
- 462.7625 MHz
- 462.7875 MHz
- 462.8125 MHz
- 462.8375 MHz
- 462.8625 MHz
- 462.8875 MHz
- 462.9125 MHz
- 464.4875 MHz
- 464.48125 MHz
- 464.5125 MHz
- 464.51875 MHz
- 464.53125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 464.56875 MHz
- 466.03125 MHz
- 466.0375 MHz
- 466.04375 MHz
- 466.05625 MHz
- 466.0625 MHz
- 466.06875 MHz
- 466.08125 MHz
- 466.0875 MHz
- 466.09375 MHz
- 466.10625 MHz
- 466.1125 MHz
- 466.11875 MHz
- 466.13125 MHz
- 466.1375 MHz
- 466.14375 MHz
- 466.15625 MHz
- 466.1625 MHz
- 466.16875 MHz
- 466.18125 MHz
- 466.1875 MHz
- 466.19375 MHz
- 466.20625 MHz
- 466.2125 MHz
- 466.21875 MHz
- 466.23125 MHz
- 466.2375 MHz
- 466.24375 MHz
- 466.25625 MHz
- 466.2625 MHz
- 466.26875 MHz
- 466.28125 MHz
- 466.2875 MHz
- 466.29375 MHz
- 466.30625 MHz
- 466.3125 MHz
- 466.31875 MHz
- 466.33125 MHz
- 466.3375 MHz
- 466.34375 MHz
- 466.35625 MHz
- 466.3625 MHz
- 466.36875 MHz
- 467.8625 MHz
- 467.8875 MHz
- 467.9125 MHz
- 469.4875 MHz
- 469.48125 MHz
- 469.5125 MHz
- 469.51875 MHz
- 469.53125 MHz
- 469.5375 MHz
- 469.5625 MHz
- 469.56875 MHz
- 460.90625 MHz
- 460.9125 MHz
- 460.91875 MHz
- 460.93125 MHz
- 460.9375 MHz
- 460.94375 MHz
- 460.95625 MHz
- 460.9625 MHz
- 460.96875 MHz
- 460.98125 MHz
- 460.9875 MHz
- 460.99375 MHz
- 461.00625 MHz
- 461.0125 MHz
- 461.01875 MHz
- 465.90625 MHz
- 465.9125 MHz
- 465.91875 MHz
- 465.93125 MHz
- 465.9375 MHz
- 465.94375 MHz
- 465.95625 MHz
- 465.9625 MHz
- 465.96875 MHz
- 465.98125 MHz
- 465.9875 MHz
- 465.99375 MHz
- 466.00625 MHz
- 466.0125 MHz
- 466.01875 MHz
Retevis is now offering a 900 MHz license free ISM radio the Retevis RT10. 902-928 MHz, 12.5 kHz channel spacing...128 channel memory, AMBE++ vocoder or SELP vocoder 8K00F3E FM voice (analog mode?!) and 7K60FXE (which is DMR digital voice). 1 watt output. ETSI-TS102 361-1,-2 specification.
- one set of 68 channel pairs
- 160 available channel pairs
- 22 available channel pairs
Often heard at construction sites, special events, shopping malls, stores, gas stations, etc.  There is also movement in the hunting community away from CB/11 meter and VHF marine towards licensed Part 90 land mobile/business radio systems.  See hunt club radio frequencies and American militia tactical frequencies and channel plans for VHF/UHF and UHF radios - Baofeng, etc..
- 151.5125 MHz - Itinerant
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8050 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz - Purple Dot
- 152.8850 MHz
- 152.9000 MHz
- 152.9150 MHz
- 152.9450 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- 154.5475 MHz
- 158.4000 MHz - Itinerant
- 158.4075 MHz - Itinerant
- 451.1875 MHz
- 451.2375 MHz
- 451.2875 MHz
- 451.3125 MHz
- 451.3375 MHz
- 451.3625 MHz
- 451.3875 MHz
- 451.4375 MHz
- 451.4625 MHz
- 451.4875 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5625 MHz
- 451.5875 MHz
- 451.6125 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 451.7125 MHz
- 451.7375 MHz
- 451.7625 MHz
- 452.0375 MHz
- 452.0625 MHz
- 452.0875 MHz
- 452.1125 MHz
- 452.1375 MHz
- 452.1625 MHz
- 452.1875 MHz
- 452.2875 MHz
- 452.3125 MHz
- 452.4125 MHz
- 452.4875 MHz
- 452.5125 MHz
- 452.5375 MHz
- 452.6375 MHz
- 452.6625 MHz
- 452.6875 MHz
- 452.7125 MHz
- 452.7625 MHz
- 452.7875 MHz
- 452.8125 MHz
- 452.8375 MHz
- 452.8625 MHz
- 452.8875 MHz
- 452.9875 MHz
- 456.1875 MHz
- 456.2375 MHz
- 456.2875 MHz
- 456.3125 MHz
- 456.3375 MHz
- 456.3625 MHz
- 456.3875 MHz
- 456.4375 MHz
- 456.4625 MHz
- 456.4875 MHz
- 456.5125 MHz
- 456.5375 MHz
- 456.5625 MHz
- 456.5875 MHz
- 456.6125 MHz
- 456.6375 MHz
- 456.6625 MHz
- 456.6875 MHz
- 456.7125 MHz
- 456.7375 MHz
- 456.7625 MHz
- 457.0375 MHz
- 457.0625 MHz
- 457.0875 MHz
- 457.1125 MHz
- 457.1375 MHz
- 457.1625 MHz
- 457.1875 MHz
- 457.2875 MHz
- 457.3125 MHz
- 457.4125 MHz
- 457.4875 MHz
- 457.5125 MHz
- 457.6375 MHz
- 457.6625 MHz
- 457.7125 MHz
- 457.7375 MHz
- 457.7625 MHz
- 457.7875 MHz
- 457.8125 MHz
- 457.8375 MHz
- 457.8625 MHz
- 457.8875 MHz
- 457.9875 MHz
- 461.0375 MHz
- 461.0625 MHz
- 461.0875 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.1625 MHz
- 461.1875 MHz
- 461.2125 MHz
- 461.2375 MHz
- 461.2625 MHz
- 461.2875 MHz
- 461.3125 MHz
- 461.3375 MHz
- 461.3625 MHz
- 462.1875 MHz
- 462.4625 MHz
- 462.4875 MHz
- 462.5125 MHz
- 463.2125 MHz
- 463.2625 MHz
- 463.3125 MHz
- 463.3375 MHz
- 463.3625 MHz
- 463.4125 MHz
- 463.4625 MHz
- 463.5125 MHz
- 463.5625 MHz
- 463.5875 MHz
- 463.6125 MHz
- 463.6375 MHz
- 464.4875 MHz - Itinerant
- 464.5125 MHz - Itinerant
- 464.5375 MHz - Itinerant
- 464.5625 MHz - Itinerant
- 466.0375 MHz
- 466.0625 MHz
- 466.0875 MHz
- 466.1125 MHz
- 466.1375 MHz
- 466.1625 MHz
- 466.1875 MHz
- 466.2125 MHz
- 466.2375 MHz
- 466.2625 MHz
- 466.2875 MHz
- 466.3125 MHz
- 466.3375 MHz
- 466.3625 MHz
- 467.1875 MHz
- 467.4625 MHz
- 467.4875 MHz
- 467.5125 MHz
- 467.7875 MHz - 2 watts
- 467.8375 MHz - 2 watts
- 467.8625 MHz - 2 watts
- 467.8875 MHz - 2 watts
- 467.9125 MHz - 2 watts
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3375 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.5875 MHz
- 468.6125 MHz
- 468.6375 MHz
- 469.4875 MHz - Itinerant
- 469.5125 MHz - Itinerant
- 469.5375 MHz - Itinerant
- 469.5625 MHz - Itinerant
Do I need a license to transmit on 151.625 MHz? Yes, you do.  You need a license to use all the business band frequencies, including 151.625 MHz, 151.505 MHz, 158.400 MHz, 151.955 MHz, 151.700 MHz, 151.760 MHz, 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.875 MHz, 467.900 MHz, etc.  Only the 22 FRS frequencies, the 5 MURS frequencies and the 40 CB channels do not require a license.  Getting a business license for the Itinerant channels is extremely easy.
- 464.5500 MHz
- 464.5000 MHz
- 467.9250 MHz
- 467.9000 MHz
- 467.8750 MHz
- 467.8500 MHz
- 469.5500 MHz
- 469.5000 MHz
- 461.0375 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.2375 MHz
- 467.8125 MHz
- 467.7625 MHz
- 451.8000 MHz
- 456.8000 MHz
- 451.8125 MHz
- 456.8125 MHz
- 151.6250 MHz
- 154.5700 MHz
- 154.6000 MHz
- 151.9550 MHz
- 151.5125 MHz
- 151.5050 MHz
- 151.7000 MHz
- 151.7600 MHz
- 151.8200 MHz
- 151.9400 MHz
- 151.8800 MHz
- 151.9250 MHz
- 151.8050 MHz
- 158.4000 MHz
- 158.4075 MHz
- 151.6550 MHz
- 151.8650 MHz
- 152.9000 MHz
Motorola refers to CTCSS and DCS as "codes", Kenwood and other companies refer to CTCSS as QT (Quiet Tone) and DCS as DQT (Digital Quiet Tone).  The terms "PL" and "DPL" are still heavily used in the two-way radio community to refer to CTCSS and DCS, respectively.  Baofeng radios refer to CTCSS as CTCS and DCS as DCS.  Transmit CTCSS is T-CTCS and receive CTCSS is R-CTCS.  Radio programming software will refer to tone encode (transmit) and decode (receive).  An example of this is the Retevis series of radios - QT or DQT Enc is CTCSS or DCS encode (transmit) and QT or DQT Dec CTCSS or DCS decode (receive).
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
This radio model is also sold under the names Radioditty GA-2S and SEODON SED-8. Other brand names include Arcshell AR-6 Walkie Talkie, TIDRADIO UHF walkie talkies with USB charging capability. (other variants with different default frequencies have been noted, including some with 420-450 MHz 70cm amateur frequencies, 450-470 MHz land mobile frequencies and even 406-420 MHz Federal government frequencies as the defaults]. TIDRADIO Two Way Radio Long Range Walkie Talkies for Adults with USB Wall Charger Air Acoustic Earpiece 2 Pack
Default Channels Frequencies Default Factory Frequencies Retevis Luiton C1 CS - Sold on Amazon in March 2022 under the name "Walkie Talkies For Adults Scrambler CS" and "LUITON Walkie Talkies Voice Scrambler with Earpiece for Adults Outdoor CS Hiking Hunting Travelling Long Distance 2 Way Radios By Luiton" CHIRP reads the firmware on these radios as identical to the Baofeng BF-888S series. CMIT ID: 2016FP5477. 400 MHz - 470 MHz. 3-5 watt output BOND TELECOM CO., LTD.
Baofeng BF-88E PMR446 default frequencies 50 CTCSS 104 DCS codes programmable out of the box frequencies FRS GMRS Part 95. The BF-88E is simply a re-named BF-888S radio with a non-detachable antenna and programmed with the 16 European standard 446.0-446.2 Mhz PMR446 analog FM frequencies.
- Channel 2 - 446.01875 MHz
- Channel 3 - 446.03125 MHz
- Channel 4 - 446.04375 MHz
- Channel 5 - 446.05625 MHz
- Channel 6 - 446.06875 MHz
- Channel 7 - 446.08125 MHz
- Channel 8 - 446.09375 MHz
- Channel 9 - 446.10625 MHz
- Channel 10 - 446.11875 MHz
- Channel 11 - 446.13125 MHz
- Channel 12 - 446.14375 MHz
- Channel 13 - 446.15625 MHz
- Channel 14 - 446.16875 MHz
- Channel 15 - 446.18125 MHz
- Channel 16 - 446.19375 MHz
TYT TC-568  - Quanzhou TYT Electronics Co. Ltd. FRS TC-568 UHF Analog FRS Portable Transceiver
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
FRS version USA FCC FRS version H777 H777PLUS
- Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
- Channel 12 - 465.5250 MHz 031 DPL
- Channel 13 - 463.5650 MHz 051 DPL
- Channel 14 - 465.7250 MHz 065 DPL
- Channel 15 - 463.7650 MHz 125 DPL
- Channel 16 - 465.9250 MHz 152 DPL
Retevis RT1-VHF RT1 RT-1
Default Channels Frequencies Retevis RT1 VHF default channels frequencies May be out dated as newer versions are shipped. Default frequencies may be replaced with VHF MURS or 149 MHz Freenet or other frequencies depending on the radio's intended market. Some vendors are showing images of the VHF RT1 radio transmitting on 136.025 MHz.
- Channel 6 - 144.6750 MHz 023 DPL
- Channel 7 - 144.7750 MHz 023 DPL
- Channel 12 - 145.5700 MHz 79.7 Hz PL - this may actually be 145.575 MHz
Retevis RT-24 FRS 16 channel
US license free 462 MHz FRS GMRS specification version.  Like the other Retevis 16 channel UHF radios, it includes the 462.6250 127.3 Hz, 462.7250 136.5 Hz BF-888S default frequencies as well as Retevis-specific frequency/tone combinations - namely 462.5625 with 67.0 Hz, 462.5875 with 118.8 Hz, 462.6125 with 127.3 Hz, 462.6375 with 131.8 Hz, 462.6625 with 136.5 Hz, 462.6875 with 141.3 Hz, 462.7125 with 146.2 Hz, 462.550 with 123.0 Hz and so on.
Retevis RT-27V MURS VHF
RETEVIS RT27V RT47V RB27V RB47  US license free 151.82-151.94/154.57-154.6 MHz MURS specification version.
Like Kenwood, CTCSS is referred to as QT and DCS is referred to as DQT.  Dec is decode (receive) and Enc is encode (transmit).
US license free UHF FRS GMRS specification version.  Note that this radio includes the Retevis standardized CTCSS tones for FRS channels 1-7 (67.0 Hz, 118.8 Hz, 127.3 Hz, 131.8 Hz, 136.5 Hz, 141.3 Hz, 146.2 Hz as well as channel 15 (123.0 Hz), 18 (127.3 Hz) and 22 (136.5 Hz).  The channel 18 and channel 22 tones match with the Baofeng BF-888S default CTCSS tones for those respective frequencies as well.
Retevis RT-47V MURS VHF
US license free 151.82-151.94/154.57-154.6 MHz MURS specification version.   New Retevis MURS RB38V with 5 MURS channels and 10 NOAA weather channels (receive only).   RT27V  RT47V RB38V
- Channel 1 - 400.1250 MHz
- Channel 2 - 410.1250 MHz
- Channel 3 - 420.1250 MHz
- Channel 4 - 430.1250 MHz
- Channel 5 - 440.1250 MHz
- Channel 6 - 450.1250 MHz
- Channel 7 - 460.1250 MHz
- Channel 8 - 470.1250 MHz
- Channel 9 - 480.1250 MHz
- Channel 10 - 490.1250 MHz
- Channel 11 - 500.1250 MHz
- Channel 12 - 510.1250 MHz
- Channel 13 - 519.9750 MHz
- Channel 14 - 136.1250 MHz
- Channel 15 - 145.1250 MHz
- Channel 16 - 155.1250 MHz
- Channel 17 - 165.1250 MHz
- Channel 18 - 173.9750 MHz
- Freq 1 - 464.5000 MHz
- Freq 2 - 464.5500 MHz
- Freq 3 - 467.7625 MHz
- Freq 4 - 467.8125 MHz
- Freq 5 - 467.8500 MHz
- Freq 6 - 467.8750 MHz
- Freq 7 - 467.9000 MHz
- Freq 8 - 467.9250 MHz
- Freq 9 - 461.0375 MHz
- Freq 10 - 461.0625 MHz
- Freq 11 - 461.0875 MHz
- Freq 12 - 461.1125 MHz
- Freq 13 - 461.1375 MHz
- Freq 14 - 461.1625 MHz
- Freq 15 - 461.1875 MHz
- Freq 16 - 461.2125 MHz
- Freq 17 - 461.2375 MHz
- Freq 18 - 461.2625 MHz
- Freq 19 - 461.2875 MHz
- Freq 20 - 461.3125 MHz
- Freq 21 - 461.3375 MHz
- Freq 22 - 461.3625 MHz
- Freq 23 - 462.7625 MHz
- Freq 24 - 462.7875 MHz
- Freq 25 - 462.8125 MHz
- Freq 26 - 462.8375 MHz
- Freq 27 - 462.8625 MHz
- Freq 28 - 462.8875 MHz
- Freq 29 - 462.9125 MHz
- Freq 30 - 464.4875 MHz
- Freq 31 - 464.5125 MHz
- Freq 32 - 464.5375 MHz
- Freq 33 - 464.5625 MHz
- Freq 34 - 466.0375 MHz
- Freq 35 - 466.0625 MHz
- Freq 36 - 466.0875 MHz
- Freq 37 - 466.1125 MHz
- Freq 38 - 466.1375 MHz
- Freq 39 - 466.1625 MHz
- Freq 40 - 466.1875 MHz
- Freq 41 - 466.2125 MHz
- Freq 42 - 466.2375 MHz
- Freq 43 - 466.2625 MHz
- Freq 44 - 466.2875 MHz
- Freq 45 - 466.3125 MHz
- Freq 46 - 466.3375 MHz
- Freq 47 - 466.3625 MHz
- Freq 48 - 467.7875 MHz
- Freq 49 - 467.8375 MHz
- Freq 50 - 467.8625 MHz
- Freq 51 - 467.8875 MHz
- Freq 52 - 467.9125 MHz
- Freq 53 - 469.4875 MHz
- Freq 54 - 469.5125 MHz
- Freq 55 - 469.5375 MHz
- Freq 56 - 469.5625 MHz
- Freq 9 - 462.5750 MHz
- Freq 10 - 462.6250 MHz
- Freq 11 - 462.6750 MHz
- Freq 12 - 464.3250 MHz
- Freq 13 - 464.8250 MHz
- Freq 14 - 469.2625 MHz
- Freq 15 - 469.5000 MHz
- Freq 16 - 469.5500 MHz
- Freq 17 - 462.7625 MHz
- Freq 18 - 462.7875 MHz
- Freq 19 - 462.8125 MHz
- Freq 20 - 462.8375 MHz
- Freq 21 - 462.8625 MHz
- Freq 22 - 462.8875 MHz
- Freq 23 - 462.9125 MHz
- Freq 24 - 464.4875 MHz
- Freq 25 - 461.0375 MHz
- Freq 26 - 461.0625 MHz
- Freq 27 - 461.0875 MHz
- Freq 28 - 461.1125 MHz
- Freq 29 - 461.1375 MHz
- Freq 30 - 461.1625 MHz
- Freq 31 - 461.1875 MHz
- Freq 32 - 461.2125 MHz
- Freq 33 - 461.2375 MHz
- Freq 34 - 461.2625 MHz
- Freq 35 - 461.2875 MHz
- Freq 36 - 461.3125 MHz
- Freq 37 - 461.3375 MHz
- Freq 38 - 461.3625 MHz
- Freq 39 - 462.7625 MHz
- Freq 40 - 462.7875 MHz
- Freq 41 - 462.8125 MHz
- Freq 42 - 462.8375 MHz
- Freq 43 - 462.8625 MHz
- Freq 44 - 462.8875 MHz
- Freq 45 - 462.9125 MHz
- Freq 46 - 464.4875 MHz
- Freq 47 - 464.5125 MHz
- Freq 48 - 464.5375 MHz
- Freq 49 - 464.5625 MHz
- Freq 50 - 466.0375 MHz
- Freq 51 - 466.0625 MHz
- Freq 52 - 466.0875 MHz
- Freq 53 - 466.1125 MHz
- Freq 54 - 466.1375 MHz
- Freq 55 - 466.1625 MHz
- Freq 56 - 466.1875 MHz
- Freq 1 - 151.6250 MHz
- Freq 2 - 151.9550 MHz
- Freq 3 - 154.5700 MHz
- Freq 4 - 154.6000 MHz
- Freq 5 - 151.7000 MHz
- Freq 6 - 151.7600 MHz
- Freq 7 - 151.8200 MHz
- Freq 8 - 151.8800 MHz
- Freq 9 - 151.9400 MHz
- Freq 10 - 151.5125 MHz
- Freq 11 - 151.6550 MHz
- Freq 12 - 151.6850 MHz
- Freq 13 - 151.7150 MHz
- Freq 14 - 151.7450 MHz
- Freq 15 - 151.7750 MHz
- Freq 16 - 151.8650 MHz
- Freq 17 - 151.8950 MHz
- Freq 18 - 151.9250 MHz
- Freq 20 - 154.4900 MHz
- Freq 21 - 154.5150 MHz
- Freq 22 - 154.5275 MHz
- Freq 23 - 154.5400 MHz
- Freq 24 - 154.6000 MHz
- Freq 26 - 158.4000 MHz
- Freq 27 - 158.4075 MHz
- Freq 57 - 462.1875 MHz
- Freq 58 - 462.4625 MHz
- Freq 59 - 462.4875 MHz
- Freq 60 - 462.5125 MHz
- Freq 61 - 467.1875 MHz
- Freq 62 - 467.4625 MHz
- Freq 63 - 467.4875 MHz
- Freq 64 - 467.5125 MHz
- Freq 65 - 451.1875 MHz
- Freq 66 - 451.2375 MHz
- Freq 67 - 451.2875 MHz
- Freq 68 - 451.3375 MHz
- Freq 69 - 451.4375 MHz
- Freq 70 - 451.5375 MHz
- Freq 71 - 451.6375 MHz
- Freq 72 - 452.3125 MHz
- Freq 73 - 452.5375 MHz
- Freq 74 - 452.4125 MHz
- Freq 75 - 452.5125 MHz
- Freq 76 - 452.7625 MHz
- Freq 77 - 452.8625 MHz
- Freq 78 - 456.1875 MHz
- Freq 79 - 456.2375 MHz
- Freq 80 - 456.2875 MHz
- Freq 81 - 468.2125 MHz
- Freq 82 - 468.2625 MHz
- Freq 83 - 468.3125 MHz
- Freq 84 - 468.3625 MHz
- Freq 85 - 468.4125 MHz
- Freq 86 - 468.4625 MHz
- Freq 87 - 468.5125 MHz
- Freq 88 - 468.5625 MHz
- Freq 89 - 468.6125 MHz
- Freq 90 - 468.6625 MHz
- Freq 81 - 456.3375 MHz
- Freq 82 - 456.4375 MHz
- Freq 83 - 456.5375 MHz
- Freq 84 - 456.6375 MHz
- Freq 85 - 457.3125 MHz
- Freq 86 - 457.4125 MHz
- Freq 87 - 457.5125 MHz
- Freq 88 - 457.7625 MHz
- Freq 89 - 457.8625 MHz
- Freq 3 - 152.8850 MHz
- Freq 4 - 152.9150 MHz
- Freq 7 - 152.9450 MHz
- Freq 8 - 151.8350 MHz
- Freq 9 - 151.8050 MHz
- Freq 24 - 153.0050 MHz
- Freq 0 - OFF (BLANK)
- Code 1 - 67.0 Hz PL - XZ
- Code 2 - 71.9 Hz PL - XA
- Code 3 - 74.4 Hz PL - WA
- Code 4 - 77.0 Hz PL - XB
- Code 5 - 79.7 Hz PL - WB
- Code 6 - 82.5 Hz PL - YZ
- Code 7 - 85.4 Hz PL - YA
- Code 8 - 88.5 Hz PL - YB
- Code 9 - 91.5 Hz PL - ZZ
- Code 10 - 94.8 Hz PL - ZA
- Code 11 - 97.4 Hz PL - ZB
- Code 12 - 100.0 Hz PL - 1Z
- Code 13 - 103.5 Hz PL - 1A
- Code 14 - 107.2 Hz PL - 1B
- Code 15 - 110.9 Hz PL - 2Z
- Code 16 - 114.8 Hz PL - 2A
- Code 17 - 118.8 Hz PL - 2B
- Code 18 - 123.0 Hz PL - 3Z
- Code 19 - 127.3 Hz PL - 3A
- Code 20 - 131.8 Hz PL - 3B
- Code 21 - 136.5 Hz PL - 4Z
- Code 22 - 141.3 Hz PL - 4A
- Code 23 - 146.2 Hz PL - 4B
- Code 24 - 151.4 Hz PL - 5Z
- Code 25 - 156.7 Hz PL - 5A
- Code 26 - 162.2 Hz PL - 5B
- Code 27 - 167.9 Hz PL - 6Z
- Code 28 - 173.8 Hz PL - 6A
- Code 29 - 179.9 Hz PL - 6B
- Code 30 - 186.2 Hz PL - 7Z
- Code 31 - 192.8 Hz PL - 7A
- Code 32 - 203.5 Hz PL - M1
- Code 33 - 210.7 Hz PL - M2
- Code 34 - 218.1 Hz PL - M3
- Code 35 - 225.7 Hz PL - M4
- Code 36 - 233.6 Hz PL - M5
- Code 37 - 241.8 Hz PL - M6
- Code 38 - 250.3 Hz PL - M7
- Code 39 - 023 DPL
- Code 40 - 025 DPL
- Code 41 - 026 DPL
- Code 42 - 031 DPL
- Code 43 - 032 DPL
- Code 44 - 043 DPL
- Code 45 - 047 DPL
- Code 46 - 051 DPL
- Code 47 - 054 DPL
- Code 48 - 065 DPL
- Code 49 - 071 DPL
- Code 50 - 072 DPL
- Code 51 - 073 DPL
- Code 52 - 074 DPL
- Code 53 - 114 DPL
- Code 54 - 115 DPL
- Code 55 - 116 DPL
- Code 56 - 125 DPL
- Code 57 - 131 DPL
- Code 58 - 132 DPL
- Code 59 - 134 DPL
- Code 60 - 143 DPL
- Code 61 - 152 DPL
- Code 62 - 155 DPL
- Code 63 - 156 DPL
- Code 64 - 162 DPL
- Code 65 - 165 DPL
- Code 66 - 172 DPL
- Code 67 - 174 DPL
- Code 68 - 205 DPL
- Code 69 - 223 DPL
- Code 70 - 226 DPL
- Code 71 - 243 DPL
- Code 72 - 244 DPL
- Code 73 - 245 DPL
- Code 74 - 251 DPL
- Code 75 - 261 DPL
- Code 76 - 263 DPL
- Code 77 - 265 DPL
- Code 78 - 271 DPL
- Code 79 - 306 DPL
- Code 80 - 311 DPL
- Code 81 - 315 DPL
- Code 82 - 331 DPL
- Code 83 - 343 DPL
- Code 84 - 346 DPL
- Code 85 - 351 DPL
- Code 86 - 364 DPL
- Code 87 - 365 DPL
- Code 88 - 371 DPL
- Code 89 - 411 DPL
- Code 90 - 412 DPL
- Code 91 - 413 DPL
- Code 92 - 423 DPL
- Code 93 - 431 DPL
- Code 94 - 432 DPL
- Code 95 - 445 DPL
- Code 96 - 464 DPL
- Code 97 - 465 DPL
- Code 98 - 466 DPL
- Code 99 - 503 DPL
- Code 100 - 506 DPL
- Code 101 - 516 DPL
- Code 102 - 532 DPL
- Code 103 - 546 DPL
- Code 104 - 565 DPL
- Code 105 - 606 DPL
- Code 106 - 612 DPL
- Code 107 - 624 DPL
- Code 108 - 627 DPL
- Code 109 - 631 DPL
- Code 110 - 632 DPL
- Code 111 - 654 DPL
- Code 112 - 662 DPL
- Code 113 - 664 DPL
- Code 114 - 703 DPL
- Code 115 - 712 DPL
- Code 116 - 723 DPL
- Code 117 - 731 DPL
- Code 118 - 732 DPL
- Code 119 - 734 DPL
- Code 120 - 743 DPL
- Code 121 - 754 DPL
- DCS Code 1 - 023 DPL
- DCS Code 2 - 025 DPL
- DCS Code 3 - 026 DPL
- DCS Code 4 - 031 DPL
- DCS Code 5 - 032 DPL
- DCS Code 6 - 043 DPL
- DCS Code 7 - 047 DPL
- DCS Code 8 - 051 DPL
- DCS Code 9 - 054 DPL
- DCS Code 10 - 065 DPL
- DCS Code 11 - 071 DPL
- DCS Code 12 - 072 DPL
- DCS Code 13 - 073 DPL
- DCS Code 14 - 074 DPL
- DCS Code 15 - 114 DPL
- DCS Code 16 - 115 DPL
- DCS Code 17 - 116 DPL
- DCS Code 18 - 125 DPL
- DCS Code 19 - 131 DPL
- DCS Code 20 - 132 DPL
- DCS Code 21 - 134 DPL
- DCS Code 22 - 143 DPL
- DCS Code 23 - 152 DPL
- DCS Code 24 - 155 DPL
- DCS Code 25 - 156 DPL
- DCS Code 26 - 162 DPL
- DCS Code 27 - 165 DPL
- DCS Code 28 - 172 DPL
- DCS Code 29 - 174 DPL
- DCS Code 30 - 205 DPL
- DCS Code 31 - 223 DPL
- DCS Code 32 - 226 DPL
- DCS Code 33 - 243 DPL
- DCS Code 34 - 244 DPL
- DCS Code 35 - 245 DPL
- DCS Code 36 - 251 DPL
- DCS Code 37 - 261 DPL
- DCS Code 38 - 263 DPL
- DCS Code 39 - 265 DPL
- DCS Code 40 - 271 DPL
- DCS Code 41 - 306 DPL
- DCS Code 42 - 311 DPL
- DCS Code 43 - 315 DPL
- DCS Code 44 - 331 DPL
- DCS Code 45 - 343 DPL
- DCS Code 46 - 346 DPL
- DCS Code 47 - 351 DPL
- DCS Code 48 - 364 DPL
- DCS Code 49 - 365 DPL
- DCS Code 50 - 371 DPL
- DCS Code 51 - 411 DPL
- DCS Code 52 - 412 DPL
- DCS Code 53 - 413 DPL
- DCS Code 54 - 423 DPL
- DCS Code 55 - 431 DPL
- DCS Code 56 - 432 DPL
- DCS Code 57 - 445 DPL
- DCS Code 58 - 464 DPL
- DCS Code 59 - 465 DPL
- DCS Code 60 - 466 DPL
- DCS Code 61 - 503 DPL
- DCS Code 62 - 506 DPL
- DCS Code 63 - 516 DPL
- DCS Code 64 - 532 DPL
- DCS Code 65 - 546 DPL
- DCS Code 66 - 565 DPL
- DCS Code 67 - 606 DPL
- DCS Code 68 - 612 DPL
- DCS Code 69 - 624 DPL
- DCS Code 70 - 627 DPL
- DCS Code 71 - 631 DPL
- DCS Code 72 - 632 DPL
- DCS Code 73 - 654 DPL
- DCS Code 74 - 662 DPL
- DCS Code 75 - 664 DPL
- DCS Code 76 - 703 DPL
- DCS Code 77 - 712 DPL
- DCS Code 78 - 723 DPL
- DCS Code 79 - 731 DPL
- DCS Code 80 - 732 DPL
- DCS Code 81 - 734 DPL
- DCS Code 82 - 743 DPL
- DCS Code 83 - 754 DPL
- DCS Code 84 - 036 DPL
- DCS Code 85 - 053 DPL
- DCS Code 86 - 122 DPL
- DCS Code 87 - 145 DPL
- DCS Code 88 - 212 DPL
- DCS Code 89 - 225 DPL
- DCS Code 90 - 246 DPL
- DCS Code 91 - 252 DPL
- DCS Code 92 - 255 DPL
- DCS Code 93 - 266 DPL
- DCS Code 94 - 274 DPL
- DCS Code 95 - 325 DPL
- DCS Code 96 - 332 DPL
- DCS Code 97 - 356 DPL
- DCS Code 98 - 446 DPL
- DCS Code 99 - 452 DPL
- DCS Code 100 - 454 DPL
- DCS Code 101 - 455 DPL
- DCS Code 102 - 462 DPL
- DCS Code 103 - 523 DPL
- DCS Code 104 - 526 DPL
- CTCSS Code 1 - 67.0 Hz
- CTCSS Code 2 - 69.3 Hz
- CTCSS Code 3 - 71.9 Hz
- CTCSS Code 4 - 74.4 Hz
- CTCSS Code 5 - 77.0 Hz
- CTCSS Code 6 - 79.7 Hz
- CTCSS Code 7 - 82.5 Hz
- CTCSS Code 8 - 85.4 Hz
- CTCSS Code 9 - 88.5 Hz
- CTCSS Code 10 - 91.5 Hz
- CTCSS Code 11 - 94.8 Hz
- CTCSS Code 12 - 97.4 Hz
- CTCSS Code 13 - 100.0 Hz
- CTCSS Code 14 - 103.5 Hz
- CTCSS Code 15 - 107.2 Hz
- CTCSS Code 16 - 110.9 Hz
- CTCSS Code 17 - 114.8 Hz
- CTCSS Code 18 - 118.8 Hz
- CTCSS Code 19 - 123.0 Hz
- CTCSS Code 20 - 127.3 Hz
- CTCSS Code 21 - 131.8 Hz
- CTCSS Code 22 - 136.5 Hz
- CTCSS Code 23 - 141.3 Hz
- CTCSS Code 24 - 146.2 Hz
- CTCSS Code 25 - 151.4 Hz
- CTCSS Code 26 - 156.7 Hz
- CTCSS Code 27 - 159.8 Hz
- CTCSS Code 28 - 162.2 Hz
- CTCSS Code 29 - 165.5 Hz
- CTCSS Code 30 - 167.9 Hz
- CTCSS Code 31 - 171.3 Hz
- CTCSS Code 32 - 173.8 Hz
- CTCSS Code 33 - 177.3 Hz
- CTCSS Code 34 - 179.9 Hz
- CTCSS Code 35 - 183.5 Hz
- CTCSS Code 36 - 186.2 Hz
- CTCSS Code 37 - 189.9 Hz
- CTCSS Code 38 - 192.8 Hz
- CTCSS Code 39 - 196.6 Hz
- CTCSS Code 40 - 199.5 Hz
- CTCSS Code 41 - 203.5 Hz
- CTCSS Code 42 - 206.5 Hz
- CTCSS Code 43 - 210.7 Hz
- CTCSS Code 44 - 218.1 Hz
- CTCSS Code 45 - 225.7 Hz
- CTCSS Code 46 - 229.1 Hz
- CTCSS Code 47 - 233.6 Hz
- CTCSS Code 48 - 241.8 Hz
- CTCSS Code 49 - 250.3 Hz
- CTCSS Code 50 - 254.1 Hz
- CTCSS (T-CTCS and R-CTCS)
- OFF
- 67.0HZ
- 69.3HZ
- 71.9HZ
- 74.4HZ
- 77.0HZ
- 79.7HZ
- 82.5HZ
- 85.4HZ
- 88.5HZ
- 91.5HZ
- 94.8HZ
- 97.4HZ
- 100.0HZ
- 103.5HZ
- 107.2HZ
- 110.9HZ
- 114.8HZ
- 118.8HZ
- 123.0HZ
- 127.3HZ
- 131.8HZ
- 136.5HZ
- 141.3HZ
- 146.2HZ
- 151.4HZ
- 156.7HZ
- 159.8HZ
- 162.2HZ
- 165.5HZ
- 167.9HZ
- 171.3HZ
- 173.8HZ
- 177.3HZ
- 179.9HZ
- 183.5HZ
- 186.2HZ
- 189.9HZ
- 192.8HZ
- 196.6HZ
- 199.5HZ
- 203.5HZ
- 206.5HZ
- 210.7HZ
- 218.1HZ
- 225.7HZ
- 229.1HZ
- 233.6HZ
- 241.8HZ
- 250.3HZ
- 254.1HZ
- DCS (T-DCS and R-DCS)
- OFF
- D023N
- D025N
- D026N
- D031N
- D032N
- D036N
- D043N
- D047N
- D051N
- D053N
- D054N
- D065N
- D071N
- D072N
- D073N
- D074N
- D114N
- D115N
- D116N
- D122N
- D125N
- D131N
- D132N
- D134N
- D143N
- D145N
- D152N
- D155N
- D156N
- D162N
- D165N
- D172N
- D174N
- D205N
- D212N
- D223N
- D225N
- D226N
- D243N
- D244N
- D245N
- D246N
- D251N
- D252N
- D255N
- D261N
- D263N
- D265N
- D266N
- D271N
- D274N
- D306N
- D311N
- D315N
- D325N
- D331N
- D332N
- D343N
- D346N
- D351N
- D356N
- D364N
- D365N
- D371N
- D411N
- D412N
- D413N
- D423N
- D431N
- D432N
- D445N
- D446N
- D452N
- D454N
- D455N
- D462N
- D464N
- D465N
- D466N
- D503N
- D506N
- D516N
- D523N
- D526N
- D532N
- D546N
- D564N
- D606N
- D612N
- D624N
- D627N
- D631N
- D632N
- D645N
- D654N
- D662N
- D664N
- D703N
- D712N
- D723N
- D731N
- D732N
- D734N
- D743N
- D754N
- DCS 023I decodes as DCS 047
- DCS 025I decodes as DCS 244
- DCS 026I decodes as DCS 464
- DCS 031I decodes as DCS 627
- DCS 032I decodes as DCS 051
- DCS 036I decodes as DCS 172
- DCS 043I decodes as DCS 445
- DCS 047I decodes as DCS 023
- DCS 051I decodes as DCS 032
- DCS 053I decodes as DCS 452
- DCS 054I decodes as DCS 413
- DCS 065I decodes as DCS 271
- DCS 071I decodes as DCS 306
- DCS 072I decodes as DCS 245
- DCS 073I decodes as DCS 506
- DCS 074I decodes as DCS 173
- DCS 114I decodes as DCS 712
- DCS 115I decodes as DCS 152
- DCS 116I decodes as DCS 754
- DCS 122I decodes as DCS 225
- DCS 125I decodes as DCS 365
- DCS 131I decodes as DCS 364
- DCS 132I decodes as DCS 546
- DCS 134I decodes as DCS 223
- DCS 143I decodes as DCS 412
- DCS 145I decodes as DCS 274
- DCS 152I decodes as DCS 115
- DCS 155I decodes as DCS 731
- DCS 156I decodes as DCS 265
- DCS 162I decodes as DCS 503
- DCS 165I decodes as DCS 251
- DCS 172I decodes as DCS 036
- DCS 174I decodes as DCS 074
- DCS 205I decodes as DCS 263
- DCS 212I decodes as DCS 356
- DCS 223I decodes as DCS 134
- DCS 225I decodes as DCS 122
- DCS 226I decodes as DCS 411
- DCS 243I decodes as DCS 351
- DCS 244I decodes as DCS 025
- DCS 245I decodes as DCS 072
- DCS 246I decodes as DCS 523
- DCS 251I decodes as DCS 165
- DCS 252I decodes as DCS 462
- DCS 255I decodes as DCS 446
- DCS 261I decodes as DCS 732
- DCS 263I decodes as DCS 205
- DCS 265I decodes as DCS 156
- DCS 266I decodes as DCS 454
- DCS 271I decodes as DCS 065
- DCS 274I decodes as DCS 145
- DCS 306I decodes as DCS 071
- DCS 311I decodes as DCS 664
- DCS 315I decodes as DCS 423
- DCS 325I decodes as DCS 526
- DCS 331I decodes as DCS 465
- DCS 332I decodes as DCS 455
- DCS 343I decodes as DCS 532
- DCS 346I decodes as DCS 612
- DCS 351I decodes as DCS 243
- DCS 356I decodes as DCS 212
- DCS 365I decodes as DCS 125
- DCS 371I decodes as DCS 734
- DCS 411I decodes as DCS 226
- DCS 412I decodes as DCS 143
- DCS 413I decodes as DCS 054
- DCS 423I decodes as DCS 315
- DCS 431I decodes as DCS 723
- DCS 432I decodes as DCS 516
- DCS 445I decodes as DCS 043
- DCS 446I decodes as DCS 255
- DCS 452I decodes as DCS 053
- DCS 454I decodes as DCS 266
- DCS 455I decodes as DCS 332
- DCS 462I decodes as DCS 252
- DCS 464I decodes as DCS 026
- DCS 465I decodes as DCS 331
- DCS 466I decodes as DCS 662
- DCS 503I decodes as DCS 162
- DCS 506I decodes as DCS 073
- DCS 516I decodes as DCS 432
- DCS 523I decodes as DCS 246
- DCS 546I decodes as DCS 132
- DCS 565I decodes as DCS 703
- DCS 606I decodes as DCS 631
- DCS 612I decodes as DCS 346
- DCS 624I decodes as DCS 632
- DCS 627I decodes as DCS 031
- DCS 631I decodes as DCS 606
- DCS 632I decodes as DCS 624
- DCS 645I decodes as DCS 325
- DCS 654I decodes as DCS 743
- DCS 662I decodes as DCS 466
- DCS 664I decodes as DCS 311
- DCS 703I decodes as DCS 565
- DCS 712I decodes as DCS 431
- DCS 723I decodes as DCS 155
- DCS 731I decodes as DCS 261
- DCS 734I decodes as DCS 371
- DCS 743I decodes as DCS 654
- DCS 754I decodes as DCS 116
*Costco
Costco stores are (allegedly) in the process of upgrading from the VHF to UHF, especially when interference from other stores using the popular VHF frequencies (including 154.570 MHz and 154.600 MHz) is an issue.  However, Costco retains extensive VHF systems and numerous licenses with dozens of VHF frequencies authorized in hundreds of locations.
- VHF:
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz
- 151.9850 MHz
- 152.8850 MHz
- 152.9150 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.6125 MHz
- 468.6625 MHz
- 451.4125 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5875 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 452.7625 MHz
- 456.4125 MHz
- 456.5125 MHz
- 456.6125 MHz
- 456.6875 MHz
- 457.7625 MHz
- 467.7625 MHz
- 467.8125 MHz
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
- 461.0375 MHz 445 DPL
- 467.7625 MHz 743 DPL
- 467.9000 MHz 743 DPL
- 467.8500 MHz Channel 1
- 467.8750 MHz Channel 2
- 467.9000 MHz Channel 3
- 467.9250 MHz Channel 4
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
- 464.5500 MHz - 67.0 Hz PL
- 467.7625 MHz - 107.2 Hz PL
- 467.8125 MHz
- 467.8750 MHz - 343 DPL
- 467.8750 MHz - 411 DPL
- 467.9250 MHz - 67.0 Hz PL
- 467.9250 MHz
- 467.8500 MHz 146.2 Hz PL
- 467.8750 MHz - 100.0 Hz PL
- 467.9000 MHz - 100.0 Hz PL
- 467.9250 MHz - 100.0 Hz PL
- 151.9400 MHz - 110.9 Hz PL
- 154.5700 MHz - 110.9 Hz PL
- 154.6000 MHz - 110.9 Hz PL
- 461.0375 MHz
- 461.1125 MHz
- 461.2125 MHz
- 462.7625 MHz
- 462.8125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 466.0375 MHz
- 466.1125 MHz
- 466.1375 MHz
- 469.4875 MHz
- 469.5375 MHz
- 467.9000 MHz - 131 DPL
- 464.5000 MHz - 162.2 Hz PL
- 464.5500 MHz - 162.2 Hz PL
- 464.5500 MHz - 413 DPL
- 467.9000 MHz - 225.7 Hz PL
- 467.9250 MHz - 225.7 Hz PL
- 467.8000 MHz ???? - unknown DCS code / DPL code
- 151.6250 MHz 179.9 Hz PL
- 151.9550 MHz 179.9 Hz PL
- 151.9250 MHz 506 DPL
- 151.8950 MHz 506 DPL
- 151.5050 MHz
- 151.6250 MHz
- 151.7000 MHz
- 151.8200 MHz
- 151.9250 MHz
- 154.5700 MHz
- 154.6000 MHz
- 158.4000 MHz
- 451.8000 MHz
- 451.8125 MHz
- 456.8125 MHz
- 154.5700 MHz - Primary
- 154.6000 MHz - Primary
- 151.8200 MHz
- 151.8800 MHz
- 151.9400 MHz
- 151.6250 MHz
- 151.7600 MHz
- 151.7750 MHz
- 151.8200 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.9550 MHz
- 461.0375 MHz 172 DPL
- 461.0875 MHz 223 DPL
- 461.1125 MHz 172 DPL
- 461.1875 MHz 172 DPL
- 461.3625 MHz 172 DPL
- 464.5000 MHz 172 DPL
- 469.5000 MHz 172 DPL
